View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22
  1. replaced injectors now starts poorly
  2. 90 Lumina Coil Pack
  3. 1990 Lumina temp guage problem
  4. Timing Chain Problem.......
  5. Vaccum Diagrams
  6. pic of fuse box cover for locating and replacing fuses
  7. Cat Plugged Up???
  8. 1995 Lumina Cat Bad?
  9. 1996 lumina horn relay
  10. Removing govenor from a 93 lumina euro
  11. Grinding noise when reversing??
  12. i cant seem to fix this stupid stalling problem
  13. 91 lumina
  14. What the hell
  15. tranny and electrical
  16. tranny and electrical
  17. Plastic visor-to-headliner clips (all GM?)
  18. electrical
  19. Multiple '92 Lumina problems
  20. Electrical Problems
  21. 95 Lumina APV engine miss
  22. interior accessories lights???
  23. no low end power z34
  24. swapping of 91 gran prix sub frame into a 92 lumina
  25. What to do
  26. 90 lumina wont start after battery change...
  27. I Need help
  28. 93 APV No Start
  29. alternator insatallation
  30. coil pack problem
  31. Lumina engine swap
  32. 1996 Lunina tail lights brake lights
  33. Oil Light!
  34. Heater and AC fan NO GO!
  35. A/C Compressor
  36. Slightly hard to start 1999 3.8 LTZ
  37. Changing Plugs on a 1999 3.8 LTZ
  38. 1990 Lumina
  39. 93 z34 not charging
  40. Blue Smoke From The Exhaust LUMINA APV 3,8L-95
  41. What the HECK: bad Water pump, head gasket...97 Lumina
  42. 3.1 engine rattle
  43. 96 Lumina Car - No Console or Tail Lights
  44. Dimmer Switch Relay?
  45. 97 lumina brake problems
  46. 95 Lumnia Reverse Lights and Power Trunk
  47. Accelaration problems on take off
  48. '90 apv - key cylinder not starting
  49. 95 apv 3.8 engine other years?
  50. Chime does not shut off
  51. Air coming through vents not sufficient to heat or cool 1992 Lumina
  52. who is right about the location of the pcv valve
  53. 93 Lumina No Go What da heck do I do next?
  54. Changing the spark plugs in 90 lumina
  55. losing tranny fluid, but where? + noises!
  56. Luminca Overheating.
  57. Lumina Engine
  58. Stalls at stop after Disconnecting battery
  59. Coolant Problem
  60. Didn't know it could do that
  61. performance parts
  62. timing belt of chain
  63. 1992 Lumina APv
  64. 93 lumina 3.1 v-6 hard starting
  65. Rear suspension noise?
  66. problem w/ electrical.says the code?
  67. 99 LTZ with 131k...sell or keep?
  68. 95 lumina whining and a little slow
  69. Sideview mirrors
  70. 91 Chevy Lumina stalls - DITTO
  71. 1997 Lumina Power window problem
  72. 96 lumina 3.1 radiator for sale
  73. 1992 Lumina Speed Sensor
  74. Tail light keeps blowing out in the rain
  75. Better way to hold door panel on?
  76. Clean headlight lens?
  77. Brake Pads
  78. '91 Euro Cooling fan prob
  79. 97 Lumina Security light
  80. 97 Lumina Won't Start
  81. 93 Lumina coolant leak
  82. 98 Lumina continuous chime problem
  83. '95 APV cooling fan won't turn on...
  84. How reliable are the mid 90's Luminas
  85. Weak ventilation air flow
  86. 91 lumina euro headlights
  87. Rich and the parts monkey...
  88. 94 Lumina fuel problem
  89. torque specs
  90. ABS problem
  91. Question about 1997 Lumina AC
  92. A Very well built car!!!
  93. lumina fuel pump relay
  94. fuse box diagram
  95. flush
  96. lumina 99 3.1 ...wheel noise on reverse
  97. loosing oil
  98. cruise?
  99. '99 Transmission shift trouble + coolant issue
  100. 95 3.4 DOHC idle surges
  101. 95 lumina heat and radiator problem
  102. 93 lum euro 3.4 fast cold idle
  103. 1991 Lumina Project
  104. `91 Lum 3.1 crank sens died on hwy, cyl 4 plug smashed, now no comp in cyl 4!
  105. 98 lumina vibration problem
  106. Cooling Fan Probs
  107. signal light
  108. 92 Z34 for sale
  109. 93 Lumina 3.1, I am becoming an expert
  110. 1992 chevy lumina z34
  111. 97 Lumina Water Pump
  112. 93 lumina euro 3.1 auto
  113. 92 lumina dying out
  114. 97 Service Engine
  115. Service Engine Light
  116. 93 Lumina Fuel Pump Control Modual???
  117. 1996 chevy lumina apv keyless remote program
  118. 97 Coolant
  119. low coolant light
  120. 98 lumina problem
  121. Location of PCV valve
  122. electrical system main harness
  123. 93 Lumina fuel filter--from trunk
  124. 1991 Lumina Z-34 Car, Will not Start, NO Power
  125. help with parts
  126. A tire review, if anybody cares...
  127. I need to rasie my Lumina
  128. '94 Lumina - whining noise
  129. 94 Lumina - dash warpage
  130. 94 Lumina - replacing bulb for HVAC controls
  131. 97 Lumina Radio
  132. 97 Lumina Coolant change
  133. 1997 Lumina Engine Light
  134. "Cheap OBDII Scanner" Is it worth it?
  135. brake pads and caliper ?
  136. New brakes in lumina...again..and again...
  137. Car refuses to start
  138. 1994 Lumina APV Headaches!
  139. 93 Lumina 3.1 "shuddering"
  140. Wire Harnesses?
  141. Extremly High Idleing During winter starts -- 93 Lumina 3.1 -- Throttle Position Sens
  142. Oil gasket replacement
  143. Heater core leak
  144. 94 Lumina Z34 problems?
  145. 1990 2dr chevy lumina so mang problems help single mother please
  146. Lumina Instrument cluster swap
  147. tranny swap?
  148. Drl......
  149. 94 lumina apv rough running
  150. where can i find website to decipher codes
  151. Swap a 3.1 for a 4 cylinder in a 1992 Lumina?
  152. 1990 Transmission goes to nuetral over 2k rpm
  153. lumina starting
  154. Lumina Sound System
  155. 96 Lumina APV transmission overdrive
  156. Lumina Z34 engine
  157. 91 Lumina stalls- even tried a psychic :-)
  158. Mass Air Flow (MAF) Sensor??????
  159. 91 Oil leak on backside of 3.1 Euro
  160. 94 Lumina shudders in between 3rd and 4th
  161. 93 3.1 Intermitantly runs rough
  162. 92 Lumina APV tranny rebuilt but wont move at all!
  163. 1991 chevy lumina
  164. `93 Lumina APV 3.1 sputters and runs rough
  165. just got a lumina... is there a distributer in the thing?
  166. 96 lumina, heres a strange one!
  167. P 102 Error On My 99 Lumina
  168. R.I.P.arts
  169. 1993z34 Not starting,pukeing fuel
  170. Fuel Filter Location for 2000 Lumina Sedan
  171. chevy man needs help in windy city
  172. catalytic converter removal
  173. 1990 Euro Dashboard Brake Light intermittently on
  174. Replaced the alternator, NOW IT WONT IDLE!
  175. 96 Lumina chugging/stalling/no start
  176. 97 weirdest noise ever !
  177. Adjusting the Idle on a 1990 Lumina
  178. Need Help! Transmission Price
  179. when in drive....
  180. door panel
  181. Heater blower motor power
  182. 94 Lumina, Battery acting like it's dying.
  183. Cruise control motor out. Help with replace.
  184. Replay asap if you know the answer pls
  185. I have a 1990 Chevvy Lumina, What kind of Coolant do i need?
  186. manifold bushing???
  187. 95 lumina ecm question
  188. fuel gauge doesnt work
  189. 2001 Lumina Hypertech Performance Chip
  190. stalling 1990 lumina
  191. 96 lumina
  192. 2000 Lumina transmisson problem
  193. 93 Lumina APV 3.1 Trans Problem
  194. 93 Chevy Lumina Euro For Sale CHEAP!
  195. I CUT MY LUMINA IN TWO!!! SERIOUSLY!!! It was fun.
  196. Just Won't Start
  197. Dash Board Wiring
  198. 91 Lumina stalling probem
  199. 91 3.1 spark plug connection
  200. 95 Lumina-2 related problems?
  201. Does my 2001 Lumina have a factory amplifier?
  202. Does anyone know any sites for wiring diagrams for a 1990 Chevy Lumina Euro 3.1 Car.
  203. Fuses
  204. Starter 1995 lumina
  205. 96 chevy lumina van something electrical
  206. 2001 Chevrolet Lumina and others factory delco CD player for sale
  207. EGR Valve
  208. Rumble
  209. cold air intake
  210. 90-94 silver lumina owners please help..
  211. '96 Lumina Radio Doesn't Work...HELP!!!
  212. Running Bad
  213. Kooterskkar question
  214. Parting Engine
  215. 93 Lumina - rough starting, please help!
  216. 1996 lumina fuse box
  217. Dash Lights
  218. EGR misfire
  219. '97 Lumina APV
  220. Dash covering
  221. Cranks but wont fire
  222. Changing front brake pads
  223. Power Steering '98 Chevy Lumina 3100
  224. 91 lumina...rain leaking into passenger side
  225. stalling 1993 Lumina sedan
  226. Help Lumina idle/miss w/Haynes codes
  227. 1990 chevy lumina starting problem
  228. 95 Dash Cover replacement
  229. 93 lumina help needed - please!
  230. New performance mufflers or cat back systems
  231. Fan slows and radio volume goes up when I go up hills
  232. Lumina Ignition Module??? Is this the issue
  233. Iac
  234. Headlight lens
  235. '93 chevy lumina 3.1 MFI idle/running problems
  236. 97 lumina won't start (please help)
  237. here ya go
  238. battery change
  239. Ignition lock cylinder
  240. Tranny Shift solenoids - 96 Lumina - Has anybody replaced em?
  241. 98' chevy lumina A/C
  242. Is it time to let go?
  243. 1996 Lumina codes
  244. Help the new bee. Oil light stays on
  245. conversion
  246. 1995 Lumina 3.1 spark plug wire connections
  247. Water dripping from muffler
  248. 92 Lumina overheating problem (yes another one)!!!
  249. cold exhaust
  250. Passkey
