View Full Version : Cavalier
- audio systems and sound
- window crank
- Chopping the top off my 89 Z24
- expert advise on 2000 cavalier abilities
- 95 Chev Cavalier Rear Hub/Bearing Assembly
- 95 valve cover
- force fed cavi
- 94 Cavalier shuts off when put in gear
- release clutch and dies
- make manual door locks automatic
- body kit questions..
- OK to drive with ABS light always on?
- Car wont start (weird/techy)
- Looking for some opinions
- 01 Cavalier ECM
- no fire
- 99 Cav. ETS and ABS lights on
- Z24 Problems??
- insurance rate?
- idle to WOT miss or high idle miss HELP!
- 97 2.2 knocking
- research
- Cavalier 1996 ECU model number?
- trouble with taillights
- Rear View Mirror
- 98 cavalier won't start sometimes
- gas/oil smell
- Cavalier 95 ABS/Brakes parking and lights no ON!
- problem with car stalling when cold
- Quiz Time Kiddies
- Low Gas Mileage
- fuel pump?
- ABS Light
- Help!! '98 2.2L S10
- advanced questons on 2.4L specs...
- 1991 Cavalier Door & Seat Belt
- Max. Wheel size
- 99 Cavalier overheating
- Buick 2.2 same as Chevy?
- 2004 cavalier for sale
- Someone help fast
- Heater fan not working in all positions
- Intakes Engine light and Low Trac Warning???
- 98 cavalier 2.2 is it possible swap in a z24 in it?
- timimg chain????
- Brake upgrade?
- Check Engine
- how are early 90's z24's ?
- windshield wiper
- easier: supercharger or turbo
- Where and how do I change the oil cartridge filter on my 2k4 cavalier???
- 1984 Chevy Cavalier.......
- please help restore my 95 not joking
- ported 2.2 head
- Stats?
- 2000 Z-24 For Sale
- 2001 2.2 vs. 1998 civic 4dr. lx
- power window and sun roof convert?...
- Block Heater location
- pcv valve '97' 2.4L
- 3 speed automatic
- 92 losing rpm when accelerating
- compression ratio stock?
- Cold Air Intake
- alternator going bad?\???//?
- I need help about my PCV The hose is split and there is a vacuum leak?
- '98 2.2 Timing Chain
- 99 Z24 tail light (In the Spoiler)
- Seat Replacement
- Which Generation?
- stumbling or missing at low rpm
- need alternator for 2.2?
- Cavalier engine revving constantly
- Eco...
- cav v.s. escort
- Painting the Interior
- How to take interior roof piece out?
- Cav Radiator
- shit blah blah
- Side Markers
- do tire sizes make differances
- Rear Reflector Cover???
- Looking for 04 Cavalier owners in Indianapolis for interviews!
- 1993 Z24 parting out
- electric turbos ????????
- PCV Valve
- please help!!!
- ?s about the throttle body and fuel pump
- another lowering question
- Euro Taillights for 2004 Cavalier...
- '95 Z24 Cavalier ABS Light & Check Oil
- coolant light...help!!
- Emergency help. PO122
- two questions
- CD Player Backlights
- 94 heater core problem
- Silent but noticeable clunking noise
- no fuel ahh!
- How to change the bulbs??
- 2002 cav airbag control mod.
- where is my tach wire?
- Brake Lock-up
- Idle gets Higher when stopped
- need pictures of 95-97 or 98-99 jbody shifter assemblies
- Grill inserts
- geez
- Thinking of buying an "02 Cavalier, have questions.
- Apexi exhaust
- who would take it?
- Toyota Cavalier Tails
- gauge cluster conversion
- 2001 1/4 mile times anyone?..
- seems weak in low rpm's..
- I need help!!
- What kind of OBD2 Code reader to use.
- Intakes
- 95 with quad 4 starts and shuts down
- 98 z24 convertible top leaks
- fixing the 12v
- 2004 door pillar gauges
- 4 door MT cavy
- 97 cavalier - high pitch while turning left
- Fuel Filter Clip
- 2001 Daytime Running Lights
- remote wire color...
- Sticking Tranny
- Flushing radiator?
- Battery Terminals/Wires
- 1992 transaxle or linkage problems
- my car will not run
- Trunk latch broken...
- New rims
- Help! I just had an accident...
- power steering pump
- misfire?
- 2.4 quad four eng swap
- Interior Neons
- check engine light
- Grinding/stuck noise and check engine light?
- Sputtering
- Battery Light
- system from the stock radio..
- safety recall question
- Rad. Fan not working
- which of these mufflers would you reccomend..
- cant get my dash off
- 97 cavalier - spark plug wires
- 97 Cavalier Fuel problems
- 91 cav igntion problems
- 97 cavalier
- cavalier ground wires
- brakes recommendation
- Jeep 4.0 Engine Swap?
- Wtf
- Leaking Connection at Fuel Pressure Regulator
- 1995 Cavalier where is the horn?
- ground kit wires...
- Cavalier Lights/Wiring Problems
- Radiator leakage/overflow
- Car Starts light Shaking
- radio
- Factory Wiring info??
- Maaco
- 1999 Cavalier Cd Player
- What spark plugs to get?
- 55k miles. is it worth it to turbo?
- 01 tach install!!
- ets light
- what all do i need for a turbo?
- rattle under my 2001 cavalier when in second
- 2003 Cavalier Dies at Deceleration
- 1994 Cavalier Dying on Decelleration
- 1994 Cavalier Check Engine Code Reading
- 94 Z24 Logo's any one?
- How to replace non-automatic antenna
- Warped Rotor, or something worse?
- Keyless entry question
- Funny break problem
- Blitz Mesh Grille Question
- How much did your cavalier cost?
- terrible shaking
- 98 z24, turning off the engine
- 96 Cavalier Z24, Little problems, what are they?
- How much bolt on hp?
- z24 sound system
- clunking noise - front upper strut mounts?
- Air Rides
- Loose Wire?
- 02 Z24 Cyl #2 mis?
- 92 cavaleir brake/abs problem
- Short Shifters
- computer output gone wrong
- 2001 - Grinding, Rattling, Squeaking
- 96 Cavi 2.2 Small Accident - Now won't start.
- blown fuse?
- 2000 Falling apart?
- 00 tail lights on an 02
- 2000 Cavalier Shaking in Idle, Stalled in Park
- interior neone lighting
- Front End Parts
- i kno Z24............Z22?
- 90 z24 that doesn't have door sensors.
- 2000 Cavalier brakes pull car.....
- spark, but no fuel and no start
- 98 z fan and a/c not working
- still wont start
- 89 cav. ball joint
- 97' Cav with near stall during medium to high acceleration
- 89 cav. door won't open from outside
- Engine and Tranny swap
- Day Time running Lights
- coolant leak! Need help!
- brake kits
- 98 Cavalier brake probelm...help!
- Off subject
- Just Wanting Your Expert Opinions.
- How to: replace center console light on 2000 Cav?
- What would u recommend??
- 2 questions
- automatic shifters
- Just some random rambling
- cavi vs camry
- Remove 92 Cavalier Front Door
- 88 Z24 Fan Belt Change
- When to call it quits....
- front brake system suggestions
- 97 Cavalier toast variable fan speed cards...
- p1870 in a 97?
- Who makes a supercharger for the 1995 2.2l motor?
- Cold Air Intake Installation Question
- Fuse
- How Low Can I Go ?
- 1996 Cav PCM location, tach hookup
- spark plugs
- Headers for a 94 cav. rs 3.1 5 speed
- AT to MT conversion
- 1/4 mile times on a 03 cavalier
- Whats the best ways to add HP?
- High RPms.
- Replacing Coolant Surge Tank...
- 94 z24 needs lowering
- Non Tech, Will there be a 2005 Cavalier
- Lights
- Can't get rear drums off 2000 Cav.
- Misfiring at stoplights
- 94 cavalier 2.4l abs light battery drain
- Header and Cat for Cavalier
- no spark in 90 z24
- Clicking sound - lurching, no power
- Radiator cause windows to fog up?
