Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
> Cavalier |
View Full Version :
Cavalier
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
HP Tuners
Garage in Houston?!?!
What Cold Air Intake?
Yer Ma Boy Blue!!!
Passive door locks?
My first Cavalier oil change-2 questions
Changing Coolant
Just bought 2004 Cavalier-My thoughts
04 Cavalier power steering fluid
blown engine
2.4 intake manifold?
Dumb ?
Ecotec head swap onto 2.4L bottom end
95 cav driver side tranny mount
Your Ride Pics and Specs
Got Unlazy
Lock Cylinder Inside Door (Rod Dangling)
Will 2001 Cavalier (4 door) seats fit in my 1999 Z24?
My z24 pics...on a cloudy day
89' cavalier Z24 VS. 96' Acura Integra
transmission linkage off
Z-24 won't turn over
i need a new exhaust system
2004 Ecotec motor-Timing belt?
Oil Light Coming On
Can it really be... some questions to ask.
dont park your car downtown......
'92 Cavalier NEED HELP ASAP!
My 96 Z-vert
Help with alarm wiring diagram
engine swap and motor mounts
More AC woes...
Rear deck removal on 02 coupe?!
Some New Pictures of my Sunfire!!
There's a ringing noise in the engine of my Z-24.....
Odometer fritz #2
drivers side brake nosie
What do you guys think about Falken Torque 5's?
Belt keeps falling off
exhaust problem
Super Troopers? I think not...
resistor for blower motor
rip off?
Price for Cavalier?
Cavalier a good car?
Quad 4 intake
alternator or fuel pump or o2 sensor
96 Cavalier engine swap
Transmission Shift Problem 1989 Auto
Should I buy this Cav for $500?
Engine Code - P440
99 Cav...odometer on the fritz?
HP&Torque differences in years for 3.1 v6
Almost got t-boned
exhaust help
ran fine this morning wont start now..97 chevy cavalier
installing power windows locks
Turbo Tech Racing Upper motor mount....
Thinking about buying-Gas mileage?
Car still makes poping noises
No fan speed on low and low/medium but fan works on med/high and high
96 cavalier engine swap problem
Wrap Intake?
uh oh...
88 z24
Transmission hose leak??
97 Z24 No High Beams????
3.1 Custom Performance Kit
Help Asap!!!!
oi cody
=] New Ride =]
What do you guys think about this pair of racing seats?
Painting a fiberglass body kit......
i need a sweet signature but i dont know how to make one.
what was recalled???
today is a bad day!
top speed limiter
AC question
Oh god, i stumbled across some old terrible photos...
97 Rear hub assembly
Happy Birthday to me and Derk!
Shuts off...
96 cavalier linkage to automatic shifter came undone
94 manual trans question
UpDated Pics of the Cav:
Overheating Problem?
V DUBS arent the only cars that play guitars
Catback suggestions needed...
lowering compression
1994 Cavalier Info
1998 belt tensioner replacement
V6 (1994 Cavalier)
1994 Cavalier
I get bored easily...
88 cavalier
91 Cavalier Problems, please help!!!
Dynotune guage
Mmmmm New Toy! :)
89 Cav
Finally had to let her go, and picked up a new toy..
light problems
upgrading spark plug wires on 03 sport
96 Cav P0440
Aftermarket Spoiler suggestions...
Help needed stalling 93 cavalier
How do you purge the air out of the cooling system?
Whats this part called?
235 tire too big for 96 cavalier?
Lower Intake Manifold Off. Now What
Jammed Clutch Pedal
running warm at high speeds
coolant leak
Replacing Water Pump 1999 Cavalier
code po442
turbo... air filter?
Don't sell your Cavaliers...
Who's a cam whore?
cavalier z24
vac
Manual Locks To Automatic?
Battery... Alternator... Drainage...
92 cavalier strut mount
What Plug Wire Brands?
oK lowering springs it is HOw low do i GO!
Painting body kit yourself! HELP!
another z24 that won't start...this one's different though
97 Cavalier noises
transmisson is being a whore!!
Cavalier Lower for look Not Proform
help asap
Removing muffler
'04 Chevy Cavalier - Chrome Rims?
exhaust leak???
*Newb* Engine Light Question
engine swap
lock out selinoid
at what temp should my fan kick on?
I feel like a noob! lol
CRJ's Box game time.
I need info on speed sensors
P0440
ECC problem
radiator question
2000 cavlier cd player
Anybody on the CAVALIER FORUM want to join a fantasy baseball league?
'01 Trans on '97 Block
2003 headlights
antenna question
Sythetic oil?
spoilers
1998 Cavalier "Head Light Issue"
3.1 conversion
3.1 motor?
help removing window
Are all 15x6 steel rims the same from 95-07 ?
Okay I should Have Thought Of This Before
engine and trans swap
Rims And Tires
Power Loss All Around
Low pressure fitting for AC on 96 4.2?
97 Cavalier Fuel Preasure Regulator Removal?
Parting out 99 cavilier
Overtightened cap on collant overflow cause seepage?
How much will a muffler shop charge?
99 cavy emmisions
2004 Cavalier difficulty starting
Fuel Injector..............
ecm fuse
How many motor mounts effect the movement?
Starting Problem
Help with 2.4 spark plug change
Hub Assembly
Automatic tranny mounts
transmission fluid change
Mini Bash??
'89 Cavalier owners..
How To: Install B&M Shift Plus on 2.4L LD9 Z24
Radiator Fill Light On
ABS Sensor for '97 cavalier
HP tuners
2001 Cavalier spoiler-brakelight question
Replacing Stock suspension?
engine swap: 2.2 auto - 2.4 5-speed
Wiring and Water don't mix.....I need suggestions please
i know this is probably rice
1999 cavalier
Who's done a coil pack/Ign. module changeout on a '96??
Boost Guage
Starter
99 cavalier turn signals
Summer plans...
Remote Start, Turbo Timer
Coverting automatic to stick
'04 Cavalier - No Air Out Windsheild Vent
dog hair
oil pressure sensor..
wat are the engine specs for a 2000 z24 cavalier?
90 cavalier 3.1 Problem
2001 cavalier check engine light does not illuminate when ignition key is turns
97 Cav questions*noob*
getting a newer cav
ETS OFF and Check Engine Light On
acceleration noise & excessive fuel comsumption
Would new Cobalt engine fit 92' Cavalier?
turbo???
fuel filter change
fuel filter change
Bad day
Some up to date pics...
Xenon Headlight Bulbs
new camshaft...
Intercooler
check out these rims i might get
Tranny oil cooler?
cars up to 75% off!!
Actually did some new stuff finally.
Painting
2005 question
Replacing Rear Lights(all of em)
CB radio mounting
Why don't Cavs have a better resale value?
PLEASE HELP- Don't have manuel for 03 Cavalier...
where's the horn
Anyone know where i can find the clear side markers?
running lean
A Real Painter Advise
Steal of a Deal - $400 for a 1997 Z24 – Need Advice
Cavalier is sold
oil gauge question
need trunk release help??
how to bleed
Everythings ok except right rear speaker
replace starter
1999 Cavalier Transmission problems
96 cavalier head gasket
Party at Yhandor's thread, eh?
Optima Yellow Top Battery
2001 is overheating
95, 2.2 surging
Heater problems 2003 Cavy
Supra Cavalier?!
Quick Airbox Question.
Turbo checklist for next month
94 Cavalier Stereo Problem
Passlock theft system
"Limp mode"
94 Cav flashing headlights
First Post here.. Pic Inside
cavalier ETS light
low coolant light comes on..
Web
AF
