View Full Version : Lumina
Pages :
1 2 3 4 5 6 7 8 9 10 11 [ 12]
13 14 15 16 17 18 19 20 21 22
- Weird thing happened
- Heating problem
- Electric Locks
- how hot is too hot?
- IAC Motor?
- Tranny fluid smells burnt, but still red/clear
- Has anyone heard from Jeffcoslacker?
- Gasoline smell inside car - except when cold
- Wet black liquid behind the butterfly valve
- Fuel Pressure reads 40 Psi
- '90 Lumina Issues
- 1996 lumina starting
- '90 lumina eurosport speedometer/rpm gage
- Transmission and Idle woes
- My Lumina doesnt suck
- Simple question,... 97 Lumina 3.1
- If you know anything about luminas, please help me
- looking for Keyless Remote Entry
- replace head gasket then bottom end goes???
- cooling fans
- belt issues help please
- Error Code 32
- *$#@&# 91 z34 code 12
- 91 lumina euro 3.1
- 1993 lumina z34
- wtb: kickdown cable lumina 90-93
- 95 Lumina LS 3.1 won't start after ign. switch replacement
- Barely any fuel pressure 92 lumina
- Timing Chain conversion???
- My lumnia sucks
- alternator
- Error code 43
- Replacing O2 sensor and spark plugs
- 3100 engine swap
- brake lights, plugs
- just a little bit of a FYI
- cs130 alternator
- fuel injectors
- timing belt
- Switch out drivers seat
- 96 lumina radiator problem
- 1997 Chevy Lumina Service Engine Soon light
- Any good Lumina repair manuals on video or paper?
- Fuel Pump
- 1995 Lumina Overheating
- Alternator....?
- Power windows
- Driivers Side mirror replacement
- 98 lumina wiper turn signal pod
- egr valve on 93 euro 3.1
- 95 Lumina bucking at downshift point
- 92 z34 starting issues
- Left front noise, any ideas?
- Brake Pads
- 1990 lumina igintion???
- how to tighten drive belt on 98 Lumina
- 92 Lumina Sedan- drivers door won't open from outside
- help with timing issue
- 92Lumina PROBLEMS!!
- 1999 Lumina LTZ Guage package
- 95 Lumina still overheating????
- Changing my oil
- 95 Lumina suspension question
- CV joint
- lumina euro 3.4/1993 - antifreeze leak
- 91 lumina rear brake calipers problem
- 1994 Door Lock
- horn electrical short
- Need new struts, and some answers!
- flasher relay
- Fan temp?
- No power from ignition switch to starter
- Noisy Engine 3.1 Litre
- 99 LTZ brake light short?
- 1996 Lumina APV p0341 engine code
- 95 lumina - Replacing 3.1 engine
- Van won't start Please Help
- '98 lumina NewMember
- My van was not used for 3 days and now won't Start
- z34 1994 rear window
- 93 Lumina left turning noise
- 1991 Lumina 3.1 - Starting Problems
- How to remove the dashboard from a 96 Lumina
- 96 Lumina Gas Smell/Brake Lights
- 1994 APV charging system
- 97 problems
- back fires out of throttle body
- 1995 lumina trans
- 95 Lumina 3.1l heating problems (long)
- Lumina running rough at times
- 95 lumina 3.4 surges when cold
- Starter Failure?
- is this turbo too big?
- '95 APV plugs
- 92 Lumina auto transmission
- 90 lumina van won't start
- 93 lumina 3.1 liter problems
- 92 Lumina APV
- '92 Lumina Z34 5 Speed
- how to change 91 lumina 3.4 spark plugs
- 93 Lumina Brake question
- finally fixed 95 lum van
- turn signal drl and brake light trouble
- '90 2.5 litre, died and has no spark
- 1990 Lumina Won't Start
- 97 Lumina 3.1 thermostat repair
- 93 lumina 3.1 with 184,334
- 95 lumina stalls out.... alot
- help! heater cold when idleing, hot when driving
- 95 3.1 Lumina Won't Start Need help pulling code
- 95' Lumina
- My 94 z34 will start for only 3 seconds
- 90 Lumina Light Problem
- Owners manual
- rotten egg smell in 91 lumina
- 1997 Lumina Fuel Pump
- 1990 Lumin TCC solenoid replacement
- no heat.
- No Power with new battery
- Exhaust problem?
- 91 Lumina Van wont start
- pipe between water pump and stat housing .......
- How Do You Change The Back Plugwires LUMINA 1999
- Brake lights on all the time
- 93 chevy lumina
- Lumina (drum) brakes
- Monroe Sensa-Trac / KYB GR-2 / ACDELCO / ??? - Any opinions?
- 93 Chevy Lumina With Problems
- Fuel Pump Relay
- Monte Carlo Dash to Lumina
- Where to find parts?
- Won't Start
- 96 Lumina APV - no brake lights - turn signal switch?
- No Spark from new coil
- 93 Lumina APV- Various issues, please help!!
- Car Door will not shut!!!!
- Coolant Leak
- Trans shot? How hard to change?
- 91 lumina euro 3.1 dies making right turn?
- stalls lunges dies
- 1993 Lumina Z34 Crank Sensor
- coolant leak
- Vents Barely blow air even on High
- Rear Disc Brakes
- help 4 starting problems
- engine will not turn over
- 96 Lumina over heating not sure y!!!!
- Is my car insecure?
- Lumina 1993 has no "choke"
- timing chain marks
- Lumina z-34 lean fuel/egr code 44 and 32
- Lumin apv wire harness
- OBD Issues on a 97 Lumina
- Electrical Insanity...Heat related???
- 92 Lumina Euro Driver Door Panel Removal
- 97 Lumina Delayed Trans Engagment When Cold
- 94 Lumina backfires through throttle body
- Coolant leak
- Fuel Filter
- removing Quarter window
- Jump start from 1996 Chevy Lumina
- 94 Chevy Lumina APV keyless entry
- 3.1L V6 Coolant Capacity
- 94 Z34 engine swap
- 1995 Chevy Lumina Newly Rebuilt and won't stay running, THEFTLOCK problem?
- turn signal flasher 97 lumina
- 93 lumina 3.1-fuel filter location
- 93 Lunina Won't Start
- 91 lumina euro 3.1L Oil leak or Transmission?
- 5 speed for a 3.4 DOHC
- anyone have a police package lumina?
- 97 Lumina 3.1 (which engine heater to use?)
- No Start-total Mystery!!! Help!
- remote starter Brands
- Seat belt problem
- Replacing fuel filter???
- 94 Z34 Hesitation at High speeds
- 91 Lumina HELP
- Remote start+Door locks
- Engine missfire after changing plugs/wires
- Low Coolant Light Keeps Going On and Off
- Just died
- 97 lumina-no taillights and no dash lights
- rear brakes
- Heat/Cold selector
- Groan on accel
- do u use (d) or d? differences?
- Still will not start.
- Cold engine?
- 1997 Lumina dies while driving
- Door handles--90-94 Sedan FYI
- broken window
- 1997 Lumina LS Taillight on the trunk
- 91 Lumina - Tie Rod Bellows and Motor Mounts
- Average Life Expectancy
- Lumina Rim offset
- I need a transmission for my lumina 1995/what transmissions will fit?
- Intermittent buck and jerk
- Advice on high mileage maintenance
- 93 lumina euro problems stalling/poor acceleration
- 93 3.1 lumina bad knock!
- just purchased a 2004 suburban
- Power window problems--put up manually?
- coolant leak below the oil (filter) cooler
- 92 Lumina downshift problem THM440-T4
- Sludge on my radiator cap!
- P1381C code - Please help!!
- 99 Chevrolet Lumina multiple problems
- Fuel Sending Unit
- fuel consumption too high
- Oil Pan Gaskets
- bucking/surging
- 93 Lumina - Rear brakes not working
- Bad idol, when in gear 70 mph
- Head Gaskets
- 95 lumina
- HELP! Van won't start
- electical problem w/ fuse
- 2002 trialblazer, Better mpg?
- 93 chevy lumina fuel pump?
- 91 factory service manual
- transmission...shifting delay in higher speeds
- 95 3.1 hard starting finally died
- flooding ?
- Lumina full throttle problem
- how tough: engine swap - 91 3800 into a 92 Lumina
- Fan does not come on
- Security & Change Oil Soon
- dash lights
- 1998 Lumina code
- Won't start when cold
- coolant light
- Seatbelt Light while driving
- coolant sensor staying on
- many problems....
- 92 Lumina APV 3.1 TBI dead spot
- 95 Lumina APV 3.1 problems starting < 30°
- Couple of repair questions -advice needed
- Cheap performance mods?
- Um, something is hanging from the bottom of my car...eerrrrrr
- 95 lumina rear lights and signals
- '91 Lumina APV 3.1 Tourqe Converter lock
- High and Low RPM at idle
- Power steering fluid leaking
- dead, only sometimes
- Replacing the "big 3" wires on 97 lumina (3.1)
- `97 Lumina have heating issues...please help if you can!
- 96 Lumina 3.4L engine
- 2000 Lumina rotor removal..how to?
