View Full Version : Cavalier
- Parting out 1992 Cavalier. EVERYTHING GOES!
- 89 cavalier 2.8 litre Z24 Convertible for sale
- center brake light
- After market stereo wont fit!
- Changed fuel injector o-ring. Now car won't start.
- Adding Power Locks and Keyless Entry
- What's wrong with my car?!?!?
- help..Changing cooling fan motor
- anybody selling a 2000 z24 front clip
- Exterior Door Handles.
- 93 Cavi front end Pop
- tires
- little money, more hp
- can i put a 3800 Intake manifold on my 1989 2.8???
- True Knock Offs
- Key won't turn in door and trunk locks!
- Smoke/Steam from Grill when started??
- cd mp3 player question?
- To all 2nd gen owners...
- Unknown warning signal on gauge???
- Back Seat...How do I get rid of it?
- How to fix door trim?
- 2000 Chevy cav brake lights and blinkers out..
- 94 2.2 disable auto lock
- Oil change...
- Turbosport Body Kit.
- Subwoofer in Cavi
- "winterize" my car
- Eibach Sportline Springs For Sale
- Auto Trans
- Dead Battery - Caused by Radio?
- 05 Cavalier LS
- Cavlier won't fire and no fuel
- Performance coils
- 93 cavalier fuel pump
- Made a video of my car
- 2000 Cav, Radio Just keeps scanning
- Here is a good one.. Highbeams make my tailights go out..
- front end problems
- question about my a/c
- Will these wheels fit my car?
- drum brake question
- 2004 Cavalier Mod questions
- Steering rack replacement
- Spark plug and Wire replacement question
- Fuel system problems
- Odometer light help
- Looking for pics
- quick question on spark plugs
- Power steering line busted. Help Please
- Hydraulic clutch cylinder
- 2000 Cavalier starter problems
- anyone used autopartsfair.com or GM-Car-Parts
- Horn not working on 96 Cavalier
- fuel pump damage
- Not car related
- Tuner Tube
- new purchase
- Help Ignition/Electrical problem
- queaking front end
- 2002 "Cavaliers" Any Chronic problems ?
- stalling
- 5 speed clutch oil leak slave cyl.
- what should i do?
- your opinion pls!
- Cavalier 98 ignition
- nitro fuel
- My busted up dash
- Cavalier fuel economy boosters
- Romote Start Passlock
- Need Help With Romote Start!!!!!! :(
- Tilt the steering wheel
- clear coat is peeling??
- cavalier 93 axle nut size?
- Glass Pack Muffler Exhaust System
- Wtb: Cavalier Spoiler Z24
- sprocket for cv joint bolt
- someone please help ME!!! 99 cav
- Brand New 03-05 Tail light
- A track, a boy, a car.
- Heater fan not blowing right
- It CAN happen to you. Theives are cowards!
- 99 Z24 Manual Shifter Assembly
- F1 Fenders
- Rotten Egg Smell
- Whats the best way to obtain replacement doors...
- theft system light
- single woman needs help
- I'm stumped! PLEASE HELP!!
- 99 Chevy Cavalier tire size?
- 2200 hp
- Fuel Pressure Regulator Chevy Cavalier 95-01 2.2l
- shift knob
- 93 cavalier
- RK Sport Bodykit.
- 94 Cavalier RS stalling
- ABS Light and Signal Problems on 99 cavi
- Two Questions
- 2003 Cavalier Stall - Scary experience
- Tach Questions
- How do I clean the EGR valve on my 97 Cavalier
- 2" inch lowering springs from RKsport (Eibach)
- So my wheels will be put on hold...
- New here
- trade me
- clutch master/slave cylinder
- turn signal replacement???
- CV Joints
- Unbelievable: Belt will not fit on new tensioner! 91 Cav
- 94 Cavalier Turbo Manifold
- Alarm
- Window Tinting, Rear - 96 Cav.
- 97 2.2 cavalier oil light engine knocking
- Any idea what could be wrong?
- Re: 2002 Cavalier LS with 2.4L engine....buyback or not?
- 1987 Cavalier stalling
- Replacing 91 Cavalier Belt Tensioner
- Alarm LED installation without alarm, for 99 cav
- dash cluster problem
- Thinking seriously about these rims, what do you think?
- new Cavalier's performance question
- 04 Cavalier starts but stalls after about seconds
- 1995 engine swap, auto in manual
- i know this has been talked about before
- How to Improve Performance on my 91 Cavalier RS?
- Speakers
- Stock wiring for stereo
- heater a/c fan problem
- Hi-Flow Cat for 2005 Cavalier
- 91 Cavalier RS Engine Swap
- Whats it worth
- messed up big time
- lifter,s ? on cavalier 2.2l
- help changing right brake light bulb
- Haynes or Chilton's?
- miss in engine/engine lite on
- tire pressure for 88 z24
- banging sound
- Viper 650XV alarm with 2 remotes
- Engine swapping question
- steering fluid??
- Winter rims
- Compatibility of Wheels and Tires
- 95 cavalier 3 speed trany slipping! nooo
- 91 Cavalier Runs bad/stalls when heats up
- cavalier 93 owners manual?
- defrost cavalier 93
- Eibach Sportline springs for sale 95-99 cav
- Knock from 3.1 L v6... Plz Help
- Throttle Body Spacer
- 98 Cav "Knocking" noise while turning
- Need HOW TO help
- Front suspension squeak fix
- how to tighten Rockers on 92 2.2
- Easy to do?
- exhuast brands
- Port and Polish
- Jet Pcm
- Pops A Dent
- Gas Leak From Fuel Injector (94 Cavi)
- pointless mod? is it legal?
- Starting
- power window!!!!
- How much is too much?
- Need your help
- Power Windows
- can I convert!02 Cavalier
- Lock radio
- Having problems starting, any ideas?
- 96 Cav Brake Light on After Towing
- is my belt tensioner going?
- Clunking sound from wheel area (rear passenger side) at low speeds, bumps
- 1994 z24 trouble code 43 need help please
- Toyota Cavailer
- 1999 Z24 won't start!
- vertical doors for '89 cavalier 2-door?
- timing chain
- Rear seat fold down and stall question
- trans am fuel
- stalling while idleing
- '87 tensioner/belt problems
- hp chip
- How Many Miles per Gas Tank
- Not getting fuel (2000 Cavalier)
- Vibrating/wobbling sound front drivers side wheel area
- '99 Calalier
- clutch
- Anti-Lock Brakes Fail when nearly stopped
- overheating
- Intermittent stalling
- Back Seat Lock?
- Need Help
- Help needed
- Parts
- Rocker arms
- 4x6's don't fit doors? any ideas
- Fan/Ventilation/Blower Help 94 Cav
- how important is Brand when shopping for breaks
- which spark plugs?
- Power Windows Help!!!!
- Trying to diagnose brake problem correctly, help
- Rear Brake Lockup on 1993 Cavalier
- holding charge problem chevy cav 98 2.2l
- New Exhaust pipe
- catalytic converter
- Antenna replacement
- Adding Keyless Entry.
- Why not thermostat controlled AC compressors?
- A/C switches engine off
- Ticking noise in the oil pan
- Has replacing this ever helped any Power window problems?
- Where did you guys mount your amp?
- Check OIL light
- 1 piece headlights for 96 cavalier
- Will 03 2.2eco strut bar fit a 96 2.2 non-eco?
- Do I fix it or not?
- Is this any thing to worry about?
- Keyless Entry
- Trunk does not open with key? any ideas?
- Sharks and Cavaliers
- signal wire
- anti theft reset?
- 97 cavalier oil light comes on when worm @ idle
- 1998 chevy cavalier rear defrost problem
- Help!!
- help wiring up headlights
- stereo removal...
- need cruise control wire harness
- 95 Cavalier chokes at 60 mph
- 2002 Cavalie power windows
- Radiator fan
- Removing Control Arm on '96 Cavalier
- How Do I Change The Breaks?
- Car won't turn on after rainy day!
- K&N Looks like they are total BS
- 1999 Cavalier Z24 window
- 1999 Cavalier Z24 Check Engine
- FYI: Water can be fuel
- 3.1L needs some help.....
- Howcome the Z24 V6 sounds so nice?
- 95-99 body kit
- 93 Cavaliers
- location
- cavy hoodscoops
- help
- Don Folk Sucks
- Nos
- Did i get a good deal?
- replacing my clutch
- 2004 style steering column shroud removal on cavy
