View Full Version : Cavalier
- 99' Cavalier (Warm weather, cold engine start problems.)
- How do you clean your engine?
- good cigarette lighters?
- Need a 96-99 cavi with no motor/tranny
- Quick gastank question
- rolling fenders/ air sus
- No Turn Signals
- AC Compressor Problem???? Fuses blowing??
- Rear window is stuck 1/2 way down, (help manually rolling it up permintly)
- pushrod / modular
- Need Help!
- Coolant leak!!!!!!!!!!!!!?
- undercarriage noise
- 2.2 Leaking At Coolant Tube
- Recharge R134?
- 1999 Cavalier RS 2.2L--2 questions
- Code Help - is it safe?
- Body Kito
- Hard decision!
- rims
- Good Lowering kit
- removing motor mounts
- 2001 Cav power sunroof won't close
- QUICK! Whats a good price for a new 04 cavalier
- clutch problem??
- grindin noise
- Z 24 Wheels
- CAT problem
- Crunching Thunking noise
- girl who needs help
- Any good sounding exhaust out there?
- e-brake
- 1998 transmission problem???
- Studdering problem
- 01 cavy brakes
- '98/cavalier/ need repair advice
- Where to buy cars
- coilovers
- Wet Floorboards
- Picture in post
- Where is the fuel supply hose located?
- Rear Spoiler Question
- No Crank, No Start
- 3.1 question
- suspension clunking
- Help please, 99' interior light trouble
- Q for moderators
- 2001 Cavalier inertia switch location.
- painting
- Overheating with a 94 cavi?
- what intake do i have?
- Max P.S.I
- new here
- 96' Cavalier Overheating
- Pin Striping
- 91 z24 specs?
- Pics of aftermarket rims
- 91 Cav V6 trouble
- 50,ooo mile tune-up
- where can i get a 160 degree thermo. for my 1991 2.2 cavalier
- fuel pump
- oil fill tube relocation for turbo??
- Best Cavalier websites
- Fuel rail reading 0psi
- 93 Cav. died - new battery, new alt.
- HID lights
- Another Headlight problem...
- 1999 Toyota Cavalier Misfires
- Premium vs. Regular
- key code for Citation ignition switch
- oil filter change
- Different intakes.
- pully kit
- tornado fuel saver
- rksport prostreet coilovers
- projector headlights
- 96' Cavalier Z24 Body Kits
- Loud Thumping noise...
- replacing driver side mirror
- how to install clear corners?
- whats the difference
- noisy suspension
- 96' Cavalier Z24 Stock CD Player
- Rims!!!!!!
- 1991 cavallier possible head gasket
- over heating problems 2001 (with new head gasket still)
- tires
- Opinion-Please Post
- high Idle at stop with brake on in drive
- radio keeps playing
- wheel size on 02 Z24
- Ignition Module?
- metal shaving in oil
- I sold out. Sorry.
- this may sound dumb but need a quick answer
- What do i need to paint?
- Clutch cable adjust??
- Fuel Line Reset switch???
- 1995 Cavalier stalls when hot
- wireing harness for trailer lights
- looking for a cavi
- exhaust poll
- 97 Cavalier ABS light on safe to drive?
- led odomter
- potential problem with my cavi?
- painting?
- 95 corsica 3.1 to 89 z24 2.8 engine swap help
- racing spec condenser
- Difference between a 4-1 and 4-2-1 Header?
- transmission
- front ground effects
- gtech pro ss
- a new engine
- 97 cavy intake
- car club
- Cd Player stopped working.
- I Need A Smart Person
- 200 Z24
- dash illumination
- smaller wheel size
- stock 1/4 mile times
- new car
- sound system problems
- is there ne difference between 91-94 and 95-99 springs?????
- where 2 paint the car
- 1993 chevy cavalier OVERHEATING
- a-pillar guage mount
- 200 Cavalier
- 97 cavalier
- Please help
- 1997 Z24 Daytime Running Lights
- replace timing chain?
- Lowering Springs
- How much does it cost to install an exhaust system?
- Colored HVAC Knobs
- 3 spd vs 4 spd auto
- Z-24 towing capacity?
- Power Locks
- 98 Cavy brake/turn light not workin
- Looking for some Help
- front end roar
- Worn rims??
- first one headlight randomly doesnt work...NOW BOTH!
- Car Conversions
- freeze plug
- swap 3 gear tranny for 4 gear tranny??
- hood
- water leaking in & getting carpet wet
- wont shift
- wont stay charged
- Tach Installation
- 01 cavalier dies every few miles
- pulsating brake pedal
- Newbie here, needs help concerning lockup sensor
- Tranny for a hp engine
- 1993 Cavalier/Coil Pack Problems
- What goes here???
- internet buying rant
- 1991 Cavalier
- ignition locked up
- What would this exactly do for my car?
- POS Motor Now Shot. New One Comming. I Got Questions
- Temp Gauge Issues
- New engine
- Lump on floor!
- DRL stay on when car off!!!!!!!!!!!!
- 2nd gear problems
- Catalytic Converter removal
- tranny questions...
- Needed : How to's and suggestions !!
- cav troubles
- performance upgrades
- 1991 Cavalier for sale or parts!!
- Anyone want it?
- somethings wrong with my 95 cavalier
- timing chain replaced,now what?
- pinstripe
- **98 Z24 Headlight Problem**
- power lock doors dont stay locked
- 93 cavalier door replacement
- Tach Adapter
- Dash bulb access
- 97 Z24 Dash/Headlights/Stereo Problems
- Throttle body or Not Throttle body that is the question
- Strange looking stuff in oil
- tach lead wire voltage
- 96 Cav - starting problems
- 95-99 Cavalier Projector Headlights for sale
- i got a leakey head g
- tach/pcm/I NEED HELP
- 87 Cav engines
- 1990 cavalier not another spot of rust except for.... is this common
- So Afraid
- head gasket on 92 cav
- Brakes same on 01 Cav as 91 Corsica?
- warrantee question
- tranny issues?
- battery problem
- tach wires
- Help needed, I am STUCK
- What is a good price for a 02
- Rare Moment!
- Help! Changing the Water Pump 94' Cavalier
- can you disable bumper signals?
- Pigs go home.
- Estimated miles before Cavalier Engine goes bad?
- muncie HM282 5-speed
- Whole Engine Moves...!?
- Stumped!!
- 2.2 cavalier timing chain again!
- Inspection
- Fuel Line ?
- CRJ's Evolution Progress..( & Rant post )
- tire n rim
- Ignition Clutch Override?
- power door locks
- Jbody no more?
- Cavy turbo vid...
- Starwars remastered!
- 96 cavalier misfire
- Codes
- auto to maual tranny swap
- Please Help Me!
- 99 Cavalier - Cruise just quit working
- Sponcership
- 93 intermittent start,click,wierd growly idle
- "Project Psycho" is moving along smoothly.
- brakes in the rain
- ground effects
- Need help
- whats my redline???
- another problem with the 98 z
- very best all around passenger car tires????
- help !
- High Rpms At Hyw Speeds
- tach adaptor question
- Strut question????
- glove compartment repair
- speedometer bouncing
- Best Tire CLeaner ?
- If you had $10,000
- RPMs climb, but car won't shift
- Spuddering . . . please help . . .
- Key won't turn past aux.
- 96 Cavalier Trans. Issue
- Knight Rider Light On A Cavi...
- Shift Problems on 92? Cav
- Cav gone for good......
- INSTALLING the knob
- body kits for a 94
