View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22
  1. Anybody found the trunk leak fix yet ?
  2. SES on, runs BETTER?
  3. Thanx ALL...wow what a P.I.T.A 97 lumi.. ball joint
  4. Brown chunky coolant !?!
  5. 91 Lumina wont' give accurate speed reading
  6. A new stall to my "92 lumina
  7. 93 trans and motor switch?
  8. trunk....
  9. APV needs reset to start...
  10. Replacing the A/C Compressor in 97 Lumina
  11. '94 AM/FM Cass issue
  12. 97 Lumina Water Pump Replacement
  13. z34 tranny issues
  14. no pressure in radiator hose
  15. 95 lumina ls van window
  16. 1998 Lumina LTZ
  17. 1998 Lumina LTZ
  18. Cigarette lighter not working-92 Lumina
  19. 93 euro stalling
  20. 97 lumi 3.1 DUMB QUESTION....Real Dumb...
  21. Can't find the bloody battery
  22. question about a 91 2.5
  23. Charging problems w/ 91 Lumina 3.1L...long
  24. 91 Lumina engine and trans swap?
  25. overheating? wont start
  26. 96 lumina transmisssion / engine light on
  27. 92 lumina euro smoking
  28. 92 lumina 3.1 problems
  29. My Latest problem on the wifes 95 Lumina
  30. steering problems
  31. Ok Here Goes...97 Lumi...3.1...For cryin out loud!!!
  32. lumina not firing
  33. Leaking under 92 Lumina
  34. Oil pan/transmission pan gasket leaks-92 Lumina
  35. Where is the pcv valve on 3.1 Lumina?
  36. Window Crank / how to remove?
  37. Where is the ECM? 93' Lumina Sedan
  38. types of engine
  39. timing problems lumina z34
  40. looking for chepest way to get more hourse and torque for my 92 z34 5-speed
  41. 92 z34 3.4
  42. 90 Lumina 3.1 no spark...
  43. z34 5 speed
  44. 93 3.8 lumina apv no spark,cranks ok
  45. 93 lumina stering?
  46. How do you replace the climate control bulbs?
  47. 1990 3.1 euro lumina oil pan help
  48. 1990 stalled got fuel pressure up to the rail
  49. 93 lumina does not start?
  50. Anyone know if a 2001 lumina and 99 can interchange parts?
  51. Where in the suspension is the front strut bearing 1993 lumina Euro?
  52. 93 lumina ignition module???
  53. Another 91 Lumina that wont start warm
  54. 99 LTZ 3.8 tranny question...
  55. New engine rebuild 3.1 '97 car install Runs Rich /Rough
  56. 96 lumina 3.1 help
  57. 93 Lumina please help
  58. 93' Door Handle/Latches broken ??
  59. pulling the ignition heeeeelllllpppppp!
  60. '98 LTZ Showing Code P0336, What Does This Involve?
  61. lumina 99 warm start problem
  62. Sun Visor retainer clips
  63. I cant lock the doors, from inside...
  64. Help w/'94 Lumina Euro Sport Blower Motor
  65. Need Help Badd Can"t Get Out
  66. How do I bleed the coolant system???
  67. Trade it or no?
  68. ECM 1991 Lumina wheres it at!
  69. Rear valve cover gasket 91 3.1
  70. 95 ls exausting from the radiator!
  71. 93 apv 3.1 TBI no gas coming out of injector
  72. hard start 01 lumina
  73. 92 chevy lumina trouble
  74. 97 Lumina Air Distribution box problems
  75. Fuel Display
  76. Anyone answer one of these questions?
  77. door won't open
  78. 90 lumina 3.1 Euro. Guages misbehaving.
  79. Bleeding Brakes - 93 Lumina
  80. 97 engin swap
  81. Engine swap 96 Lumina now has Bucking?
  82. 1990 Lumina 3.1L , Tried this now what?
  83. i need fuel pump help!
  84. 1993 lumina apv cranks,no start wiring problem?
  85. 91 Lumina Turn Signal problem
  86. Heating Control System
  87. Heating Control System
  88. 97 Chevy Lumina Oil Change Light
  89. 97 Lumina starts but won't shift from park
  90. 92 Lumina
  91. 98 Lumina Stalling
  92. WTF is my car stalling????
  93. clicking noises
  94. Future mod, Maybe
  95. Another easy 1.. 1997 lumina 3.1 A/C compressor
  96. Proof I'm not crazy
  97. 92 Chevy Lumina Stalling
  98. Is a Used Lumina a good buy?
  99. 95 Lumina engine swap
  100. How 'bout one of these in your Lumina?
  101. 93 Lumina Rear Disc Brakes
  102. keyless entry problem.....
  103. 91 chevrolet lumina
  104. This is strange,95 temp guage HELP!!!!
  105. 1995 Lumina APV idel speed motor
  106. trouble code 53 & 23
  107. 91 3.1 Engine Help Plz!
  108. Kickdown cable replacement
  109. Air Bags? Would it be the Best way to go on 98Lumina
  110. Leaking head gasket
  111. 93 lumina driver door
  112. Fuel Injector or Transmission Problems?
  113. 96 Lumina APV Tailgate lock
  114. 97 lumina help
  115. 1992 Chevy Lumina APV -No ignition switch or guts
  116. oil leak
  117. stuck in park --- parking pawl?
  118. 1998 3.1 with internal coolant leak
  119. LTZ Starting and Steering prob??????
  120. 90 Lumina APV 3.1 won't get fuel through injectors! HELP!!
  121. How to replace passenger side view mirror in 98 Lumina
  122. Fuel Problems
  123. 93 Cherolet Lumina backfireing help
  124. 90 Lumina Fuel Filter Trouble...
  125. Coolant
  126. Brakes
  127. '97 runaway idle, erratic upshift
  128. Drivers Window Help
  129. power steering
  130. tranny filter busted!
  131. replacing gauge face on 1998 lumina
  132. Radio removal on 98
  133. Easy Question for 97 chevy lumina 3.1
  134. Can I test a starter with a battery?
  135. Freezing and Overheating... fun!
  136. Post Your Lumina
  137. Cannot Get into my Lumina Doors won't open
  138. Power Steering & Noise
  139. 97 Lumina won't go into Gear or out of Gear
  140. Replacing Outer Door Handles-92 Euro
  141. Automatic lights have a problem
  142. MAF Sensor?
  143. Intermittent Heater
  144. EST Mystery
  145. Tailligths, dashboard lights off all the time
  146. '97 Lumina 3.1 sometimes won't stay running
  147. '93 Lumina intermitt. high revs. above 2mph
  148. 98 Lumina Over Heating
  149. Overheated"HOT",Waterpump wont spin, White cream on the oil cap, WHAT HAPPENED?
  150. OEM part numbers!!!!! AAGGHHH!
  151. Ash Tray removal on 98 lumina
  152. As If Anyone Is Interested???
  153. new lights
  154. Trans cooler lines
  155. 98 Lost low beam and driving lights
  156. Lots Of Problems With 1995 Lumina 3.1
  157. Lumina idles too low and misses.
  158. 97 Lumina Problems
  159. 91 Lumina 3.1 Euro Panel Light Issues...
  160. 96 #5 Cyl Misfire problems
  161. 93 Lumina 3.1 with ABS. Brake problem
  162. Flasher Unit for '91 Lumina APV?
  163. need help - 95 Lumina no dash light or
  164. 93 euro, odd problems
  165. 1995 lumina sedan - rack and pinion remove
  166. Need new seat
  167. Need help, mechanics and dealership dont know what it is!
  168. Lumina (sedan) wing mirrors
  169. 1990 Lumina APV --- Breaking (UK)
  170. Chevy Lumina 3.1L v6 Euro Inheritance
  171. remove caliper bracket from caliper!!
  172. Stereo Questions! PLease
  173. supsension problems
  174. Fuel Rail Assembly
  175. 96 Lumina INPUT NEEDED!!!
  176. Looking for performance mods
  177. Fuel pump relay chattering
  178. Good source for replacement parts?
  179. EST Wire
  180. tranny problems with acceleration
  181. Need Some Parts!!!
  182. Hey everyone,
  183. 96 lumina: should I?
  184. tranny leak question
  185. idle re-learn question not covered by the sticky
  186. 93 Euro problems (electric/battery)
  187. 93 lumina euro tranny
  188. 93 Lumina Euro-no Spark Or Injector Pulse-puzzled
  189. crazy stereo
  190. popcorn noise
  191. Help Locating/Removing Starter From 3.8L
  192. Coolant Issue
  193. Power Steering Whine
  194. 95 Lumina APV 3.1L - not starting - diagnosed my butt off
  195. Should I replace my timing chain?
  196. 3.8?
  197. 98 Lumina knocking and slow accel.
  198. Which plugs?
  199. 99 Lumina 3.1 Spark Plugs
  200. Windshield replacement
  201. oil leak
  202. Alternator Upgrade
  203. '95 APV tailgate lock
  204. 1992 Chevy Lumina rear spark plugs/PCV valve
  205. 1992 Chevy Lumina soft brake pedal
  206. 1992 Chevy Lumina wheel bearings
  207. 91 chevy lumina stall issue
  208. gas gauge ??
  209. battery going dead
  210. 93 Lumina Door Lock
  211. Fuel pump relay chattering
  212. speedometer to fast
  213. Anyone ever had a bad trans mount on a 3.1L Lumina?
  214. help!!! wont start
  215. My '92 Eurosport died, what to do?
  216. Replace Air Box
  217. Replacing coil packs/ICM .. Any tips or tricks?
  218. Newb Lumina guy
  219. Problem with 92 lumina 3.1 v6
  220. Parking brake light won't go out
  221. 94 Lumina APV rough start...int. hiccups...
  222. 98 Lumina Automatic Door Locks?
  223. Trans Shift Problem
  224. hating my 1995 chevy lumina
  225. Driver Side Master Window Switch?
  226. 98 Lumina Funky Fan Problem
  227. 95 Lumina 3.1 Litre Starter
  228. 1998 Chevy Lumina Engine Problems? Engine Swap to 3.8
  229. 93 Lumina
  230. 1992 z34(alternater amperage?)
  231. Oil filter leak
  232. over heats
  233. 1992 Lumina Problem(s)
  234. Lumina won't stay running
  235. Adding New Key to car?
  236. Tune-up tips
  237. Miss at heavy to Full Throttle
  238. Single Mom needs good advice
  239. 92 lumina 3.1 fuel tank problems
  240. 93 Lumina Warm Starting Issues
  241. Intake or Head Gasket
  242. Removing center console to replace carpet
  243. Change Altenator 94 Lunina
  244. z34 stalls
  245. Plug Wrenches
  246. Blinker light problem
  247. '95 Lumina, Dashboard lights out.
  248. transmission fluid#@^&#^#
  249. Clearing codes without disconnecting battery? (92 3.1L)
  250. exhaust though the engine.... hmmmmm!
