View Full Version : Cavalier
- new muffler, bogging down.
- where do i post my car for sale? (noob)
- Hey
- My 4 dr cavalier
- shift knob removal for 97 z24
- Taillights--help please
- Cavalier Performance
- Car Spec Site
- 95 Cav makes clicking noise when you move from a stop
- 95 Cav that surges - FIXED thanks cujotom
- Motor Swap
- Help,
- getting pissy
- Looking for the best motor swap
- question before installing new CD player
- Recently got myself a newer Cav, I want to give it some boost.
- Fan not comming on
- 91 cavalier 2.2liter tranmission question
- Damn seatbelt
- 96 2.2 wont start
- Sad Story
- '89 Cavalier stalls while idling
- Guages
- who's faster
- performance mods
- 93 runs like crap
- '88 Cavalier -- Fresh from shop, ready for graveyard
- 305???
- Any one have a clue?
- ETS Light comes on when ever it feels like....whats making it do that
- Driver Side Power window problems
- back interior
- 2000 Cavalier Ignition Problems
- Shift Light Help
- New 2.2 Ecotec Motor?
- LS or Base
- Help please, the car just stalled.
- ignition problem PLEASE HELP!
- DRL for 97 2.2 interior light flashing, not working
- Quad 4
- cavalier rs chopped top
- 98 or 2000 model
- 1998 Cavalier Fuel Filter Change
- 1992 Cavalier Z-24 Convertable
- 2000 cold air intake for a 2.2
- weights???
- Strange headlight Prob
- 95 cavalier 2.3litre
- 2003 cavalier blinker problems
- how do i insert pics?
- Upgrades?
- won't take gas?
- Engine computer the same as PCM?
- thermoswitch
- axle seals
- Gauges for Cavalier?
- 91 cavy 2.2 backfires after 15 minutes of running
- 4door auto
- z24 hesitating after punching out motor
- in need of body parts..
- HELP!! no power to Starter?
- 88 z24 help?
- 92 cav clicked, then started, now just clicking
- Muffler recommendations
- Please help!
- Where is the engine computer?
- Weird Sound?
- wheel offset
- 2002 Cavalier - New Clutch at 30,000 miles - HELP
- Engine Swap on 98 Cavalier 2.2 Liter
- 1998 cavalier vent fan speed control
- neons mounted...now what
- Will Headlight Covers Off A 99 Work On A 00
- idle/air conditioning
- How to torque water pump pulley?
- HELP! thermostat bolthead stripped
- starting problems
- 91 cavy 2.2 runs poopy when warm
- 93 CAV install new deck
- two 1993 3.1L identical wagons 4 sale
- Removal of Headlights
- 2001 Stereo switch...
- lights
- oil thickness
- 96 ford taurus electrical problem
- Gas Guage
- door panel (carpe)
- stereo problems
- kills
- Rookie questions
- Bigger Fuel injectors?
- turbo??
- Engine computer
- Thermostat installation
- What is fed through this fuse?
- 97 cavalier left turn signal light need bulb replacement
- lagging in second
- 2.4 to a 1996 cavalier
- 91 Cav automatic stalling at stops
- Throttle body cleaning
- shift knob
- Misc. 03 Cav Parts for sale (pics)
- 92 Cavalier Ground up remake project need everyones ideas and suggestions
- Toucan/Ractive RAM Air... Any Good?
- Wheels for 88 z24?
- 2.8 not getting spark.
- Finally! Pics of the improved "DeceptiCav" !
- header frying my car
- 82 cavalier
- Chevy Racing Sticker on rear (removal)
- Squeaky when braking (new brakes)
- Do it yourself fuel injection cleaning kit?
- try to explain this problem!!!
- 89 cavalier backfireing, tried evrything, please help!
- 90 2.2 automatic "chews through" starters
- removal of balance shafts
- how tos
- will swapping out doors from a 93 cavalier RS to a 91 z24 work
- just died
- Vibration while turning and accelerating.
- last try to fix my cav
- Alittle drag
- aftermarket parts for 2.4?
- PCV Valve on 87 cavy
- Stall problem
- Re: 98 overheating problem
- 1991 Chevy Cavalier Engines! Please Reply......
- how many miles is an oil pump good for?
- when to replace 94 timing chain
- fuel pressure regulator/theft light
- crank sensor
- muffler sounds
- 03 Cav oil change question
- Innocent friend with a cavi
- Please Help - Cav refuses to start
- Cav is problem!!!
- 02 Cavalier Engine Issues
- Key problem...anyone else?
- Lowering Kit installation.
- A few speaker / amp problems.
- overheat
- no fire 93 cavalier 2.2
- ETS how to turn it off?
- aftermarket wheels and tires need sizes
- '93 cavalier. ABS light comes on. Troubles Starting the vehicle
- exhaust systems???
- '96 Tach Problems (HELP)
- Cavi for sale
- Dash removal
- dumb question
- My 88 z24
- Head Gasket Leak
- Hard Wire Cavalier Cooling Fan
- 2000 Z24 Won't Start!!!
- Leaking gasket
- Opinion on my Engine Bay / Mesh Grillwork
- oil change
- 1998 Cavalier clutch/transmission problem
- Gtp engine
- I'm retarded!
- 350 small block
- Need Help Finding Turbos
- Advice about non factory radios
- drivetrain problem
- 95 2.2 liter engine miss
- Gauge needles
- turn signal switch problem 92 2dr Cav
- rubber to metal??
- Disabling SIR (Air bag) system
- Sound system question
- New motor maybe
- what should i get? help plz
- anti-ignition system pb
- 99 Problems
- starting problem
- turbo on a 01 z24
- Pulling engine
- Electrical issues w/my '98 - Help!
- power window on convertable
- Cavalier Won't shut off!
- Engine For Sale
- 2002 Problems
- 87 oil pressure regulator
- just a question
- coil/ignition module replacement 1992 cavalier
- new intake
- Cavalier BodyKit In Need (Help)
- Manual Transmission Problem
- ANyone Need An imperfect 91?
- Strange "Warm Weather" Problem
- 1995 Cavalier fuel pump
- While driving my 92 cavalier it shuts off
- Stalling
- Re: problems with a 98 Cavy.
- exhaust upgrade
- 2000 Cavy Engine
- leaking head gasket.
- What does the fuel filter look like???
- integra
- 2000 cavakier stalling,driving me crazy
- engine line
- 1990 Cavalier Z24 3.1L V6 Engine Trouble
- is this right!?
- Cavy Engine?
- Scrolling LED Sign
- '94 Cavalier RS
- performance chips
- reverse lights
- gauge wiring
- paint job
- speedometer cable
- 95 cavi z24 2.3 ?
- gauge bezel
- Z24 won't Start, need advice, mechanic can't figure it out
- painting stock bumpers ?!?
- Cavalier Exhaust ? O2 sensor delete w/ magnaflows and headers
- LEDs
- RIP Cavaghini 1991-2004
- Cai
- body kit for sale
- oil pressure problems on my 87 cavy
- 04 cavalier gauges
- so i got this car
- Stock Hp
- molding
- mechanics are stumped on my 89 2.0L 4cyl. Cavy
- Lotsa Questions (A/C, Kits, etc)
- how the hell!!!
- coilovers or lowering springs?
- Ecotech engine blows
- New person needs help!
- Cavy Vs J-body Kill stories
- V6 Twin Turbo Cavy??
- Some new pics my 2002 LS Sport
- 2002 mpg?
- 89 Cavy. no one knows what's wrong with my stupid car!!!
- why is it so good
- Noisy air intake
- Nitrous?
- 2000 Cavalier Z24 Tranny Trouble
- 1989 Z24 Motor Problem
- Stupid Cavy
- 1989 Cavalier (ready to set my car on fire!!!!)
- Cavalier 2000 fuel filter
- mechanics stunned! 1989 Cavalier dies/won't start/won't stay running
- Engine Swap Compatibility
- ecotec swap please help
- how much is an ecotec worth?
- Cabin Air Filter
- cavalier or celica???
