View Full Version : Cavalier
- Brake dust
- I'm bored/ Where you from
- coolant
- motor swap
- bulb replacement
- Electrical Problem Maybe?
- help please
- bad experiences with turbo?
- 89 Z24 2.8L e-test help...fuel staying rich!
- No headlight
- Wiring
- 2003 Cavalier Engine dying occasionally
- Dirty Coolant Reservoir. Tricks, Tips?
- Need help with possible tranny problem?
- I got rear-ended
- Dash Light Problems... HELP
- Speakers
- I have a couple questions....
- location of rear main seal
- Just bought a 2002 z24, and I'm pretty stoked!
- Racing Seats And Harnesses (HELP!)
- Module Gasket
- 3.1 throttle body
- 94 cavalier abs light
- has anyone used the eibach (1.7" front 2.3" rear) sportlines?
- Radiator or Gasket??
- head gasket leak
- what?
- 1999 cavalier hard starting when engine is hot?
- sterio problems....
- knock sensor location on 2.4 cavalier
- 98 cavy...wont start..
- painted dashes
- DRL relay help . . . .
- 1989 Cacalier Heater Core
- Oil leaking form back of block
- whats is the same as an 04
- HVAC lights for 04 Cavalier.....
- Any High Mileage Cavaliers With 2.2 Ecotec
- !!FOR SALE!! 1993 Cavalier RS, 131K Miles, Grand Rapids MI
- 3400 Swap
- Better MPG
- Cruise control
- I have a check gages light!!!!!!!!!
- 97 Cav, 2.2L
- fuel question for cavy
- Airbag question
- Supercharger and the ECU
- no power at full throttle
- power problems on 90 cavi
- Where's the fuel filter?
- Ebay Black Housing Projector Headlights
- 2004 Radio and Window tinting
- Drive belt help
- how do you remove the carpet on the door panel
- front upper blinker how in the heck to I change it... (1996)
- Knock sensor questions
- 95 cavalier
- No start and auto tranny quit at same time
- 98 Cavalier
- Heater fan won't change positions
- 2002 Cavalier Climate Control Problem..
- 93 cavalier rad hoses
- Autozone
- blend door???
- Question about a 1988 Cavalier RS
- Tachometer Wiring, Avoiding Adapter
- Any 1 have a picture of a 4 cylinder engine?
- 95 cavalier question?
- Remove 2.2 crank while in car??
- What direction does the engine come out of a 1991 cavalier 2.2?
- How to fold rear seats???
- Interior Paint?
- engines that will fit in a 96 2.2 cav
- Euro Tail Lights
- modding a 94
- interesting noise!
- What to to with my engine
- difference in transmissions
- transgo or any other brand shiftkit question
- Electrical problems..
- Dimming lights
- i once had a 1985 cavalier type-10
- bought 99 cavalier, need suggestions for maintenance
- Water in the trunk (1997)
- brake conversion ????
- Need help finding part....
- 96-2002 Vs. 2003-2004 Cavalier
- Question on Redline'ing
- Will 225/40/18 tires rub on a 04 LS?
- What is the normal temperature that a 1996 cavalier runs?
- Weird light in the dash
- Late Model Cavalier Cracked Dash Recall
- 99 Cavalier Hot engine!
- 18x8
- ground wire install?
- Help vibration problem
- 95 Coupe won't start
- Everything i need to lower
- antifreeze leak ?????
- power window motor in convertable (please help)
- Mystery Fuel Problem?
- few newbie questions
- please help!!!
- Interior Colors
- 1996 cavalier z22 info
- 96 97 cavavlier engines
- I need some help
- Spark plug wire question
- coil overs for sale brand new.......
- 93 Cavalier 2.2L has bad head
- Signal Lights
- New here
- Radio Question
- annoying squeak
- lambo doors?
- Muffler
- Car Running Hot
- Problem With Tach
- Tough Question: 94 Cav, 2.2L Cowl Hood Heater Fan Unit
- swapping exhaust system from sunfire
- adding in a tac
- Installing new speakers on a '93
- thermostat location on 97 z24
- cheap set of 17's
- transmission question
- Headlamps' power consumption...
- Turbo for a 92 cavalier?
- Will a 2.2 five speed work with a 2.4 ?
- best struts for the money..
- Exhaust change... problems??
- 1995 2.3L Quad 4 DOHC Cavalier Z24 cold air intake
- What other motor will fit in a 91,2.2 litre rs cavalier/Standard?
- suggestions for add on's
- Capatability of 2002 cavy and 2004.
- Sub Wiring Through Firewall
- battery question
- 2.2 engine swap
- 2.2 liter Ecotec
- 2.2 questions
- engine fan not starting
- 93 cavalier went kapoots
- 97 cavalier 2.2 change
- question about a 89 cavalier
- no more warning lights
- Brakes
- 93 Cavalier heater core
- '84 Cavalier Radio.............
- AutoMatic-Manual
- High performance Intake and other ?'s
- air fuel ratio guage help
- Somebody slap this guy for me
- need supercharger for 05 cavy help
- 96 cav horn not working,clicking
- '95 cavalier 2.2, no compression
- gas coming out of exhaust
- ABS and TC on 2000 Cavalier
- Front Main Seal on 92 Cavalier
- Help with subwoofer problem
- cluster change
- Please give me your expert opinions...
- Electrical System
- combo switch and other questions
- 88 Cavalier z24 5 speed stuck in neutral?
- horn
- brake adjustment
- need some help
- Error Code P0420 on 97 Chev Cavalier
- Conforming - Buying A Cavalier
- 2.2 Fuel Injectors
- only revs to 4 grand
- Rod knock in my 92 cav
- Piece of friggin shit Cavalier
- Help finding my ECU
- 93 cav heater core schematics?
- Wondering what seat to get...
- bcm diagrams plz we(JBO) need your help!
- Owner's Manual for 2002 Cavalier?
- HELP! Car Won't Run
- Sry Guys
- Mssive 92 Cav Oil leak
- 1992 Cavalier interior heaterfan blocked
- theft code
- Dealership don't know.. HELP
- bleeding coolant
- How easy is it to change the dash lights?
- 97 Cavalier Change Antifreeze
- Change Serpentine Belt HELP
- 96 Z24 Driver side window
- Need To Go Faster
- 1997 cav aftermarket cd player installation...
- 88 z24 cavalier 2.8L blown head gasket pls help ...
- Help needed quickly 94 cavalier
- *96*cav throttle body spacer 2.2l????
- Miles to Kilometers? Gauges.
- 96 2.4L Water Pump replacement
- 93 cavalier check engine light does not work
- 2.2 Motor
- 2005 Cavalier
- 96 Cav Bucking Question????
- 92 chevy cavalier.look here.
- Jegs Catback Exzaust??????
- 91 and 93 cavalier body kits.... WHERE can i find them???
- Someone PLEASE help me reset my clock!
- Cavalier Problems 1988/1997
- 92 cavalier runs worse after motor rebuild
- automatic transmission- reverse gear is gone!
- 94 cav died on the hwy. Won't start now!
- conversion kit
- 1997 cav factory radio......
- Engine noise while turning
- 92 cavalier need some help
- PO420 code
- Changing ABS Pads
- 92 cavalier power window removal
- 1994 Chevy Cavalier, just brought it...
- Race Question???
- is this worth it?
- 2.2L swap for a 2.4L
- Help needed in Radiator Replacement
- Parting out 96 cavalier
- Bright and Dims not working right on 2004
- Rear Rotors are stubborn, wont come off
- where do i take my 96 cavalier
- 2000 Cavalier just dies
- replace cluster?
- question about o2 sensors and oil
- Rag Tops?
- Carbon Fiber Hood?
- wheel bearing???
- help removing radiator fan?
- Shaving the emblems off...
- automatic stuck in nuetral?
- just got a cavalier
- Name for my Cavy?
- 95 Fuel pump work in 96?
- Car "Newbie" and his problems
- head gasket
- Problems with wiring....
- Who would win?
- Engine Swap 2.8 to 3.1
- Help a newbie
- Cooling fan prob
- coolant leak in my 93 cavy
- where to buy crank for 1992 2.2
- 1997 cavalier motor upgrade
- Nitrous question.
- OH NO! crossed wires?!
- 98 cav dash lights problem!!
