View Full Version : Cavalier
- New here, need help with g/f car.
- wiring a stock radio
- do cavyz burn a lot of oil?
- Oil Pan
- Trying to hook up neons
- Turbocharging the ecotec
- Does this sound like the Catalytic Convertor
- need help with struts, and fan doesn't work
- cavalier 2000 lights for the gears dont work
- anyone have msd coil packs?
- Who sells high amp alternators for 2.2l OHV?
- Clutches
- keyless remote entry
- How much do you think i can get for my cavalier?
- Rear widoe defogger not working
- urgent Horn (hooter) help
- suspension experts only
- New Website!!!
- leaky trunks? 95ish
- body kits for a 4 dr
- aftermarket tachometer install
- Performance parts for a "senior citizen"
- Ground Effects
- 96 Cavalier ABS Light
- 3.1 Engine Mods???
- Engine Stalling '93 Cavalier RS
- how to change a light bulb
- rim/tire size
- Custom stereo installs
- bondo question
- 93 Cav Loss of Power post Ignition Module
- removing body parts
- Aftermarket ACC Problem
- 20-30hp gain for 04 cavy?
- Serious Problem
- How fast is your cav 1/4 mile
- 91 sunbird gt turbo on my 2000 cavalier
- Odd Hesitation/loss of power in my 2001 Cavalier
- 1987 z24
- Chrome Wheels And Parts For Sale !!
- cavalier parts
- Replacement side mirror
- bypassing egr?
- anyone with oversized injectors
- Anyone want to buy a RADAR DETECTOR??
- Quick help needed - Spark plug gaps
- Anyone wanna trade STOCK Cavalier Aluminum 16's??
- How Do you turn off the daytime running lights on 02 cavalier?
- 1995 Cavalier parts up for sale!!! You name it, I got it!
- Body kit and spoiler NEEDS TO GO!!
- Information on 2.4 swap into 97 cavy
- Wanted Z24 parts
- belts behaving badly
- Gages and Dummy Lights
- Speed sensor
- white rims?
- Electrical problem?
- Do you have a 'Suped Up' Cavalier?
- OBX Racing Headers 95-97 2.2L
- Horn Location 96 cavalier
- 89 cavalier 2.8 how to adjust drive belt
- Calvalier climate control fan switch problem
- muffler
- 89 cavalier belt adjustment
- ok last one..i promise
- got another one...this time about shift knob
- question about intake
- looking for cav's
- PLaying in the Snow
- 1st Gen to 2nd gen 2.2l
- what to do with turbo
- climate control knobs
- 2.2 ecotec to 3.8 supercharged
- Coolant System Prob, Need Help
- Cavalier BODYKITS CHEAP!!!
- Supercharger on 2.2L
- color codes
- engine/car shake
- 98 Cavalier Problems--Cold Weather
- SHOULD i BUY $350.00 1996 CAVY 5SPD BAD MOTOR ?
- Location of Engine Coolant Heater?
- Electrical problems
- 2.2 to 3.1 swap..is it worth it?
- tranny drop
- 97 Cavalier parking brake adjust
- Servicing History
- lamp dimmer control module help
- after market stereo problem: no power
- 89 Z24 Oil Pump Help
- 2.2 ecotec or 2.4
- Overheating and coolant leak
- Rims For Sale
- Abs Problem? Dash Lights Go Out!
- Does anyone know of any after-market performance parts for 2nd gen cavaliers?
- Side View Mirror Replacement
- Someone Please Help!!!
- help with installing a tach?
- question about fuel injection cleaner
- Remote start help?
- Replacing the stereo when it says LOC
- Help if anyone can
- Jeep Cruise Control Problem
- Electrical problem 1988 Cavalier
- Where is the tps on a '98 2.2
- Location of signal light flasher units
- air in cooling system
- Flashing Daytimes Indicator
- Need a driver's side rear door stationary window
- Exhaust, what should i get?
- cold engine/ start off problems
- no start and ticking
- Startup Issues
- cluster light problem
- Car having trouble staying started
- new here please help with 92 cav
- Fog Lights for a 2003 Cavalier?
- New Motor?
- Selling my Cavalier
- 88 Z24 no spark, please help!!!!!!!!!
- Interior repaint probs
- need help with a 91 chev cav z24
- trying to get the codes out of stereo
- 97 aftermarket cd player
- Left Signal Light Problems
- Help: Car drops temperature and runs cold when driving on highway at 55+MPH only.
- can't remove the key from ignition
- 88 Cavalier Volts Light flickers
- Tach Install For 93 Cavalier
- 97 wont start turns over fine
- 17" ENKIE RS6 RIMS FOR SALE
- Help me find the Ignition Coil
- 83-98 Cavalier Convertible Top w/plastic window New $165.00
- Need help, no one know what to do
- Take the shock out of it! Really...
- Climate control knobs?
- replacement rims
- 91 cavalier dash pad
- anything wrong with the z24?
- Help, Intake Gone Wrong!
- z24 swap
- E-Brake in an 2004... can you remove it? if so how?
- 91 Z24 steering problem
- painting the interior
- Fan blower
- finding lube points
- price of a z24
- 10g's
- That Cobalt is Hot
- 04 cav ls sports coupe speaker remove/replace
- Hubcaps from 2nd? gen cavalier
- 96 cavalier heating problems
- Ecotech
- Reoccurring starter problems 92 Wagon
- alero engine into cavalier
- Manual Shift Knob Difficulties
- chrome wheels and parts for sale
- Setting time in 2000 cav
- Bulb Replacement
- 96 2.2L Dies
- 3.1 Dies after longer trips
- clicking noise from steering shaft
- theft system light....engine dies
- sill panels
- need help with a 96 2.2l
- Did i just wast my money?
- 1995 Ignition (start) circuit fuse location (fusible links)? Won't turn over.
- new engine and drivetrain for my cav
- help on installing Prostart remote starter amd keyless
- maybe blown head gasket?
- Paint Job????
- what should i DO??!?!?! please read!
- J-body w/ headers
- 97 chevy cavalier 2.2l
- a trashed 96
- Auto X
- offset for 92 Z24
- Dads 93 Cavalier Won't Start
- Few questions before swapping engines!?
- need help with cav. ASAP!!!!
- Rear speakers, 92 Z24
- post your 1/4 times and 0-60
- what voids my warranty
- ARG Damn flip roofs!!!
- '98 RS Coupe
- oil light keeps comming on
- WTB: heater/ac controller ASAP....
- Need Major Help On My Cavalier
- 2004 LS Sports Coupe (Auto)
- the rare 2.3 quad
- What parts next on the ecotec
- 93 cav motor swap
- Help me please
- 92 Z22 Cav with ABS and P brake lights on all the time
- warped rotors -- common cavy problem?
- what is LSD??
- How do you remove the dome light cap in an 03?
- blower airflow direction not working
- 96 Cavilier Rear Defogger
- how many valves
- What Gen cav!?
- Just Bought a 1993 Cavalier
- Air Intake Prob!
- How do I know if my axle is bent?
- Power steering cooling tube
- horrible 3.1L idle
- fan noise question?
- exhaust
- Burnt odometer backlight
- some one with a carfax account
- How many miles can you get out of Cavalier
- Whats better?
- No Heat in '93 Cav.
- dropping engine out of 94'
- Ignition problem with 99 Cavalier 2,2
- Humming noice under hood
- lowering 03' cavalier
- anti freeze leake
- 2000 Cavalier z24 rear bumper
- ecotec turbo
- A few future mods.
- nevermind...
- upgrades to my 96 2.2L cavalier
- Remote car starter
- Cavalier Steering Knock
- 1998 Z-24 rotor replacement problems
- Need help with '97 Cavalier Manual Transmission.
- First post, need help!
- z24 body kit?
- 2003 manual transmission power loss
- z24 owners
- shaved door handles
- Suggestions for chrome tips
- heater core (n00b)
- how much trouble to shave side moldings?
- Temperature Gauge
- Question about my Cav
- car not starting??
- transmission problem
- day runners
- car just will not start
- Lambo Door Hinges
- black 3rd gen trunk lid... z24 ECU, tail lights
- need a 95-99 2.2L head? bid now, it ends in 2 hours!
- Parking Brake
- apc 4d mirror install problems
- remote starter
- 1998 Windshield scratch repair
- Where is fuel filter on 89 cavalier???
- Z24 Chain tensioner
