View Full Version : Cavalier
- swap
- Coolant loss mystery
- Looking to buy a 5" tach, in ANY condition
- Removing and installing a door, 96 cav
- vss sensor
- I Need A New Engine
- Grocery list for a/c please
- difference
- need answers on on rebuilding 93 cav wheather to get a 3.1 or can i put a ecotec in
- Pics! Cavy made a friend, plus some updates
- Its finally running right after.......
- Hardtop convertible conversion?
- Pick n Pull in Central NY
- Cheapest yet good quality bodykit/fenders?
- Tune Up ? after winter
- 96 Cavalier DRL relay location. . . . .
- 94 fuel problem
- Need tcc-Torque Converter Lockup Silinoid Location-95 z24 3sp.
- Wanted to buy 98 cavy 2.4L motor
- 1989 z24 Cavalier--Son want's as Drive Car
- mobil 1 oil filter
- when should I change oil
- Getting new engine and turbo. 2.2 or 2.4?
- Doors, 2 Door Cav
- Cavalier Iceman Intake for sale ( NEW )
- Code P1137
- rad fan dosen't work
- problems with starting car 95 z24
- Is it so Expensive to install Fuel pump anf fuel filter to caavalier 2003
- rad fan
- Coolant Light On
- Vibration while driving, except when turning right.
- NEED T25 Turbo
- 1995 cavalier fuel filter
- How do you replace stud for lug nut on 2003 cavalier?
- Cavalier Z24's invited to New Hampshire Car Meet
- Miles
- Turbo On the Cav
- Wiring up 2 1 ohm subs in series or parallel
- 03 cav died, needs fuel pump. couple ?'s
- For Sale:2001 Chevy Cavalier 5-speed
- 94 Cav 2.2L problems
- Bang.. Wheel Allignment?
- 94RS instrument cluster?
- 2000 Calvalier Fusable Link To Cooling Fan
- Throttle Position Sensor TPS location???
- Pretty stupid question
- engine temp problem?
- 99 cavalier engine swap from a 2.2 to a 2.4
- 1994 Cavalier z24 Problems
- What do those indicator lights tell
- Sloooow Blinkers
- Easiest way to remove oil pump?
- I'm about to buy a '96 Cavalier, have any advice for me?
- For Sale
- Airbag Warning Light
- Misfire resolution if it just doesnt make sense for all dohc
- Vacuum Lines
- Replacing front struts on 01 sunfire
- '94 trouble, need suggestions
- Gapped plugs/Torque?
- 95 cav backfire 2.2L
- Front Strut Mount
- Flashing check engine light
- Do-It-Yourself
- Banging noise
- Dangers/precautions for supercharging 02 z24
- Cavalier For Sale (so i can buy another one lol)
- 93 gauge cluster
- 95 Cavalier spark plug wires
- engine swap 1995 Z24 cavalier
- Trouble filling up with gas
- ExtremeDimensions/CarbonCreations Shock wing
- idle speed is 600rpm...is this normal for automatic?
- Longer oil filter?
- 94 RS 2.2 floor board rust.
- motor mounts and brackets
- ? on replacing o ring
- Thermostat location on 1996 z24 cav
- Blower only works in 3rd and 4th positions
- FS: 2.2 Valve Cover
- FS: 1996-99 Cavalier Tail Lights!
- FS: 96-99 Cavalier Bomex Drift Body Kit
- Some Matrix projection headlights up for grabs, dirt cheap!
- steering wheel isnt straight after accident
- Think i should buy?
- windshield wiper fluid leak
- tire rubbing against front fender
- bent wheels
- cavayy club
- Regarding Radio On 97 Cavalier
- helpful stuff
- door is messed
- cavay fuel leak
- Turbo Write-up
- SELLING 92 Cavalier Parts!!!
- Toyota cavalier???? WTF
- electric turbo any good?
- ODB-ll not working????HELP PLEASE
- One more new toy from Eibach
- looking for a spoiler/rims
- 00 Cavalier Acceleration issue HELP!
- where is it ?
- Just installed my Mark Pain lower engine mount
- help
- traction control? Can you turn it OFF?
- Bushings and tranny question
- Is a used Cavalier a good buy?
- oil light and hard to turn
- aftermarket O2 sensor or simulator for the ecotec??????
- 97 2.4 dying on me...please help!!!
- `92-94 4-door cavvy for cheap, should i ?
- DRL-Day Time running Light lights keeps flashing..
- Oxygen sensor replacement-question please...
- Cavalier Reliability
- shop manual for 03??
- Changing Spark Plug Wires Need some help.
- hooking up my tach
- Blow off valve???
- smokes like hell
- 2000 Z-24 Battery Leak
- Thermostat?
- Head Light Switch Lever?
- Ractive air filter?
- Instrument cluster bulb?
- EGay to good to be true bodykit?
- How many weep holes on a '96 2.2L Water pump
- Short Shift BOOT
- Best spark plugs? Ngk, Greddy, Hks, Denso?
- how long?
- turbo a z24
- Headlights, Parking, Lights, Signal Lights???
- 97 cav hesitates when starting off
- ice cold radiator 96 2.2 cavalier
- Early 90s thermostat
- New here... but not a new problem...
- Car is squeaking...
- front speaker suggestions...
- Radio won't shut off when doors open.
- B&M install pics
- Projector/halo/any cool headlights for 00-02?
- door trim panel removal
- Thinking about sunroof what you all think?
- Engine Questions.
- Sunroof Issue
- defective guage cluster??? again HELP PLEASE
- clicking with air on???? HELP
- How to test fuel pump...
- Being the pic whore that I am.... here ya go!
- Shrieking A/C in 90'
- noise in front end of 97 cavalier
- 94 Remote Door Locks
- Where did you install aftermarket fog light switch?!?!?
- Hi Im new! 2003 cavy owners?
- 94 RS Roller Valves.
- cd player install?????
- newbie needs help
- 03-05 3 piece euro style tail light set...
- Pic Help Please
- Shifter...
- Resonator
- Anyway to improve acceleration for 96 automatic?
- Any updates/reviews for the Venom 400?
- little power??
- Timing belt or chain?
- Replaced Starter now the care dont Start
- 1997 Sunfire Non-Shifting Transmission
- 1999 key less remote
- Black tube
- Anyone with Carbon Fiber... Check this post... and some new CRJ updates!
- Shakes after 90?
- 93 Cavalier Bad Vibration -- Motor Mounts?
- 94 Cavalier - Replaced Head Gasket - Need Advice
- RkSport Type-J bodykit & 00 headlight conversion?
- Spit and Spudder
- Shifter Bushing Kit
- 4:2:1 OR 4:1 header ???
- Gauge Lights
- dual exhaust
- 94,95 cavalier 2.2
- timing belt replacement
- Tranny Fluid
- 97 Cavalier running hot??
- 2001 anti-theft light on hard to start
- 99 dim odometer
- 96 Cav, Ignition & Door locks
- Short Shifter question
- PRoblem with tranny?
- Spark Plugs
- idle surge
- Post pics of your Cavaliers
- temperature gauge goes up & down
- Clueless about cars, I'm sorry.
- Coolant Temp Sensor Location
- Component help
- change serpentine belt 2202 Cav Eco
- Chassis Number- Where to find it
- Lightweight Pulley
- Fuel Gauge Problem
- CarDomain.com
- 96 to 97 cavalier engine swap
- Rack & Pinion install/removal HELP please....
- Interior light on except when moving!
- 93 3.1L Stalls and won't start when warm.
- Coolant problem as always
- cavalier 2002 rpms go up
- Need some answers
- Clunking from rear, exhaust area?
- anyone!!!!!
- Engine Change
- Help! Coolant boiling...overheating
- Battery alternator power problems HELP!!
- Z24 Power Window
- Removing plastic peices in the rear seat area
- HELP!!!! 95 cavalier dies when I brake
- Heater Blower motor quitting...
- windows inside cav icing?
- help!!!!!
- 2003 Cavalier, remove the heat shield
- Intercooler without Turbo?
- engine swap
- Your opinion...?
- EGR Valve--whats make it tick?!!
- Need help with motor mount
- Windshield washer jug leak
- Windshieldwasher jug leak
- 94 cavalier RS trans filter.
- Hooking up a Tach to Measure RPM's
- about to buy a 2000
- Rough Idle When Sitting Still
- help
- For Sale : 2000 Cavalier Z24 BCM (Body Control Module)
- 04 Cavalier,Im changing the oil (not a filter question)
- 2003 Cavalier LS Sport Coupe (Road Noise)
- intermittent overheat
- Seafoam question
- Another pic of my car
- 95 CAVY, 2.2, STILL SKIPPINGl--HELP!!!!!!
- is there interest in custom angel eyes?
- Remote Start Help?
- 2001 Shortshifter?
- Trans problem
- Racing
- Replacing airbags 2000 Cavalier
- anyone mechanically inclined, PLEASE HELP!
- 1994 Cablier Wagon
- head gasket blown
- picture of starter conections
- 99 Cavalier - No Brake lights or cruise
- 04 Cav Tail Lights
