- Weird light in the dash
- Late Model Cavalier Cracked Dash Recall
- 99 Cavalier Hot engine!
- 18x8
- ground wire install?
- Help vibration problem
- 95 Coupe won't start
- Everything i need to lower
- antifreeze leak ?????
- power window motor in convertable (please help)
- Mystery Fuel Problem?
- few newbie questions
- please help!!!
- Interior Colors
- 1996 cavalier z22 info
- 96 97 cavavlier engines
- I need some help
- Spark plug wire question
- coil overs for sale brand new.......
- 93 Cavalier 2.2L has bad head
- Signal Lights
- New here
- Radio Question
- annoying squeak
- lambo doors?
- Muffler
- Car Running Hot
- Problem With Tach
- Tough Question: 94 Cav, 2.2L Cowl Hood Heater Fan Unit
- swapping exhaust system from sunfire
- adding in a tac
- Installing new speakers on a '93
- thermostat location on 97 z24
- cheap set of 17's
- transmission question
- Headlamps' power consumption...
- Turbo for a 92 cavalier?
- Will a 2.2 five speed work with a 2.4 ?
- best struts for the money..
- Exhaust change... problems??
- 1995 2.3L Quad 4 DOHC Cavalier Z24 cold air intake
- What other motor will fit in a 91,2.2 litre rs cavalier/Standard?
- suggestions for add on's
- Capatability of 2002 cavy and 2004.
- Sub Wiring Through Firewall
- battery question
- 2.2 engine swap
- 2.2 liter Ecotec
- 2.2 questions
- engine fan not starting
- 93 cavalier went kapoots
- 97 cavalier 2.2 change
- question about a 89 cavalier
- no more warning lights
- Brakes
- 93 Cavalier heater core
- '84 Cavalier Radio.............
- AutoMatic-Manual
- High performance Intake and other ?'s
- air fuel ratio guage help
- Somebody slap this guy for me
- need supercharger for 05 cavy help
- 96 cav horn not working,clicking
- '95 cavalier 2.2, no compression
- gas coming out of exhaust
- ABS and TC on 2000 Cavalier
- Front Main Seal on 92 Cavalier
- Help with subwoofer problem
- cluster change
- Please give me your expert opinions...
- Electrical System
- combo switch and other questions
- power steering pressure hose leak
- 88 Cavalier z24 5 speed stuck in neutral?
- horn
- brake adjustment
- need some help
- Error Code P0420 on 97 Chev Cavalier
- Conforming - Buying A Cavalier
- 2.2 Fuel Injectors
- only revs to 4 grand
- Rod knock in my 92 cav
- Piece of friggin shit Cavalier
- Help finding my ECU
- 93 cav heater core schematics?
- Wondering what seat to get...
- bcm diagrams plz we(JBO) need your help!
- Owner's Manual for 2002 Cavalier?
- HELP! Car Won't Run
- Sry Guys
- Mssive 92 Cav Oil leak
- 1992 Cavalier interior heaterfan blocked
- theft code
- Dealership don't know.. HELP
- bleeding coolant
- How easy is it to change the dash lights?
- 97 Cavalier Change Antifreeze
- Change Serpentine Belt HELP
- 96 Z24 Driver side window
- Need To Go Faster
- 1997 cav aftermarket cd player installation...
- 88 z24 cavalier 2.8L blown head gasket pls help ...
- Help needed quickly 94 cavalier
- *96*cav throttle body spacer 2.2l????
- Miles to Kilometers? Gauges.
- 96 2.4L Water Pump replacement
- 93 cavalier check engine light does not work
- 2.2 Motor
- 2005 Cavalier
- 96 Cav Bucking Question????
- 92 chevy cavalier.look here.
- Jegs Catback Exzaust??????
- 91 and 93 cavalier body kits.... WHERE can i find them???
- Someone PLEASE help me reset my clock!
- Cavalier Problems 1988/1997
- 92 cavalier runs worse after motor rebuild
- automatic transmission- reverse gear is gone!
- 94 cav died on the hwy. Won't start now!
- conversion kit
- 1997 cav factory radio......
- Engine noise while turning
- 92 cavalier need some help
- PO420 code
- Changing ABS Pads
- 92 cavalier power window removal
- 1994 Chevy Cavalier, just brought it...
- Race Question???
- is this worth it?
- 2.2L swap for a 2.4L
- Help needed in Radiator Replacement
- Parting out 96 cavalier
- Bright and Dims not working right on 2004
- Rear Rotors are stubborn, wont come off
- where do i take my 96 cavalier
- 2000 Cavalier just dies
- replace cluster?
- question about o2 sensors and oil
- Rag Tops?
- Carbon Fiber Hood?
- wheel bearing???
- help removing radiator fan?
- Shaving the emblems off...
- automatic stuck in nuetral?
- just got a cavalier
- Name for my Cavy?
- 95 Fuel pump work in 96?
- Car "Newbie" and his problems
- head gasket
- Problems with wiring....
- Who would win?
- Engine Swap 2.8 to 3.1
- Help a newbie
- Cooling fan prob
- coolant leak in my 93 cavy
- where to buy crank for 1992 2.2
- 1997 cavalier motor upgrade
- Nitrous question.
- OH NO! crossed wires?!
- 98 cav dash lights problem!!
- before i spend money, how about some opinions!
- knocking sound
- upholstering
- 96 2.2 Swap Not Running
- spark but no fuel, tried everything
- audio systems and sound
- window crank
- Chopping the top off my 89 Z24
- expert advise on 2000 cavalier abilities
- 95 Chev Cavalier Rear Hub/Bearing Assembly
- 95 valve cover
- force fed cavi
- 94 Cavalier shuts off when put in gear
- release clutch and dies
- make manual door locks automatic
- body kit questions..
- OK to drive with ABS light always on?
- Car wont start (weird/techy)
- Looking for some opinions
- 01 Cavalier ECM
- no fire
- 99 Cav. ETS and ABS lights on
- Z24 Problems??
- insurance rate?
- idle to WOT miss or high idle miss HELP!
- 97 2.2 knocking
- research
- Cavalier 1996 ECU model number?
- trouble with taillights
- Rear View Mirror
- 98 cavalier won't start sometimes
- gas/oil smell
- Cavalier 95 ABS/Brakes parking and lights no ON!
- problem with car stalling when cold
- Quiz Time Kiddies
- Low Gas Mileage
- fuel pump?
- ABS Light
- Help!! '98 2.2L S10
- advanced questons on 2.4L specs...
- 1991 Cavalier Door & Seat Belt
- Max. Wheel size
- 99 Cavalier overheating
- Buick 2.2 same as Chevy?
- 2004 cavalier for sale
- Someone help fast
- Heater fan not working in all positions
- Intakes Engine light and Low Trac Warning???
- 98 cavalier 2.2 is it possible swap in a z24 in it?
- timimg chain????
- Brake upgrade?
- Check Engine
- how are early 90's z24's ?
- windshield wiper
- easier: supercharger or turbo
- Where and how do I change the oil cartridge filter on my 2k4 cavalier???
- 1984 Chevy Cavalier.......
- please help restore my 95 not joking
- ported 2.2 head
- Stats?
- 2000 Z-24 For Sale
- 2001 2.2 vs. 1998 civic 4dr. lx
- power window and sun roof convert?...
- Block Heater location
- pcv valve '97' 2.4L
- 3 speed automatic
- 92 losing rpm when accelerating
- compression ratio stock?
- Cold Air Intake
- alternator going bad?\???//?
- I need help about my PCV The hose is split and there is a vacuum leak?
- '98 2.2 Timing Chain
- 99 Z24 tail light (In the Spoiler)
- Seat Replacement
- Which Generation?
- stumbling or missing at low rpm
- need alternator for 2.2?
- Cavalier engine revving constantly
- Eco...
- cav v.s. escort
- Painting the Interior
- How to take interior roof piece out?
- Cav Radiator
- shit blah blah
- Side Markers
- do tire sizes make differances
- Rear Reflector Cover???
- Looking for 04 Cavalier owners in Indianapolis for interviews!
- 1993 Z24 parting out
- electric turbos ????????
