View Full Version : Lumina
- Should I buy 1992 lumina euro???
- AC ??? 2001 136,000 mi
- 1996 Lumina intermittent problems
- A/C Service?
- Time for the Graveyard? (97)
- car cover.....somebody....please
- Engine Torque Strut
- 95 Lumina dies suddenly at 50mph and at stop light
- MAP sensor
- alternative to armor all?
- normal???
- 93 lumina, Heating/cooling- direction?
- 1997 Lumina A/C question
- chevy lumina rest in peace
- Can anyone help me here?
- help! ignition problems
- Easiest Question on the Forums!!!!
- 1997 Lumina 3.1 parting out or whole
- best engine???
- coolant
- Brake lights
- 97 lumina waterpump bolt torque setting
- BIG engine Trouble I Think 97 3.1 Lumi... HELP!!!
- 1998 chevy lumina (broken axel)
- car cover
- '93 Coolant leak, oil fine, pump, heater core/pipe OK near fire wall pass side HELP!
- Cooling fan not working
- High/Low Beams
- what price??
- luminn 1998 3.1 spark plugs help
- LT.carguy has a leak
- 3.1 Fresh top end, now zero compression. Help
- AC 1998 lumina 3.1
- 98 Lumina LTZ Service Engine / Idle Problem
- Odd problem
- Check it out
- 92 3.1 Lumina missing
- 92 3.1 studders at idle and acceleration, cruises fine
- 1998 3.1 Lumina Troubles AGAIN! HELP!
- 91 lumina 3.1 motor mount
- 93 lumina dies while in idle or at stoplights
- '97 Lumina - Rear Brake Job - Questions
- Lumina Z34 stalling.
- 1997 Lumina Evaporator installation
- 1998 lumina front end noise
- 1998 lumina A/C problem
- ABS Brakes--Light On Dash Remaining Lit!!
- 96 3.1 lumina fuel problem?
- My Lumina Has A Mind Of Its Own!!!
- Lumina '99 break problem
- How do you remove an antenna from a '95 Lumina
- 92 3.1 Lumina NO SPARK problem
- Check engine light on .. need help
- 98 Lumina tail light fuse #
- Easy One probably... 97 3.1 lumi...
- 97 Lumina running REALLY rough, P0300, P0442 showing
- 91 Lumina Euro rough idle
- 97 Lumina - Air Condition Troubleshoot & Repair
- type of plugs to use?
- Spark Plugs
- A/c
- Vacuum Line Help...97 3.1 Lumi
- opening the trunk
- Clear Taillights for Z34
- How Many of Yoy have done the Base to Euro cluster upgrade?
- easy strut installation=
- Base and Running Timing? (94 AVP 3.1)
- Blower resistor block!!***!!!
- 98 base lumina seats
- 1994 Z34 Door Handles
- really stupid question
- Bolt Circle??
- Radio Lights
- 98 Lumina Service Manuals
- 1995-2001 Chevy Lumina Headlights
- How many miles to reset codes?
- Change water pump on 95 limina with 3100 engine
- Rolling the Engine Forward (GM Engine Moving Tool - Link/Description)
- Please help me out.
- Good engine is STL, MO area
- '97 lumina LS
- 98 Lumina LTZ
- 98 LTZ A/C issue
- Transmission Code P1870
- Lumina APV 94 ..coolant leaking
- 93 lumina wont stay started
- HELP! 97 lumina L&R brake light gone first, then won't start totally
- 98 Lumina Code P0300
- Rodent entry into HVAC?
- Transmission Noise??????
- Shuttering at acceleration
- What Would YOU Do???
- Paint?
- z34 ground effects
- 1994 APV 3.1: Recommended Coolant & O2 Sensor Missing?
- lumina for sale
- instrument lights go off when outer lights are turned on!!
- Part number help please
- '95 Lumina APV problems/NEED HELP PLZ
- Lumina DIS fuse blows
- What did you paid for your Lumina
- 93 Lumina APV cruise and AC problem
- non peeling?
- PROBLEM 3.1 car RUNNING BAD!
- Is A 1992 Lumina Z34 Worth fixing up?
- 97 Lumina - air conditioner
- Compressor not working - where to start?
- 94 Z34 summer project
- 98 Lumina Air Conditioning
- Body Kits
- What Year Is Your Lumina???
- clicking on start up
- Going to look at a 92 APV tomorrow.
- Shock Replacement
- 1998 lumina blower direction?
- Now Im confused..97 Lumi 3.1 A/C probs...
- How to replace AC evaporator
- 90 Lumina Warm Rough Idle
- warning lights
- 1990 3.1 randomly runs/doesn't
- 93 Lumina Rear Disk Brakes
- Coolant Leak?
- Engine update
- whine
- 1996 Lumina For Sale
- mirror
- fuel problems?
- 1990 Lumina -Engine NOT turning over
- Transmission wont shift to 3 & 4 gear
- 92 Lumina 3.1L Radiator Leak / Replacement
- Bucking\Hesitation
- help me!
- Looking for some help...
- Lumina paint issue
- 96 Radio question
- fuse for cig lighter
- For Sale: 92 Lumina Z34 5-Speed
- yet another strange problem
- another strange occurance
- weatherstrip
- Help me fix up a good car.
- 98 Lumina LTZ?
- 92 Lumina power steering problem
- '98 Lumina LS power door lock problem
- brake light
- 92 3.1L problems
- Confused
- Phantom Horn Honker
- Idling Problems
- 90 Lumina 3.1 has no power starting off.
- what was I thinking?
- 95 lumina 3.1 electrical problems
- help, smoke!
- Wiper delay mod?
- 2001 Lumina Body Creak
- Lumina A/C Problems
- Stumped on something!!!
- 3.1 :Fix or Replace?
- New A/C PAG
- Acceleration problem -97 Lumina - Please Help
- Threads
- 93 lumina 3.1
- lumina troubles with acceleration
- 98 Lumina Recharging Aircondition with freon
- faulty throttle position sensor?
- Do front calipers on 93' Euro have 2 copper compression washers on brake line?
- Correct idling speed?
- 98 Lumina EGR
- ANYBODY PLEASE!?!? 1995-2001 Ashtray
- coolant flush?!
- lumina euro key dinger
- interchangeable years
- 91 Lumina engine swap?
- #1 Cooling Fans Not Working!!
- CD Player
- Rocker arms
- Hanging on for Z-34
- 93 Lumina Voltage Light?
- 97 3.1 Crankcase breather tube part#
- Testing the cooling fans
- When I start up it does no stay on
- Transmission problems-96 Lumina
- No Spark 3800 apv helpppppppppppp!
- Junkyard Parts
- 91 Chevy Lumina, a couple of problems!!
- 95 lumina duel exhaust
- Cannot start 1999 Lumina
- 92 3.1 cooling problems
- 1990 lumina idle to low
- Factory Fog/Driving Lights 1999 LTZ
- New Thermostat in 97...
- A Body Kit for Lumina what hink you about this...
- 1997 Lumi Fuel Pump.... Figures
- Is it my head gasket?
- Looking to buy 1997 3.1 Motor Mount & Throttle Body Cable
- 97 Lumina......New Color....wat color should i paint it
- 2000 Lunima - need to change battery
- Replacing Spark Plugs 92 Lumina Z34
- how to back probe cam sensor to ensure it is working?
- Lumina 3.1 l camshaft sensor test
- 1995 Black Limina FOR SALE **PICS**
- Vent turning on after car shut off
- 97 Lumina ABS light
- Lumina cooling and air conditioning
- 1995 lumina bucks
- 1995 lumina car 3.1 bucks in overdrive
- Sell for parts
- HVAC - Vaccuum Leak
- Compression
- 95 Lumina Sedan - 3.1 - Power door lock
- 95 Lumina sedan - 3.1 - Power window problems
- my 95 apv lumina 3.1l misfired around 40mph and shut off around 50mph
- Changing Thermostat in 1997 Lumina 3.1?
- 1998 Lumina LTZ Again
- z34 wiring
- Towing question
- just when you think it couldn't have any more problems..
- 93 Lumina Needs New Engine
- 1997 Lumi 3.1 A/C probs....
- 97 Lumina oil leak
- Please help me out! No bleed screws
- Air conditioner problem
- It's hard to push!
- O2 code
- '95 Lumina A/C Compressor problems
- 1991 lumina trouble starting / makes horrible noise!need help!
- APV 3.1 Bleed cooling system
- 94 APV 3.1l No hazard or brake lights
- JeffCoSlacker...
- 1997 Lumina Overheating Problem?
- 91 Lumina !KEY PROBLEM!
- 90 Lumina Gas Pedal Sticks
- Error Codes who can help...
- 98 Lumina LTZ 3.8 water in oil
- Does $3500.00 Sound Good?
- '92 Euro ignition problem?
- Electrical or computer problem?
- 99 lumina p0440 code .Help please
- Question about monte rims on 1996 Lumina.
- 96 Lumina with 20k miles
- Rack and pinion is clonking. Help!
- speed reading innacurate
- Where is my anti-freeze going?
- Thought I broke it...
- 96 lumina stumbles on acceleration
- Turn signals
- 94 Lumina APV Window Problems
Automotive Network, Inc., Copyright ©2013
