View Full Version : Cavalier
- what is wrong with my ABS!!!!
- Quick Question
- Farewell...
- 92 cavalier ignition control module interchange
- what would you guys recommend
- whats the stock horsepower?
- What's the best place to
- So I want a new....
- All 00+ J-bodies, concerning aftermarket stereos
- 03+ LS Sport Front Bumper Question
- Wiring for Rear 6x9 Speakers
- Dex-Cool
- Starting on '08
- Thanks for your help guys, Check this out.
- 1994 Cav Convertible
- 96 Cavalier Conv?
- Parking on an angle?
- Quarter Mile Predictions
- Just wanted to say farewell, sort of
- Slug mobile
- Need advice re: replacing seized 2.2l engine - esp. price
- Sea Foam Question...
- Ohh boy...
- licence plate filler on front bumper
- Short RAM Cai.. winter friendly?
- 2001 cavalier
- Bad idea?
- Factory Sunroof, can it be done?
- Having Intake installed
- Post Pics of your Ride and selves. Pt. 2
- Inline fuse
- help on using an ohm meter
- F#&K! Blew my FORTH ENGINE!
- Suspension Swap
- 2 much bass,not enuff music?
- Im Selling My Car
- Side Mirrors
- im sooo pissed!!!
- Finally, Check it out.
- Amp Wiring Kit
- 1971 charger 500 2000 cavy z24 5 speed
- Auto trans vs. Manual- Manual much faster?
- My Body Kit!
- Parting ways...
- 2002 Gauge System - Gear Selection Lighting
- 2001 Cavalier
- Wire Loom
- 04 Cav and a 01 S-10-Will the radios swap?
- Ahahaha. John Deere's finest LOL.
- Front Door Speakers??
- headlight assembly
- how to disable a theft system 99 z24
- where is trunk button???
- Lookin for performance parts 96 cavalier 2.4l
- Will this parts warranty transfer???
- Fog light trouble
- What's Your MPG?
- Wheel Lock
- Interior L.E.D's
- 92 2.2l fuel injector o rings
- Windshield washer pump-Pumping but no fluid
- 99 cavalier wont start
- windshield wipers get stuck, help!
- 98 Power Loss
- Is anyone else wondering
- Buzzing sound
- Coolant problem
- ABS light only comes on over 100km
- 2.2l valve noise when cold
- Check engine light -- what if it DOESNT come on?
- What do you think about lucas oil stabilizer?
- Thermostat
- Transmission trouble?
- Motor mount
- 97 cavalier overheating
- Haven't been here in awhile...
- Christmas present and need help!!!
- Under drive pully
- 1990 headlight problems
- Just a couple questions any help/insight wanted (Stereo+Body Kit)
- 2000 cavalier no fuel pump
- 4-gauge power wire?
- What you need for Neon Rear Disc Swap.
- knock
- Possible Solution for the 89 Z24 random stall
- In need of a sig!
- 97 Cavalier Idle Air Control?
- Tranny Swap
- 2002 chevy cavalier stereo install
- temp gauge and more...please help
- ABS brakes sensitive
- Which is better?
- '93 Cavalier Z24 3.1
- blue cold cathode lights
- Cold Air Intake
- Newbie question here
- What's up you clowns
- Cracked dash / seat belt
- Cavalier SS Ram Air Fiberglass Hood....
- backseat
- Front end swap?
- Headlight Bulbs
- need advice on subs/speakers
- Dual Exhaust Question?
- I need to put a tach in my 00' 2.2l ???
- 1993 Chevy Cavalier 2.2L 4 cyl
- Wiring CD DECK
- 1999 Cavalier Gauge Cluster
- freaking CD deck!!!
- 2004 cavalier dash
- windsheild
- drum to disc rear brakes
- Questions from a non sunfire/cav. guy
- 05 Cavalier Replace cluster bulbs with White or Colored bulbs
- Can anybody tell me what this is?
- 1991 Cavalier
- So I got this phone call...
- New Gauges. Whew.
- DRL's are gay
- Do Not Use B&m Shiftplus!
- Removing Quarter Panels
- Fast Car for sale
- 97 cavalier door dinger
- Trim question
- Subwoofers and Amp
- radio
- Loud knocking coming from engine
- Need key code for 99 cavalier
- cracked dash 2002 cavalier Z-24
- Headlight and High/Low Beams not coming on...daytime running lights on all the time
- Headlight Covers
- 2.2 l engine mount torque specs
- 1997 Cavalier ETC light
- blinkers question
- i need a turbo!!!
- parting out my cavalier...
- 99 z24 5 Speed shift linkage stuck
- New here
- Should I get these Rims
- Motor Swap
- 96 Caviler
- engine drop
- oil filter location 02 2.2 ecotech
- Updated Pics and a New Exhaust Clip
- BCM, what is it?
- Locktronics
- 2000 cavalier
- should i buy?
- any good
- 1998 cavalier
- 1996 Shifter
- '90 door panel
- Detailed Supercharger Instructions
- Cavalier series 1995 to ____?
- 1998 Cav vs 1994 Tercel
- Just recieved my HPTuners and Turbo Update!!!
- Fast Blinker Question
- dropping heat shield
- 1988 1994 strut compatibility?
- changing the auto transmission to manual
- tranny problem
- How to check clutch fluid level
- Replacing Clutch
- 97 Z24 - Airbag sensor (by Hood latch)
- Part Help
- Pulled Over by Police!
- 1989 Cavalier Z24 Vs. 1995 Honda Del Sol
- '99 Cavalier Dash Panel replacement
- Supercharger or Turbo?
- 1999 cavalier odd dash light?
- cobalt wing on cavalier???
- Change of weather.... noise
- Transmission oil
- The Midnight Blues
- looking for a 96 2.4L
- Catalytic converter
- suspension
- removed the side molding today!
- Installing wheel studs
- guess...
- Problem with automatic start
- what is the ABSOLUTE least i can expect to pay for a replacement radiator?
- Duplicolor vs. Krylon Paint
- What's the diffrence?
- passlock problem
- Installing a Bodykit
- CRJ's new ride...
- I painted the front end.Hows does it look
- subs
- Where should I stop?
- Maintenance
- hopeless
- Speakers..
- Da Beach!
- To buy or not to buy?
- Turbo Turbo...Im craving Turbo!
- 1992 Question
- $70 Cavy supercharger...pretty fishy.
- 02 cavalier w/4 wires on 6x9s
- Bought a Racing Wheel.....now what....confused?!
- Cavalier Fog Lights
- Cavalier Steering Wheel Removal
- Instrument cluster swap problem...
- HID Kit.......
- what the hell are u all doing with your cavaliers these days?
- 96 into a 92
- Steps to upgrade stock 2.2 Ecotec
- 94 engine vs 99 engine
- Cops, Go Suck A Lemon!!!! !@$#
- Will a 00-03 instument cluster work in a 99?
- Need a cylinder head for a 95 Cavalier z24
- 1989 -- 2.8 to 3.1 swap
- Mmmmm Wide body....
- Mandrel vs. Crimp piping
- Just to know ahead of time.
- Halossssssssssssssssssssssssssssss
- Having a hard time desiding...
- Interference motor or not?
- Shift Knob
- Neon Rear Disc swap outcome
- 1997 Chevrolet Cavalier
- where can i get parts??
- 88 wagon body kit???
- Car Chokin in Acceleration
- 94 a/c
- Didn't pass DEQ
- 97 Chevy Cavalier Coupe - Rear driver window pane
- Need help finding something.
- GUESS WHAT'S IN THE BOX and new manifold pics!!
- Muffler/Cat
- shocks/struts
- 2.2L to 2.4L swap - Can it be done?
- Thinking of Buying 2003 Cavalier
- Stoppers.... ;-P
- 1990 Z-24 timing chain
- need help 92 cavalier
- Boosting plan, tell me if im doing the right thing...
- running hot!!
- water pump in 3.1
- Life after J-Body...What Ive been up to
- 99 cavalier auto - anti-theft taking my time
- Cops, go suck a lemon.
- my new exhaust wOOt!
- intake for 2.4 L
- Mods for 02' z24 2.4L
- the what's in the box game
- Hmm
- tachometer to fit in this pod
- O2 Sensor
- nokya bulbs???
