Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
> Cavalier |
View Full Version :
Cavalier
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
DRL's
solenoids
Car will not start.
man do i need help
2001 cavalier LE 2.4L Timing belt or Chain?
help with my 2001 cavalier
Automatic shift knob
How To Remove Radio Out Of 2001
electric problem
fuel filter removal
Need Help With Installing My Rear Euros
Cavalier body styles
some cavy stuff listed on ebay
Cavalier Running Rough
160 degree thermostat for 02 2.2l
Flame glow gauges
Engine overheat
Foggier than London...
2000 Low Speed Heater / AC blower not working
Engine Coolant-Please help
installing a stereo in my car
looking for a 2.4 z24 motor
2000 Z24 engine cranks but won't start, stalls sometimes
after market gauges
2.4 DHOC motor
Cavalier engine
Cavalier help
GM performance tuning
anyone in the north florida area?
1995 Cavalier Injector
race shifters
interior mods..i need help
93 cavalier elec ign control module
cooling fan switch
2.2L 2001 Cavalier Tuning parts
cavalier turbos
diza hurricane body kit
any lowering spring info will be helpful
Lowering 2k4 cav
DRL's (Daytime Running Lamps) for 2004 Chevy Cavilier
cold air intakes
Help with interior lighting
throttle body sizes
a few probs.. any advice???
98 Cavalier won't start
rear window defroster
turbo??????
Chevy Cavalier 1999 Won't Start
Cavalier PCM code
info on cavaliers
Does anyone know the hp/ torque and also what the tire size are on a 2002 Cavy!!!!???
Problem in the cold...
2k4 cav stereo hookup
ECU problems
'90 Cavalier Fuel guage doesn't work after fill when < 10 degrees F... why ?
Does anyone know the street driving laws in VA???????
Wings West for sale!
Electrical
Nitrous?
Bodykit problems....
Powertrain mounts
cavalier model cars
Advice on buying a 95 Cav
Trans Shift cable
99 cavy...low rpms
94 2.2 Won't Start in cold weather
Need info- Z24 door panel
new (or remanufactured) engine for cheap?
coolant leak
interior question
any magazinesfor cavaliers?
93 cavalier RS engine swap
99 cavalier Check engine light
Brakes are acting up.
ERG Valve
2000 Cavalier Upgrades
Performance Mount Inquiry?
coolant problems
i've looked every where for a cavy
94 Cav Stalls when Placed in Drive
What can make my 02' 2.2L cav have more torque/acceleration/horsepower????
Help With Cavalier!
Cavalier Wants to turn off at stop..SOMETIMES
Whats the best turbocharger kit??
fuel pump wiring problem
transmissions
new here and looking for a cavalier
Turbo choise
motor swap for an 03
quick ECOTEC question!
1994 Cavi V6
1988 Cav, Hard starting
Engine
Cavalier Trunks
throttle body
fastest stock cavalier
I have to replace the headgasket on my 97 Cavalier
Help with my 92 Cavalier
turbo or supersharger
motor mods?
Is there a V6 Z24 engine for a 2001 cavalier?
turbo for a 03 cavalier??
1994 cav 2.2 hesitation
belt problems?
Anyone else have a V6 Z24
FS: Everything on my '97 Cavalier
rear wing questions
2.4 dohc maintance questions
2003 cavalier oil filter
Motorvac Cleaning Question
Dashboard Right Turn Signal Light/ABS Light Question...
Cav Taillights Questions????
neons
neons
2k+ Clutch Search
86 swap
97 Cavalier 2.2L suspension noise
91 Cav question
Ok weres the oil filter go on a 04 Cavalier
89 cav not running right
What's the hp/torque on a 2' cav and how do i increase acceleration on my car???
batt. light
2000 lowered cavy with problems
Stock 2.2L cavalier hp/torque
Engine Problems
Transmisson Service
sterio wiring
97 Cav with high K has engine shake
rev limiter
BCM/RFA Power Door Locks Malfunction
96 cavalier ABS light
Theftlock
1999Z24 Headlight Problems NEED help!
restoration
Slotted Fenders and unique kits for 90 Z24
clip on window winder
NEED Big help with 92 3.1L Engine Hesitation Please
Cavalier light question (VERY URGENT, PLEASE RESPOND ASAP)
1993 Cavalier axles
how to get window winder off
Defroster on 88 Z24 doesn't work. Please help!
2003 cavilier
black housing projectors for 01 cavalier z24
budget lowering
1995 Cav. Cost
ignition coil repair costs
95 CAV. Z24 Wont Stay on after turning it on! HELP AHHH..
'92 Cavalier runs like crap post 'repair'
girlfriends 2000 cavalier for sale mint con low miles
Please help trying to change alt. and cant get belt loose
2.4L engine horsepower
Glow Gauges
2.2L 1994 Cavalier Cold Air Intake
Just purchased a 98 Cavalier, and theres oil on the sparkplugs
98 Z24 Factory octane rating???
transmission swap
1997 Z24 - Switching from 16" RIMS to 15" RIMS
Short ram intake install
97 cavi rear struts
Rough Running 1996
cam specs
gear ratio
Injectors not working
'98 Cavalier Drive Belt specs?
Turbo..
cavalier ignition coil
'03 Cavalier Dome Light Question
FuelMaster install
I need help on Climate control seems not to work
93 Cavalier has the shakes
ecotec motor for sale
oil pressure gauge
1997 Cav theftlock
Please help...instrument cluster light problem
For 2002 Cavalier Owners Only!
2000 Z24
2000 cavalier - convert rear drum brakes to disc brakes
losing power
How to remove Belt holder on front seats
Intake systems
coilovers
Speedo & Tech Quit??
ignition coil
2000 Cavalier idle problem O2 sensor?
Help with Remote Start??
Daytime Running Lights
How can I clean my Fuel Injectors or Fuel Injection system?
bad fuel pump??
where the hell is my ecu?
can i do any thing to my car??? and how?
Installaton Cost?
great product
Quick ecotec question
Can I get a 2.2L fuel pump for less than $300?
How to get factory 6x9 out?!
99 cavalier brake caliper bolt size question...
Lowering Question?
How Much?
Cavy vs Civic
Air Ride System
another question
rear brake issues
Getting Sponsered??
heater problem
if a rim is rusted onto the drum (97 cavalier).. what to do???
Changed the rad, engine light is ticking me off!
high and low temp code
1995 transmission swap
clyinder head package
increasing horsepower
Headlight Conversion?
Problem with door and headlight warning sound
I'm looking for an ECU chip for my 1996 Sunfire GT
Mod Chips
weird noise coming from fan?
2003 tail light piece(middle)
aftermarket radio install
How do you change headlights in a 02 cav?
Cylinder Firing
Coolant Leaking Problem
Obx Catback Help
Turbos or superchargers
SHORT RAM AND CAI for Cavy
Heater problem
z24 ground effects on '94 base model
Hard Start . . . Symptom or Problem?
2003 oil change help
E-Brake handle removal
1997 Chevy Cavalier Fs $3000 34k
How do I get through my dashboard to replace my radio?
Heres a dumb question
What should I do first?
Strange Noise from Underneath when accellerating
Check Engine light after loose Gascap
What About The ECU ("Computer")???
Mods for a '93 2.2
2004 Chevy Cav mods???
Cheaper Lambo door kit.
Is this normal?
90-93 cavalier ac charge.
Pods For a 2003 Cav???
electrical problem with a 96 cavalier
Motor Problem
Park/Run, Wipers
88 Z24 Ground Effects 4 sale
96 cavalier
Z24 vs Ecotech
Its been through a lot!
Headlight bulb question
99 cavy engine swap
Web
AF
