View Full Version : Cavalier
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31
  1. two 1993 3.1L identical wagons 4 sale
  2. Removal of Headlights
  3. 2001 Stereo switch...
  4. lights
  5. oil thickness
  6. 96 ford taurus electrical problem
  7. Gas Guage
  8. door panel (carpe)
  9. stereo problems
  10. kills
  11. Rookie questions
  12. Bigger Fuel injectors?
  13. turbo??
  14. Engine computer
  15. Thermostat installation
  16. What is fed through this fuse?
  17. 97 cavalier left turn signal light need bulb replacement
  18. lagging in second
  19. 2.4 to a 1996 cavalier
  20. 91 Cav automatic stalling at stops
  21. Throttle body cleaning
  22. shift knob
  23. Misc. 03 Cav Parts for sale (pics)
  24. 92 Cavalier Ground up remake project need everyones ideas and suggestions
  25. Toucan/Ractive RAM Air... Any Good?
  26. Wheels for 88 z24?
  27. 2.8 not getting spark.
  28. Finally! Pics of the improved "DeceptiCav" !
  29. header frying my car
  30. 82 cavalier
  31. Chevy Racing Sticker on rear (removal)
  32. Squeaky when braking (new brakes)
  33. Do it yourself fuel injection cleaning kit?
  34. try to explain this problem!!!
  35. 89 cavalier backfireing, tried evrything, please help!
  36. 90 2.2 automatic "chews through" starters
  37. removal of balance shafts
  38. how tos
  39. will swapping out doors from a 93 cavalier RS to a 91 z24 work
  40. just died
  41. Vibration while turning and accelerating.
  42. last try to fix my cav
  43. Alittle drag
  44. aftermarket parts for 2.4?
  45. PCV Valve on 87 cavy
  46. Stall problem
  47. Re: 98 overheating problem
  48. 1991 Chevy Cavalier Engines! Please Reply......
  49. how many miles is an oil pump good for?
  50. when to replace 94 timing chain
  51. fuel pressure regulator/theft light
  52. crank sensor
  53. muffler sounds
  54. 03 Cav oil change question
  55. Innocent friend with a cavi
  56. Please Help - Cav refuses to start
  57. Cav is problem!!!
  58. 02 Cavalier Engine Issues
  59. Key problem...anyone else?
  60. Lowering Kit installation.
  61. A few speaker / amp problems.
  62. overheat
  63. no fire 93 cavalier 2.2
  64. ETS how to turn it off?
  65. aftermarket wheels and tires need sizes
  66. '93 cavalier. ABS light comes on. Troubles Starting the vehicle
  67. exhaust systems???
  68. '96 Tach Problems (HELP)
  69. Cavi for sale
  70. Dash removal
  71. dumb question
  72. My 88 z24
  73. Head Gasket Leak
  74. Hard Wire Cavalier Cooling Fan
  75. 2000 Z24 Won't Start!!!
  76. Leaking gasket
  77. Opinion on my Engine Bay / Mesh Grillwork
  78. oil change
  79. 1998 Cavalier clutch/transmission problem
  80. Gtp engine
  81. I'm retarded!
  82. 350 small block
  83. Need Help Finding Turbos
  84. Advice about non factory radios
  85. drivetrain problem
  86. 95 2.2 liter engine miss
  87. Gauge needles
  88. turn signal switch problem 92 2dr Cav
  89. rubber to metal??
  90. Disabling SIR (Air bag) system
  91. Sound system question
  92. New motor maybe
  93. what should i get? help plz
  94. anti-ignition system pb
  95. 99 Problems
  96. starting problem
  97. turbo on a 01 z24
  98. Pulling engine
  99. Electrical issues w/my '98 - Help!
  100. power window on convertable
  101. Cavalier Won't shut off!
  102. Engine For Sale
  103. 2002 Problems
  104. 87 oil pressure regulator
  105. just a question
  106. coil/ignition module replacement 1992 cavalier
  107. new intake
  108. Cavalier BodyKit In Need (Help)
  109. Manual Transmission Problem
  110. ANyone Need An imperfect 91?
  111. Strange "Warm Weather" Problem
  112. 1995 Cavalier fuel pump
  113. While driving my 92 cavalier it shuts off
  114. Stalling
  115. Re: problems with a 98 Cavy.
  116. exhaust upgrade
  117. 2000 Cavy Engine
  118. leaking head gasket.
  119. What does the fuel filter look like???
  120. integra
  121. 2000 cavakier stalling,driving me crazy
  122. engine line
  123. 1990 Cavalier Z24 3.1L V6 Engine Trouble
  124. is this right!?
  125. Cavy Engine?
  126. Scrolling LED Sign
  127. '94 Cavalier RS
  128. performance chips
  129. reverse lights
  130. gauge wiring
  131. paint job
  132. speedometer cable
  133. 95 cavi z24 2.3 ?
  134. gauge bezel
  135. Z24 won't Start, need advice, mechanic can't figure it out
  136. painting stock bumpers ?!?
  137. Cavalier Exhaust ? O2 sensor delete w/ magnaflows and headers
  138. LEDs
  139. RIP Cavaghini 1991-2004
  140. Cai
  141. body kit for sale
  142. ok, i need some help now
  143. oil pressure problems on my 87 cavy
  144. 04 cavalier gauges
  145. so i got this car
  146. Stock Hp
  147. molding
  148. mechanics are stumped on my 89 2.0L 4cyl. Cavy
  149. Lotsa Questions (A/C, Kits, etc)
  150. how the hell!!!
  151. coilovers or lowering springs?
  152. Ecotech engine blows
  153. New person needs help!
  154. Cavy Vs J-body Kill stories
  155. V6 Twin Turbo Cavy??
  156. Some new pics my 2002 LS Sport
  157. 2002 mpg?
  158. 89 Cavy. no one knows what's wrong with my stupid car!!!
  159. why is it so good
  160. Noisy air intake
  161. Nitrous?
  162. 2000 Cavalier Z24 Tranny Trouble
  163. 1989 Z24 Motor Problem
  164. Stupid Cavy
  165. 1989 Cavalier (ready to set my car on fire!!!!)
  166. Cavalier 2000 fuel filter
  167. mechanics stunned! 1989 Cavalier dies/won't start/won't stay running
  168. Engine Swap Compatibility
  169. ecotec swap please help
  170. how much is an ecotec worth?
  171. Cabin Air Filter
  172. cavalier or celica???
  173. Can someone please tell me how to get the dash off of my 2002 cavalier.
  174. Check Engine Light
  175. Fuel pump - rattling at idle.
  176. Help
  177. To All Who Want Turbo 4 Cavalier
  178. 3.1 mega problem
  179. Fire Fire Fire
  180. cavalier body work
  181. white smoke out tail pipe
  182. 98 Cav headlights
  183. 97 sunfire / No headlights
  184. Best Catback system?
  185. clear headlights and taillights
  186. Cigarette Lighter
  187. neon license plate wiring
  188. LT1 intake manifold
  189. Homemade Air Intake
  190. help me plz
  191. IAC on a 1987 convertable.
  192. New Cavalier
  193. % cav 5sp From auto... will it affect rev limiter
  194. cavalier anti theft light - wont stay running
  195. High Revs @ Stop
  196. cav vs. accord
  197. Please Help 99 Cavalier
  198. Have a blown head gasket? Read this.
  199. How do I find an Interior Light relay?
  200. Cavalier Parts 4 Sale
  201. 04 underbody light help
  202. tested the rx-8 waters?
  203. b&m shift plus kit
  204. Guage color?
  205. Lifter noise??? #2
  206. I give up.
  207. 99 Cavalier Lifter Noise
  208. which catback is the best?
  209. WTB: Carpet for 93Z
  210. new bumper
  211. Filling in the Z-24 Side Molding
  212. Need Engine Swap Help QUICKFAST
  213. body kit installion
  214. Polished Wheels
  215. Parking Brake Swap
  216. whats a good system to get
  217. Odometer light in my 87 convertable cavalier
  218. 2.2 to 2.4 z24
  219. need 91 bodykit
  220. Wing :( Help
  221. k car engine swap
  222. Engine Swap
  223. Can the seat Head Rests on an 03 be removed??
  224. Intakes???
  225. speed limiter?
  226. RCA outs in Delco?
  227. How do I get my dash off to replace my stereo?
  228. possible electrical/charging problem
  229. Problem with turn single / brake light
  230. side molding and vinyl
  231. from 105 to 80
  232. cheapest mod??
  233. Head and Cam on ecotec
  234. How to get horsepower from an 89 2.8
  235. What size are the 03 door speakers?
  236. want newer car!!!
  237. wont start /anti theft light flashing
  238. kill stories
  239. Oil change....mistake???
  240. Wanted: 2002 16" factory alloys
  241. New guy with question
  242. replacing shifter knob on automatic
  243. blinking odometer and ETS light
  244. 94 cruise control
  245. 98 cavalier exhaust
  246. spark plugs
  247. sub mounting
  248. Z24 88 won't start!
  249. 04 Cavalier
  250. APC glow guages
