View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22
  1. Must press accel hard to start off 97 Lumina 3.1
  2. 97 Lumina Drive Belt Tensioner
  3. Oil light reset...
  4. Tranny neutrals on hard left
  5. 99 Lumina, 3.8L #6 missfire
  6. Transmission Change
  7. Oil Pressure Drop Van Cuts Off
  8. 1993 euro just stopped on the highway
  9. Transmission fluid change/TCC on 95-3.1
  10. transmission
  11. 92 Lumina 3.1 having trouble running
  12. '91 Z34
  13. Problem with 95-3.1 "transmission" solved!
  14. 93 3.1 lumina intermittent rough running
  15. Static from Radio
  16. clear a computer code
  17. Where is crankshaft position sensor?
  18. WTB:lumina 3.4
  19. looking for Rear door window molding
  20. How to check codes
  21. Power Lock Problem
  22. Battery Removal 2000 Lumina
  23. 92 Euro door won't open
  24. lumina 97 miss fire
  25. Information on a 1991 Lumian Euro 3.1
  26. Airbag Light. Help Plz.
  27. No cold air
  28. Transmission, lost second gear
  29. 96 Lumina Instrument cluster
  30. 1990 APV steam engine?
  31. '95 Lumina APV, need timing BTDC number
  32. 95-3.1 Drivers side door lock switch not working
  33. 90 Lumina 2.5L Won't Friggin Run revisited
  34. 98 Lumina issues
  35. shaking loss of power '97 Lumina
  36. Water Pump on 92 Euro
  37. 98 Lumina Sound Woes
  38. 1993 APV Lumina 3.8 173,000 miles
  39. heater return
  40. 1994 lumina
  41. 1990 Chevy Lumina V-6 question...
  42. 1990 Chevy Lumina Starts fine but dies right away
  43. replace heater core
  44. 96 Lumina engine blown after transmission flush
  45. Police issue Recaro seats
  46. 1990 Chevy Lumin Engine/Tranny Problem?
  47. A word of Advice for my car brethren...(about brakes)
  48. 93 Lumina Euro won't start
  49. 3rd time this week my 97 broke...help!
  50. 1990 Lumina missing/misfire
  51. Removal of a 96 trannie...help
  52. Climate Control Problems
  53. DIY problems, '90 APV, help?
  54. 97 Lumina 3.1 Ticks when 1st cranked
  55. 95 Lumina APV ABS Master cyl replacement?
  56. Security light- 95-.3.1
  57. 92 Lumina 3.1 will not roll over
  58. 2000 theftlock radio code
  59. upper intake manifold
  60. Lumina Instrument Panel Lighting Failure
  61. Z34 stalling
  62. Need replacement door for 95 Lumina
  63. 1992 Chevy Lumina Part Car
  64. Engine power loss
  65. 97 ls or not?
  66. Side marker lamp socket for a 99?
  67. 96 lumina, trannie problems
  68. fuse box diagram
  69. Replacing the exhaust manifold on a 3.1?
  70. 1992 lumina smoking after idle
  71. V8 Lumina?
  72. 1991 Chevy Lumina Euro 3.1
  73. Thanks to A Stranger for fixing my Lumina APV
  74. Thanks to A Stranger for fixing my Lumina APV
  75. 97 3.1 Cooling system Issue........
  76. Intermittent starting...it's the key !!!
  77. See if this sounds familiar....
  78. 1990 APV tbi engine change
  79. 97 Lumina Brakejob/Windshield
  80. Lumina Head Gasket HELP!!!
  81. dash lights
  82. Power steering pump
  83. 1996 chevy lumina apv transmission trouble
  84. speaker size on 97 lumina
  85. 3.1 l Lifters
  86. To Anybody With A Z34 Lumina!! Please Read!!!!!!
  87. question for anyone who knows regarding the 3.1L V6
  88. 95 Lumina van ,dist harness for 3.1
  89. 3.1 to 3.4
  90. 1990 Chevy Lumina Horn
  91. 1999 Lumina Power windows
  92. 1997 Lumina
  93. Where's the fuel pressure regulator please
  94. Trouble Code
  95. Oxygen sensor and brakes
  96. 95 Lumina 3.1- AutoTransmission "thumps at overdrive speeds
  97. 99 lumina multistick mafunction
  98. Lumina 1/4 Mile and 0-60 Times
  99. 95 Lumina- 3.1
  100. cost of intake gasket replacement
  101. '96 Lumina 3.1 - Jumpy shift in OD when hot
  102. 91 lumina transmission
  103. Theftlock GM dealer account #
  104. intake vs. head gasket leak
  105. question about lumina Mods
  106. Tranny codes
  107. 93 lumina drivebelt question
  108. CD changer harness
  109. 95 Lumina APV cracked subframe at rear mount
  110. 1997 Lumina Service Engine Soon ??????
  111. Locked out of my 92 Lumina!!!! Please Help
  112. iridium Plugs?
  113. 1995 Firing order issues
  114. Cooling Fans not working
  115. Trunk Leaking ? - need input please
  116. Wheel Upgrade
  117. Factory Radio for 1996 Lumina
  118. 1990 Lumina Euro Tach and Speedometer Stopped Working
  119. 1992 Lumina APV
  120. Ignition Control Module
  121. Difficult Starting
  122. 96 lumina
  123. 93 lumina not starting right / stalling out
  124. Check engine Chevrolet Trans sport
  125. Car won't start floods out.
  126. Quick disconnect
  127. Starting problem
  128. Blackout Tape?
  129. Lumina Body Kit
  130. 2 problems
  131. richtazz is back!!!
  132. Antifreeze Disappearing From Overflow
  133. annoying squeak
  134. EGR trouble code, where is it??
  135. electrical problems
  136. got the code info
  137. Cold air intake for 3.4 dual twin cam
  138. rattle noise from 97 3.1 lumina
  139. codes, too fast
  140. mannyboy, question for u/ or anyone that can answer it
  141. 91 euro , engine issues
  142. My 1998 Lumina has code PO303
  143. Valve Cover Leaking Oil
  144. 91 3.1 stalls while turning around
  145. Engine Disassembly
  146. Z-34 Rear Calipers
  147. trans prob in z34
  148. 96 Lumina - Clunking noise in suspension
  149. Marvel Mystery Oil
  150. 97 Lumina fast idle, low acceleration
  151. 94 Lumina starts-but stalls out
  152. Try This
  153. Desparate for help.....95 Lumina sedan 3.1L
  154. Please HELP! My 93 Lumina won't start
  155. 96 lumina exhaust leak ?
  156. Need Asst. please
  157. 3.1 L oil filter nippel
  158. Transmission disengaging
  159. 1992 Chevy Lumina wont start
  160. Lumina Police Rim Caps
  161. CEL/Knock Sensor
  162. Transmission Overdrive Slip
  163. Good Tires
  164. Valve Sticking
  165. 93 Lumina Euro Door Handle Installation
  166. 92 Lumina Z34
  167. 1993 Lumina Power Steering
  168. Lumina Hood Release Lever..BROKEN...HELP!!
  169. 1990 lumina wheels
  170. my dad fially retired from gm!
  171. Oil pan on 94 sedan
  172. Wanted: Z34 Mufflers
  173. Panel Lights
  174. Locked Out
  175. Belt squeak when warm
  176. Engine problems Need Help Desperately
  177. sound system wiring on a '98 lumina
  178. Help
  179. 95 Lumina won't run after warmed up?!?!
  180. bigtime trouble-1990 lumina apv
  181. 97 Lumina Vaccume
  182. Starter Removal
  183. Leaking Engine Coolant?
  184. 3.1 engine rebuilding
  185. Intake Manifold Gasket Repair
  186. weird noise from under hood or steering wheel?
  187. vacuum leak in 94 3.1 apv?
  188. 94 Lumina Ecu Problem?
  189. dash lights
  190. smoke at start up.
  191. egr
  192. transmission
  193. transmission noise
  194. Okay, new thread, new topic
  195. Leaking Head gasket
  196. 98 Lumina
  197. 97 Lumina hesitation
  198. Anyone know (fuses)
  199. random misfire #2 cylinder, 97 Lumina
  200. 98 Lumina lacks power
  201. Not kicking into gear... tran probs
  202. Replacing Battery
  203. Leaking oil pan gasket
  204. 92 lumina
  205. P0446 - 1998 Lumina LTZ
  206. Does anyone have programming instructions for the 94-96 Lumina APV remotes?
  207. Cluster
  208. stumble
  209. Euro gagues in a regular sedan?
  210. 1990 Lumina Van wont friggin run
  211. 97 Lumina,3100 fuel injectors
  212. Paint for Hubcaps?? Any ideas?
  213. 97 lumina fuel injector install
  214. velly velly strange
  215. 1997 Lumina Transmission
  216. need help wit engine stalling and jumping
  217. 97' Lumina (Fixed it..) But another Problem..HELP!!
  218. 97' Lumina (Fixed it..) But another Problem..HELP!!
  219. name of body panel?
  220. Transmission is wailing, what now???
  221. '93 Z34 Lumina High Idles when i start it.
  222. Removing Headlights on 93' Lumina
  223. 1990 lumina interior panel clips
  224. 96 Lumina - Speedometer Malfunction
  225. z34 starter removal
  226. hub problem on 1990 Lumina
  227. 2000 Lumina, heat gauge problem or sensor problem
  228. Please help...brake pedal vibration
  229. 1992 Chevy Lumina APV
  230. Rattle noise from steering column
  231. How to replace a drive shaft seal?
  232. 1997 Lumina - Good Head Unit?
  233. tac vs. no tac
  234. heat problem on 3.1l
  235. Side Skirt for Rocker Panel
  236. Engine Stalls Out
  237. Help With Pulling Codes
  238. Replace Rear Signal on 96 Lumina Sedan
  239. 1997 Lumina Problems (Major?/Minor?) Help PLEASE!!
  240. Headlights: hi beams work, low don't
  241. 1995 Lumina problem
  242. Wanting To Learn How To Rebuild 95 lumina Transmission
  243. rough idle
  244. Suspension Problem
  245. Where is the temp gauge sensor at?
  246. '95 Lumina 3.1 Transmission Choppy
  247. changing out an Ilumina 3.1 engine
  248. Trouble Code p0304
  249. 98 getting hot.
  250. Trouble Code p0304
