View Full Version : Cavalier
- coilover spring installation
- New pics with my buddies 05 SS S/C Cobalt
- three questions...
- Grrrrr!
- i want this car sooo bad!
- tps problems?
- Butterfly Knife Keys
- Suspension swap & install pics...
- okay...
- lip kits for a 98 cavy
- Help Needed applies to `96 Cavalier fuel injectors
- Keyless Entry 97 Cavalier help?
- Time to Play whats in the box game?!
- 1999 Cavalier - Back Brake Vibrations
- z24cai for 2.2
- 2001 Z24 Keyless entry?
- '98 Z24 Starting Problems
- high idle
- Clusters
- Advice needed
- what the hell?!
- Self forced oil change guys!
- Horn Help
- Turbo is hawt :(
- 1999 z24 or 1999 Prelude???
- Removing Rear Seat (97 Cavalier)
- just couple new pics.. hehe
- Front end swapping thread
- quick question (let's try 4 posts or less)
- O2 sensor, which one???
- sunroof problem
- Slow Turbo Tech
- Rattling noise.....A/C..........
- No more Cavy :(
- Alarm Wiring?
- Bored... New pics on the way to Taco Bell
- Just purchased a 02 Cavy Z24.
- VERY pissed off
- 00 z24 cavalier with dim low beams....
- What would you guys do?
- Broken strut stud
- Almost made it through friday the 13th
- wiper blade size
- anti theft /anti start
- front end noise 97 cav
- 2004 Cavalier LS Interior Dash Lights?
- 03 cavalier lots of issues plez help
- projector headlight wiring
- 94 cavalier manual tranny swap
- WHAT is the best miles you can get out of a 95-97 cavy
- need help
- side marker light replacement
- ABS&TC lights on when making left turns
- which add more hp?
- Stupid Question
- pillar pods
- my 16 yr olds 1992 z24 cavalier
- Probly a stupid question BUT...
- Keyless Remote Died?
- quick question...
- Air bag sensor
- power window problem
- Bye Guys
- Unmounting tires
- 85 cavalier...don't know a lot
- changing door hinges..
- Defrost turns AC on???
- how do i change my fuel filter?
- 93 2.2 Plugs & Wires
- 3.8 v6 supercharged swap
- Installing Drfit Rear Bumper?
- Can anyone please help,pinking problem
- Broken into and want to buy alarm
- Black Cavy
- Black Cavy
- 04 ls sport.. need to replace trunk
- Cleaned my rims (way over due)
- 95 cav - clutch problem
- 2004 Cavalier Tranny Prob!
- check this out
- windows fog up when raining..
- Another Problem
- Things that make you say (...)
- Problems with fan (cabin)
- service engine light when shifting from park
- 97 cavi RS exhaust!!!
- trunk button ?????
- stock radio question
- Got an Idea Need Help
- help me PLEEASSSEE!!!!!
- The Best thing to happen to a car
- CAI on ebay....good or not???
- Mushy Shifter
- soaked floor
- So...
- horn relay
- Motor Mounts Are Coming!
- lowered cavy??
- check this out
- interior paint?
- new headlights
- 99 cav convertable needs new weather stripping
- Problems
- What can i do?
- Gauge Lighting
- Thermostat Location?
- So...what's in the box?
- 1998 Cavalier RS
- SUNROOF WON'T Close
- Hosing out the engine
- air bags on 98 z24
- Why did this happen?!
- battery disconected -Sequence to get past anti-theft
- Just when I thought it couldnt get worse....
- Woot!!!! Only 3 1/2 Hours
- unknown stalling problem
- will engine fit?
- Adjusting hand break..
- Should I worry about high miles?
- 96 Cavalier gas smell, no noticable leak...
- 2.4 worth doing?
- Cobalt 2007 or Acura RSX Type-S?
- What have you done to your cavy, and how much invested thread
- How to repair windshield washer fluid reservoir?
- 2200 power steering pump
- Z24 Engine light
- ..I just couldn't help myself
- Wow.. Anyone ever hear of this before...
- New Exhaust??
- Id like to share this wallpaper.
- New tires?
- Now i'm in a pickel...again
- Where do I plug this in?
- Should I?
- spark plugs..
- new rotors and brakes, new clunking sound?
- P0455 2004 Cavalier
- Oh hell... why not.
- Look what i bought!!!
- headlight question
- Mileage backed-up
- winter tires and rims
- What the hell??
- 1989 z24 cavalier front clip with ram air hood
- Two little things
- 03 Cavy Steering Wheel Removal
- clunking sound
- steering wheel squeaks
- need a little help
- Blower motor resistor
- Window Regulator OmgWtfBBQ?
- Check Engine and ETS lights...........
- Chevy nightmare
- Eibach Anti Sway Kit?
- Greetings Everyone!
- Projectors!
- Heats up way too fast
- AC Works On 3 but not 1 or 2
- Why isn't my amp/subs getting power/optima red top question..
- 2.4 swap
- 96 Cav Clutch problems need help!
- Should they bring back the cavalier??
- Airbag replacement, anyone done this before?
- ABS light comes on then heater fan shuts off at the same time
- starter replacement
- A little get up and go.
- What's is going on with my car???
- Ticking, "low fuild light", ect ect...
- odometer light 2002 cavalier
- Deal, Or No Deal? =]
- Bad night at the street races
- Repair manual
- can you believe it????
- 1999 Cavalier wont turn over
- 96 window crank
- very weird
- Airbags deployed now car will not start HELP
- drag racing tips
- Odometer and Speedometer Problem
- K&N air filter/air intake
- wont start
- Gas Milage
- Hi couple questions...AC
- 97 cavalier with abs/traction control problems.. help!
- engine surge when in drive and AC on!!
- A-Pillars
- Bob Mull's ''EVIL Z24''
- Lowering Springs
- Horn doesn't work with the ignition on
- 1999 Cavalier fan problem.
- cams flywheel and supercharger???
- Engine Light On
- Official Product Review Thread
- Cracked clear coat..
- stupid ?
- help, electronical problems
- Soo... I'm stumped. Car still misfires, tore alot apart and found this.
- Removing rear speakers.
- My venting session
- ATT 91-94 cavalier owners..lil tech help
- J-bash 2005
- will 95 engine fit 97?
- engine noise
- Sticky paint
- quick q?
- How far is too far?
- wipers (motor & column switch) ?
- What a father will do for his daughter...Fuel pump change-out
- help
- my future Z24...
- subs and amp help
- Help me out
- convertible kit
- Help please with my Chevy
- Re: Abs problems
- well I got my new z24..
- programming keyless entry 2003 cavalier
- bolt pattern on 95
- 2001 cav louvers
- The Almighty 3400. Tell me about YOUR motor swap!
- How many miles are on your cavy/sunfire
- power mirrors
- can the front wheel speed sensors be reached
- Can someone tell me how to wire up my horn again? I got a pic.
- Speed control volume?
- hello there new z24 2002
- hi there my new z24
- disappearing oil
- power windows
- 2 questions
- Bulbs?
- Help me with this decision on speakers plz.
- Weird Noise
- radar dectors
- racing seat?
- Blower motor on 99 Cavalier, only works on the 2 high speeds??? WHY??
- Post pics of your ride and you
- Stock
- picture sig...
- Can somebody tell me what this is in my trunk and connected to my speakers?
- ignition mod on 89?
- new to the forum
- Tranny Problem 99 z24
- Exhaust idea
- Will spark plugs that I got for the 2.2 work well for the Z?
- drilled rotors, worth it?
- 96 Cavalier Motor Compatability
- capacitor?
- Final pics for the year, till next spring... Hopefully.
- Bad Coil Pack!
