View Full Version : Cavalier
- ho do you install a new shift knob
- 98 cavy z24 mod ?
- Rear Brake Lines...
- z24 plug wires
- tachometer installation
- Changing Head Gasket.....1995.....Question
- Fuel system issue
- im f***ed lol need help with the 98 z
- new rim sizing
- new cavalier section moderator
- Ignition Control Module '96 2.2L
- Dash Light Question?
- Security light comes on for no reason
- is there 2 oxygen sensors on a 2000 cavalier?
- drivers door & trunk won't unlock with remote
- head lights
- possible cracked cylinder or blown head gasket
- Any cavalier question about one
- 02 Cavy shifting problem
- underdrive pulley
- ABS Craped out light on
- cav wont start/.
- crankshaft
- crazy 96 cav
- cavalier parts
- help with ebrake. . . please. . .
- cav 2004 fog lights
- 01 loss of power and gas milage
- 87 Z24 cavalier hesitation
- Ultimate POS for your car!
- '97 Cavalier, overheating
- 2003 cavalier retractable antenna mast
- Changing My Front Breaks...
- flip flop trunk and other mods
- Why Stock Cd Decks so expensive ?
- Automatic Shift Knob not Manual
- 2003 cavalier center console
- cavalier history
- ? about lowering
- Just got a 99 Z24, and got 2 problems
- 2000 cavalier z24
- INTAKE on A 95' 2.2L
- 89 cavalier drive axle removal
- new wheels
- 2003 cavalier carpet/trim color
- day running lights
- 95 Cavalier start problems
- How to disable panic alarm
- Two Questions "Body Kit" and "Radio"
- Keyless programming for 04 Cav
- Need Help With Firing Order!91Cav.Z24(3.1)
- AAA competition- wish me luck
- Looking for parts for 94 cavalier
- broken bleeder screws... help?
- Squeeky steering
- Lubrication
- Keyless Entry Programming For 2001 Cavi
- Healing old Wounds
- pops out of reverse
- altenator output, 4cl VS. V6
- shaking in the rain!
- Carriers?
- 2.4 cold air intake install
- Euro Cavs plus
- '98 Cavalier DRL Problems
- Question about one of my sensors.
- 2000 Cavalier Brake light Probs
- head gasket...
- Turning Clunking Noise
- help my arm is stuck!!!!
- check out this cav
- tring to find body kits for 03 /04 cavalier
- upgrading my altenator.....
- Autoshow
- 1996 2.2 153k, uneven braking??
- 1996 2.2 153k, Head Gaskett Replacement??
- Rotors
- 1998 Engine capability
- vacuum pressure at idle
- looking for a 94 cavalier z24 full cat back exaust system
- Swapping a 2.8L with a 3.1L?
- Missfire
- sticky shifter
- quick tune up question for a 92
- proper rpm range for 2.2L
- is this right for temperature (pics)
- 92 cav stalls in drive not in neutral
- 94 Cav. 2.2 mpi My speedo does not work
- High beams wont work
- check engine light / iat sensor
- Custom 96 4dr cavi
- airbags
- z24 race
- again . . .
- Temperature Gauge Reading? Where does yours read?
- Tcc Victim Here Has Question
- Burning smell from underneath?
- 2.8 L Broken timing chain..replace engine?
- tcc solenoid???
- wuz up
- Underglow
- AIT Sensor Resistor
- Question about 94 cavalier
- whats the best way to repair a rusted weather strip spot
- Kicked out
- 89 Cav 2.0 Fuel Delivery Problem
- 94 Cavalier 2.2 MPI wayward wire goes where?
- How Many People here have the GM Supercharger?
- torque spec?
- Temp gauge gone wacko
- 00-02 Chevy Cavalier Tach Euro Reverse Glow Gauges-HOT!
- Water Leak!! help, somebody throw me a life preserver...
- crankshaft sensor
- Cavalier XTREME!!!!!!!!!!!!!!!!!1
- Need some answers
- wash the car
- 86 ConVerTIBLE engine swap
- Hello
- Cavalier Guages
- vss...
- Moonroof interior slider
- 93 Cav Tach help
- Metric or Imperial
- Replacing 97 Cav's Carpet
- Looking for 94 cavy air intake
- '03 LS Sport
- overheating???
- alternators
- diesel???
- throttle body port and polish
- Headlight issue
- 97 Cavalier 2.2L/Auto Average Lifespan???
- cd player
- start problem
- 92 Cav 2.2 4 cyl
- engine cleaning
- put the wrong spark plug wire in the wrong socket; need help
- 94 cavalier and 94 z24
- Gas Mileage
- 2001 Cavalier - problems with reduced fuel economy/gas mileage
- Sea foam?
- 92 cavalier 2.2l stalling out
- shift nob
- Is my head gasket going or what!?
- 94 goes through coolant
- Graphic Art
- Serpentine belt replacement for 91 Cavalier
- Spark Plug Gapping Question
- Need Help car over heating
- Bad Spinout.....Tires Covered?
- bent valves
- 98 4 door+Z-24 parts...
- cavalier performance mod
- transmission fluid
- replacement shifter
- Throttle Body, or IAC?
- Front End
- barely ant heat
- cavalier cold air intake
- F/S or F/T: '96 Cavalier w/ many modifications
- 96 cav no power
- 98 z makin screazin noise
- overheating
- Valve Job on 2002 Cavalier
- major oil leak
- heater blows cold
- hard shift
- Rear brake Bulb Warning.
- 2000 Cavalier Timing Cover Gasket Install Price ??
- stereo wont unlock
- Underdrive pulley
- Post a pic of your favorite J that is not your own!.
- Temperature won't go past1/4
- Help With Interior Paint...
- i had enough of these cavaliers already!
- 96 Corsica Starts Only With Foot on the Gas Pedal
- code reader p0440
- another winter driving question
- Cavalier power drivers window cold weather malfunction
- need advice on winter starting
- window tinting in alberta?
- pull up to reverse..huh?
- 98 cavalier red line shut off
- engine light
- shaking like crazy
- Cavalier 94 wont start. Any suggestions
- No horn on 2001 cavalier
- Question for you hardy winter folks...
- 2004 cavalier remote
- no power
- How to Lower 01 Z24?
- 97 2.2 Overheating - End of My Rope
- spare key help
- struts or spare tire?
- 3T40 Trannie Help - Code 62
- need a z24 spoiler...
- Block heater or no block heater
- Any Arizona people out there?
- cams
- Don't Buy Weapon-R Intakes
- AutoTrans Interceptor (4T40E 4 Speed)
- Starts and runs with few probs please help me......
- o2 sensor ?
- 01 Z24 Suspension Upgrades
- brakes
- 96 Cavalier with engine rattling help please
- '89 Cavvy performance mods?
- Valve cover gasket '89 cavvy
- 01 Cavy Z24
- Z24 Engine Help!!!!
- 1996 cavalier z24 rear axel
- crj
- 1993 cavalier
- Help, please? Piston Problems?
- Learning about my car
- Aluminum Radiator
- Hesitation, bucking, jerking, you name it
- Needs everyones opinion..
- car stops when moving ...
- Check out thi crazy cavy!
- starts but doesnt run NEED HELP(1989)
- I was Wondering
- Diagnostic plugins/computer chips
- Rhino car ramps
- need z24 parts!
- 03 fuel tank/heat shield
- Newbie
- Cavalier
- Car Sterio
- Spark plug wires in '89 Cavvy?
- fan motor
- starter/ignition wire
- Door sensor removal?
- synthetic oil?
- What other year front ends will bolt right onto a 2000 cavalier?
- How much $$$
- Starting in winter
- 2003 cavalier stalling?
- IAC how to find/clean/remove/replace
- Bass only in the rear speakers?
- remote starter recommendations and feedback
- bent valves?
- Horn
- Official Show off your car post and what your all about!
- whos it gonna be???
- rpms
- Remote start, Stupid stick
- 3rd gear "clunk".. hmmm..
- What amp should i get?
- '97 Cav Parking Lights
