View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22
  1. 1994 overheating wheels
  2. where is ecm?? help
  3. 1996 Lumina 3.1 idling surges
  4. Same old story--'96 Lumina Will Not Start.
  5. Fuel Sending Unit
  6. 95 lumina
  7. 97 Lumina 3.1 won't start
  8. Lumina wont start
  9. Charging System? Battery Drain?
  10. Lumina Disease
  11. JET Performance Chip for lumina
  12. How can i make my car louder?
  13. 96 gas smell when starting, can I drive it?
  14. any picts or actual mastercylinder - 92 APV
  15. 91 Lumina Apv short in dash
  16. Radiator Fans not working
  17. 97 lumina fuel smell from engine oil
  18. 95-3.1 short in radio/chime module circuit
  19. Oil In The Radiator
  20. learning the 3.1 radiator for the 93 Lumina Euro
  21. 96 Lumina 3.1 // high speed stalls
  22. Rough idles after starting car at high temps
  23. Another Braking thread
  24. 95 Lumina keeps running when turned off.
  25. Service Engine Soon Light
  26. IGNITION PROBLEM-'90 lumina APV 3.1L
  27. Designing Microcontrolled Booster...Need feedback
  28. 1992 Lumina I want the alarm system OFF
  29. Piston Head Cleaning
  30. 1990 lumina stalls only when it's hot outside
  31. Vehicle Speed Sensors
  32. Is the fuel pump going bad or is it something else?
  33. 90 Lumina 3.1 lots of problems. HELP!!!
  34. Idle Out of Control (IOC)!
  35. 96 Lumina Head Gasket Replacement
  36. Ebay Jet Chip?....any good?
  37. air cond. question
  38. Turn Signal Switch
  39. wtb: 90-94 air box and air intake hose
  40. 93 Lumina 3.1L shuts off when hot
  41. 95 drl, cruise, and air conditioner not working
  42. 1993 lumina no spark on #4 cly
  43. 91' Lumina Euro won't shift out of first gear
  44. 93 Lumina 3.1 starting problems
  45. ignition problems
  46. Power Window motor removal
  47. Electrical Problem W/ 96 Lumina
  48. 1990 Lumina 3.1 liter V6 needs help.
  49. '95 losing overdirive
  50. 90 lumina questions about brake booster and wires
  51. airbag light
  52. compressing replacing - need suggetions
  53. How to test coil pack....rough idle on 92
  54. what's the difference between a Euro and reg 92 Lumina
  55. Bought a 98 Lumina lemon! Bucks/hesitates hot on hwy. HELP!
  56. 94 Lumina APV , engine dies instantly after warm-up...please help
  57. Oil pan plug gasket 1990 lumina APV
  58. Intake Manifold Gasket
  59. 92 lumina 3.1 running BAD HELP
  60. 98 lumina
  61. Weird noise from front end
  62. o2 sensor check engine light
  63. lumina steering
  64. Need Codes for 97
  65. overheated but fans didn't turn on
  66. batterty issue
  67. Vacuum Modulator line Boot?
  68. Lumina APV 95 engine won't start
  69. 90 3.1 coolant bleed
  70. 99 lumina oil capacities
  71. tranny slipping?
  72. 1991 lumina auto fuel shut off switch?????
  73. 96 Lumina with misfire problems
  74. 1997 Lumina LS (3.1L) Jet Chip
  75. 1997 Lumina 3.1 won't start
  76. Monroe or Gabriel
  77. 1993 APV 3.8L TCC Location/Problem
  78. 1996 Lumina APV keeps blowing fuse
  79. '91 Z34 question.
  80. restoration in WI
  81. 94 Lumina Z34 Master brake Cylinder Replacement
  82. hesitating and stalling
  83. Lumina turn signals switch inop?? Here's the fix
  84. 1997 Limina Won't Start
  85. Parting Out 97 Lumina
  86. 92 Lumina Fast idle problem, starting problem
  87. lumina 93 a/c
  88. Help me with my 1990 Lumina Euro
  89. How do I test the oil light on 92 lumina 3.1
  90. WHERE IS FUSE BOX - 1996 lumina
  91. Where Is Fuse Box - Brake Lights Broke
  92. tornado
  93. 91 front rotor help
  94. Exhaust - Cat-back pipe upgrade
  95. Junkyard motor
  96. no spark
  97. Im going to buy a '91 Z-34, what are the common problems ?
  98. Hesitation On Aceleration
  99. Help or something
  100. 92 3.1 Sedan possible oil pressure problem
  101. 92 Lumina 3.1 help
  102. Please Help Me With My Lumina
  103. I need help with my 2000 Lumina HELP!!!
  104. 91 Lumina - how to check codes?
  105. 96 Lumina A/c Bypass
  106. carbon in intake
  107. A/c
  108. A/c
  109. spark plugs and wires
  110. stutters, stalls - 1993
  111. 1990 3.1L Lumina - My Problems
  112. Confused about AUX button
  113. temp light comes on sometimes
  114. Cruise Control
  115. 95 lumina struts
  116. 95 Z34
  117. lumina 1995 camshaftsensor and p1670 code
  118. dummy question: Cruise switch
  119. Can't access trunk.
  120. power issues
  121. 1991 Euro 3.1 Torque Strut Question
  122. 90 Lumina needs to "rest" between starts!
  123. Power Window Issue
  124. chevy lumina van
  125. How do you re-program the keyless entry
  126. P0401 '97 Lumina
  127. '97 Lumina Vacuum Leak (Diagram Req.)
  128. do a valve job or not?
  129. felpro head gaskts writing up or down?
  130. police center caps
  131. economy
  132. balancer removal advice
  133. Location of the ECM?
  134. electric mystery
  135. 90 dashlight problem revisited
  136. I need some help
  137. very high idle
  138. 97 Lumina dies, won't start (for a while).
  139. rear dics brakes
  140. 90 lumina wont keep a charge
  141. 95-3.1 HVAC vacuum problem
  142. No brake lights
  143. no tail lights
  144. 1997 Lumina 3.1 has fast idle after starting
  145. need info on 3.1 police edition engines on '97 Lumina
  146. ABS brakes
  147. A/C electrical?
  148. Please Help
  149. siphong gas from 91 Lumina to replace fuel pump
  150. 95-3.1- EGR Valve
  151. '93 Lumina -- *sudden* jerking @ ~ 45mph, *please* help
  152. vacuum diagram
  153. Curious
  154. lumina apv has no spark
  155. K&N intake kit for 90-00 Lumina's (Sweet)!
  156. Rpm
  157. 90 Lumina tachometer wire?
  158. Check engine light and weird excelleration?
  159. 90 Lumina Euro Turn Signal.
  160. RPM's rising too fast at little speed
  161. Does anyone know how to fix this?
  162. 93 lumina euro running hot.
  163. help with replacing 1990 lumina battery
  164. noisy a/c when off - clutch?
  165. Please help me with my electrical problem
  166. '92 3.8 APV Oil Pump???
  167. my car hates me
  168. Ignition
  169. 97 3.1 surges on take-off and has massive torque steer
  170. Lumina sedan turn signal working intermittently
  171. RE-Advice
  172. Advice Again
  173. "Sawtooth" rev pattern when I gun it.
  174. Thnx to cadgear and all
  175. Now What?
  176. advice
  177. flickering lights
  178. Coolant leak/dead battery...connection?
  179. newbie trunk question
  180. 99, 3.1L, Won't shift to 2nd gear when cold
  181. 90 Lumina Auxiliary cooling fan problem
  182. 95 Lumina LS 3.1 Speedometer Issue
  183. 99 3.1 lumina slow out of first
  184. WOW! (and I need some help)
  185. several problems w/ 3.1
  186. Will my Chevy make it?
  187. check this out!
  188. '93 lumina overheating
  189. Loud groan in reverse?
  190. 99 lumina 3.1
  191. Ticking Noise
  192. 97 probly lifters
  193. Drivers Side Mirror
  194. O2 sensor after cat
  195. Torx Screws
  196. lumina trans for dummy
  197. Outer Tie Rod
  198. '93 regular Lumina CAI, a real improvement????
  199. 92 Lumina Stalling
  200. Remote Start
  201. 93 Lumina with 3.1L 1st Gen wont start
  202. '93 won't start, then starts - continual problem
  203. how do i set the clock?
  204. check engine light help
  205. 24x crank sensor
  206. tranny question
  207. Performance?
  208. stuck accelerator pedal
  209. 92' won't downshift
  210. cars cars and more cars
  211. newbie has dome light trouble
  212. 91 3.1 stalls
  213. Pictures of amplifier install, MP3 and speakers
  214. P/W switch illumination
  215. factory fog lamps and CAI for a '93 chevy lumina
  216. Aftermarket Stereo wiring
  217. a/c problem
  218. shakin' when brakin'
  219. lumina gague cluster
  220. Another brake issue thread
  221. 93 Lumina Power Window Problem
  222. '93 chevy lumina 3.1 tranny slip quick fix?
  223. 1992 Fuel Pump Wiring Diagram?
  224. 1995-3.1 & 2002-3.1 Engine Swappable ??
  225. gm wheels
  226. Help w/oil in water
  227. noise unknown source
  228. Trans slipping in 1st; can VSS be bad if odometer is working?
  229. car shakes when braked
  230. 1998 Monte carlo a/c problems
  231. exhaust questions
  232. 1994 lumina apv shorted
  233. 2001 Chevy Lumina Tranny
  234. 1997 Lumina tranny gone
  235. How to remove 98 lumina dash?
  236. Help identify the part from the pictures
  237. Should I clean it with a spray?
  238. Dash Light Ground.. where? 95 3.1 Lumina
  239. 3.1 liter engine for sale
  240. 93 lumina rough running problem solved
  241. DOHC injectors
  242. 98 Lumina how to remove back seat?
  243. 91 Euro Alternator issues
  244. 96 Turns on but when gas pedal is press it wont accelrate
  245. Signal Light Possesssed !
  246. 96 Lumina sucking air through oil fill
  247. 2001 Lumina keyless entry programming
  248. 93 Lumina won't downshift when hot
  249. 98 has poor braking ? =
  250. squeak.
