View Full Version : Cavalier
- Handbrake
- Window help needed quick!!
- Torque Converter locks up at 27 mph at light throttle
- I can't stand this brake dust
- Running a little hott
- 18" KONIG APPEALS with TIRES 4 SALE***
- Radiator Support Pads Needed
- spark plug problem
- clutch and flywheel ??
- buzzing sound
- '04 Cav. Brake Lights Quit
- 97 cavvy Hesitation
- Chevy Cavalier stock steel rims need one
- postting a thread
- engine swaps
- 92 Cavalier starter problem.
- How do i install my air intake?
- I gotta question
- hesitation problems
- pcm
- oil leakage
- if u want to see my slip how do i get it on here
- RK Sport Dual Exhaust System
- New pics of the CRJ cav..
- Gauges gone crazy?
- Group Buy.
- Please help my 96 cav
- They started it I finished it !!!
- engine performance for 88' 2.0 tbi 4 cylinder
- AC Compressor Working????
- all of u who love hatin why u gotta hate
- body kits for 88-91 cavaliers
- RKSPORT front valence poly-eurthane cheap new
- 03 cavy custom parts
- 3.0l v6 into 91 ls wagon?
- trans
- How many problems can my car have?
- Cavalier 2,2 98 Manual Gear Oil, and Fuel Pump
- cavalier convertible & body kits
- 4T40 trans 1996 cav
- About A/C accumulator
- Rad rubber pads needed for '94
- Clicking when I turn the wheel.
- Why did YOU buy a Cavalier?
- need advice
- I think the UPS guy is stalking me
- Main diff between cavaliers
- Problem with cylinder #2
- getin pulled over
- O2 Sensor need help
- Lowering my 97 cavi
- Brake Lights????????
- 94 - where is my Torque Converter Solenoid
- Engine Reving while accelerating
- New User hello with a motor and trans question
- Tons Of Troubles Stalling Etc.
- '91 Cav 2.2 60k, Radiator fan not working, what are these plugs?
- If your Cav's interior is noisy read this..
- Just wanted to thank everyone
- wind noise
- 99 Cavalier 2.2 120k overheating
- center console
- can u believe this fool tried to race me?
- Engine trembling and flameout
- serious engine problem
- squeaking drive belt
- Knocking problem
- automatic shift improver?
- any good sites for 88 z24 performance
- new shifter for 88 z24
- Bored/ Bumper cover
- new steering column question
- Not all cylinders working
- 2,000 Posts... Go me!
- Headlight problem
- horsepower
- question about pacesetter headers
- Knocking on junkyard's door...
- Stereo Replacement Problem
- 2.3L H.O. swap (vin A)
- I love the UPS man!!!!
- engine swap 3400 88 cavalier
- Fuel Filter
- OBX muffler
- 92 Cavalier parts?
- Stalling cavi
- AC Fuses Keep Blowing???
- what exhuast should i get for my 88 z24
- "trac off" light comes on
- Heres a laugh!
- So I was thinking...
- Will factory Z24 sway bars fit my 2000 2.2 base coupe?
- cost for front rotors & pads replacement
- Where is TCC plug 92 Cav
- 93 chevy cavalier right side brake problem
- Intake Problems
- 1994
- Timing?
- front lower Control Arm Bushings
- ok! dumb question about compressors
- pcv valve & hose
- 1998 Z24
- Friend has a service light
- Like it or not?
- Z24 speed/power?
- smells like shit
- oily spark plugs
- New Brakes in 92 Cavalier
- Double DIN?
- Caliper removal
- V8 in 1992 Cavalier?
- body kit install
- the cheapy scan tools any good?
- oil pan plug leak
- About replace AC hose from Low pressure end to compressor?
- 98 Cavalier passlock?(manual)
- 2.2l 99 cav
- Funny Movie
- Got a real brain twister of a problem for you guys
- Wet Floorboards
- Upper/Lower Engine Mount Kit
- '91 2.2 rs alternator wire
- What the hell is this?
- Cheapest place online to find an AEM CAI?
- Head Gasket
- Lotus Performance Products for Cavalier? – Need your feedback
- auto tranny problem
- gm supercharger article 2.2l ecotec
- ss ram air hood
- rpm gauge
- Brake fluid on reservoir
- Damsel in destress needs a cheap-o bass solution!!!
- 1989 Cavalier Problems
- Things under Bumpers
- how much to replace a AC tube?
- Having problems with 93 cav starter
- burning oil help....
- 95 2.2 blowin smoke! help me!(no noob here)
- I'm broke cant afford a new one
- 93 2.2L wont start
- 94 cavalier heat/ac power
- O2 Sensor
- HVAC Panel
- accident
- 93 Fuel Pump
- trunk condensation
- Listen to this...
- 94 parting out
- Wheelmax
- will 205/60/16 or 205/65/16 fit?
- Heater smell
- VIS Bodykits
- Paint
- Air
- 91 Cav quits
- 2.5 tuen up
- wiring fog lights
- Scratches and door dings
- Spal power window switches
- Exhaust Type
- painting
- fenders / quarter panels
- Cluster gauge
- Factory Tint Question
- Engine producing a rattling sound and oil pressure is low
- 99' Cavalier (Warm weather, cold engine start problems.)
- How do you clean your engine?
- good cigarette lighters?
- Need a 96-99 cavi with no motor/tranny
- Quick gastank question
- rolling fenders/ air sus
- No Turn Signals
- AC Compressor Problem???? Fuses blowing??
- Rear window is stuck 1/2 way down, (help manually rolling it up permintly)
- pushrod / modular
- Need Help!
- Coolant leak!!!!!!!!!!!!!?
- undercarriage noise
- 2.2 Leaking At Coolant Tube
- Recharge R134?
- 1999 Cavalier RS 2.2L--2 questions
- Code Help - is it safe?
- Body Kito
- Hard decision!
- rims
- Good Lowering kit
- removing motor mounts
- 2001 Cav power sunroof won't close
- QUICK! Whats a good price for a new 04 cavalier
- clutch problem??
- grindin noise
- Z 24 Wheels
- CAT problem
- Crunching Thunking noise
- girl who needs help
- Any good sounding exhaust out there?
- e-brake
- 1998 transmission problem???
- Studdering problem
- 01 cavy brakes
- '98/cavalier/ need repair advice
- Where to buy cars
- coilovers
- Wet Floorboards
- Picture in post
- Where is the fuel supply hose located?
- Rear Spoiler Question
- No Crank, No Start
- 3.1 question
- suspension clunking
- Help please, 99' interior light trouble
- Q for moderators
- 2001 Cavalier inertia switch location.
- painting
- Overheating with a 94 cavi?
- what intake do i have?
- Max P.S.I
- new here
- 96' Cavalier Overheating
- Pin Striping
- 91 z24 specs?
- Pics of aftermarket rims
- 91 Cav V6 trouble
- 96' Cavalier Z24 ETS light keeps coming on
- 50,ooo mile tune-up
- where can i get a 160 degree thermo. for my 1991 2.2 cavalier
- fuel pump
- oil fill tube relocation for turbo??
- Best Cavalier websites
- Fuel rail reading 0psi
- 93 Cav. died - new battery, new alt.
- HID lights
- Another Headlight problem...
- 1999 Toyota Cavalier Misfires
- Premium vs. Regular
- key code for Citation ignition switch
- oil filter change
- Different intakes.
- pully kit
- tornado fuel saver
- rksport prostreet coilovers
- projector headlights
- 96' Cavalier Z24 Body Kits
- Loud Thumping noise...
- replacing driver side mirror
- how to install clear corners?
- whats the difference
- noisy suspension
- 96' Cavalier Z24 Stock CD Player
- Rims!!!!!!
