View Full Version : Cavalier
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. dashboard
  2. Battery or alternator
  3. God damn it...
  4. my dreaded interior :(
  5. 97 Cavalier Cooling Fan
  6. Doors
  7. Question?
  8. Why Import Cars?
  9. proceedur for replacing head gasket???
  10. saftey feature for reverse
  11. Question for you 2200 Owners
  12. A day at the junkyard..
  13. Joining up
  14. 97 cavalier fuel problems
  15. Cluster ****
  16. Some pics from the car show
  17. ported vs sealed box difference
  18. 96 Chevy Cavalier
  19. annoying problem with brakes, suggestions??
  20. Chrome wheels Powdercoated??
  21. yellow headlights???
  22. Will these speakers wire up to my doors?
  23. how many qts of trans on a filter change?
  24. Cavalier with a 350
  25. Shift kit for an automatic
  26. Nitrous + Supercharger...safe?
  27. 97 2.2 gasoline running out of exhaust?
  28. engine upgrade to a 3.8L from a 2.8L
  29. Z24 running rough!!
  30. check out this cavy!!!
  31. 2.2 to 2200 swap help
  32. Need Cavalier Info picking up my first one tomorrow. Please help.
  33. New clutch now we cant get it in gear! HELP!!
  34. Trunk Release...err not
  35. changed starter now car won't start??
  36. Plug gap 01 Cav
  37. As promised... RDFABS exhaust install.. Truly one off..( 56K will die)
  38. 98 cavalier abs light on
  39. 2001 torque converter switch
  40. 97 Cavalier 14,700 miles- Suggested Maintenance?
  41. Keyless Entry Problem
  42. Header Gasket
  43. Removing fabric on door panel? Also, the bezel around the handle?
  44. I Am SOOOOO going to this...
  45. Banter Thread
  46. double clutching...?
  47. Sunfire eyelids/hood?
  48. Problem With Radio
  49. AC Stopped Without Any Warning
  50. 2.2 timing issues
  51. 1998 Random missfire 2.4L engine
  52. 95 engine conversion
  53. Are these stock speakers?
  54. Cavalier '93 z24 coolerfan Max and Min temp
  55. This past weekends car show...56k. NO WAY!
  56. High pitch whining sound when in 1st, 2nd, 3rd gears??
  57. Speaker Sizes
  58. performance upgrade help
  59. should there be a ''off-topic'' subforum for cavalier
  60. Where's the A/C Low pressure switch located on 99' Cavalier?
  61. Possible way to wire?
  62. NOS question
  63. 91 cavalier heat up problem
  64. no transmission?!
  65. No Oil Is Responible For My cavy
  66. Can a 2.2 liter go into a 95 cavalier
  67. Just Checking
  68. wiring harness and antenna adapter ..Work?
  69. how to agust the hand brake on a 98 cavalier
  70. rear bumper reinforcement
  71. What car should I get a 96 civic or a 02 cavalier?
  72. cold air intake design
  73. cold air intake design
  74. front bumper
  75. changing fuel filter
  76. T3 turbo manifold
  77. check this out
  78. Inspired by Cody...
  79. MY ac problem
  80. Soo... I was Looking at some old pictures..
  81. paint code
  82. For a highly tuned performance motor - 2.4 or eco?
  83. crankshaft hub on cavalier
  84. Shocks and Struts
  85. cosmo racing website???
  86. Rims
  87. Problem starting
  88. 2.4l
  89. newb question from....... well... a newb.
  90. Interior Panels
  91. Rear Allignment
  92. anyone????
  93. The Official Rice Cop Tread.
  94. My Speedometer is not working !!
  95. Horn relay on '03 cavalier
  96. back Left turn signal
  97. Question?
  98. what state does everyone live in??
  99. airbag help please !!
  100. can't find any pics of my ride....HELP!
  101. 90 Cav 3.1 electrical problem
  102. ok antenna wire ripped *Pics* and progress
  103. need help high beams
  104. I need a explanation of head unit wiring
  105. Rear Brakes
  106. The check engine code
  107. Apology
  108. fuel fittings
  109. Coil Pack
  110. 2004 Cavalier AC Question
  111. 1997 Cavalier making strange groaning noise
  112. what happens when you run out of oil
  113. Question about larger motors and swapping
  114. need help fast before we go any further please!!!!
  115. Timing chain replacement cost for '97 Cavalier
  116. measurements of exhaust
  117. 96 Sunfire temp gauge moving up and down when driving?
  118. Transmission adapter plate for a 98 Z24?
  119. somebody help please and dont just respond with dumb messages
  120. 97 Cav Axel Change
  121. 97 cav stereo
  122. cobalt SS sc or srt-4???
  123. subs
  124. cavalier horsepower.
  125. SlUGGISH!!!!!!!!
  126. Need Advice On 1995 Cav!!!
  127. 1991 cavalier z24
  128. To jetaylorpb re Retro Cavalier
  129. fireing order
  130. significant upgrade from Cavalier?
  131. What is oxygen sensor for?
  132. difference between 2.3l and 2.4l
  133. Water pump replacement
  134. what is my cars problem ugh...
  135. spark plugs
  136. 2001 Chevy Cluster/Gauges Problem and Question
  137. track times
  138. killing the rust with a very good cheap product
  139. Its been fun...
  140. kickers....any good?
  141. what 4 w7's will do to the trunk
  142. Gauge Cluster Swapping?
  143. weak battery?
  144. W00t Finally Came
  145. track lites
  146. i raced a mitsubishi gallant tonite
  147. rota slipstreams
  148. '98 rear speaker removal help
  149. Where is the coolant temperature sensor???
  150. dies when coming to a stop
  151. dies when coming to a stop
  152. dies when coming to a stop
  153. 03 cavalier bogging in 1st and 2nd
  154. why did i win
  155. Your thoughts on this ignition set up?...
  156. Still no turnin over!!
  157. Surging Idle on '96 Z34
  158. 2001 Calvalier Wheel Bearings
  159. Where did the "Z" come from???
  160. temp problem
  161. 94 Cavalier Fuel Pressure?
  162. ¿Can anyone help?
  163. ABS light coming on over bumps...
  164. Track
  165. 99 cav serpentine belt
  166. Where is the DRL relay in a '97 cavalier?
  167. Question about belt
  168. Check out Zee DUUUBS... YO!
  169. 2003 cavalier - horn not working
  170. Body Parts - Does anyone know?
  171. Cavalier Opinions and Ideas
  172. 97 cavalier 2.2 stalling.. need a techs help.
  173. Home-Made Tire Rotation
  174. Perfect Launch
  175. Plugs, coils, plug boot inserts...
  176. Bleeding Cooling System on 97 Cavalier??
  177. where's the crankcase sensor located?
  178. Help: Guage Cluster
  179. spark plug wires
  180. 1997 Cavalier Loosing Coolant? Need Help!
  181. Big Day, Much Help Needed, 1989 Steering Column Job
  182. need help with 94 not starting
  183. Annoying High Speed Dash Noise
  184. Recommendation for Wheel size
  185. Why is my key getting stuck in the ignition??
  186. Lowered + Body kit + Need 4 alignment = PITA!!
  187. Radiator Fan Motor??
  188. Race Prep.
  189. random question bout cams...
  190. friggin finally
  191. Help finding knock sensor on a 98 Z24........
  192. Pictures
  193. posting pictures help?
  194. Help diagnose my problem!
  195. Header install
  196. ECU Replacement
  197. Hot Import Nights anyone?
  198. Funk Master Flex Car Show Pics!
  199. Real Dumb Fun
  200. Molding Inserts for 98 Z24
  201. want to buy Quad4DualCam !!!please help!!!
  202. Someone with a tach?
  203. nicely priced wheels...
  204. 1999 z24 auto tranny needs help
  205. Is the horn wired through the radio???
  206. Help with radio please
  207. Questions about my subwoofer in my cavalier
  208. compatibility
  209. Hands Down 2nd Annual Custom Car Show!
  210. z24 exhaust questions
  211. i need to no what is the name 4 euro lights
  212. Throttle body
  213. Gauge Cluster
  214. Z24 timing chain
  215. Transmission Problems
  216. Finally! Got the trunk and interior finished. Check it out!
  217. Difference between oil filters?
  218. '96 2.2 Engine R&R cost..
  219. Where Do I Find a WAI or CAI for an 89 L4 2.0 coupe?
  220. Bearing hub assy R/R
  221. looking for a video
  222. 1998 2.4 map vacuum line missing
  223. finally finished my interior paint!!!
  224. vinyl
  225. 89 Cavalier on SKINNIES
  226. BIG problem w/ my exhaust
  227. I need a favor... Anyone got like 5-10min to spare?
  228. P0442
  229. best prices on brakes?? (drums)
  230. Help!!
  231. Where to buy Fiberglass Materials???
  232. dash cluster conversion
  233. JUST developed a weird ticking..
  234. is this worth it
  235. Does A+ Performance send their own decals when you order from them?
  236. 87 cavy no injector pulse
  237. sideskirts
  238. Help Me Out...
  239. Help Me Out...
  240. WTF! Stupid Coolant!!!
  241. pleassee helpp
  242. 2000 z24 wont start....
  243. The WORST Feeling In The World
  244. MagnaFlow Sound (my exhaust)
  245. turbo
  246. antifreeze coming out exhaust but compression test was fine.
  247. cooler line doesn't fit.. how would I fabricate new one?
  248. Now these.....are Cavaliers....
  249. fuel injector
  250. Which would win in a drag race? Z24 or Neon
