View Full Version : Lumina
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 [ 13]
14 15 16 17 18 19 20 21 22
- who's bright goddamn idea was it to use TORX head caliper bolts?!
- Need directions for MAP sensor install
- Please help me fix my '98 Lumina 3.1 Need help!!
- 90' apv 3.1 engines stalls in gear while hot
- '98 Lumina trans. fulid fill?
- 3, 2, 1, No ignition!
- 2000 Lumina missfire
- TCC Shutter
- '93 sedan door locks
- Truck cuts out during acceleration
- DRL only works during daytime
- exchanging motors
- Lumina 4T60E trans trouble
- looking at 95 Lumina
- low voltage,then normal
- 97 lumina airbag light
- 99 Lumina LTZ Overheating/Losing Break pressure
- pulsating/flickering headlights, `01 Lumina
- 2002 s10 blazer limited slip rearend
- P0300 Code Please Help
- hm..?
- 2.5L Engine Swap
- 93LuminaHighIdleAfterWarmedUpStart
- 1999 Lumina rear struts
- Can anyone tell me the intake manifold torque specs. for a 1991 Z34?
- 90 Lumina that just won't run
- The Loserboy Riced Out Lumina's Thread
- Convert rear brakes to disk
- 96 lumina 3.1 same as 2000 3.1?
- Questions from new Lumina owner
- cam shaft sensor replacement
- EGR Insuf Flow
- Lunima APV 1993 3800 V6 -No spark
- 93 lumina euro won't start during jump
- 95 Lumina Driver Side Window Problem
- 95 Lumina, connecting AUX audio source, is it possible?
- 98 Lumina Braklights in-op
- 96 lumina noise
- Getting a gas gauge fixed?
- i hate fuel lines
- lumina mods
- Replacing Rotors
- 90 Lumina 2.5 to 3.1 engine swap? Anyone done it?
- Coolant Leaking (but from where?)
- 1996 Lumina keeps blowing Security 10amp fuse
- Acceptable "piston slap"?
- Torque Specs
- AC not working
- Loss of acceleration
- Power sliding door stopped working
- 94 Lumina APV Starting problems
- 1999 curise control
- Heater air flow is stuck in Blend mode and AC doesn't not work
- 1991 chevy lumina won't start !!!
- squeaky door
- '99 LTZ PSP resevoir
- 1990 Lumina oil problem
- 97 Lumina $1700??
- replacing injector, need tips
- APV poor fuel consumption
- My 92 lumina runs great then like a piece of crap
- 98 lumina service engine light problem
- Looking for part information
- How to determine Bleeder Valve P/N?
- Lumina stalls/hesitates/lunges
- lumina z34 engine switch but no spark
- Interchange steering col.
- man i wish luminas had cool body kits
- 1992 Euro/Z34 compatible?
- How do u lift up the rear deck panel?
- Daytime Running Lights on 2001 Lumina
- 96 won,t start=
- cleaning erg valves
- 92 Lumina Cranks But Wont Start
- 92 lumina euro stalling at stops
- EGR valve question.
- No running lights or parking lights
- Airbag light dissapears
- 92 Euro power sterring
- 96 Lumina car daylights
- How to take off tail lights? (want to paint)
- 3.4 stumbles at 4000 RPM
- New filter for lumina?
- Air bag replacement
- 97 lumina 3.1 #3 missfire bad plz help
- EGR valve
- 96 Lumina Sedan NEED OIL PAN REPLACEMENT HELP
- Temp gauge rising
- Gremlins are messin with my electrical
- Will a TranSport computer work in APV
- 01 Lumina sedan keyless question...
- 92 3.4 5 speed high idle NEED HELP FAST
- Gas Mileage
- daytime running lights not working
- Heater not working...
- Where should i mount my amp? and my fuse block?
- Vapor Cylinoide 98 lumina
- The Following Parts Are Available:
- Where would I purchase a Vapor Cylinoide?
- high nox readings
- 1998 lumina just stops
- 96 lumina running cold
- Power window problem
- Locating a Vapor Cylinoide
- 007 Car Accessories
- Which head gasket?
- car does not run right
- ignition wiring
- Lifters ticking?
- heater blower motor where is it in 1990 lumina
- Trans 2000 lumina
- Rough Idling/Stalling, all 6 cylinders burning super rich, please advise.
- Routing AMp cables.... Please help
- warning symbals
- Weird Hesitation...
- miss at idle
- 1992 Lumina APV
- Engine Knocking!!!
- Runs Rough, Smell Gas, Low Gas Mileage
- Cold air intake on a 3.1 Lumina
- '94 lumina minivan 3.8 stalling speedo jump
- 92 Lumina APV 3.1 3t40 no forward gears
- 92 Euro Coolant in the motor
- Help Im clueless, I smell antifreeze
- What is the path for the large belt.. to put on.
- Lumina APV Jerking Hesitating
- Adjusting Valves on 96 3.1 Sedan
- 91 z34 brakes
- Dead Battery.1993 Lumina Z-34
- grind grind click grind grind click...
- fuel pump 95 chevy lumina
- Transmission 1991 125c no reverse
- Who thinks what...
- 96 Lumina APV Wiper troubles
- Chevy Lumina 90 Euro Help!!!
- Struts
- 93 lumina help
- Please help give some ideas...
- How I fixed my stalling at low rpm 92 lumina!!!
- Anyone ever broken a crankshaft?
- abs related(?) electrical problem?
- 1990 Lumina Euro Stalls/spits/coughs/won't start/run when hot
- The Check Engine light 5
- 93 3.1 lumina overheating
- trans
- She just wont start
- Chevy Lumina APV Minivan
- missing and tach jumping with the miss
- Parts Compatibility for a 1993 or 1991 z34.
- problems after intake gasket change on 3.1
- 1994 stall
- 92 Lumina Z34 for Sale
- Timing
- Power steering fluid 99 3.8
- car dies
- '92 White vs. '93 White
- What is this????????
- 91 Lumina - Engine doesn't start right up - have to hold gas down to get it to run
- 98 lumina 3.1 missfire
- well, lets throw something else in the mix...
- cd player
- Anyone have a dynomax muffler on their lumina?
- flex fuel
- issues after a trans swap...
- Part ID
- Electrical
- New driver
- New Driver
- bad ecm
- Starting issues
- Block heater, need help
- 93 lumina motor swap
- 99 Lumina Overheating
- push rods and engine ID super riddle
- For Sale!!!
- Obd1 And Obd2 Code Scan Tool Recomendations
- Breaking Caliper Pins
- O/d Light Flashing
- oil leak
- injector cleaner 3m adapter kit
- lumina shuddering
- 92 Lumina Gas Tank Pressure...
- Differences between Monte carlos and luminas?
- Need quick advice on if I should buy!!
- What all can be done to a lumina?
- Did I Get The Shaft???
- Idle problem and down shifting problem.
- Surge/Hesitation, Stalling, Flickering
- Air conditioner trouble
- 92 Lumina Z34 won't start has spark
- OBD2 <> Computer Interface (115200 K/Bps)
- 1990 3.1 No Injector Pulse - Intermittent
- wiered problem - coolant/temp/heater
- humming noise from back of car
- 2000 lumina ABS noise
- 2000 & 2001 Lumina chronic problems?
- 91 chevy lumina
- 1996 Lumina APV overheating - air pocket?
- i fixed it
- Glass Pack Muffler Exhaust system
- '97 3.1 now with new problem
- lumina/luminaz34
- Abs Warning Light
- gettin' there
- 98 Lumina won't turn over
- Lumina Dies randomly... weird problem
- Transmission, disengages, wont go in reverse...
- 97 Lumina w/157K
- 92 Lumina Shocks
- Well.... Im back
- 1995 Chevy Lumima central locking tranmitter module - where the h
- winshield wipers won't turn off.
- Bypass A/C compressor on 3.1 litre
- smoke coming out of the steering column ??
- Euro Tail Lights
- code 42
- IMPORTANT:----->>> $10 Oil Filter POLL!
- Reaching the lower Manifolds
- 95 lumina power locks
- white smoke and water from tail pipe
- Gas fuel gauge needle doesnt work
- 99 Overheats when heater is on..
- fuel line clean out
- 1992 Lumina 3.1
- im gunna blow this !@#$%^& car up !
- 91 Lumina Oil sending Unit (With gauges)
- Automatic door lock
- 95 lumina ls flashing low coolant light
- Bucking Engine
- 93 lumina
- Decode a Lumina vin for 9C3 or 9C1 option?
- Battery Died
- dang 93 lumina
- Stupid question about OD and D
- Lumina overheats at high speed+a/c problem
- Do Not Post Until You Have Done A Search!!!!!!!!!!!!!!!
- Idling too high, esp in park
- Parting out 92 Lumina
- engine temp stays at 210 - 92 lumina apv
- button start
- Just changed brake pads
- Fatter tires for my 98
- $1200 CDN for 1992 LUMINA 3.1 is it ok?
- clicking sound
- 90 lumina problems
- Going to look at a 93 APV tomorrow
- Thermostat Change
- Just completed a Trans. Filter Change.
- Heater Blower for 1990 Lumina Van
