View Full Version : Cavalier
- 94 cavalier 2.4l abs light battery drain
- Header and Cat for Cavalier
- no spark in 90 z24
- Clicking sound - lurching, no power
- Radiator cause windows to fog up?
- Sweet Stuff
- 1995 Cavalier trunk release
- DRIFT kit ?
- FS: 1989 RS Coupe $500
- Is this dealer trying to take me for a ride?
- Rear Hub Bearing ??
- base model - z22 - z24?
- o2 sensor help
- Simple question. How many quarts?
- New to the cavalier world
- Engine Light and Heat problems
- Just Painted! ....check engine light
- Lowering My 96 Cavalier??
- 1994 z24 convertible, good idea?
- Lowering springs
- Satinless Steel Cat back exhaust
- Wow!!!!!!!!!!!!!!
- My car has been in storage for a few months but when I start it up and try to reverse
- rusty bolts
- Weird Noise
- New CD Player problems
- '98 2.4L Timing chain tensioner shoe... help
- 2001 can't decide on a gear
- Idle Learn Procedure
- no spark on 86 cavalier
- cavy exhaust/intake info. read before moding
- HELP! Got a high pitched whistle 2000 Cav
- Clutch/shifting problems
- Modding me car
- Gas smell....never a good thing
- Exhaust System for 96 Cavalier
- water leak in passenger side footwell
- Water Temp problem
- just a little question....
- Brake line replacement
- Signal lights aren't working!!
- Can't move passenger seat forward/backward
- Besides coilovers
- where is the oil pressure sensor on a '95?
- loose Steering wheel
- Gear Grinding? Please Help
- interior painting
- horn, interior light, and no dinging noise
- help this young lady.... with foglights?
- help - water damage
- HELP! Confusing Problem
- ecotec
- Should i stay or should I go
- High performance ignitions
- overheating probs plz help asap
- is it worth it? cavi drivers opinion please...
- Lowering The cav
- dash board removal
- misfire/camshaft/crankshaft
- 1996 Cavalier Convertible
- door panels
- exhaust system
- motor starter problem
- Cavalier value?
- inexpensive upgrades
- Blue Neons
- backup lights and parking brake ?'s
- '97 Cavalier Wiper Arm Removal - Help!
- Crashed the Cavi, need opinions!
- wipers just quit
- crank.. no start! fart!!
- HELP!! Problems with my A/C!
- 92 3.1 oil pressure sensor location
- Engine Swap
- check engine light appears when immediate braking.
- Please Help!!!
- HID for cavaliers
- rough idle
- Would this (link inside) be the best for an '03 Intake?
- Car staggers on acceleration intermittently.
- No lowbeam headlights
- tranny mount bolt broken
- paint for door handles...
- E-turbos
- undercar lighting
- 2001 Cav-2.4L - CRANK
- 91 cavalier many questions
- Please help with specs
- Rear Dash
- Plastic trim thingies
- warning light on panel
- Are headers really worth the money?
- 2002 Cav LS resonator?
- 00 z smokin when start but thats it.
- Auto to Manual?!
- Throttle Body Induction/Spacer 02' Z24?
- This is a very good find
- Cav. vs. Civic
- ecotech
- 94 cavalier will not shift into 3rd most of time
- Cavalier body kit Instalation
- key wont turn
- 00 Cav revving high at idle
- Brakes/ ABS light on a 98 Cavy.
- very cool thing about Cavalier
- how do I take the the govenor off ?
- 2002 2.2L Ecotech Cavy exhaust?
- cruise control don't work
- 2001 headlight alignment
- Master Mechanics! Can Faulty oil pressure sending unit cut both fuel and spark?
- cavy z24 vs talon tsi
- Gas gauge problem
- 96 2.2 0-60 In 11.3 Is It Good R Bad?
- Torque converter solenoid unplugged....
- '97 Cavalier Body Kit Installation Questions
- Humming...alternator or water pump?
- Starts but won't run more than 3 seconds- 96 Cavi
- Wiring diagrams
- Stall Problem
- HELP!! 95 Cavi no start no fuel no spark turns over
- Stalling problems on an 84
- Spoiler Help
- '02 Z24 Specs... where?
- Where Can I Get A Kit In Canada!!!???
- Cavi will not start, turns over, no fuel, no spark
- '90 Cavalier...changing ignition lock
- My Inner Ricer....
- my car won't start; please help!
- emission test with catback
- 91 Cavalier dash light problems
- 2.4L Cavy Rough Runnin
- Turbo For 2004 Cav from GM
- Turbo or Supercharger
- In Need Of A Good Mechanic!!
- http://www.cavalierracing.com/board/
- wireing neons
- Cheap Brake Pads
- 2.2 Ecotec Anti drainback Valve For Oil Filter
- Help! my car wont start!
- Motor Oil & Coolant removal
- short throw
- Load clicking from motor plz help!!!
- 2 brake lights not working, third brake light works
- emission tests?
- will it fit my 02?
- 97 cav ets off, engine light on
- want to lower my z
- radiator
- Running Rough
- does anybody know?
- cavi z24 vs. v6 mustang
- Colored Dashboard
- 2nd Gen Cavy convertible-Moldy carpet problem
- door panels
- dashboard color
- GTA people 17 inch wheels for sale.
- fan not working
- 91 Cav z24 Overheating Problem!
- VL and RS
- radio will not shut off when car turned off
- Can anyone help me??
- engine stalls......help please
- Want a little more power - 02 Z24
- noisy tranny
- Antifreeze In Fuel
- 2001Chev Cavalier
- 99 Cavalier won't start
- Motor Mounts '98 and pvc valve
- factory power windows not working properly
- Dashboard trim in different color where can i get it?
- '01 Cav Popping Sound!
- Exterior on 2002 Help!!
- 1994 Chevy Cavalier Engine Quesiton
- Cavalier Drivers and Racers
- ruff idle
- Need help with front speakers for a cavalier
- lost ignition key!
- 2.2L into 2.4L/2.3L
- AirBag Light
- Front rotors warped AGAIN!!!
- 1995 Cavalier high temp problem
- Will a 2.2 work
- Suspension problems
- random question about factory radio
- spark plug help
- 97 Cavalier maintenance
- Headrest won't budge!
- 97 Cav - ETS Off, Chk Eng, Gear Jerking
- stats
- air conditioner not totally working
- Was this a good deal?
- 02 shiftknob
- Fuel Gage Broken
- Couple of 2000 Cavalier Z24 Questions
- speakers
- please help!!
- need more power
- Auto to Standard conversion/What do I need?
- 94 rolls in park.
- 91 cav. floorboard soaked...A/C just serviced...any connection ?
- please help me
- 86 Cavalier starter problem
- Please help!!!!
- 275 Horsepower Eco-tec 2.2
- 1998 cavalier z24 - need geqar shift recommendations
- 93 Z24 runs rough most of the time with bad exhaust fumes?
- Tenzo R Racing Seats in 02 Cavalier..
- 93 Cav, Wont start???
- "add coolant" light stays on after coolant drain & refill
- i hate stock tails
- 01 z24 governer
- Any tricks to opening the Radiator plug (Petcock)
- replace fuel inj filter
- service engine light turn on!
- 02 carbon fiber hood on an 04
- 99 cavalier radio chimes- need info please
- Need help on 87 Cav and parts to sell
- questions bout 02 Cavalier
- stalled while driving
- humming
- Any1 use Prestone Flush and Fill kit on a 2.2L
- Cavalier fender
- Help!!!!!!!!!!!!!!!!!!!!!
- 88 2.8L cavalier, 43 trouble code?
- Running BAD
- Cavalier confusion
- What's wrong with my 90' cav???
- What To Do Next
- 1989 Cavalier 4 Cyl. 2.0L
- WTB: Trunk Lid
- parking lights stay on
- Racing Seats for sale
- blown head gasket?
- rims
- Why is my cavalier bucking?!
- Air Bag Light
- Fuel Pump Breaker Switch?
- 91 cavalier 2.2 wont stay running
- Just got 1st car (89 Cav). Want to supe up! What do you suggest? Here's some stuff...
- Free car
- Hub Bearing?
- Re: brake issues on a 98 Cavy
- Serpentine Belt
- K&N GOLD SERIES OIL FILTER.
- Best Performance
- Interior console help
- ecotec or twin cam?
- 1996 Cavalier Ran out of gas!
- Need help with shift knob
- woofer vibration question
