View Full Version : Cavalier
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. 96 Cavalier Conv?
  2. Parking on an angle?
  3. Quarter Mile Predictions
  4. Just wanted to say farewell, sort of
  5. Slug mobile
  6. Need advice re: replacing seized 2.2l engine - esp. price
  7. Sea Foam Question...
  8. Ohh boy...
  9. licence plate filler on front bumper
  10. Short RAM Cai.. winter friendly?
  11. 2001 cavalier
  12. Bad idea?
  13. Factory Sunroof, can it be done?
  14. Having Intake installed
  15. Post Pics of your Ride and selves. Pt. 2
  16. Inline fuse
  17. help on using an ohm meter
  18. F#&K! Blew my FORTH ENGINE!
  19. Suspension Swap
  20. 2 much bass,not enuff music?
  21. Im Selling My Car
  22. Side Mirrors
  23. im sooo pissed!!!
  24. Finally, Check it out.
  25. Amp Wiring Kit
  26. 1971 charger 500 2000 cavy z24 5 speed
  27. Auto trans vs. Manual- Manual much faster?
  28. My Body Kit!
  29. Parting ways...
  30. 2002 Gauge System - Gear Selection Lighting
  31. 2001 Cavalier
  32. Wire Loom
  33. 04 Cav and a 01 S-10-Will the radios swap?
  34. Ahahaha. John Deere's finest LOL.
  35. Front Door Speakers??
  36. headlight assembly
  37. how to disable a theft system 99 z24
  38. where is trunk button???
  39. Lookin for performance parts 96 cavalier 2.4l
  40. Will this parts warranty transfer???
  41. Fog light trouble
  42. What's Your MPG?
  43. Wheel Lock
  44. Interior L.E.D's
  45. 92 2.2l fuel injector o rings
  46. Windshield washer pump-Pumping but no fluid
  47. 99 cavalier wont start
  48. windshield wipers get stuck, help!
  49. 98 Power Loss
  50. Is anyone else wondering
  51. Buzzing sound
  52. Coolant problem
  53. ABS light only comes on over 100km
  54. 2.2l valve noise when cold
  55. Check engine light -- what if it DOESNT come on?
  56. What do you think about lucas oil stabilizer?
  57. Thermostat
  58. Transmission trouble?
  59. Motor mount
  60. 97 cavalier overheating
  61. Haven't been here in awhile...
  62. Christmas present and need help!!!
  63. Under drive pully
  64. 1990 headlight problems
  65. Just a couple questions any help/insight wanted (Stereo+Body Kit)
  66. 2000 cavalier no fuel pump
  67. 4-gauge power wire?
  68. What you need for Neon Rear Disc Swap.
  69. knock
  70. Possible Solution for the 89 Z24 random stall
  71. In need of a sig!
  72. 97 Cavalier Idle Air Control?
  73. Tranny Swap
  74. 2002 chevy cavalier stereo install
  75. temp gauge and more...please help
  76. ABS brakes sensitive
  77. Which is better?
  78. '93 Cavalier Z24 3.1
  79. blue cold cathode lights
  80. Cold Air Intake
  81. Newbie question here
  82. What's up you clowns
  83. Cracked dash / seat belt
  84. Cavalier SS Ram Air Fiberglass Hood....
  85. backseat
  86. Front end swap?
  87. Headlight Bulbs
  88. need advice on subs/speakers
  89. Dual Exhaust Question?
  90. I need to put a tach in my 00' 2.2l ???
  91. 1993 Chevy Cavalier 2.2L 4 cyl
  92. Wiring CD DECK
  93. 1999 Cavalier Gauge Cluster
  94. freaking CD deck!!!
  95. 2004 cavalier dash
  96. windsheild
  97. drum to disc rear brakes
  98. Questions from a non sunfire/cav. guy
  99. 05 Cavalier Replace cluster bulbs with White or Colored bulbs
  100. Can anybody tell me what this is?
  101. 1991 Cavalier
  102. So I got this phone call...
  103. New Gauges. Whew.
  104. DRL's are gay
  105. Do Not Use B&m Shiftplus!
  106. Removing Quarter Panels
  107. Fast Car for sale
  108. 97 cavalier door dinger
  109. Trim question
  110. Subwoofers and Amp
  111. radio
  112. Loud knocking coming from engine
  113. Need key code for 99 cavalier
  114. cracked dash 2002 cavalier Z-24
  115. Headlight and High/Low Beams not coming on...daytime running lights on all the time
  116. Headlight Covers
  117. 2.2 l engine mount torque specs
  118. 1997 Cavalier ETC light
  119. blinkers question
  120. i need a turbo!!!
  121. parting out my cavalier...
  122. 99 z24 5 Speed shift linkage stuck
  123. New here
  124. Should I get these Rims
  125. Motor Swap
  126. 96 Caviler
  127. engine drop
  128. oil filter location 02 2.2 ecotech
  129. Updated Pics and a New Exhaust Clip
  130. BCM, what is it?
  131. Locktronics
  132. 2000 cavalier
  133. should i buy?
  134. any good
  135. 1998 cavalier
  136. 1996 Shifter
  137. '90 door panel
  138. Detailed Supercharger Instructions
  139. Cavalier series 1995 to ____?
  140. 1998 Cav vs 1994 Tercel
  141. Just recieved my HPTuners and Turbo Update!!!
  142. Fast Blinker Question
  143. dropping heat shield
  144. 1988 1994 strut compatibility?
  145. changing the auto transmission to manual
  146. tranny problem
  147. How to check clutch fluid level
  148. Replacing Clutch
  149. 97 Z24 - Airbag sensor (by Hood latch)
  150. Part Help
  151. Pulled Over by Police!
  152. 1989 Cavalier Z24 Vs. 1995 Honda Del Sol
  153. '99 Cavalier Dash Panel replacement
  154. Supercharger or Turbo?
  155. 1999 cavalier odd dash light?
  156. cobalt wing on cavalier???
  157. Change of weather.... noise
  158. Transmission oil
  159. The Midnight Blues
  160. looking for a 96 2.4L
  161. Catalytic converter
  162. suspension
  163. removed the side molding today!
  164. Installing wheel studs
  165. guess...
  166. Problem with automatic start
  167. what is the ABSOLUTE least i can expect to pay for a replacement radiator?
  168. Duplicolor vs. Krylon Paint
  169. What's the diffrence?
  170. passlock problem
  171. Installing a Bodykit
  172. CRJ's new ride...
  173. I painted the front end.Hows does it look
  174. subs
  175. Where should I stop?
  176. Maintenance
  177. hopeless
  178. Speakers..
  179. Da Beach!
  180. To buy or not to buy?
  181. Turbo Turbo...Im craving Turbo!
  182. 1992 Question
  183. $70 Cavy supercharger...pretty fishy.
  184. 02 cavalier w/4 wires on 6x9s
  185. Bought a Racing Wheel.....now what....confused?!
  186. Cavalier Fog Lights
  187. Cavalier Steering Wheel Removal
  188. Instrument cluster swap problem...
  189. HID Kit.......
  190. what the hell are u all doing with your cavaliers these days?
  191. 96 into a 92
  192. Steps to upgrade stock 2.2 Ecotec
  193. 94 engine vs 99 engine
  194. Cops, Go Suck A Lemon!!!! !@$#
  195. Will a 00-03 instument cluster work in a 99?
  196. Need a cylinder head for a 95 Cavalier z24
  197. 1989 -- 2.8 to 3.1 swap
  198. Mmmmm Wide body....
  199. Mandrel vs. Crimp piping
  200. Just to know ahead of time.
  201. Halossssssssssssssssssssssssssssss
  202. Having a hard time desiding...
  203. Interference motor or not?
  204. Shift Knob
  205. Neon Rear Disc swap outcome
  206. 1997 Chevrolet Cavalier
  207. where can i get parts??
  208. 88 wagon body kit???
  209. Car Chokin in Acceleration
  210. 94 a/c
  211. Didn't pass DEQ
  212. 97 Chevy Cavalier Coupe - Rear driver window pane
  213. Need help finding something.
  214. GUESS WHAT'S IN THE BOX and new manifold pics!!
  215. Muffler/Cat
  216. shocks/struts
  217. 2.2L to 2.4L swap - Can it be done?
  218. Thinking of Buying 2003 Cavalier
  219. Stoppers.... ;-P
  220. 1990 Z-24 timing chain
  221. need help 92 cavalier
  222. Boosting plan, tell me if im doing the right thing...
  223. running hot!!
  224. water pump in 3.1
  225. Life after J-Body...What Ive been up to
  226. 99 cavalier auto - anti-theft taking my time
  227. Cops, go suck a lemon.
  228. my new exhaust wOOt!
  229. intake for 2.4 L
  230. Mods for 02' z24 2.4L
  231. the what's in the box game
  232. Hmm
  233. tachometer to fit in this pod
  234. O2 Sensor
  235. nokya bulbs???
  236. Just did oil change-4 quart's?-5 quart's??
  237. StreetGlow( Optix ) Underbody Neon Lights
  238. 1994 Clutch
  239. removing radio
  240. Chervorlet Cavilair Starting Error
  241. windshield washing
  242. Exhaust/header wrap
  243. oil level sender connector
  244. New Shift Knob-Help please
  245. Bug Deflector or clear hood shield??
  246. Clear Lights Finally!!
  247. painting interior green and walmart sux
  248. Cavalier making strange noise
  249. 04 Cavalier-Odd color on dash and radio
  250. Mice & Cavaliers in same family?
