View Full Version : Cavalier
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. new rim sizing
  2. new cavalier section moderator
  3. Ignition Control Module '96 2.2L
  4. Dash Light Question?
  5. Security light comes on for no reason
  6. is there 2 oxygen sensors on a 2000 cavalier?
  7. drivers door & trunk won't unlock with remote
  8. head lights
  9. possible cracked cylinder or blown head gasket
  10. Any cavalier question about one
  11. 02 Cavy shifting problem
  12. underdrive pulley
  13. ABS Craped out light on
  14. cav wont start/.
  15. crankshaft
  16. crazy 96 cav
  17. cavalier parts
  18. help with ebrake. . . please. . .
  19. cav 2004 fog lights
  20. 01 loss of power and gas milage
  21. 87 Z24 cavalier hesitation
  22. Ultimate POS for your car!
  23. '97 Cavalier, overheating
  24. 2003 cavalier retractable antenna mast
  25. Changing My Front Breaks...
  26. flip flop trunk and other mods
  27. Why Stock Cd Decks so expensive ?
  28. Automatic Shift Knob not Manual
  29. 2003 cavalier center console
  30. cavalier history
  31. ? about lowering
  32. Just got a 99 Z24, and got 2 problems
  33. 2000 cavalier z24
  34. INTAKE on A 95' 2.2L
  35. 89 cavalier drive axle removal
  36. new wheels
  37. 2003 cavalier carpet/trim color
  38. day running lights
  39. 95 Cavalier start problems
  40. How to disable panic alarm
  41. Two Questions "Body Kit" and "Radio"
  42. Keyless programming for 04 Cav
  43. Need Help With Firing Order!91Cav.Z24(3.1)
  44. AAA competition- wish me luck
  45. Looking for parts for 94 cavalier
  46. broken bleeder screws... help?
  47. Squeeky steering
  48. Lubrication
  49. Keyless Entry Programming For 2001 Cavi
  50. Healing old Wounds
  51. pops out of reverse
  52. altenator output, 4cl VS. V6
  53. shaking in the rain!
  54. Carriers?
  55. 2.4 cold air intake install
  56. Euro Cavs plus
  57. '98 Cavalier DRL Problems
  58. Question about one of my sensors.
  59. 2000 Cavalier Brake light Probs
  60. head gasket...
  61. Turning Clunking Noise
  62. help my arm is stuck!!!!
  63. check out this cav
  64. tring to find body kits for 03 /04 cavalier
  65. upgrading my altenator.....
  66. Autoshow
  67. 1996 2.2 153k, uneven braking??
  68. 1996 2.2 153k, Head Gaskett Replacement??
  69. Rotors
  70. 1998 Engine capability
  71. vacuum pressure at idle
  72. looking for a 94 cavalier z24 full cat back exaust system
  73. Swapping a 2.8L with a 3.1L?
  74. Missfire
  75. sticky shifter
  76. quick tune up question for a 92
  77. proper rpm range for 2.2L
  78. is this right for temperature (pics)
  79. 92 cav stalls in drive not in neutral
  80. 94 Cav. 2.2 mpi My speedo does not work
  81. High beams wont work
  82. check engine light / iat sensor
  83. Custom 96 4dr cavi
  84. airbags
  85. z24 race
  86. again . . .
  87. Temperature Gauge Reading? Where does yours read?
  88. Tcc Victim Here Has Question
  89. Burning smell from underneath?
  90. 2.8 L Broken timing chain..replace engine?
  91. tcc solenoid???
  92. wuz up
  93. Underglow
  94. AIT Sensor Resistor
  95. Question about 94 cavalier
  96. whats the best way to repair a rusted weather strip spot
  97. Kicked out
  98. 89 Cav 2.0 Fuel Delivery Problem
  99. 94 Cavalier 2.2 MPI wayward wire goes where?
  100. How Many People here have the GM Supercharger?
  101. torque spec?
  102. Temp gauge gone wacko
  103. 00-02 Chevy Cavalier Tach Euro Reverse Glow Gauges-HOT!
  104. Water Leak!! help, somebody throw me a life preserver...
  105. crankshaft sensor
  106. Cavalier XTREME!!!!!!!!!!!!!!!!!1
  107. Need some answers
  108. wash the car
  109. 86 ConVerTIBLE engine swap
  110. Hello
  111. Cavalier Guages
  112. vss...
  113. Moonroof interior slider
  114. 93 Cav Tach help
  115. Metric or Imperial
  116. Replacing 97 Cav's Carpet
  117. Looking for 94 cavy air intake
  118. '03 LS Sport
  119. overheating???
  120. alternators
  121. diesel???
  122. throttle body port and polish
  123. Headlight issue
  124. 97 Cavalier 2.2L/Auto Average Lifespan???
  125. cd player
  126. start problem
  127. 92 Cav 2.2 4 cyl
  128. engine cleaning
  129. put the wrong spark plug wire in the wrong socket; need help
  130. 94 cavalier and 94 z24
  131. Gas Mileage
  132. 2001 Cavalier - problems with reduced fuel economy/gas mileage
  133. Sea foam?
  134. 92 cavalier 2.2l stalling out
  135. shift nob
  136. Is my head gasket going or what!?
  137. wiring diagram for a 02 cavalier...im gonna bypass that class 2 data thingy
  138. 94 goes through coolant
  139. Graphic Art
  140. Serpentine belt replacement for 91 Cavalier
  141. Spark Plug Gapping Question
  142. Need Help car over heating
  143. Bad Spinout.....Tires Covered?
  144. bent valves
  145. 98 4 door+Z-24 parts...
  146. cavalier performance mod
  147. transmission fluid
  148. replacement shifter
  149. Throttle Body, or IAC?
  150. Front End
  151. barely ant heat
  152. cavalier cold air intake
  153. F/S or F/T: '96 Cavalier w/ many modifications
  154. 96 cav no power
  155. 98 z makin screazin noise
  156. overheating
  157. Valve Job on 2002 Cavalier
  158. major oil leak
  159. heater blows cold
  160. hard shift
  161. Rear brake Bulb Warning.
  162. 2000 Cavalier Timing Cover Gasket Install Price ??
  163. stereo wont unlock
  164. Underdrive pulley
  165. Post a pic of your favorite J that is not your own!.
  166. Temperature won't go past1/4
  167. Help With Interior Paint...
  168. i had enough of these cavaliers already!
  169. 96 Corsica Starts Only With Foot on the Gas Pedal
  170. code reader p0440
  171. another winter driving question
  172. Cavalier power drivers window cold weather malfunction
  173. need advice on winter starting
  174. window tinting in alberta?
  175. pull up to reverse..huh?
  176. 98 cavalier red line shut off
  177. engine light
  178. shaking like crazy
  179. Cavalier 94 wont start. Any suggestions
  180. No horn on 2001 cavalier
  181. Question for you hardy winter folks...
  182. 2004 cavalier remote
  183. no power
  184. How to Lower 01 Z24?
  185. 97 2.2 Overheating - End of My Rope
  186. spare key help
  187. struts or spare tire?
  188. 3T40 Trannie Help - Code 62
  189. need a z24 spoiler...
  190. Block heater or no block heater
  191. Any Arizona people out there?
  192. cams
  193. Don't Buy Weapon-R Intakes
  194. AutoTrans Interceptor (4T40E 4 Speed)
  195. Starts and runs with few probs please help me......
  196. o2 sensor ?
  197. 01 Z24 Suspension Upgrades
  198. brakes
  199. 96 Cavalier with engine rattling help please
  200. '89 Cavvy performance mods?
  201. Valve cover gasket '89 cavvy
  202. 01 Cavy Z24
  203. Z24 Engine Help!!!!
  204. 1996 cavalier z24 rear axel
  205. crj
  206. 1993 cavalier
  207. Help, please? Piston Problems?
  208. Learning about my car
  209. Aluminum Radiator
  210. Hesitation, bucking, jerking, you name it
  211. Needs everyones opinion..
  212. car stops when moving ...
  213. Check out thi crazy cavy!
  214. starts but doesnt run NEED HELP(1989)
  215. I was Wondering
  216. Diagnostic plugins/computer chips
  217. Rhino car ramps
  218. need z24 parts!
  219. 03 fuel tank/heat shield
  220. Newbie
  221. Cavalier
  222. Car Sterio
  223. Spark plug wires in '89 Cavvy?
  224. fan motor
  225. starter/ignition wire
  226. Door sensor removal?
  227. synthetic oil?
  228. What other year front ends will bolt right onto a 2000 cavalier?
  229. How much $$$
  230. Starting in winter
  231. 2003 cavalier stalling?
  232. IAC how to find/clean/remove/replace
  233. Bass only in the rear speakers?
  234. remote starter recommendations and feedback
  235. bent valves?
  236. Horn
  237. Official Show off your car post and what your all about!
  238. whos it gonna be???
  239. rpms
  240. Remote start, Stupid stick
  241. 3rd gear "clunk".. hmmm..
  242. What amp should i get?
  243. '97 Cav Parking Lights
  244. Car Starter T-Harness Question
  245. 2000 Cavalier Stalls Out & ?
  246. low RPM at stop
  247. girlfriends car driving me crazy with problems...or maybe its more so her
  248. coilovers
  249. Getting new car, need to know best engine
  250. Dimming lights problems??? Pls Help!
