View Full Version : Corsica
- Help! Changing brake pads for 93 corsica
- 1993 chevy corsica...
- 1990 Timing
- Turn signal replacement
- Brakes same on 01 Cav as 91 Corsica?
- Haunted Corsica's
- won't Idle
- start up
- help! I have no headlights
- TCC Solenoid, 89 corsica
- Engine Swap
- fuel pump
- 1 set Free Spark Plug Wires in Delaware
- speakers
- '94 Corsica Head Unit Install
- 94 corsica code scanner
- bad idle
- i need help knowing what is wrong with my 93 corsica
- still having startup problems
- dropping a 92 chev lumina 3.1 in my corsica what will i expect?
- cigaret lighter
- startup problems
- replacing the headlight switch
- Replacing Fuel Pump in 1990 Corsica.
- 91 Corsica, No heat, temp gauge max, speedo dead
- Heater Cores
- No Clue What Is Wrong?
- 96 Corsica Starts Only With Foot on the Gas Pedal
- why won't my 1992 corsica blow heat?
- Beretta to corsica
- cant get hood open
- Corsica Lurches forward at startup
- ignition switch is stuck! HELP on 1991 Corsica
- Ac clutch touching pulley with no Power
- 96 Corsica, won't start, clicks.
- 93 corsica overheating and leaking antifreeze
- 1990 Corsica Rough Idle
- transmision or converter problem ?
- All Sensors Clicking
- Overheating on a 1994 3.1 Corsica
- my fan isnt turning on?
- Ive replaced everything-- Help Please?
- 1996 corsica 2.2L
- Solenoid replacement
- hard start & back firing
- 1991 3.1, idle problem
- where are my speakers?
- 1994 Corsica front calipers
- 96 Corsica 3.1 V6 Engine Miss
- Would No power steering fluid cause the alternator wheel to snap off!?
- Coolant leak from the engine bolock? ist thats possible?
- Normal Temperature for 1994 Corsica ? 3/4 ?
- fuel,spark,compression and wont start
- '89 2.8l
- overheated my engine
- too tough to tame!
- Charging problems!
- 1989 corsica has no spark
- No Signals
- No heat
- 93 corsica running problems
- 1993 Corsica starts only when jumped
- Looks like my car does not have enough power
- starter on 89 corsica
- Now I am Scared!
- wiper arm needs adjustment
- 96 2.2 Timing... car quit
- Installing fog lights 96 Corsica
- 88 Corsica Cd Player Installation Help
- 96 Corsica belt tensioner
- 95 Corsica electrical
- '89 not starting... ignition module??
- 96 corsica "chattering"
- Camshaft timing
- question about 96 Corsica
- '92 Corsica
- Where can I get a rebuilt head for 1996 2.2L Corsica Cheap?
- 94 Corsica would like some adjustments
- A/C Compressor clutch doesn't engage
- Can idle speed be adjusted?
- Should I get this Corsica?
- '91 plug wire replacement
- I simply Don't Know!
- Corsica alternator
- High Voltage???
- 91 Corsica horn
- 1989 Corsica Tilt Steering Wheel Removal
- 89 Corsica Won't Start With Key
- Fuel Pump in 96 Corsica
- Turn Signal Problems...please Help!!!
- Underdrive Pully
- power?
- '91 Corsica running rough
- no heat, or air-- help
- lights all lit up
- For Sale: Any Part or Whole Car '89 2-door Corsica(Beretta GT)
- Chevy won't start
- Junk Corsica
- FOR SALE 1992 CORSICA Tail lights
- 89 Corsica Horn
- 1990 2..2 idles how she wants
- tire vibration
- where is the horn located on a 96 corsica?????????
- Overhead Light problem
- 1995 Corsica drive belt diagram
- 93 Corsica Hood
- Beretta GTZ '91 3.1 ltr. "gremlins"
- 91 corisca LT For Sale!! has 2 go!
- 93 Corsica 3.1T, temp gauge diagnostics
- Help Please
- anybody got a scanner and a haynes book for the firwall and heater core
- 93 3.1 v6 stalls, stumbles, dies
- Temp Gauge
- turbos in corsica
- help on replacing the left blinker
- 1990 hole in block
- Where can I find Beretta twin turbo hood
- corsica problems please help
- Corsica Engine Exchange!
- Help! Corsica cold brake clunking, grabbing
- cooling problem
- dual exhaust
- parts
- 1990 chev baretta
- oil pressure
- 1992 Overheating Problem
- OBD Code P0441 What is it?
- 95 Corscia
- www.corsicas.com
- SES Code C0441
- Replaced AC Accumulator - NO A/C Now
- Have fire and compression; need fuel
- Stalling when put in gear
- Need Help.........
- Engine Shakes
- Corsica Speakers
- 88 Corsica Stalled
- PCV valve
- 1990 Chevy Corsica
- Please need help on 90 fuse's
- 91 corsica, driving me crazy
- How much longer???
- 89 corsica for sale
- heating or moving some air around
- Need corsica, Beretta, or Cavalier Parts??
- Big problems
- 1995 Head Gaskets
- 89 corsica
- Rear Speakers
- SKIP THIS "FORUM" AND HEAD OVER TO...
- http://corsica.berettatalk.com/
- heater core
- engine info
- Blowing Fuses
- corsica wont start
- Removing my V6 3.1 from '94 Corsica
- Service Engine Soon
- Engine cranks too long when cold.
- Question for the Merlin
- Runs for 15, then dies
- 89 Tempest 2.0L --> Rough Idle :/
- Low fuel milage and black exhaust smoke
- No brake lamps, blinkers
- Pushrods
- low/no air flow on '91
- Corsica Racers
- Car goes completely dead.
- Corsica Died on me..
- No Horn, No Doorlocks
- Engine Light
- 96 leaks
- Engine hunting at idle
- Rain water leaking into car
- head gasket
- Fuel Mileage
- Stalling Problem
- oh yea
- oh yea
- CD Player install
- well..... if you want the truth
- Hey any corsica racers out there.....
- Hey
- need an owners manual '88 corsica
- alternator problems
- Corsica AC Relay
- where is everybody?
