View Full Version : Cavalier
- Car Starter T-Harness Question
- 2000 Cavalier Stalls Out & ?
- low RPM at stop
- girlfriends car driving me crazy with problems...or maybe its more so her
- coilovers
- Getting new car, need to know best engine
- Dimming lights problems??? Pls Help!
- chevy 350 small block
- Fuel Injector Installation
- my car is shaking when pressing brake pedal to stop at low speed
- Parts
- 2000 z24 speedo
- My cavalier ticks
- 2000 Cavaler won't start!!! HELP!!!
- need an all black interior
- Parking brake ?????
- 2002 Cavalier Heating problems
- where is the radiador drain plug
- TB Spacer
- Motor Mounts
- drivers side window
- Hoods
- heating problems
- need to know where to find a new engine?
- blown head gasket - how much time -what else
- chevy cavaleir
- Clutch pedal is loose
- Engine Swap "Sort of"
- Brain
- Custom Interior
- Tire Tips
- water leak another question
- 02 Cav humming noise
- actuator
- what stereo size can i fit in the 2003 cavalier?
- 97 Z24 ?'s
- Shaking while braking
- Mounting Sirius Car Kit in 2002 Cavalier
- no horn, tail light, dash, cig
- New Battery
- cavalier bmx aero kit opion?
- Lost turning capability
- WTB Ignition Module
- Ignition module
- 94 cavalier has a mind of its own
- Car Temp
- Instrument Panel Lights and Air Condition Lights
- 94 Cavalier Blinkers not Working????
- Need Help With Prostart Program
- 96 cavalier code p1133
- clear knobs
- Stereo Installation
- springs?
- can't find horn
- Posting
- make car faster vroom vroom
- heater helpppppppppp!!!
- Starter issues 88 cavvy
- how can i tell if my engine head is fucked?
- motor mount help?
- My car is making noise too!!
- FOR SALE: 87' Cavalier Z24 Auto
- Remote driver door and trunk unlock
- Dimming lights
- Not a forum(speed limiter)
- speed limiters (drag strip)
- Speed limiters suck
- caliper bolt specs
- 2000 2.2L Turn Signal Bulb Replacement
- 1996 Blazer turn signal
- 2 problems need help
- 2003 fuel filter removal ???
- Wiring Speakers
- check engine light
- amp remote turn on??
- o2 sensor????
- Installing Speakers
- shocks or tire?
- 1999 Cavalier Z24 Stuck Key
- Programming remote
- alarm
- installing subwoofer
- Trans shift problem 2002 cavalier
- 96 Cavalier Trans remains in park until drive is selected
- couple problems with an 86 cavy
- O2 sensor
- err message on cd player
- Black Widow Car Alarm
- Fuel Injector Vapor Leak recall ???
- Front Speakers
- Speedometer Problems
- manual reverse lock
- 2000 headligh removal
- Replacing front/rear speakers in '89 cavvy
- '96 bulb replacement help!
- How to get headrest off of 04 cav.
- freezing doors
- heater core
- O2 sensors..what the?
- happy holidays
- 1986 Cavalier
- f*!#ing idiot
- 2003 cavalier front defrost problem
- Scary Problem: Stuck Gas Peddle on 97 Cav, I think???
- Weird Starting Problem
- Horn is silent!
- gas mileage.
- thermostat problem?
- For Sale 1994 Cavalier
- WHere is A/C compressor
- Turbo and turbo parts cost
- Mine overheats too
- z22???
- cold highway driving [96 2.2L]
- New Battery, Which one should I buy?
- Strange Heat problem
- 98 cavalier no horn or cig lighter? help me please
- strange "sisisisi" noise when start the car
- Z24 vs. ECOTEC...help!
- temp sensor prob ?
- no tail lights
- commpression test
- Motor Swap
- '96 Cav. hard to start (Sometimes)
- Performance Chips on Ebay
- difference between 1994 z24 vs. rs vs. standard 2-door model
- suicide hood?
- magnaflo vs flomaster
- n00b question about turbos
- friends electrical problem
- how to??
- Z24 Won't Start
- Cavalier heater problems
- cold air
- Fog lights
- 96 Cavalier Mystery
- 97 Cavalier rear defog light problem . . . .
- battery life?
- What would be the best route......
- Hate the police!!
- Custom Sub Boxes
- Gas Mileage
- License Plate light...HELP!!
- 2 1/16 gauges
- Venting Read if you want.
- ? about air box
- Check engine light help?!
- Flip Flop Suicide Trunk CHEVY CAVALIER
- Crack in Cavalier Dash
- Apc
- Fan motor removal
- 96 Cavalier.New cd player,now no interior light
- what is a good mod for my cavi
- 95 Lumina 3.1 Swap\For Sale
- crankshaft position sensor removal??????
- Prostart Clutch by pass
- Convertible Boot?
- covering dash
- replacing cavalier's cigarette lighter
- Need some help with my alternator
- Vents
- will a 98 cavalier engine work in a 97 cavalier rs?
- out with old, in with new(er)
- '94 cavalier problems!!!!!! HELP!!
- 2005 GM Small car bash Announcement!
- Msd Ignition Or Headers
- intake ???
- Check Engine Light
- 2.2L Swap suggestions
- 2003 Will Not Start
- Apc
- turbo cavi?
- 92 cavalier fuse panel
- Frozen
- Wheel Spacers
- 92 Z24 Overheating
- Underdrive Pulley
- Oil Catch Can?
- intake
- 89 cavi
- K&N Air Filters...?
- old lady seeking a answer please help
- 96 Cavalier rear bumper cover removal
- Parts For Sale
- 89 Wiper removal
- brake issue
- engine hot and bad gas mileage it seems
- Psi??
- Im a newb...cavvy a good car for me?
- Engine knocking?
- My First Cavalier
- Head Lamps
- car keeps dieing losing power?please help
- Dual
- Re-Installing Rear Seat
- selling my 2003 bomex 4pc body kit for '03 cavalier
- Help me out Again
- does 3spd o/d or 4spd o/d hav governor or both?
- starter wiring 97 cavvy?
- Car Rolls in park
- removing fuel pressure regulator on 1997 Z24
- 1994 cavalier/sunbird le 3.1 won't crank
- Cold Air Intake
- Head gasketeer
- performance chips
- custom intake
- Siggy Request.. and how to post sigs.
- brakes
- Opinions Needed, Head Gasket going???
- Noisy AC compresser stories lets hear them!
- Suspension
- muffler
- Where is the heat going ?
- ball joints seat themselves?
- Power windows not going up
- I'm probally an idiot
- How many O2 sensors do a 2004 Chevy Ecotech Have???
- Brain Fart
- *@&# getting banned
- need some info
- need some help
- Auto-Trans Interceptor
- more power
- 4 door Z24?
- New To AF's Cavalier section? READ BEFORE POSTING! Updated!
- dash lights 1997 cavalier
- eco
- muffler
- 97 Cavalier door locks
- Radiator Plug??????
- speed limiter removal 96-98 j-bodies?
- Need Z24 Parts!!
- removing center console
- How do I fix this
- 2000 2.2L Headers
- TURBO Etc.,.
- 1986 Cavilier - Alternator
- 2.4L head on 2.2 engine
- Convertable adjustment 2000 z24
- Bypassing the ignition clutch switch.
- While the tranny's on the ground....
- choaking and stalling while idling
- Hooking up linkage for passing gear on '94 Cavalier
- have to hold idn on to start
- Installing Boa remote car starter w/ keyless entry
- ignition switch and fuel pump fuse hot side
- Type of Header
- Exhaust
- Coilovers
