View Full Version : Lumina
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 [ 14]
15 16 17 18 19 20 21 22
- 94 Z34 starts, idles, but step on gas it dies
- Lumina Codes
- smoking steering wheel
- Overheating 1995 3.1L
- New member... 1996 Lumina Brakelights
- BIG Z34 Problems
- Anyone want to buy a cd player for their lumina?
- Connecting a 3.5mm connector via AUX on car stereo (96’ Lumina). Is it possible?
- 92 Lumina APV gets to highways speed; then stalls
- 97 Lumina stumbles on acceleration
- vent fan switch malfunction??
- Cylinder #4 is Dead
- condenser water inside but drain not plugged
- Help with 97 Lumina
- RWD Conversion
- over heating problem?
- 97 Lumina Hazzard flasher
- Back right wheel wont spin. why?
- Uneven tire wear
- fuel injection fuse keeps blowing
- MPG for 1996 Lumina APV
- windsheild tracks
- A/C drain plugged!
- Turn signals
- early lumina's drivers door handle generic problem
- 90 Euro bucking while accelerating
- sputtering lumina fixed
- Help 92 lumina code 23 and 35?
- 1997 Lumina AC Problem
- 97 Lumina
- Lumina Spoiler
- Z34 Parting Out
- TilT Steerin prblms Lumina Z34 93'
- 93 Euro Lumina MPG
- cranks but not starting. Ideas please.
- Multi-Vacuum Leaks
- A/c Blower And Turn Signal 99 Lumina Ltz
- how to remove the dashboard?
- 1991 z34 3.4 hard start/runs rough
- Blower motor problem
- I Need Help
- rear wheel camber
- Drum brakes to Disc Brakes? '97 Lumina 3.1L
- Just for future reference, gas tank
- Multifuncition lever assy 1996
- A dumb question I know.
- running rough
- 95 lumina
- Crank Shaft Sensor --- OR --- Other ignition problems?
- 91 Lumina Euro 3.1 power steering hose questions
- ways to upgrade a 98 lumina
- Maybe my alternator?
- Anyone want an alternator to rebuild?
- how many gas?
- engine replacment
- ? in park, rev up engine then it starts going up and down up and
- 91 Lumina Z34 Air Conditioning help
- Lumina Minivan
- 1991 lumina dash light prob??
- Torque specs
- idiot lights
- lumina engine stops suddenly
- Lumina Door Locks
- 97 lumina
- Problem with Car
- Caliper Pins
- CAI, interesting
- Engine Interchange?
- 92 Lumina Euro Engine cuts out
- Steering Problems
- Tailgate lock
- Parting out a '96 sedan
- air condition
- No electric pulse to injectors
- Misfire, engine runs poorly
- putting manual transmission in z34
- self paint job
- Lumina APV engine problems
- 97 Lumina fuel issues
- injector testing (in car)
- 90 Chevy Lumina rear strut replacememt
- Smoke coming from steering column...turn signals don't work
- heater hoses locations
- 94 Lumina Euro
- 97 lumina crankshaft sensor problem
- HELP!!!!!!!!! NO dash or tail lights
- Bought a '92 Lumina Z34...
- 97 Lumina, lots of issues...
- Smelling Fuel
- 1997 Lumina Rear wheel ABS Sensor
- Do I need new Alternator?
- Power Steering Pressure Line (Caused me Stitches)
- PCM location on 95 Lumina APV 3800
- sputtering lumina
- 1990 chevy lumina euro 3.1 turns over does not start
- radio reinstall
- Idle surge/rough/dies
- alternator diodes
- location of pressure switchs?
- transmission
- intake on 97 Lumina - advice needed
- 97 Lumina fuel pump
- Intake for my Lumina!
- injector power
- Please Help Me
- lumina sputtering
- 95 Lumina trans slips on take off
- Intake and Exhaust 3.1 Lumina
- 93 z34 new front brakes grinding
- 1995 chev lumnia van
- Seafoam
- 94 lumina van electrical problems
- location of ac filter for 95 Lumina Sedan
- 2001 Lumina idle/maintenence questions
- please help a girl.with a 90 lumina 3.1,starting and try pressing gas pedal then dies
- Front struts
- My Air
- How to Find
- LS7 in a 93 lumina euro sedan
- 3.8L engine
- 97 lumina Steering play
- 93 Lumina Euro problems
- 96' Lumina 3.1 power window motor?
- jumping / bucking / stalling
- Water Outlet Tube
- please help me fix cruise 96 Lumina
- could use help with coolant system - 2000 lumina
- Manifold / heat shield expansion (99 3.1)
- Bad news for my Lumina
- Power locks out of control
- vacuum leak on a '96 lumina
- 91 APV blowing fuses
- '99 With a Coolant Leak
- Question About Wiring
- Brake efficiency in 96 Lumina
- Need door panel, and window. Passenger side
- location of the temp sensor
- 1994 overheating wheels
- where is ecm?? help
- 1996 Lumina 3.1 idling surges
- Same old story--'96 Lumina Will Not Start.
- Fuel Sending Unit
- 95 lumina
- 97 Lumina 3.1 won't start
- Lumina wont start
- Charging System? Battery Drain?
- Lumina Disease
- JET Performance Chip for lumina
- How can i make my car louder?
- 96 gas smell when starting, can I drive it?
- any picts or actual mastercylinder - 92 APV
- 91 Lumina Apv short in dash
- Radiator Fans not working
- 97 lumina fuel smell from engine oil
- 95-3.1 short in radio/chime module circuit
- Oil In The Radiator
- learning the 3.1 radiator for the 93 Lumina Euro
- 96 Lumina 3.1 // high speed stalls
- Rough idles after starting car at high temps
- Another Braking thread
- 95 Lumina keeps running when turned off.
- Service Engine Soon Light
- IGNITION PROBLEM-'90 lumina APV 3.1L
- Designing Microcontrolled Booster...Need feedback
- 1992 Lumina I want the alarm system OFF
- Piston Head Cleaning
- 1990 lumina stalls only when it's hot outside
- Vehicle Speed Sensors
- Is the fuel pump going bad or is it something else?
- 90 Lumina 3.1 lots of problems. HELP!!!
- Idle Out of Control (IOC)!
- 96 Lumina Head Gasket Replacement
- Ebay Jet Chip?....any good?
- air cond. question
- Turn Signal Switch
- wtb: 90-94 air box and air intake hose
- 93 Lumina 3.1L shuts off when hot
- 95 drl, cruise, and air conditioner not working
- 1993 lumina no spark on #4 cly
- 91' Lumina Euro won't shift out of first gear
- 93 Lumina 3.1 starting problems
- ignition problems
- Power Window motor removal
- Electrical Problem W/ 96 Lumina
- 1990 Lumina 3.1 liter V6 needs help.
- '95 losing overdirive
- 90 lumina questions about brake booster and wires
- airbag light
- compressing replacing - need suggetions
- How to test coil pack....rough idle on 92
- what's the difference between a Euro and reg 92 Lumina
- Bought a 98 Lumina lemon! Bucks/hesitates hot on hwy. HELP!
- 94 Lumina APV , engine dies instantly after warm-up...please help
- Oil pan plug gasket 1990 lumina APV
- Intake Manifold Gasket
- 92 lumina 3.1 running BAD HELP
- 98 lumina
- Weird noise from front end
- o2 sensor check engine light
- lumina steering
- Need Codes for 97
- overheated but fans didn't turn on
- batterty issue
- Vacuum Modulator line Boot?
- Lumina APV 95 engine won't start
- 90 3.1 coolant bleed
- 99 lumina oil capacities
- tranny slipping?
- 1991 lumina auto fuel shut off switch?????
- 96 Lumina with misfire problems
- 1997 Lumina LS (3.1L) Jet Chip
- 1997 Lumina 3.1 won't start
- Monroe or Gabriel
- 1993 APV 3.8L TCC Location/Problem
- 1996 Lumina APV keeps blowing fuse
- '91 Z34 question.
- restoration in WI
- 94 Lumina Z34 Master brake Cylinder Replacement
- hesitating and stalling
- Lumina turn signals switch inop?? Here's the fix
- 1997 Limina Won't Start
- Parting Out 97 Lumina
- 92 Lumina Fast idle problem, starting problem
- lumina 93 a/c
- Help me with my 1990 Lumina Euro
- How do I test the oil light on 92 lumina 3.1
- WHERE IS FUSE BOX - 1996 lumina
- Where Is Fuse Box - Brake Lights Broke
- tornado
- 91 front rotor help
- Exhaust - Cat-back pipe upgrade
- Junkyard motor
- no spark
- Im going to buy a '91 Z-34, what are the common problems ?
- Hesitation On Aceleration
- Help or something
- 92 3.1 Sedan possible oil pressure problem
- 92 Lumina 3.1 help
- Please Help Me With My Lumina
- I need help with my 2000 Lumina HELP!!!
- 91 Lumina - how to check codes?
- 96 Lumina A/c Bypass
- carbon in intake
- A/c
- A/c
- spark plugs and wires
- stutters, stalls - 1993
- 1990 3.1L Lumina - My Problems
- Confused about AUX button
- temp light comes on sometimes
