View Full Version : Lumina
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. removing door panels to replace speakers ('97 lumina)
  2. Help I need parts for my Lumina Z34
  3. msd plug wires
  4. Lumina sputtering
  5. Ashtray light and gauge probelm
  6. 96 lumina frt. end noise
  7. 96 Lumina intake or head gasket replacement
  8. 1992 Lumina Wont Start
  9. 93 Lumina Z34 no high stop light all of a sudden
  10. 93 Lumina Z34 Battery went dead now car will not stay running
  11. clicking noise
  12. Locks & lights circuit
  13. 1997 Lumina.....Harmonic Balancer?
  14. Should I buy a Lumina
  15. chattering doors
  16. '98 Lumina - Majorly Strange. HELP!
  17. Re-using FelPro metal LIM gasket?
  18. 91 3.1 T injectors
  19. No Brakes When Applied Hard
  20. 1996 lumina
  21. 97 chevy lumina auto, v6, 3.1 engine tapping power loss misfire when warm
  22. serpentine belt
  23. 98' Lumina front lug stud R&R
  24. fuel pump
  25. 97 lumina engine acting erratically.
  26. '97 Lumina: Rear Struts or Shocks?
  27. 1995 lumi ls problems
  28. Brake lights not working
  29. 97 lumina wont start
  30. OBD2 Question...
  31. 98 Lumina wont start
  32. 98 Lumina Stalling/Backfiring
  33. Torquing down the LIM
  34. Lumina 3.8L 98 is running worriedly
  35. More front seat leg room '99
  36. How to turn on your fan Manually on a 94 lumina
  37. coolant loss
  38. ABS LIght on Hard Acceleration
  39. Egr valve?
  40. Beaten to Death - LIM or Headgasket?
  41. Did my LIM, Serp wont go on.
  42. low oil light tempermental
  43. No Power
  44. 98 Lumina 3.1, Water in Oil, Help!
  45. Open Vaccum Hose, Parts Catalog Needed
  46. 98 Lumina trans slip?
  47. turning sigs do not work
  48. 1995 lumina trans
  49. Won't move forward but will move in reverse
  50. tire choices=
  51. 98. tire pressure=?
  52. Torque Wrenches ft. lb. and in. lbs.
  53. Help
  54. starter relay
  55. Who has a 3.1/3.4L with valve chatter?
  56. any idea's please
  57. 1990 Lumina Hesitation / "putt" @ idle
  58. 2001 lumina wiper problem
  59. Metal Tube
  60. Intermittent CEL, need help.
  61. 1999 lumina ltz 3.8 fuel leak
  62. 94 Lumina sedan automatic locks
  63. My car is bleeping nuts...
  64. pics
  65. wheel bearings or not?
  66. what ya think
  67. 93 Chevy Lumina 3.1
  68. lumina clicking sound
  69. 95 Lumina 3.1 Sputter
  70. 92 lumina 3.1
  71. I'm getting around 15mpg
  72. 1997 Chevy Lumina - All Dashboard lights on
  73. Heating
  74. Vibration
  75. Coolant in oil after LIM replacement.
  76. Speed sensor location on 92 chevy lumina 3.1?
  77. Speaker Problems
  78. 95 lumina head or intake gasket?
  79. richtazz or Jeffcoslacker
  80. 95 Lumina temp/no heat
  81. please help
  82. dash battery light on
  83. Doing my LIM, a couple ?.
  84. overheating while freezing outside?
  85. Cylinder Head Removal
  86. no brake pressure
  87. 97 Lumina spraying antifreeze
  88. Frozen cooling water...
  89. whatchya think
  90. 91 Lumina dead
  91. 97' loosing antifreeze
  92. Some guesses?
  93. Replacing Fuel pump
  94. 92' 3.1L - Battery draining but alternator and battery test good...
  95. Light roar coming from AC/Heat
  96. 92chevy lumina stalls
  97. something burning while warming up
  98. brake problem
  99. install manual fan switch=
  100. 98, p/s fluid question=
  101. 90 Lumina 3.1 AT Issues
  102. 93 Lumina Z34 pucking bubbling dash any suggestions?
  103. 97 Lumina will not start
  104. How do you replace the front wheel speed sensor?
  105. Can I adjust toe out?
  106. Airfilter Box loud noise
  107. 96 Lumina brake lights and dash lights
  108. Rough Idle
  109. 96 Lumina no oil pressure - Camshaft issue?
  110. 1997 chevy lumina abs question
  111. Lumina Fuel and sensor problems
  112. Rear Defogger -- Stumped
  113. 95 Lumina, Speedometer erratic and car wont shift
  114. bad tracking. alignment?
  115. 91 Lumina rear brake caliper won't adjust
  116. 1998. replacing carpet =
  117. 93 Lumina Shift Selector Console Shift
  118. 93 Lumina Z34 heater control no lights
  119. 93 Lumina Z34 Anti Lock Brake Light Just Blinks
  120. brake shoe stuck onto the rotor
  121. Lumina 93 - V6 3.1
  122. disable "low coolant' light on 98=
  123. stalling at stops loud
  124. Location of sensors
  125. 93 Lumina problem
  126. auto door locks
  127. Hood lock?
  128. brake conversion?
  129. replacing shoes on drums
  130. 95 Lumina Short Circuit
  131. 97 Lumina coolant not circulating
  132. 96 Lumina "Anti-Lock" light
  133. 97 lumina 3.1 fuel pump
  134. 95 chevy lumina is not getting any fire from spark plugs
  135. 92 lumina - rear disc brakes
  136. Fixing trunk pop
  137. need HELP ... ASAP !!!
  138. Brake light switch wiring
  139. spoiler
  140. 99 lumina won't start
  141. SeaFoam?
  142. 97 Keyless Entry question
  143. Oil in Coolant - Head or Intake Gasket?
  144. Stepped on the brake and it died
  145. 97 lumina 3.1 o2 sensor and egr valve problem-help!
  146. jump start created problem
  147. jump start created problem
  148. 97 lumina 3.1l thermostat
  149. help getting amp wiring through firewall
  150. Aftermarket performance suspension parts
  151. Low amount of heat from upper vents
  152. Rough cold weather starts
  153. 1992 Chev. Lumina 3.1 L
  154. Transmission tuneups
  155. 98 Lumina 3.1 - P1671 Driver 4 Line 1, code?
  156. 98 Lumina Won't Start Sometimes
  157. Bizzaro problem-clock on all the time
  158. Lumina Just Died
  159. 91 3.4 Z34 Heater Core Removal Help
  160. 98 Lumina heads
  161. 1990 Chevy Lumina Shuts Off when engine warms up.
  162. 90 lumina speedometer
  163. 96 lumina ignition switch pin diagram
  164. No Ignition power
  165. 99 Lumina full urethane suspension kit
  166. A new toy
  167. 1999 3.8 Spark Plug Thread size
  168. Buying a Lumina tomorrow
  169. "97 Lumina won't start - NO power
  170. Exhaust swap on 00 Lumina
  171. 97 lumina/monte carlo po141 o2 sensor???
  172. quick tire question
  173. 99 chevy lumina
  174. 98 Lumina 3.1 Loses Fuel Pressure sitting. New Pump/Filter/Regulator!
  175. 96 lumina temp gauge not working help!
  176. Lumina'97 - dashboard "Brake" light is on, then getting dimmer
  177. The dreaded Unibody Repair...Trailing Arm (Stab.bar)
  178. 1999 Lumina 9c6 car.. MINE!!!
  179. 1992 Lumina Euro NO Spark #6
  180. cylinder # 5 dead at idle
  181. 96 Lumina Brake lights illuminate intermittenly
  182. 96 lumina pulls to the right
  183. 92 lumina crank position sensor location
  184. Damn aftermarket
  185. hard to start after sitting
  186. 1992 Lumina Euro Fuel Filter Question
  187. Renaming the Lumina: POLL
  188. 90 lumina speedometer
  189. #5 Cylinder Dead At Idle
  190. hard starting, dead spot, and bogs down
  191. engine code 24 lumina apv
  192. 97 Lumina remote trunk button
  193. doing the PCV valve in 3.4L v6 (/94 Lumina)
  194. removing the instrument cluster
  195. Electric Fans always on
  196. water pump???
  197. 1994 Lumina Euro - Wiper and windshield spray not working
  198. 1990 euro speedometer help please
  199. 3800 Alternator Replacement Guide!
  200. Shifting Malfunction
  201. 2001 Chev Lumina 3.1 v-6
  202. Can '96 transaxle be removed without pulling engine?
  203. Help! Car Died, Mechanic says computer went out
  204. What the hell color is my /94 Lumina?
  205. 91 3.4 Tranny Slipping in 2nd gear i think?
  206. 1992 chevy lumina
  207. 96 lumina temp guage problem
  208. '98 Ltz 3800 power steering
  209. 96 Lumina intermittent heat
  210. 96 Lumina Hesitation during acceleration
  211. '97 Lumina stumbles and stalls when hot
  212. 91 Lumina sudden death problem
  213. 98 (base) brakes *&_#@
  214. 97 lumina 3.1 belt problem
  215. How do I change the Oxygen Sensor? /94 3.4L v6...
  216. Egr?? Need Help!!!
  217. Idle speed for 1995 3.1L Lumina
  218. Help! Front vents won't work
  219. will it work?
  220. wher to find?
  221. Crankshaft Position Sensor Variation Learning Procedure
  222. 1996 Chevy Lumina won't start
  223. E-fans on 1995 3.1L Lumina
  224. 1995 Lumina 3.1L Backfire at 2000-3000 RPMs
  225. Still overheating!
  226. 1991 lumina, front strut assembly
  227. Gas Tank Rattle
  228. 4T65-E Pressure Control Solenoid fix
  229. Transmission losing gears
  230. 93 Euro: fuel pump and EGR valve
  231. 1997 chevy lumina abs light is on
  232. 93 lumina euro 3.1
  233. 3.8 Harmonic Balancer Removal
  234. speed sensor 90 lumnia
  235. 91 Chevy Lumina Euro
  236. cold mornings: hard to start, rough running, low idle, stalls out
  237. Speedo Stopped Working
  238. 95 Lumina Humming Noise
  239. Install universal remote...
  240. 91 Lumina PLEASE HELP
  241. 2001 Air Pump full of water!
  242. Clicking when touching brake
  243. Tune up Parts (OEM or AutoZone/Pep Boys)
  244. what turbocharger can I use on a lumina ss 2003 ?
  245. 1998 lumina LF wheel bearing trouble.
  246. 99 Lumina Defrost Problem
  247. Oem Spark Plugs ???????
  248. 92 lumina reverse problem
  249. Rear Struts/shocks /94 Euro w transverse spring - How to / Help
  250. I have had enough!
