View Full Version : Lumina
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [ 18]
19 20 21 22
- 99 lumina 3.8 sedan exhaust down pipe section
- No Heat on 90 Lumina Sedan
- Injectors
- accessories?
- Keyless entry question
- remote start/keyless/alarm
- 94 lumina Z34 3.4 Pwr Steering fluid leak
- 95 3.1 Lumina major probs starting
- 95 Lumina service engine soon no code
- 1995 Chevy Lumina LS
- Location of crank sensor?
- 99 Lumina Injector or Coil?
- Rough Idle after car sits for about 20 minutes
- looking for a Lumina
- No high on fan control
- 95 Lumina 3.4
- NO power under load, backfires thru carb, overheats.
- 96 chevy lumina wont start
- 3.1 to a 3.4?
- car will not start
- Seafoam in vaccum line
- 92 Lumina turn signal flasher/relay quit
- international help wanted regarding temp sending unit!
- 3.1 96' torque specs PLZZZ?
- 3.1L hesitation
- new fuel pump no pressure
- Fuel in the vacuum lines. Pls Hlp.
- injector cleaner
- ACCCKKKKK....My 98 Lumina is DEAD!
- Problem with electric fan
- 96 lumina issues
- chevy lumina apv electrical problems
- intake gaskets again
- '97 chev lumina check engine light
- 98 Lumina misfires flashing SES
- Prob with 92 Lumina A/C pulley
- Fuel gauge dropping to zero slowly
- 94 Z34 idle issue
- 97 Lumina Won't Start
- relay
- drive axle
- TPS trouble code
- Front of Oil Pan gasket leak 93' Eurosport 3.1
- Dash Cluster
- 95 Lumina 3.1 For Sale/Swap
- 95 Lumina APV problems, suggestions wanted
- 91 Lumina Starter
- Front wheel bearings
- Body Parts
- 1996 Chevy Lumina Auto side door
- Head Gasket
- no turn signals-1992
- Injectors
- 96 lumina transmission issue
- 4t60e Elctrical? Downshifts
- 92 lumina 3.1 euro WOOSH from air filter, now dead!
- Head gasket
- P0440 Code
- 95 lumina having trouble starting
- 3.1 v6 rocker arms
- Better gas mileage
- timing belt
- 1997 Lumina Accelerating Problem
- hard time selling lumina!?
- 93 lumina fixed
- Performance components
- I broke both drive axles.
- UnderDash Fan Speed.
- 96 Lumina; Blinker and Brake lights
- 96 Lumina; Check engine light and low coolant
- '92 Electrical Schematics
- valve lifters
- '93 Lumina 3.1
- 1190 Lumina 2.5L No Spark or fuel to intake
- 92 Lumina APV wont start
- engine/torque converter/tranny ?
- 91 Lumina APV - Rear Door
- 1991 Lumina Won't run
- 95 3.1L Intake manifold replacement
- 92 Lumina
- LTZ stuck in Park
- 97 lunima rpm
- What a depressing brake issue.
- 1990 Lumina euro window messed up-need help
- 95 lumina turn signal switch & air bag
- heater hose routing 97 lumina
- 1997 Lumina - low power
- Rough acceleration, lacking power
- oil pressure
- Help Please!!!
- Engine falter or stops after 30 minutes, intermittent
- 96 Lumina Misfire and slow start
- 96 Lumina Spark Plugs?
- Recent Stalling Issues
- 98 Lumina timing chain
- 93 lumina stops after 10 minutes
- 96 lumina apv cleaning egr
- 1991 lumina won't start
- chugg
- Decals...
- Alternator...
- Power door locks won't shut off
- Antifreeze question
- What's procedure to remove engine?
- What's Happening to my Paint!!??
- My car is dieseling (1994 Lumina Z34)
- '96 Lumina - misfire?
- 94 lumina apv tranny problems
- 93' EURO Secondary Cooling fan and mysterious leak in passenger floorboard
- way over my head..help!
- F-15: 1, Lumina: 0
- Im getting a code P0441
- 1992 Lumina Tranny Problem
- 91 Lumina stalls when put in gear?
- I love GM brakes...
- 99 lumina LTZ, front struts
- smoking lumina
- engine problem
- 95 Lumina Problems
- 3.1 engine starts bucking
- new problem with the Lumina
- Help!
- 93 lumina 3.1 spark plugs issues
- Lumina APV Open Loop
- 94 APV Wiring diagram
- A REAL CHALLENGE for you Experts out there
- '93 Lumina - Is it a good car?
- speedometer wont work and transmission wont shift
- Drilling a hole in a 1996 Lumina APV firewall
- 90 Lumina down shifting in cold weather
- 98 Lumina LTZ ABS clicking/flickering lights.
- Electric Mirror Replacement
- 92 lumina trans/ power sterring help
- 90 apv fuel pump relay location
- Lumina 92 V6 3.1 Standard Transmission
- Audio Troubles for me
- Still Yet another problem with my 92 lumina apv
- head gasket?
- Changing 1995 Limina Thermostat
- 96 list of problems
- P401 code
- extra wires
- Automatic Hard to Shift
- 1995 Lumina Heat Problems
- 92 lumina apv door handle
- Rims
- surging idle...
- Ran out of gas and now Lumina won't start :(
- ignition timing and problems...
- '92 - charging problems HELP
- Lumina stalling and jerking
- Low Coolant Light On
- 1990 lumina euro 4-door
- lumina
- 90 Lumina Euro throttle drops out
- thermostat
- 95 3.1 Lumina only starts in Neutral
- Flapping Noise in Intake
- Spark Plugs
- 98 3.8 Lumina
- getrag 284
- Blend Door Actuator
- 93 Lumina 3.1 v-6 Ignition module
- Transmission troubles... if its not one thing...
- 94 Lumina-Car stalled...now barely running
- 1994 Euro: had tranny rebuilt, now stalls
- ABS and BRAKE light on
- 90 lumina euro heater doesnt work
- How to lower one
- chip mod question
- 4t60e Trans......
- 1991 Lumina Power Steering Pump
- Theft-Lock feature
- 98 Lumina Coolant Leak
- lumina just stop on me
- caliper, and hub assembly
- Any-one with a code reader in Toronto area
- 96 Lumina turn signals/brake lights
- No air or heat will blow out
- 1990 Lumina 2.5L 4 Cylinder Problems Revisited
- Turbo??
- lumina/monte carlo compatibility...
- 1990 Current Status
- Super charger
- 96 lumina apv stalling
- Anti-Lock Brake Stays On
- Anyone parting out??
- Power Window Switch...can't find one online..
- Lumina (95 And 96), No brake lights
- '92 Lumina Cruise Control Quit
- might be buying a lumina apv van
- '97 Lumina overheating
- Major Electrical Problems!!! Please Help
- PROM Location 93' Lumina
- 5w-30 vs 10w-30 3.1 engine
- Upgrade Sources
- 3.1 1990 Lumina Spark Plug and Wire replacement went bad
- Brakes
- 92 Lumina 3.1 Will not stay running.
- 93 Chevy Lumina v-6 3.1
- 95 chevy lumina apv 3.1
- 1994 lumina euro engine replacement
- 96 Lumina, 146K, $1200 - what's your opinion?
- Test Drove Lumina
- need your opinion
- "SECURITY" light...
- 93 3.1 Lumina stalls
- My Lumina
- P0401 EGR Insufficient Flow
- What goes wrong in 1992 euro lumina
- 1992 lumina wont shift could it be the VSS
- 3.4L van intermittent no-start/fuel pump relay chattering
- exhaust..... need input
- Obd???
- a/c fan problems
- Fuzablelink???
- headlights adjustment
- Locked Keys in Car
- 2001 Lumina Firewall
- Where are the luminas
- struts need replacing
- Low coolant light
- RPO code
- 94 APV - resetting the computer
- 97 Lumina Code 1870
- 1992 Lumina APV
- Tach Wire
- Car making loud noises!
- pleas read Thanks
- 98 Lumina - replacing brake pads
- Beef up my Lumina?
- No air pressure when max heat on?
- obII or Ob1 or even a data log??
- RichTazz, Lumina 3.1. I need your brainPower
- Tail Lights and Dashlights
- Starting problems with 98 Lumina
- 1998 chevy lumini wont start
- 96 lumina multi-cylinder misfire HELP
- My dashboard lights
- 97 Lumina Flushing
- 98 w/3800 & coolant leak question
- Shifting Rough
- 96 Lumina cruise control stopped working
- New radiator makes my car run worse
- 94 Fuel Injector system
- Juice in the gear shift
- 96 Lumina power window.
- 2001 Lumina Coolant Flush
- 1991 Lumina fuel troubles
- High pitched sound from rear wheels....
