View Full Version : Cavalier
- 2001 Shortshifter?
- Trans problem
- Racing
- Replacing airbags 2000 Cavalier
- anyone mechanically inclined, PLEASE HELP!
- 1994 Cablier Wagon
- head gasket blown
- picture of starter conections
- 99 Cavalier - No Brake lights or cruise
- 04 Cav Tail Lights
- Lots of parts for 1995 Cavalier Coupe
- 1997 Chevrlot Cavalier Z24 FOR SALE.
- 1997 Chevy Cavalier tail lights don't work
- Grease points
- 1997 2.2 Cavalier Starting and Idling Problems
- 1998 Alternator Light Isuue
- interchangeable parts
- Couple Teaser shots... ;-P
- 1987 Chevy Cavalier Sludge
- Genius Help Needed!!!
- Heater Problem '94 Cavalier
- 97 Chevrolet z24
- Source for weatherstriping
- 1993 tilt steering broken
- 2001 Cavalier 75000mi maintenance
- Track Off light on
- 97 cavalier for sale
- 96 Cav, Guage Cluster.
- Engine Block
- 1994 Cavy Oil Change
- side to side play in front wheel???
- 2000 2.2 HID Lights screwed up..? Funny
- O2 Sensor question
- Tips on coilover adjustments
- Looking for Aftermarket Parts for 1998 Cavalier!!
- HELP 01 Z24 Tranny Problem?????
- 98 z24 cavalier recall question
- kind of a dumb question
- 05 Cavalier
- will this 2.4 engine work???????
- looking for body kit for 2001 cavalier
- 2003 cav. wiper springs
- Studder question Please look
- 92 Cavalier feels like a standard after 60km/h(ish)
- *PARTS* Parting out a 98 cavalier 2.2 sedan *PARTS*
- 93 cavalier 2.2 runs good and dies in 2 min
- Power Window
- 5x100 19"s for sale
- 00 Cavilier, Dies on Occasion
- 1999 2.2L Car Won't Start
- 99' 2.2l Starting Problem
- 1991 cavilear torque specks
- 99 Cavalier Brake Repair - Allen Wrench Size
- Engine not warming up....Need opinions.
- Weapon R vs. Pacesetter
- How do you read the OBD codes on a 95 Cavailer
- '94 V6 3.1 Idling Rough
- 96 Cav, Starting Problem.
- power door locks
- Auto Insurance Comparison Site
- Manual transmission drain plug
- 98 cavalier muffler sound
- changing headlight bulbs to HID
- Changing 00 Cavalier Fuel filter
- 1997 Cavalier
- TCC solenoid 89 Cavalier
- Ebay...
- cleaning throttle body
- ALL the lights are on in the dash
- Letting my 17"s go for dirt cheap!
- Fuel managment
- 2003 wont start
- question about rear brakes
- cavalier clutch help PLEASE
- 93 Cavalier stalls when coming to complete stops
- new gauges
- E-85 Conversion
- for sale z24 motor
- rear left tire??
- what do you guys think?
- RK Sport Coilovers
- 2000, How to......Strut???
- Replacing Head Gasket on 1990 Cav.
- Remotes
- Eco-Tech oil filter cap
- No backup lights
- Change plug wires from the coil pack 95 Cav
- colour code
- heater blower resistor
- No clue!! Can you help me out a little???
- 1993 Ford Explorer Eddie Bauer Cd Player
- Front wheel stud replacement
- need new idler pulley/belt tensioner assembly which one should i get..
- noisey brake pedal
- removing the center consol
- try this one! radiator geyser??????
- Please Help!!!
- sometimes smoke/steam comes out of my hood@!?@!?
- alternator pulley/ dyno
- help engine swap 2.3l to 2.4l
- 1997 cavalier cranshaft position sensor location
- spark plug gap
- fuel injector setting
- What is the best Cavalier ever made?
- 97 cavalier AC COMPRESSOR PULLEY SYSTEM???
- 2002 cavalier mods
- Possible rad problem/rad fan
- Cutting my losses
- Stays in 5th gear then stalls?
- Garrett T28BB turbo Kits
- bumper replacement
- 98 Cavilier HeadrestRemoval ????
- Rear window defrost
- help ME PLEASE
- Help with an odd clutch issue
- sweet tricks!!!
- Determinging what 95 Cavalier OBD COnnection do I have?
- 1 wheel front tire drive?
- Help with Throttle Cable Bracket (need help fast)
- reverse lights
- anyone know how to remove the Belt Tensioner Assembly
- Bosch Platinums
- Rear Seat & interior 2k 4d 2.2
- Descreet modz needed...
- Tachometer signal for Remote starter
- anyone know were i cant get a idler pully?
- cd player problem
- 91' z24 bumper question
- Locked Up Manual Transaxle
- headlight troubles
- 98 Cav overcooling, yes, I replaced the thermostat
- Radio Removal
- spare car
- torque steering
- removing gaslines from engine???
- 95 Cavalier obc trouble codes
- s15 head lights
- Squishy hose?
- STP Products for Cavs?
- '97 Cavalier thermostat replacement
- help with coilovers
- Cold weather idle
- Lost Keys
- Check guages just now turned on. HElP
- 1993 Cavalier Z24!!! (Turbo)
- cd player installation
- Back Bench
- Hp
- torque specs.
- anyone know how mcuh an idler pulley cost?
- 93 cav
- 3rd Seat
- Air Bleeder Screw
- P0172 HELP!! Desperate need of any guidance!
- 96 bonneville - random misfire
- got a saturn thanks for the help guys
- what is the problem
- interior painting
- 1990 Z24 4 SALE (or parts)
- engine swap from 98 cavi OHV to 2.2 SFI
- cavalier=cobal?
- A-Pillar Gauges
- major problem!!!!!!!!!!!!!
- the rksport coil-overs?
- passlock problem need help
- How to pull out stuborn Fuel Injectors
- Check Engine Light
- mounts and strut bars
- Removing CD player
- Power Steering Pump question
- turbo 2.2L
- Minor Problem, 96 Cav
- idler pully ?
- Name this part...'92 Cavalier (pics)
- Engine swap causing inspection failure
- rocker arms, roller tips?
- Mufflers!!!
- Gas smell, hard starting, rough idle?!
- 2001 cavalier wont start, Not battery problem
- headlights
- 91 chev cav z24 flasher unit
- Creaking from steering wheel area?
- '92 Ignition Cylinder/switch
- Borla Exhaust
- Body Kit Question
- Z-24 1992
- Heating problems in Cavalier
- need a new rear deck mat
- Changing Headlights 2001 cav Z24
- Shift boot
- 95 Cavalier Check Oil Light
- ? about head
- Radio fuse shorting
- Short Throw Shifter
- 1993 Chevrolet cavalier brake problem?
- new here, pics of my car from begining to end (no 56k)
- Replacing the spark plugs
- hood
- Fuel Pump
- cavalier website?
- 83 Cavalier hood won't open
- Car noise need help finding what it is.
- sold the cav got a supra
- 2.4 Z24 1999 Convertible need engine
- 4t40e slipping when really cold out
- Will a 2004 4t40E fit a 1997 cav with a 4t40e
- MIGHT be coming back.
- why does it stall?
- Over-heating
- fuel filter troubles with quick connector 99 Cavalier
- Starting 94 in cold
- alright another question...major problems with my cavi
- Stainless Steel or Aluminzed Steel
- Head Gasket shims?
- why am i so stupid?
- The Fast and The Furious 3
- 86 Cavalier transmission connector
- Rk Sport speaker box / sub enclosure
- 2001 z24 2.4 litre missfire
- Airbag Compatability
- 03 CAVALIER LS Problems with starting
- turbo or s/c
- Man vs Auto
- selling 93 vl coupe
- Wtf???????????????
- 2000 Cavalier 2.2L Starts, immediately dies if no throttle given. UNIQUE problem
- Rear Right Engine Mount Bracket
- heat
- heater core
- Was I ripped off?
- noise in engine
- 98 cava
- 95 wiring diagram
- Larger Tire Size Question
- tach
- Looking at buying a 95 Cavalier
- Timing chain
- Bad Day for Oil Pan
- 2002 z24 running trouble
- Z24 cluster on 2.2
- Sweet Video
- Z24 Thrown Rod
- $1000
- Rims Questionnnn
- Vintage Cavalier
- sterio parts
- Engine Coolant
- Engine Coolant
- Shifting an Automatic
