Chevrolet
> Cavalier
View Full Version :
Cavalier
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
2000 Z24 Cavalier Convertible
When do you change Tranny fluid on a 2003?
Rims
Forum
Exhaust
Ignition issues! PLEASE HELP!!
same shift knob?
Cant get all coolant in
louder!!!
Fuel Injectors....
Mint Like New 97 Cavalier FOR SALE
Turn Signal Mirrors
Help Defrost problem
96 z24
'92 Ignition problem...
how to remove 98 cavalier shift knob please help
selling the cav
Bleeding air
e-brake loose?
governor on a 94 cavalier
Shift timing 2000 cavalier
96 Cav overheating problem
96 Caviliar with no blower fan?
When do you consider a cav dead? 200k?
Replacing(or repairing) windsheild washer fluid bottle + not working?
Cavalier nitrous system
Engine
pulling steering wheel? on a 96
Lights in the vents
Radiator Fan
new top
gear selector not selecting
Sound Activated Neon Lighting
Belt diagram
brakes brakes brakes??? cavalier 93
1991 Cavalier - No Vacuum on Hoses is there suppose to be
Parting 98 z24
full specs of stock car
Burning Smell coming in the Car...Please Help
Headlight Covers
Motorswap
2000 Cav. No dash, radio, or interior lights?!?
torque converter, and solinoid
catalytic convertor
master cylinder or brake booster?
Numerous Amp and Sub issues
where do i restart my airbag module??
clearing code 0440?
brake pedal seek to floor when engine running
Bleed Valve????
overheating after coolant change
Cams and Engine/Transmission mounts
ETS lite off, and check engine lites
cam
Cavalier No Spark
1991 Cavalier - Acceleration problems - misses and lags
DTC Code 0442
Headlight is dim
89 cavalier 2.8 litre Z24 Convertible for sale
EGR valve
Unplugging a TCC?
I need a transmission rebuilding manual
Engine Rebuild ?
Bulb Replacement Question
starter question
new rims
where can i find CAMS for 99 Z24??????? pleas help
how can i remove a broken valve cover bolt?
Service Soon Vs Check Engine
2001 Cavalier Stalling
Scanned Code
Cold Weather
98 motor swap into 97 cavalier
94 cavalier motor swap question
low coolant light
FOB Programming 2003
Awsome New Idea For In Car Gaming!
99 Cavalier hard starting
Painting rims???
Auto transmission slipping in first gear
ecotec question
NEED 97' Cav. DIAGRAM!! HELP!!
Engine Swap
New Car input
no hot air from heater
Please help!!!!!!
Wire plugs?
Whats Your Favorite Car
Fuel Problem Car Floods & No Start
2.3 to 2.4
need help!
Spark PLug gap '91 Cavalier 2.2L
2003 GM Radio Harness info
inner tie rod removal
suspension combo
tach
remote start delema
2004 Exhaust diameter
Owners Manual
time for a new intake manifold!!!
programming remote.
Check Engine
KN&N Oil filter
B&M Shift Plus
::PICS:: My Muffler Burned a Cord And I Don't Know What The Cord does
attachments/photos
Fuel Filter
What would be the best header?
95 cav fuel line disconnect?
03 Cavalier LS won't start
SLR MCLAREN doors on a cavy?
1997 Z24 Fuel rail removal
Which One?
Timing Chain on a 1996 2.2
FS: *NEW DEPO 95-99 Diamond Headlights
Sponsorships
dash questions.
lambo doors
tranny? 1997 2.4 z24
Head Unit!
Refilling coolant.
Short throw shifter
quick question about cavy parts
turn signal
BLUE Armor-Coat Header
cavy vs supra 3
Some stuff that has to go!
98 Cavalier temp gauge problem with check engine light code P0117
cavy vs supra 3
1992 TCC Selenoid location...
New Cluster
what else but cv axle????
Black Hubcaps
1990 Cavalier daytime running lights
my baby wont start :(
Jensen
You know your girl is dumb if...
axil replace
Looking to buy Z24-Need Help
Body kit
Transaxel Oil Changing
Question on cavalier turn signal wires
ABS Question 94 RS
Looking for part name or number
arcade like steering?
03+ Ugly Rear Lights Answer
Parting out 89 Cavalier Z24
well..i guess its about that time
CV Boot Replace
Rksport Dual catback exhaust
wtb body kit 4 cavalier in houston (white)
Airbag light on???
mid 90's Cavalier
painting interior questions
91 cavalier ignition
head gasket
Adding power windows/door locks to 99 cavalier
drunk drivers (check this out!)
Apology
Cracked dash.
Fuel Filter!!!
Anyone else have this problem?
To much?
My 96 Z-24 is too slow.
Engine swap
Too much exhaust?
Anybody seen single piece headlights?
Turbo on 96 2.2???
94 cav, 2.2l will not start, Fuel Injector???
Head Unit Question!
NEW 2004 Dash Design Suggestions
Selling Car?
overheating problems
Cold air intake Fab question
2004 Cavy Dash Removal problem
Side moldings
Noob Muffler Question
How do I test Fuel pump on 1999 Cavalier?
Just like CRJ
I Need Rims AAAAAAAAHHHHHHHHHH
Air Bags
1999 Ignition Switch broke in theft attempt
Cavalier Z24
helpppppppp!
serpentine belt
Cavy's 106 Neon's ??
Head Gasket Replacement
AC control
fuel filter
Cavy Vs Supra 3
Tune-Up Suggestions
Clutch master cylinder
03 Cavalier Ls Air Control problem
rad fan
cavy vs supra 2
cavy vs supra
some pics of my fav cavys!
95 cavalier tranny swap help!! 3 SPD TO 4 SPD
Removing ABS?
Midas Muffler Installation
Wheel bearings & ABS
about seats
Advice on New Muffler
Tranny Pressure Line Upgrade?
Where Can i get good aftermarket parts for cheap?
Question.
limiter not
HELP... "Chevy took a shit"
2003 Cavalier front panel
2000 computer in a 99 z24 5spd?
help please
supercharger
89 cavalier vacuum line from pcv valve
New Stereo
Cavy Mod... What can I do?
Help me! Need to sell rest of led under kits.
exhaust pipe?
92 cavalier abs light
Rattle
Changing the altenator
Go me
transmission
0 too 60 mph times
03 Cavi Problem
Now this is some FUNNY shit! Won 3 races!
My baby is 4-sale..
Computer
turbo
B&M shift improver
HELP!!!!!!!!! programing a keyless remote
cavalier project for sale
Overheating/Rad Fan not working? ABS etc.
suspension
Clear Hoods
Duel Cannons
Help with ac/heater defrost!!!!!!!!!!!!
sig
89Z24 conversion
Installing a tach
1/4 mile time
Fuel Gage
New Person Again
2004 Trunk Bezel question
96 cavalier ac noice
Opinion?
coolant leak
New Person
Need Quick Help
Engine Swap -Help plz before i do something dumb lol-
