View Full Version : Cavalier
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31
  1. Sweet Stuff
  2. 1995 Cavalier trunk release
  3. DRIFT kit ?
  4. FS: 1989 RS Coupe $500
  5. Is this dealer trying to take me for a ride?
  6. Rear Hub Bearing ??
  7. base model - z22 - z24?
  8. o2 sensor help
  9. Simple question. How many quarts?
  10. New to the cavalier world
  11. Engine Light and Heat problems
  12. Just Painted! ....check engine light
  13. Lowering My 96 Cavalier??
  14. 1994 z24 convertible, good idea?
  15. Lowering springs
  16. Satinless Steel Cat back exhaust
  17. Wow!!!!!!!!!!!!!!
  18. My car has been in storage for a few months but when I start it up and try to reverse
  19. rusty bolts
  20. Weird Noise
  21. New CD Player problems
  22. '98 2.4L Timing chain tensioner shoe... help
  23. 2001 can't decide on a gear
  24. Idle Learn Procedure
  25. no spark on 86 cavalier
  26. cavy exhaust/intake info. read before moding
  27. HELP! Got a high pitched whistle 2000 Cav
  28. Clutch/shifting problems
  29. Modding me car
  30. Gas smell....never a good thing
  31. Exhaust System for 96 Cavalier
  32. water leak in passenger side footwell
  33. Water Temp problem
  34. just a little question....
  35. Brake line replacement
  36. Signal lights aren't working!!
  37. Can't move passenger seat forward/backward
  38. Besides coilovers
  39. where is the oil pressure sensor on a '95?
  40. loose Steering wheel
  41. Gear Grinding? Please Help
  42. interior painting
  43. horn, interior light, and no dinging noise
  44. help this young lady.... with foglights?
  45. help - water damage
  46. HELP! Confusing Problem
  47. ecotec
  48. Should i stay or should I go
  49. High performance ignitions
  50. overheating probs plz help asap
  51. is it worth it? cavi drivers opinion please...
  52. Lowering The cav
  53. dash board removal
  54. misfire/camshaft/crankshaft
  55. 1996 Cavalier Convertible
  56. door panels
  57. exhaust system
  58. motor starter problem
  59. Cavalier value?
  60. inexpensive upgrades
  61. Blue Neons
  62. backup lights and parking brake ?'s
  63. '97 Cavalier Wiper Arm Removal - Help!
  64. Crashed the Cavi, need opinions!
  65. wipers just quit
  66. crank.. no start! fart!!
  67. HELP!! Problems with my A/C!
  68. 92 3.1 oil pressure sensor location
  69. Engine Swap
  70. check engine light appears when immediate braking.
  71. Please Help!!!
  72. HID for cavaliers
  73. rough idle
  74. Would this (link inside) be the best for an '03 Intake?
  75. Car staggers on acceleration intermittently.
  76. No lowbeam headlights
  77. tranny mount bolt broken
  78. paint for door handles...
  79. '98 Cavalier belt tensioner bolt HELP!
  80. E-turbos
  81. undercar lighting
  82. 2001 Cav-2.4L - CRANK
  83. 91 cavalier many questions
  84. Please help with specs
  85. Rear Dash
  86. Plastic trim thingies
  87. warning light on panel
  88. Are headers really worth the money?
  89. 2002 Cav LS resonator?
  90. 00 z smokin when start but thats it.
  91. Auto to Manual?!
  92. Throttle Body Induction/Spacer 02' Z24?
  93. This is a very good find
  94. Cav. vs. Civic
  95. ecotech
  96. 94 cavalier will not shift into 3rd most of time
  97. Cavalier body kit Instalation
  98. key wont turn
  99. 00 Cav revving high at idle
  100. Brakes/ ABS light on a 98 Cavy.
  101. very cool thing about Cavalier
  102. how do I take the the govenor off ?
  103. 2002 2.2L Ecotech Cavy exhaust?
  104. cruise control don't work
  105. 2001 headlight alignment
  106. Master Mechanics! Can Faulty oil pressure sending unit cut both fuel and spark?
  107. cavy z24 vs talon tsi
  108. Gas gauge problem
  109. 96 2.2 0-60 In 11.3 Is It Good R Bad?
  110. Torque converter solenoid unplugged....
  111. '97 Cavalier Body Kit Installation Questions
  112. Humming...alternator or water pump?
  113. Starts but won't run more than 3 seconds- 96 Cavi
  114. Wiring diagrams
  115. Stall Problem
  116. HELP!! 95 Cavi no start no fuel no spark turns over
  117. Stalling problems on an 84
  118. Spoiler Help
  119. '02 Z24 Specs... where?
  120. Where Can I Get A Kit In Canada!!!???
  121. Cavi will not start, turns over, no fuel, no spark
  122. '90 Cavalier...changing ignition lock
  123. My Inner Ricer....
  124. my car won't start; please help!
  125. emission test with catback
  126. 91 Cavalier dash light problems
  127. 2.4L Cavy Rough Runnin
  128. Turbo For 2004 Cav from GM
  129. Turbo or Supercharger
  130. In Need Of A Good Mechanic!!
  131. http://www.cavalierracing.com/board/
  132. wireing neons
  133. Cheap Brake Pads
  134. 2.2 Ecotec Anti drainback Valve For Oil Filter
  135. Help! my car wont start!
  136. Motor Oil & Coolant removal
  137. short throw
  138. Load clicking from motor plz help!!!
  139. 2 brake lights not working, third brake light works
  140. emission tests?
  141. will it fit my 02?
  142. 97 cav ets off, engine light on
  143. want to lower my z
  144. radiator
  145. Running Rough
  146. does anybody know?
  147. cavi z24 vs. v6 mustang
  148. Colored Dashboard
  149. 2nd Gen Cavy convertible-Moldy carpet problem
  150. door panels
  151. dashboard color
  152. GTA people 17 inch wheels for sale.
  153. fan not working
  154. 91 Cav z24 Overheating Problem!
  155. VL and RS
  156. radio will not shut off when car turned off
  157. Can anyone help me??
  158. engine stalls......help please
  159. Want a little more power - 02 Z24
  160. noisy tranny
  161. Antifreeze In Fuel
  162. 2001Chev Cavalier
  163. 99 Cavalier won't start
  164. Motor Mounts '98 and pvc valve
  165. factory power windows not working properly
  166. Dashboard trim in different color where can i get it?
  167. '01 Cav Popping Sound!
  168. Exterior on 2002 Help!!
  169. 1994 Chevy Cavalier Engine Quesiton
  170. Cavalier Drivers and Racers
  171. ruff idle
  172. Need help with front speakers for a cavalier
  173. lost ignition key!
  174. 2.2L into 2.4L/2.3L
  175. AirBag Light
  176. Front rotors warped AGAIN!!!
  177. 1995 Cavalier high temp problem
  178. Will a 2.2 work
  179. Suspension problems
  180. random question about factory radio
  181. spark plug help
  182. 97 Cavalier maintenance
  183. Headrest won't budge!
  184. 97 Cav - ETS Off, Chk Eng, Gear Jerking
  185. stats
  186. air conditioner not totally working
  187. Was this a good deal?
  188. 02 shiftknob
  189. Fuel Gage Broken
  190. Couple of 2000 Cavalier Z24 Questions
  191. speakers
  192. please help!!
  193. need more power
  194. Auto to Standard conversion/What do I need?
  195. 94 rolls in park.
  196. 91 cav. floorboard soaked...A/C just serviced...any connection ?
  197. please help me
  198. 86 Cavalier starter problem
  199. Please help!!!!
  200. 275 Horsepower Eco-tec 2.2
  201. 1998 cavalier z24 - need geqar shift recommendations
  202. 93 Z24 runs rough most of the time with bad exhaust fumes?
  203. Tenzo R Racing Seats in 02 Cavalier..
  204. 93 Cav, Wont start???
  205. "add coolant" light stays on after coolant drain & refill
  206. i hate stock tails
  207. 01 z24 governer
  208. Any tricks to opening the Radiator plug (Petcock)
  209. replace fuel inj filter
  210. service engine light turn on!
  211. 02 carbon fiber hood on an 04
  212. 99 cavalier radio chimes- need info please
  213. Need help on 87 Cav and parts to sell
  214. questions bout 02 Cavalier
  215. stalled while driving
  216. humming
  217. Any1 use Prestone Flush and Fill kit on a 2.2L
  218. Cavalier fender
  219. Help!!!!!!!!!!!!!!!!!!!!!
  220. 88 2.8L cavalier, 43 trouble code?
  221. Running BAD
  222. Cavalier confusion
  223. What's wrong with my 90' cav???
  224. What To Do Next
  225. 1989 Cavalier 4 Cyl. 2.0L
  226. WTB: Trunk Lid
  227. parking lights stay on
  228. Racing Seats for sale
  229. blown head gasket?
  230. rims
  231. Why is my cavalier bucking?!
  232. Air Bag Light
  233. Fuel Pump Breaker Switch?
  234. 91 cavalier 2.2 wont stay running
  235. Just got 1st car (89 Cav). Want to supe up! What do you suggest? Here's some stuff...
  236. Free car
  237. Hub Bearing?
  238. Re: brake issues on a 98 Cavy
  239. Serpentine Belt
  240. K&N GOLD SERIES OIL FILTER.
  241. Best Performance
  242. Interior console help
  243. ecotec or twin cam?
  244. 1996 Cavalier Ran out of gas!
  245. Need help with shift knob
  246. woofer vibration question
  247. Coilovers
  248. 2000 2.2 Cavalier, Automatic...Upgrades!!
  249. z24 for sale
  250. xenon lights???
