View Full Version : Lumina
- 1997 chevy lumina coolant flush
- 1995 lumina 3.1L TBI (FUEL PUMP)
- 97 3.1 engine swap
- Emergency Brake Ripoff - key warning
- 97 lumina still no start
- ABS brake sensor cable - a rapscalion to fix
- 1990 w/2.5L 4cyl - random rough running
- lumina loses all power and dies
- 1999 Spedo Stopped Working
- Added coolant = Screwed everything
- Adding Coolant --> Bleeder Thing
- 97 lumina transmission fluid black
- 1993 Lumina euro transmission issues
- Programming Keyless Entry Remote
- 1996 Chevrolet Lumina
- High pressure steering line,leak,replace
- Luminas for sale?
- Replacing a rear Brake Caliper...need some advice/help
- Used Lumina for parts: is this a good deal?
- The Lowdown
- Loosing Coolant "Oringinal Gaskets"
- Spark Plug wires...
- Rust on Fuel Line...
- 3.8 Water Pump
- Small Black Bar
- maybe you know?
- Full size tire replacing spare.
- total power loss while driving
- Factory Part Numbers
- Torque Ange Meter and Water pumps
- GM 3.1L lower intake manifold gasket problems
- 1997 chevy lumina 3.1L valvetrain rattle/noise?
- Spark Plugs...
- Engine Rev
- 98 lumina brake issue
- 97 lumina turn signal switch
- Where is the starter relay on my 97 Lumina that has anti theft system
- Ive a problem with the a/c on my 98 chevy lumina
- alternator
- 94 Lumina 3.4L: MAP sensor or MAF sensor system?
- Quick Question
- Stupid things that make you freak out
- 1997 lumina 3.1 oxygen sensor
- Any good retailers that do brakes?
- Lumina vs. Park Avenue
- Knock from the engine! :(
- OEM Keyless can I use this Module?
- Interesting Find On 93 3.1v-6
- Flasher issue...
- 97 Chevy Lumina brakes/Master Cylinder
- 1997 chevy won't pass smog code P1870
- Z34 Very hard to start SOMETIMES
- Key Stuck In Ignition
- Car knocks/pings when cold
- RPMs
- 96 Lumina Blowing ECM fuse
- 97 Lumina 3.1 leaking coolant
- 1990 lumina fuel delivery issue
- Gauge Help
- 1994 Z34 Lumina
- Cylinder 6 misfire
- Question about oil
- Driver's Seat Annoying cushion problem fixed.
- Front Corner Light Repair - How To
- Rattling Hubcaps 97 Lumina
- 1990 Lumina will not start, Just keeps cranking
- brakeline leads to broken springs?
- Safe to run SeaFoam?
- Flowmaster 40 muffler (dual out) + 2 cherrybombs?
- exhaust shield ??
- OEM Keyless Entry install
- My 1998 Lumina won't start
- 97 Lumina Volts Light
- Quick ? regarding replaced alternator
- 1997 Lumina "c1236 Low System Voltage"
- Starter ? on a 92' 3.4
- Can better Exhaust system give better MPG?
- Converting to E85/Ethanol or any mixture of Ethanol/gasoline
- 91 lumina hunting idle and dieing
- '96 front strut cartridge problem
- Replaced trunk and glove box locks on Lumina
- who is better?
- Are cooling fans using to much electricity?
- HHO Hydrogen fuel suppliment for better MPH & savings
- Neither Fan Turning? is that normal in summer?
- Install an overhead light switch: 3 good reasons!
- Saving old battery as spare: EDTA reconditioning...
- 2nd Alternator in place of AC unit?...
- Trunk release button revisted
- 1991 lumina
- Keyless Remote with universal?
- Can these Sparkplugs save 10% of my gas (MPG)?
- AC Problem
- 1990 Lumina 3.1 Overdrive Transmission Apple Coring/Reluctor Drive Shaft No shift
- Not another problem!?!?! 92' lumina z34
- Which fuse did I pull??
- OEM Keyless entry
- Lumina 1998 3.8L RKE Receiver
- '96 rear brake drum stuck.....
- 97 check engine light problem
- 95 lumina rear noise
- Cabin air filter
- Intermittent problem with Lumina97
- 99 Lumina a/c clutch wont engage
- 1997 lumina 3.1L Coolant in oil?
- Cracking Tire
- 91 Lumina Ignition switch problem
- Ran then didn't..
- 97 Lumina 3.1 High RPM after thermostst change
- Spare Tire Replaced with Full Tire
- 98 Lumina Will Not Start
- air filter
- waterpumps
- Wires cut coming out of passenger front wheel well and down...
- Yet another issue
- 1990 Lumina Stalls After Exiting Highway
- 93 Lumina Chime Issue
- 1996 Lumina starting problem
- 1999 lumina turbo
- 1991 lumina problems # 2
- 95 Lumina A/C Inop
- Tie Rod Ends: What torque for castellated nut on steering arm?
- What ECM and EPROM should my /94 3.4L v6 be running on?
- What Thermostat and Eprom gives best mileage?
- How to rebuild your own alternator in 10 minutes!
- Where is the DLC on a 99 lumina?
- 99 lumina driving me crazy
- Mmmm fresh cold AIR!!
- Where is "illumination delay relay" for dash lights? /94 lumina
- battery draining overnight - dead, 3 problems
- Lumina not charging, please help.
- Compressor wiring bad?
- loosing coolant
- A few questions about the z34
- 1999 lumina
- Getting tired.... Engine Tick.
- 1990 Lumina Euro 3.1 Overdrive Automatic Transmission Problem
- 96 z28 engine /98 Lumina swap
- Spark plug wires - what's good?
- crazy mult. problems
- 1993 Check coil packs.
- 98 Lumina, groaning fuel pump?
- 2000 Lumina Needs Your Help
- A new A/C issue
- Knock and the loss of power
- Another 92 Euro 3.4 A/C question
- K&N Air Filter (Worth it?)
- 92 Lumina Euro 3.4L ABS Brake Problem
- ICM, ECU? How do I determine which one?
- question for the pro's
- Idle issue with 94 Lumina 3.1 V6
- Install a Trunk release button
- AC only on drivers side?
- ‘96 Lumina 3.1 with a rough idle
- Speed Sensor Shift Issue 1990 Lumina Euro 3.1
- Need a slim jim...
- 97 Check Engine Light
- 1993 code 42
- 3.1 overflow hose part number?
- Horn Location in 1999 Lumina
- New fuel filter = hard starts?
- no a/c no shift check engine light on
- engine makin funny noise
- Knocking noise
- how goes it?
- 98 Runs great but starts hard.
- Drivers side door lock stuck ('97)
- '97 Fuse Block
- 95 lumina security lite is on on
- 1993 starts then dies. Possible ECM problem?
- A/C Problem
- Knocking noise from under car.
- 94 lumina swap question
- Can't find?
- 99 Lumina brake lights
- 98 lumina ltz
- Yeh, 97 Lumina starts again
- What Controls the speedometer?
- 97 Lumina Won't Start
- 92 Lumina Z34 Shifting Issues
- Posting Rules
- 92 Lumina Diagnostic Error Code List
- Pics/Profile
- Another question about my 92 z34
- 1993 Lumina Z24 Blinker Issues.
- 1999 3.1 blows fuse every time i hit the brakes
- New Problem: Stiff/Hard Gear Selector
- A oil cooler
- 97 Lumina 3.1 Front bumper
- Sequencial Brake Lights
- where does the antifreeze go
- 92 lumina 3.1
- Mechanics
- 97 Lumina wireing
- lumina 1992 3.1 problem
- heater motor
- looseing coolant
- Insurance Question
- Strange thing with AC
- Whats a PVC Hose
- 92 Euro brake problem
- One more post for Maaco paint Good or Bad
- forever lights? 92 z34
- Lumina 98 3.8 L Cooling water...
- 92 lumina z34 Knock sensor?
- Anyone have Engine Codes for Z34 3.4L???
- 1992 3.4 Liter Chevy Lumina Euro getting HORRIBLE gas mileage
- hydraulic lifters-3.1 L 97 Lumina
- where to get diagnostic help.
- low coolant light
- Dash Lights / Parking Lights don't work
- My Lumina is getting too hot! Please help and see if there isn't something cracked!
- 90 lumina a/c problems?
- 1998 Lumina Speedometer cluster
- 1995 Chevrolet Lumina 3.1 (M) Motor>>>>Runs rough at idle and under acceleration
- 1992 Lumina tail lights
- 93 Lumina 3.1 TCC replacement
- Inner tie rod replacement, 1996 Lumina
- Car won't crank to start
- 1990 Lumina Euro 4 speed automatic transmission
- 93 Lumina 3.1 cranks, no start, no spark
- Check Fix, Surging, Wanting to die, Service Engine Light
- 1991 lumina PROBLEMS
- Transmission - Rough Shifts and Whine
- Air Intake for Lumina
- lumina transmission
- hello im new to AF
- 98 fuel pump ?
- Side Window Lights
- 1992 Chevy lumina Euro 3.4 Liter getting terrrrrribble gas mileage
- I am completely flustered
- Not starting after new timing chain...HELP!
- Digital speedo
- 95 Lumina dash lights
- Pcv Question?????
- Cooling problem
- Brake fluid? Or some other Problem
- ac blows on the floor when i step on the gass
- Got The A/c Converted To R134a
- rear wheel seals
- 93 Lumina ... Gas tanks ?
- 1995 Lumina Intermittant Problems
- Hypertech Chip
- 1990 Chevy Lumina APV - need help with door handles/locks
- Lumina start problem
- oil cooler on 92 z34
- okay not much of a question but you know :P
- 97 Lumina Cranks, but won't start
- 2000 Lumina 3.1 Lights dim, tach jumps, often needs to be jumped
