View Full Version : Cavalier
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. 93 Cavi front end Pop
  2. tires
  3. little money, more hp
  4. can i put a 3800 Intake manifold on my 1989 2.8???
  5. True Knock Offs
  6. Key won't turn in door and trunk locks!
  7. Smoke/Steam from Grill when started??
  8. cd mp3 player question?
  9. To all 2nd gen owners...
  10. Unknown warning signal on gauge???
  11. Back Seat...How do I get rid of it?
  12. How to fix door trim?
  13. 2000 Chevy cav brake lights and blinkers out..
  14. 94 2.2 disable auto lock
  15. Oil change...
  16. Turbosport Body Kit.
  17. Subwoofer in Cavi
  18. "winterize" my car
  19. Eibach Sportline Springs For Sale
  20. Auto Trans
  21. Dead Battery - Caused by Radio?
  22. 05 Cavalier LS
  23. Cavlier won't fire and no fuel
  24. Performance coils
  25. 93 cavalier fuel pump
  26. Made a video of my car
  27. 2000 Cav, Radio Just keeps scanning
  28. Here is a good one.. Highbeams make my tailights go out..
  29. front end problems
  30. question about my a/c
  31. Will these wheels fit my car?
  32. drum brake question
  33. 2004 Cavalier Mod questions
  34. Steering rack replacement
  35. Spark plug and Wire replacement question
  36. Fuel system problems
  37. Odometer light help
  38. Looking for pics
  39. quick question on spark plugs
  40. Power steering line busted. Help Please
  41. Hydraulic clutch cylinder
  42. 2000 Cavalier starter problems
  43. anyone used autopartsfair.com or GM-Car-Parts
  44. Horn not working on 96 Cavalier
  45. fuel pump damage
  46. Not car related
  47. Tuner Tube
  48. new purchase
  49. Help Ignition/Electrical problem
  50. queaking front end
  51. 2002 "Cavaliers" Any Chronic problems ?
  52. stalling
  53. 5 speed clutch oil leak slave cyl.
  54. what should i do?
  55. your opinion pls!
  56. Cavalier 98 ignition
  57. nitro fuel
  58. My busted up dash
  59. Cavalier fuel economy boosters
  60. Romote Start Passlock
  61. Need Help With Romote Start!!!!!! :(
  62. Tilt the steering wheel
  63. clear coat is peeling??
  64. cavalier 93 axle nut size?
  65. Glass Pack Muffler Exhaust System
  66. Wtb: Cavalier Spoiler Z24
  67. sprocket for cv joint bolt
  68. someone please help ME!!! 99 cav
  69. Brand New 03-05 Tail light
  70. A track, a boy, a car.
  71. Heater fan not blowing right
  72. It CAN happen to you. Theives are cowards!
  73. 99 Z24 Manual Shifter Assembly
  74. F1 Fenders
  75. Rotten Egg Smell
  76. Whats the best way to obtain replacement doors...
  77. theft system light
  78. single woman needs help
  79. I'm stumped! PLEASE HELP!!
  80. 99 Chevy Cavalier tire size?
  81. 2200 hp
  82. Fuel Pressure Regulator Chevy Cavalier 95-01 2.2l
  83. shift knob
  84. 93 cavalier
  85. RK Sport Bodykit.
  86. 94 Cavalier RS stalling
  87. ABS Light and Signal Problems on 99 cavi
  88. Two Questions
  89. 2003 Cavalier Stall - Scary experience
  90. Tach Questions
  91. How do I clean the EGR valve on my 97 Cavalier
  92. 2" inch lowering springs from RKsport (Eibach)
  93. So my wheels will be put on hold...
  94. New here
  95. trade me
  96. clutch master/slave cylinder
  97. turn signal replacement???
  98. CV Joints
  99. Unbelievable: Belt will not fit on new tensioner! 91 Cav
  100. 94 Cavalier Turbo Manifold
  101. Alarm
  102. Window Tinting, Rear - 96 Cav.
  103. 97 2.2 cavalier oil light engine knocking
  104. Any idea what could be wrong?
  105. Re: 2002 Cavalier LS with 2.4L engine....buyback or not?
  106. 1987 Cavalier stalling
  107. Replacing 91 Cavalier Belt Tensioner
  108. Alarm LED installation without alarm, for 99 cav
  109. dash cluster problem
  110. Thinking seriously about these rims, what do you think?
  111. new Cavalier's performance question
  112. 04 Cavalier starts but stalls after about seconds
  113. 1995 engine swap, auto in manual
  114. i know this has been talked about before
  115. How to Improve Performance on my 91 Cavalier RS?
  116. Speakers
  117. Stock wiring for stereo
  118. heater a/c fan problem
  119. Hi-Flow Cat for 2005 Cavalier
  120. 91 Cavalier RS Engine Swap
  121. Whats it worth
  122. messed up big time
  123. lifter,s ? on cavalier 2.2l
  124. help changing right brake light bulb
  125. Haynes or Chilton's?
  126. miss in engine/engine lite on
  127. tire pressure for 88 z24
  128. banging sound
  129. Viper 650XV alarm with 2 remotes
  130. Engine swapping question
  131. steering fluid??
  132. Winter rims
  133. Compatibility of Wheels and Tires
  134. 95 cavalier 3 speed trany slipping! nooo
  135. 91 Cavalier Runs bad/stalls when heats up
  136. cavalier 93 owners manual?
  137. defrost cavalier 93
  138. Eibach Sportline springs for sale 95-99 cav
  139. Knock from 3.1 L v6... Plz Help
  140. Throttle Body Spacer
  141. 98 Cav "Knocking" noise while turning
  142. Need HOW TO help
  143. Front suspension squeak fix
  144. how to tighten Rockers on 92 2.2
  145. Easy to do?
  146. exhuast brands
  147. Port and Polish
  148. Jet Pcm
  149. Pops A Dent
  150. Gas Leak From Fuel Injector (94 Cavi)
  151. pointless mod? is it legal?
  152. Starting
  153. power window!!!!
  154. How much is too much?
  155. Need your help
  156. Power Windows
  157. can I convert!02 Cavalier
  158. Lock radio
  159. Having problems starting, any ideas?
  160. 96 Cav Brake Light on After Towing
  161. is my belt tensioner going?
  162. Clunking sound from wheel area (rear passenger side) at low speeds, bumps
  163. 1994 z24 trouble code 43 need help please
  164. Toyota Cavailer
  165. 1999 Z24 won't start!
  166. vertical doors for '89 cavalier 2-door?
  167. timing chain
  168. Rear seat fold down and stall question
  169. trans am fuel
  170. stalling while idleing
  171. '87 tensioner/belt problems
  172. hp chip
  173. How Many Miles per Gas Tank
  174. Not getting fuel (2000 Cavalier)
  175. Vibrating/wobbling sound front drivers side wheel area
  176. '99 Calalier
  177. clutch
  178. Anti-Lock Brakes Fail when nearly stopped
  179. overheating
  180. Intermittent stalling
  181. Back Seat Lock?
  182. Need Help
  183. Help needed
  184. Parts
  185. Rocker arms
  186. 4x6's don't fit doors? any ideas
  187. Fan/Ventilation/Blower Help 94 Cav
  188. how important is Brand when shopping for breaks
  189. which spark plugs?
  190. Power Windows Help!!!!
  191. Trying to diagnose brake problem correctly, help
  192. Rear Brake Lockup on 1993 Cavalier
  193. holding charge problem chevy cav 98 2.2l
  194. New Exhaust pipe
  195. catalytic converter
  196. Antenna replacement
  197. Adding Keyless Entry.
  198. Why not thermostat controlled AC compressors?
  199. A/C switches engine off
  200. Ticking noise in the oil pan
  201. Has replacing this ever helped any Power window problems?
  202. Where did you guys mount your amp?
  203. Check OIL light
  204. 1 piece headlights for 96 cavalier
  205. Will 03 2.2eco strut bar fit a 96 2.2 non-eco?
  206. Do I fix it or not?
  207. Is this any thing to worry about?
  208. Keyless Entry
  209. Trunk does not open with key? any ideas?
  210. Sharks and Cavaliers
  211. signal wire
  212. anti theft reset?
  213. 97 cavalier oil light comes on when worm @ idle
  214. 1998 chevy cavalier rear defrost problem
  215. Help!!
  216. help wiring up headlights
  217. stereo removal...
  218. need cruise control wire harness
  219. 95 Cavalier chokes at 60 mph
  220. 2002 Cavalie power windows
  221. Radiator fan
  222. Removing Control Arm on '96 Cavalier
  223. How Do I Change The Breaks?
  224. Car won't turn on after rainy day!
  225. K&N Looks like they are total BS
  226. 1999 Cavalier Z24 window
  227. 1999 Cavalier Z24 Check Engine
  228. FYI: Water can be fuel
  229. 3.1L needs some help.....
  230. Howcome the Z24 V6 sounds so nice?
  231. 95-99 body kit
  232. 93 Cavaliers
  233. location
  234. cavy hoodscoops
  235. help
  236. Don Folk Sucks
  237. Nos
  238. Did i get a good deal?
  239. replacing my clutch
  240. 2004 style steering column shroud removal on cavy
  241. bad problem with 95 sunfire tranny/clutch?
  242. Funky noise
  243. Door hinges 1995-1999
  244. 91 Cav - 3.1 L Runs rough w/ Air Con on?
  245. 99 cavy headrest removal?
  246. Clutch Actuator Pipe
  247. 90 cav- they're trying to cheat me
  248. 95 Cavalier Bad ECM???
  249. Still can't figure out what's wrong!!!!
  250. 1994 z24 code 13,43,44
