Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
> Cavalier |
View Full Version :
Cavalier
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
chevy 350 small block
Fuel Injector Installation
my car is shaking when pressing brake pedal to stop at low speed
Parts
2000 z24 speedo
My cavalier ticks
2000 Cavaler won't start!!! HELP!!!
need an all black interior
Parking brake ?????
2002 Cavalier Heating problems
where is the radiador drain plug
TB Spacer
Motor Mounts
drivers side window
Hoods
heating problems
need to know where to find a new engine?
blown head gasket - how much time -what else
chevy cavaleir
Clutch pedal is loose
Engine Swap "Sort of"
Brain
Custom Interior
Tire Tips
water leak another question
02 Cav humming noise
actuator
what stereo size can i fit in the 2003 cavalier?
97 Z24 ?'s
Shaking while braking
Mounting Sirius Car Kit in 2002 Cavalier
no horn, tail light, dash, cig
New Battery
cavalier bmx aero kit opion?
Lost turning capability
WTB Ignition Module
Ignition module
94 cavalier has a mind of its own
Car Temp
Instrument Panel Lights and Air Condition Lights
94 Cavalier Blinkers not Working????
Need Help With Prostart Program
96 cavalier code p1133
clear knobs
Stereo Installation
springs?
can't find horn
Posting
make car faster vroom vroom
heater helpppppppppp!!!
Starter issues 88 cavvy
how can i tell if my engine head is fucked?
motor mount help?
My car is making noise too!!
FOR SALE: 87' Cavalier Z24 Auto
Remote driver door and trunk unlock
Dimming lights
Not a forum(speed limiter)
speed limiters (drag strip)
Speed limiters suck
caliper bolt specs
2000 2.2L Turn Signal Bulb Replacement
1996 Blazer turn signal
2 problems need help
2003 fuel filter removal ???
Wiring Speakers
check engine light
amp remote turn on??
o2 sensor????
Installing Speakers
shocks or tire?
1999 Cavalier Z24 Stuck Key
Programming remote
alarm
installing subwoofer
Trans shift problem 2002 cavalier
96 Cavalier Trans remains in park until drive is selected
couple problems with an 86 cavy
O2 sensor
err message on cd player
Black Widow Car Alarm
Fuel Injector Vapor Leak recall ???
Front Speakers
Speedometer Problems
manual reverse lock
2000 headligh removal
Replacing front/rear speakers in '89 cavvy
'96 bulb replacement help!
How to get headrest off of 04 cav.
freezing doors
heater core
O2 sensors..what the?
happy holidays
1986 Cavalier
f*!#ing idiot
2003 cavalier front defrost problem
Scary Problem: Stuck Gas Peddle on 97 Cav, I think???
Weird Starting Problem
Horn is silent!
gas mileage.
thermostat problem?
For Sale 1994 Cavalier
WHere is A/C compressor
Turbo and turbo parts cost
Mine overheats too
z22???
cold highway driving [96 2.2L]
New Battery, Which one should I buy?
Strange Heat problem
98 cavalier no horn or cig lighter? help me please
strange "sisisisi" noise when start the car
Z24 vs. ECOTEC...help!
temp sensor prob ?
no tail lights
commpression test
Motor Swap
'96 Cav. hard to start (Sometimes)
Performance Chips on Ebay
difference between 1994 z24 vs. rs vs. standard 2-door model
suicide hood?
magnaflo vs flomaster
n00b question about turbos
friends electrical problem
how to??
Z24 Won't Start
Cavalier heater problems
cold air
Fog lights
96 Cavalier Mystery
97 Cavalier rear defog light problem . . . .
battery life?
What would be the best route......
Hate the police!!
Custom Sub Boxes
Gas Mileage
License Plate light...HELP!!
2 1/16 gauges
Venting Read if you want.
? about air box
Check engine light help?!
Flip Flop Suicide Trunk CHEVY CAVALIER
Crack in Cavalier Dash
Apc
Fan motor removal
96 Cavalier.New cd player,now no interior light
what is a good mod for my cavi
95 Lumina 3.1 Swap\For Sale
crankshaft position sensor removal??????
Prostart Clutch by pass
Convertible Boot?
covering dash
replacing cavalier's cigarette lighter
Need some help with my alternator
Vents
will a 98 cavalier engine work in a 97 cavalier rs?
out with old, in with new(er)
'94 cavalier problems!!!!!! HELP!!
2005 GM Small car bash Announcement!
Msd Ignition Or Headers
intake ???
Check Engine Light
2.2L Swap suggestions
2003 Will Not Start
Apc
turbo cavi?
92 cavalier fuse panel
Frozen
Wheel Spacers
92 Z24 Overheating
Underdrive Pulley
Oil Catch Can?
intake
89 cavi
K&N Air Filters...?
old lady seeking a answer please help
96 Cavalier rear bumper cover removal
Parts For Sale
89 Wiper removal
brake issue
engine hot and bad gas mileage it seems
Psi??
Im a newb...cavvy a good car for me?
Engine knocking?
My First Cavalier
Head Lamps
car keeps dieing losing power?please help
Dual
Re-Installing Rear Seat
selling my 2003 bomex 4pc body kit for '03 cavalier
Help me out Again
does 3spd o/d or 4spd o/d hav governor or both?
starter wiring 97 cavvy?
Car Rolls in park
removing fuel pressure regulator on 1997 Z24
1994 cavalier/sunbird le 3.1 won't crank
Cold Air Intake
Head gasketeer
performance chips
custom intake
Siggy Request.. and how to post sigs.
brakes
Opinions Needed, Head Gasket going???
Noisy AC compresser stories lets hear them!
Suspension
muffler
Where is the heat going ?
ball joints seat themselves?
Power windows not going up
I'm probally an idiot
How many O2 sensors do a 2004 Chevy Ecotech Have???
Brain Fart
*@&# getting banned
need some info
need some help
Auto-Trans Interceptor
more power
4 door Z24?
New To AF's Cavalier section? READ BEFORE POSTING! Updated!
dash lights 1997 cavalier
eco
muffler
97 Cavalier door locks
Radiator Plug??????
speed limiter removal 96-98 j-bodies?
Need Z24 Parts!!
removing center console
How do I fix this
2000 2.2L Headers
TURBO Etc.,.
1986 Cavilier - Alternator
2.4L head on 2.2 engine
Convertable adjustment 2000 z24
Bypassing the ignition clutch switch.
While the tranny's on the ground....
choaking and stalling while idling
Hooking up linkage for passing gear on '94 Cavalier
have to hold idn on to start
Installing Boa remote car starter w/ keyless entry
ignition switch and fuel pump fuse hot side
Type of Header
Exhaust
Coilovers
Replacement Bulbs?!
Need a Engine
Need shocks
rear defrost problem
Parting Out 88 Sunbird GT
97 Z-24 Cavalier Ignition problem
Cruise Control
Web
AF
