View Full Version : Cavalier
- bad problem with 95 sunfire tranny/clutch?
- Funky noise
- Door hinges 1995-1999
- 91 Cav - 3.1 L Runs rough w/ Air Con on?
- 99 cavy headrest removal?
- Clutch Actuator Pipe
- 90 cav- they're trying to cheat me
- 95 Cavalier Bad ECM???
- Still can't figure out what's wrong!!!!
- 1994 z24 code 13,43,44
- Wiring the 12v for a radio
- What wrench should I buy to change serpentine belt on 97 cavalier?
- Venom 400
- ETS OFF + Check Engine light
- painted dash
- Power Window Kit Help
- played out mods.........
- Replacing coil packs
- Another ? by bh04
- Mounting a tach
- Please help, little knowledge trying to fix car.
- Rattling Noise coming from engine
- Loose steering?
- Painting Carbon Fiber
- 1998 Cavalier Starting Problem
- Fuel gauge 2k cav
- center consol
- Mods to increase fuel efficiancy?
- Some very much needed (and rather expensive) changes on my car! LOTS OF PICS!!!
- OH NO!!.... CRJ has gone MOPAR!
- Ok... how bout engine codes? Ratchet Shifter?
- battery light
- check engine still on. Occasional gas smell
- :WANTED: 1982-1987 Cavalier
- Adding Power Windows...
- Transbrake anyone???
- 60K service
- ticking noise from a '94 cavalier
- Hydralic Valve Tensioner?????
- HELP! Ignition lock cylinder!
- Reliability question regarding '00 Z24
- 89 Cavalier Radiator Fan not turning on
- how to mount lcd motorized lcd screen
- Problems with the tail lights
- 2001 Cavalier Hoods
- WTF is up with bringing back the dead?!?!
- For Sale
- coilovers
- E-Brake.... Help me Please!!!
- Problem in 5th gear on 2001 Cavvy
- 94 RS 4 cyl. engine making whining noise
- Rs Vs. Vl
- Quick vs question
- What to look for
- Timing Chain Tensioner
- lowering a 2005
- Can someone help me with my brake problem PLZ!!
- Engineering questions
- whining noise coming from front end
- Dash Replacement
- engine swap
- 1999 Cavalier Front bumper turn signal bulb
- '88 Cavalier won't run
- loose rattle noise in engine at start
- help please performance q
- motor mount help
- got my sig
- simple question
- OBD 2 Interface
- Changing ATF/FILTER O-RING HELP!
- lock rod removal door trim 1993 cavalier
- 91 door
- how to fit a cd player in a 1997 cavalier?? starting from a scratch.
- Does a non-cruise control car have the workings installed?
- New cavalier,Where to start?
- Exhaust questions
- 2004 Cavalier LS coupe
- Stereo Question
- 94 wiper problem
- wtb: engine for 97 cavalier 2.2 $$$$$$$$$$$
- Front end rythmic shimmy
- door help for my 2-door '88 cavalier
- black jell in coolent tank?
- 1994 Cavalier spark plugs
- sunroof questions
- conversion
- RIP da cavi
- 95 cavalier, signals aren't flashing
- Rear Brake Adjustment
- torques settings
- 1994 Cavalier stock Exhaust piping size?
- I feel dumb
- Bastards--new tires and rims problem
- 2005 questions??
- 2003 Cavalier funny noise
- Anti Theft
- 95 cavalier
- Clicking noise at very low speeds. Anyone else have this problem?
- 96 radio-reactivation?
- crankshaft sensor
- Squeaky dash
- is 1994 2.2l cav engine ok to switch parts with 98 2.2l engine?
- leaking antifreeze
- passenger rear strut? anyone got a spare???
- fs: 97 cavalier convertable needs engine
- Ignition switch/Neutral Saftey switch question
- 2004 Cavalier Stereo Questions
- Atf
- Does this actually work?
- best way to route wires through the firewall?
- strut bars
- sound systems..
- How many more miles will my 01' Cavy go? Currently 127,000
- Help lowering 2005
- Torque to me.....please
- Serpentine Belt
- Popcorn noise in rear
- Weird clunking sound from front suspension!!
- ABS sensor cost?
- 99 cavalier center console removal
- ABS Light
- Black Smoke from gas tank cap?
- Seat Belt Sticking
- AC Compressor turning slowly
- 1990 cavalier steering column
- a/c on my sierra 1500 z-71
- 2002 WONT START (similar to the buzz relay thread)
- Few things for sale
- Fuel gauge?
- problem installing deck
- Rotor Removal on 2001 Cavalier
- 2005 upgrades
- Wiper Removal 2000
- I need help with shift knobs, i cant get mine off!
- 1998 Cavalier air bags deployed, what needs to be replaced?
- 1997 Z24---dash removal to remove the radio?????????
- I for real need help with my sunroof.
- quick Q: need awswer asap
- Average Life?
- Cavalier Sunroof
- Can someone diagnose this noise?
- Cavalier Blower Switch
- I need help with replacing Vacuum booster on 97 cavalier.
- Speed Chips???? Please Help!!!
- bolt on body kit??
- help me start my cavalier
- need a driver window 97 cavalier convertable
- 98 -- removing door panel
- govenor
- Ebay Vs. Other Places
- important i need help
- Is this for real?
- rims
- Trany
- 97 Z24 - Electrical Weirdness!!!
- 95 lurching
- Most Common cavalier problems
- Installing a Aftermarket radio in a 01
- tires
- Where do you jack an '05 Cav?
- Adds by goooooooooogle
- Thumping sound coming from driver's side wheel
- AC Pressure Too High? What's Causing it?
- Problem with wheel and air conditioner, any suggestions??
- 2.2l L4 A/c, Diagram
- tinted windows
- Painted Tail Lights
- Random Missfire Problem!!!
- 89Z TH125 TRanny Help PLease!!!!
- highbeam indication light flicker
- police back seats?
- 2.2l ecotec performance?
- power window motor replacement
- Ebay Audio!!!!
- 2003 cavalier tranny
- Replacement Keys -- where to get & how much will it hurt?
- EBAY stress bar
- stalling 2003 Chevy Cavalier
- Stall out/jerky transmission
- 2000 Cavalier Orriface tube location
- Recommended Oil Again
- 2000 Cavalier fuel relay Buzz
- Decal
- Recommended Oil for 2.2 Ecotec
- A new sig
- 96 cav speakers
- Fuel rail wiring problem.
- tranny help plzzzzzzz
- need some parts
- 99 body kit
- 99 cavy for sale
- 1994 Cav Z24 needs a new engine
- OEM Fenders
- Pi$$ed
- 1996 Cavalier Auto Theft Light coming on
- were is the radiator fill cap on...
- clear corner lenses
- Cavalier Fault Codes
- hello, new.
- how2 install gauges
- 2000 cavalier keeps dying
- license plate
- input appreciated
- Turbo?
- Diagrams
- Yet another fishy cavalier problem
- cold air intake
- i need help
- AC should be working now, but...
- I really need help, car help.
- 95 2.2 engine into 97 cavalier problem!
- whats the best way to remove the chevy emblems?
- Z24 Cav Reliability?
- Worth it?
- Dark Graphite LS Seats front and rear wanted
- Cavalier timing help
- AC Speed
- Brakes
- Car wont start...only sometimes though.
- bad belt problems
- Stupid Question But How Do I...
- how to drain and replace coolent...
- 98 cavalier speakers
- 95 cavalier looses power
- 96 cav DRL
- headlight issue
- A/C question on cavalier
- 1990 Z24 Dash Removal to fix heater vacuum lines
- Slick 50
- Picture of my rims
- Biggest Tires/Best Tires
- 1990 Z24 Power Windows
- Timing...
- need some help
- 1989 chevy cavalier z24 for sale
- Newbie to the Forum but an Old Dog with the Z's
- pioneer deh - 525
- 3.1 v6 93 sunbird
- trouble starting 96
- brakes a little "soft"
- Lambo Doors
- New Top Poly Motor Mount
- Trans?, Steering?, somethings broke I think o_O
- Wheel Hub Bolts
- engine light on code po1810
- billy bob joe
- engine
- Changing brake line....3 quick questions.
- battery light
- What's wrong with my car?!?!??
