View Full Version : Cavalier
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Chervorlet Cavilair Starting Error
  2. windshield washing
  3. Exhaust/header wrap
  4. oil level sender connector
  5. New Shift Knob-Help please
  6. Bug Deflector or clear hood shield??
  7. Clear Lights Finally!!
  8. painting interior green and walmart sux
  9. Cavalier making strange noise
  10. 04 Cavalier-Odd color on dash and radio
  11. Mice & Cavaliers in same family?
  12. HP Tuners
  13. Garage in Houston?!?!
  14. What Cold Air Intake?
  15. Yer Ma Boy Blue!!!
  16. Passive door locks?
  17. My first Cavalier oil change-2 questions
  18. Changing Coolant
  19. Just bought 2004 Cavalier-My thoughts
  20. 04 Cavalier power steering fluid
  21. blown engine
  22. 2.4 intake manifold?
  23. Dumb ?
  24. Ecotec head swap onto 2.4L bottom end
  25. 95 cav driver side tranny mount
  26. Your Ride Pics and Specs
  27. Got Unlazy
  28. Lock Cylinder Inside Door (Rod Dangling)
  29. Will 2001 Cavalier (4 door) seats fit in my 1999 Z24?
  30. My z24 pics...on a cloudy day
  31. 89' cavalier Z24 VS. 96' Acura Integra
  32. transmission linkage off
  33. Z-24 won't turn over
  34. i need a new exhaust system
  35. 2004 Ecotec motor-Timing belt?
  36. Oil Light Coming On
  37. Can it really be... some questions to ask.
  38. dont park your car downtown......
  39. '92 Cavalier NEED HELP ASAP!
  40. My 96 Z-vert
  41. Help with alarm wiring diagram
  42. engine swap and motor mounts
  43. More AC woes...
  44. Rear deck removal on 02 coupe?!
  45. Some New Pictures of my Sunfire!!
  46. There's a ringing noise in the engine of my Z-24.....
  47. Odometer fritz #2
  48. drivers side brake nosie
  49. What do you guys think about Falken Torque 5's?
  50. Belt keeps falling off
  51. exhaust problem
  52. Super Troopers? I think not...
  53. resistor for blower motor
  54. rip off?
  55. Price for Cavalier?
  56. Cavalier a good car?
  57. Quad 4 intake
  58. alternator or fuel pump or o2 sensor
  59. 96 Cavalier engine swap
  60. Transmission Shift Problem 1989 Auto
  61. Should I buy this Cav for $500?
  62. Engine Code - P440
  63. 99 Cav...odometer on the fritz?
  64. HP&Torque differences in years for 3.1 v6
  65. Almost got t-boned
  66. exhaust help
  67. ran fine this morning wont start now..97 chevy cavalier
  68. installing power windows locks
  69. Turbo Tech Racing Upper motor mount....
  70. Thinking about buying-Gas mileage?
  71. Car still makes poping noises
  72. No fan speed on low and low/medium but fan works on med/high and high
  73. 96 cavalier engine swap problem
  74. Wrap Intake?
  75. uh oh...
  76. 88 z24
  77. Transmission hose leak??
  78. 97 Z24 No High Beams????
  79. 3.1 Custom Performance Kit
  80. Help Asap!!!!
  81. oi cody
  82. =] New Ride =]
  83. What do you guys think about this pair of racing seats?
  84. Painting a fiberglass body kit......
  85. i need a sweet signature but i dont know how to make one.
  86. what was recalled???
  87. today is a bad day!
  88. top speed limiter
  89. AC question
  90. Oh god, i stumbled across some old terrible photos...
  91. 97 Rear hub assembly
  92. Happy Birthday to me and Derk!
  93. Shuts off...
  94. 96 cavalier linkage to automatic shifter came undone
  95. 94 manual trans question
  96. UpDated Pics of the Cav:
  97. Overheating Problem?
  98. V DUBS arent the only cars that play guitars
  99. Catback suggestions needed...
  100. lowering compression
  101. 1994 Cavalier Info
  102. 1998 belt tensioner replacement
  103. V6 (1994 Cavalier)
  104. 1994 Cavalier
  105. I get bored easily...
  106. 88 cavalier
  107. 91 Cavalier Problems, please help!!!
  108. Dynotune guage
  109. Mmmmm New Toy! :)
  110. 89 Cav
  111. Finally had to let her go, and picked up a new toy..
  112. light problems
  113. upgrading spark plug wires on 03 sport
  114. 96 Cav P0440
  115. Aftermarket Spoiler suggestions...
  116. Help needed stalling 93 cavalier
  117. How do you purge the air out of the cooling system?
  118. Whats this part called?
  119. 235 tire too big for 96 cavalier?
  120. Lower Intake Manifold Off. Now What
  121. Jammed Clutch Pedal
  122. running warm at high speeds
  123. coolant leak
  124. Replacing Water Pump 1999 Cavalier
  125. code po442
  126. turbo... air filter?
  127. Don't sell your Cavaliers...
  128. Who's a cam whore?
  129. cavalier z24
  130. vac
  131. Manual Locks To Automatic?
  132. Battery... Alternator... Drainage...
  133. 92 cavalier strut mount
  134. What Plug Wire Brands?
  135. oK lowering springs it is HOw low do i GO!
  136. Painting body kit yourself! HELP!
  137. another z24 that won't start...this one's different though
  138. 97 Cavalier noises
  139. transmisson is being a whore!!
  140. Cavalier Lower for look Not Proform
  141. help asap
  142. Removing muffler
  143. '04 Chevy Cavalier - Chrome Rims?
  144. exhaust leak???
  145. *Newb* Engine Light Question
  146. engine swap
  147. lock out selinoid
  148. at what temp should my fan kick on?
  149. I feel like a noob! lol
  150. CRJ's Box game time.
  151. I need info on speed sensors
  152. P0440
  153. ECC problem
  154. radiator question
  155. 2000 cavlier cd player
  156. Anybody on the CAVALIER FORUM want to join a fantasy baseball league?
  157. '01 Trans on '97 Block
  158. 2003 headlights
  159. antenna question
  160. Sythetic oil?
  161. spoilers
  162. 1998 Cavalier "Head Light Issue"
  163. 3.1 conversion
  164. 3.1 motor?
  165. help removing window
  166. Are all 15x6 steel rims the same from 95-07 ?
  167. Okay I should Have Thought Of This Before
  168. engine and trans swap
  169. Rims And Tires
  170. Power Loss All Around
  171. Low pressure fitting for AC on 96 4.2?
  172. 97 Cavalier Fuel Preasure Regulator Removal?
  173. Parting out 99 cavilier
  174. Overtightened cap on collant overflow cause seepage?
  175. How much will a muffler shop charge?
  176. 99 cavy emmisions
  177. 2004 Cavalier difficulty starting
  178. Fuel Injector..............
  179. ecm fuse
  180. How many motor mounts effect the movement?
  181. Starting Problem
  182. Help with 2.4 spark plug change
  183. Hub Assembly
  184. Automatic tranny mounts
  185. transmission fluid change
  186. Mini Bash??
  187. '89 Cavalier owners..
  188. How To: Install B&M Shift Plus on 2.4L LD9 Z24
  189. Radiator Fill Light On
  190. ABS Sensor for '97 cavalier
  191. HP tuners
  192. 2001 Cavalier spoiler-brakelight question
  193. Replacing Stock suspension?
  194. engine swap: 2.2 auto - 2.4 5-speed
  195. Wiring and Water don't mix.....I need suggestions please
  196. i know this is probably rice
  197. 1999 cavalier
  198. Who's done a coil pack/Ign. module changeout on a '96??
  199. Boost Guage
  200. Starter
  201. 99 cavalier turn signals
  202. Summer plans...
  203. Remote Start, Turbo Timer
  204. Coverting automatic to stick
  205. '04 Cavalier - No Air Out Windsheild Vent
  206. dog hair
  207. oil pressure sensor..
  208. wat are the engine specs for a 2000 z24 cavalier?
  209. 90 cavalier 3.1 Problem
  210. 2001 cavalier check engine light does not illuminate when ignition key is turns
  211. 97 Cav questions*noob*
  212. getting a newer cav
  213. ETS OFF and Check Engine Light On
  214. acceleration noise & excessive fuel comsumption
  215. Would new Cobalt engine fit 92' Cavalier?
  216. turbo???
  217. fuel filter change
  218. fuel filter change
  219. Bad day
  220. Some up to date pics...
  221. Xenon Headlight Bulbs
  222. new camshaft...
  223. Intercooler
  224. check out these rims i might get
  225. Tranny oil cooler?
  226. cars up to 75% off!!
  227. Actually did some new stuff finally.
  228. Painting
  229. 2005 question
  230. Replacing Rear Lights(all of em)
  231. CB radio mounting
  232. Why don't Cavs have a better resale value?
  233. PLEASE HELP- Don't have manuel for 03 Cavalier...
  234. where's the horn
  235. Anyone know where i can find the clear side markers?
  236. running lean
  237. A Real Painter Advise
  238. Steal of a Deal - $400 for a 1997 Z24 – Need Advice
  239. Cavalier is sold
  240. oil gauge question
  241. need trunk release help??
  242. how to bleed
  243. Everythings ok except right rear speaker
  244. replace starter
  245. 1999 Cavalier Transmission problems
  246. 96 cavalier head gasket
  247. Party at Yhandor's thread, eh?
  248. Optima Yellow Top Battery
  249. 2001 is overheating
  250. 95, 2.2 surging
