View Full Version : Cavalier
- Heater problems 2003 Cavy
- Supra Cavalier?!
- Quick Airbox Question.
- Turbo checklist for next month
- 94 Cavalier Stereo Problem
- Passlock theft system
- "Limp mode"
- 94 Cav flashing headlights
- First Post here.. Pic Inside
- cavalier ETS light
- low coolant light comes on..
- Compatability???
- new motor turns over, but won't start!!
- Cavalier Z24 '96 Tunned..
- 96 Cavalier 2.2 thermostat question
- Mmmm...Turbo!
- Transmission Overhaul
- 98 z24 struts
- Need Info ...pleaseeeee
- Will These Fit?
- quick dumb question
- Super newb here.
- at the Track this summer...
- Air condition question
- 2003 cavalier stalls ???
- Car Show in Baltimore, MD
- Wet Carpet HELp
- Hard to start when cold.
- 01 cavalier radio LOC
- 1990 throttle body no fuel at start up
- Headlight switch problem.
- hanging plug??
- 1997 Cavalier 2.4 stalls when warm
- you think you got problems? look why i haven't been on here much:
- 2000 z24 trouble starting
- 2000 Caviler For your info only
- 2 coldest days = 2 rough starts - time for new battery?
- Interesting gas tank problem.
- 04 alteza tails
- 92 cavy, ABS light on, no heater/ac fan, no wiper motor
- engine swap
- Stabaliser bar bushings..
- Turn signal and rear defrost
- What Car are you?
- 1999 Cavalier, Removing rear seat
- Stock Cd Player Locked
- 2001 Cavalier oil
- Hard time starting... Going crazy
- rear defog not working
- changing the front discs..
- squealing noise
- Brakes
- no spark
- Car dead not starting
- Towing 2001 cavalier
- 99 cavy ignition
- Are 2.2 Cavaliers Fast?????
- 95 cavalier problem when cold....
- I'm Baaack!
- Z24 Question
- Z24 Question
- New pics
- could it be the shocks ??
- Guess whats in the box game!!
- Nitrous on my 2000 Z24
- my cavalier wont start..
- lifting my cavilier
- Time to Play whats in the box game!?
- 92 Cavalier 4cyl clutch question
- 99 Cavalier overheating
- Car not starting after sitting awhile, what should I check?
- ETS Light OFF Check Engine Light On
- Speaker Question
- Easiest way to change door hinges
- 1990 2.2 Cavalier
- Upgrading...2.2 to 2.4
- what caused this??
- `94 Chev Cavalier Electrical problem
- Gauge cluster stopped working after battery install on 01 sunfire?
- Help anyone
- abs. air bag
- Intercooler "style" air filter?
- Gas milage low
- that shifter nob....
- 03 Cavalier Audio System Help!!!
- 94, idle engine shudder
- HELP PLEASE- Front Defrost
- 2003 brake drums
- Cavy Mid engine... Possibly..
- 99 Cav. eng light on O2 sen.
- car not starting, frozen gas?
- 1998 Cavalier 2.2 mid throttle hesitation
- Hello
- ABS light is on while driving
- top plates and bushings
- Shocking car!
- new to cav's...need some info
- Headlight Problem
- 97 cavalier alternator or???
- Z24 no power
- '95 Cavalier starting problem
- 94, brief smell of gas when starts
- Ties Size 98 Cavi Z24
- Clutch Master Cylinder
- Adjusting hand break
- pcv valve location
- Hub assembly replacement issues.
- Throttle / Idle problem
- Engine Swap...
- to Fix or buy.. hmm
- Door panel and turn signal questions
- Cavalier Overheating, PLEASE HELP
- power window slow..
- 94 brakes soft
- Cav starts then stalls...
- No start, have fuel and spark. 95 2.3L DOHC
- New shoes!...No not rims....shoes!
- catalitic converter
- Yea so guess what the cops want now.
- Venom 400
- Should I turbo the cavy?
- 1997 Z24 tranny nightmare!
- GM intake manifold, Will it work?
- 1990 Caveliar 2.2l New Fuel Pump Dies
- Grr... Problems during installation...
- 95 cavy 2.2, 23-25 mpg sound right?
- cheap fenders quarter panels
- Guys & Girls, I Need Help!
- good idea for an air intake?
- New problem...
- Running wire from Battery to Amp
- heater core write up?
- Has anyone w/ a cavi on this forum done an L67 engine swap?
- Ebay CAI
- 97 cavalier w/ 2.4L, transmission is acting up!
- Quick Qs
- Horn??
- Cavalier Accident Help
- Fuse box...
- 04 cav coupe, 05 cobalt coupe?
- Couple of Cavy questions...
- 94 cav with bad head gasket
- low end upgrades
- changing thermostat
- how to drain coolant?
- leaking cavalier....whats new
- Need Help Installing Motor Mounts
- 00 sunfire se - high temp at idle & squeel from ac
- ripped off??
- Some new toys
- Heater Fan
- What's the best oem replacement battery?
- Winter mod... Found something to kill time with.
- door strips, anyone ever take them off?
- Windshield removal, Who’s done it before?
- smashed up bumper lol
- Cav has risen from the grave with only minor wounds
- F Bodies forum????
- Idling Problem
- Place to Lift?
- in need of green z-24 bumper
- Small Block
- Plastic hubcap lugs
- a sad day for a local j-body owner
- Funny Story
- Flushing the cooling system
- 94 cavalier tire size change
- Do you need dex-cool II in car ??
- OK - I give up
- Front Dash Piece
- new to the forums, hey all
- buy cavalier
- 98 chevy cavalier
- 2000 Cav Heater Blower Motor Speeds
- Tail Light Filler Panels???
- need advice on sway bars/strut bars
- Started another project....
- 98 windshield replacement, what years will fit?
- z24 tranny HELP PLZ
- Can't cancel eng. light????
- I said i would never do it.. but... :-/
- 1998 Cavalier (Starts but stalls right away) Help Me please
- cd player code
- Clock light is out, is it serviceable?
- Greddy Oil Catch Can
- fuel feed line
- Coil Pack resistance?
- Cav Engine Swap
- fuel filter help
- 2004 Cavy Air Conditioner LED
- Urban definitions of ''Chevy Cavalier'' lol
- Have you seen this cavy yet??
- New Tail light Pics
- Parking Brake Switch
- help me ! i am a girl'''
- front drivers side blinker bulb
- 97 Cav Rear Bumper/Chicago
- 2001 Cavalier Transmission Fluid Change
- Trunk Wont Open
- Side markers, aftermarket bumper
- right front blinker
- how to remove door panels
- 95 Cavalier - turn signals not working
- replacing transmission
- 98 cavalier z24 water pump
- How to reset air bag light
- 97 cavalier engine question.
- Transmission help
- Sunroof will not open
- Is it possible to mount the hvac in the sunvisors?
- '94 cav too much draw car dying
- 1996 land rover radio
- transmission
- Losing Radio Presets on Factory Radio
- Whats the best memory about ur car?
- Guess whats in the Box Game!?
- ETS/Check Engine light.....deactivating.....
- Filler primer or self etching primer?
- Why on earth
- How to remove back 03 Cavalier Rear Seats
- 92 cavalier bad bad bad misfire.. please help
- New Z24, its time for the 1992 z24 to retire..
- Have any of you seen this?
- 96 Cavalier Blinker Problem
- Pic Request: Bucket seats in the rear, replacing the bench
- 99 cavys..wtf?
- Chevy Chevrolet Cavalier Hyper Voltage System
- 96 Cavalier Tie Rods And Control Arm Bushing...help
- 02 cavalier service engine light
- Help, Acorns in my AC/Heating fan and ducts
- left turn signal not work, help please
- What 2.3 Quad4 parts are interchangable with 2.4?
- 2000 vs. 95
- Bumper Difference?
- Buying new Z24 - 02 2.2 ecotec or 2.4 twin cam??
- not starting
- 92 Cavalier RS 3.1 quits while driving, won't restart for at least an hour
- wheel bearings
- alternator
- Wanna know how much HP these babies have
- clutch kit
- Anyone have a good idea...
- today was a good day
- Heating Problem
- Only in Ohio...
- Urine in the gas tank.
