View Full Version : Corsica
Pages : 1 [2] 3 4
  1. help me find? thanks
  2. 92 Corsica - For Sale/Parts
  3. Strange noise coming from belt area
  4. Stall, no fuel pressure
  5. Help diagnosing a problem
  6. Unable To Find 89 Ignition Key Lock
  7. Low Coolant Light -what is the cause (besides the obvious)
  8. 1996 Corsica Heating System
  9. corsica fuel gauge
  10. TCC solenoid
  11. O2 Sensor -- How to change it?
  12. Alternator - '90 Corsica, 4 cyl.
  13. squealing brakes?
  14. 1993 Corsica stalls out at stop
  15. 1991 corsica
  16. 1990 corsica NEED MORE POWER!!!
  17. Removal of instrument cluster
  18. 88 2.8 corsica no randomly no fire HELP!
  19. What to fix?
  20. 95 Corsica cooling problems/Need help!!
  21. 96 Corsica P301 code error
  22. 92 Corsica - No Reverse
  23. 95 corsica no defrost or heat to floor
  24. 94 Corsica/Car Locked Up
  25. 94 Corsica/Where is codes located to read
  26. '91 fan and temp gauge not working
  27. 92 Corsica Stalls
  28. Timing Chain Replace '96 2.2L Corsica
  29. Need Help w/ Work Car: 2.2L died won't start
  30. 94 chevy corsica v6 problem starting
  31. shifter cable adjust
  32. 89 Chevy Corsica
  33. corsica coil pack
  34. chance CPM
  35. head problems real bad
  36. 94 Corsica Spark Plug Sequence/2.2 engine...Need Help
  37. Corsica dies after idling,cools then restarts
  38. 93 Corsica wont charge battery, dies often.
  39. 1995 corsica heater problem
  40. '92 3.1L - CEL Code 13
  41. '96 Corsica 2.2L Idles rough, runs fine.
  42. 90 Chevy Corsica LT won't start.
  43. transmission and other problems
  44. 96 Corsica hard start, rough idle
  45. 95 corsica 2.2 has undercarrage popping
  46. 1996 corsica completely dead
  47. 94 Corsica 2.2 - surges.....HELP!
  48. Car Won't Shut Off - '90 Corsica
  49. 1990 corsica, no power
  50. 95 Corsica codes
  51. Will not stay in reverse....
  52. 94 corsica radiator fan
  53. 96 cosica ABS light on
  54. Service Engine Soon Light Flashing
  55. 95 Corsica won't run
  56. 94 Corsica 3.1 Water Pump
  57. 92 Corsica won't run, out of ideas
  58. abs light on
  59. ** BODY KIT for CORSICA **
  60. 89 corsica
  61. check engine light
  62. 1996 3.1 Corsica motor wan't to start, but won't
  63. '89 Corsica Trouble
  64. 95 corsica surges
  65. Trans Cooling Lines
  66. 96 corsica abs light on
  67. 94 Corsica 3.1L, engine dies
  68. just bought a 90 corsica 2.2 for my son....what should i know?
  69. 96' leaking head gasket
  70. fuel injector fix
  71. 96 O2 sensor wire colors?
  72. 93 3.1...acting like its not getting fuel...
  73. wix filter or k&n filter
  74. weeding out the rat
  75. 88 Corsica - bucking
  76. Tranni gone??!!
  77. (4 Power window motor problem with 94 Corsica
  78. Radiato replacement
  79. My brights stay on all the time
  80. Whirring noise and sluggish turn signals
  81. 90 Corsica drive shaft removal
  82. Fan relay and fuel relay
  83. 91 4 cyl rumbles like no tommorow
  84. Weird noise - like a whirring sound
  85. '95 Engine Trouble
  86. Paint on '90 Corsica
  87. Corsica seat replacement
  88. Temperature help
  89. 93 corsica brakes
  90. 90 corsica heat/air problem
  91. 95 Corsica Ignition Coil Dead Engine Knocking
  92. 96 corsica bogging and dying like it's out of gas
  93. 92 Corsica dies in drive or reverse.
  94. 91 corsica/radiator fan relay/switch/inline fuse
  95. flushing radiator of 1987 corsicia
  96. 93 corsica cooling fan
  97. removing cig lighter housing.....
  98. Water leak question
  99. Heater core question
  100. '90 Corsica DTC P0441 any hints?
  101. 89 Corsica where is the IAC
  102. 89 2.0L Radiator Fan
  103. 89 Corsica 4 cyl. Temp Switch/Sensors
  104. Heli Coil??
  105. Removing headrests in 96 corsica
  106. 88 door and wiper
  107. 95 Corsica A/C Problem
  108. Shifter knob 96 Corsica
  109. 95 Corsica gearbox will not engage
  110. New to this forum thing
  111. No Brake Lights-96 corsica
  112. 1990 Corsica 147,000miles.
  113. 91 corsica heater problem
  114. Blown HeadGasket?
  115. Speakers
  116. '92 3.1L Fuel Filter Replacement
  117. 95' corsica
  118. '96 Corsica 2.2L IAC Question
  119. 95 2.2 cold start problem.......
  120. 94 corsica jerking on highway speed! Help me
  121. Coolant motor help
  122. Fuel Pressure Regulator
  123. Fuel Pressure Regulator
  124. 95 corsica noise
  125. Rim Removal
  126. 95 corsica troubles PLEASE HELP!
  127. Door Locks
  128. 3.1 litre uneven compression
  129. 1990 corsica 3.1 problem
  130. Considering a Corsica?
  131. '93 2.2L Water Pump
  132. popping noise on front left side
  133. problem with brake lights on 90 corsica
  134. New, kinda old, Car!
  135. My 96 corsica starts to jerk as soon as i go over 45
  136. 92 Corsica power steering keeps getting low
  137. 92 Corsica power steering keeps getting low
  138. 95 Corsica klunk from park to R To Drive
  139. 95 Corsica klunk from park to R To Drive
  140. Corsica Radiator Fan Not Working....PLEASE HELP!!
  141. 94 corsica radiator fan
  142. Need to turn off DRL on '96 Corsica 2.2L
  143. '92 Corsica Door Latch Problem
  144. crankshaft sensor
  145. lights on instrument cluster?
  146. AC/heat controls
  147. corsica signal problems
  148. 94 corsica stumbles at hwy speed
  149. 89 Corsica runs rough and backfires
  150. '95 that won't go in park
  151. 1996 Corsica w/ 2.2L needs rebuilt head.
  152. 91 Corsica
  153. 92' Water Pump and Belt Tensioner
  154. !995 2.2L Transmission problem
  155. Starting issue
  156. cigarette lighter not working
  157. 94 corsica driner side floorboard wet
  158. 95 Corsica 2.2L
  159. help!!!!92 3.1 chatters /knocks can't figure out.
  160. Corsica Alternator odd problem? ...---...
  161. 93 corsica: battery???
  162. brakes
  163. 1995 V-6 Corsica Problems, Need advice ASAP!
  164. Jsgold Story on 1994 Corsica
  165. Wiper assembly
  166. 89 corsica 2.0 problems
  167. 93' Corsica
  168. Corsica quit running all of a sudden
  169. Thumping noise in speakers?? Short??
  170. Door Won't Open
  171. What engine to replace 94 2.2L
  172. Can I use a chevy 3.1 to replace a Buick 2.2 ?
  173. stalls upon acceleration
  174. 96 Corsica Blower Motor
  175. 1996 Corsica 3.1L V6 How to change thermostat?
  176. 1995 corsica 2.2
  177. corsica no code won't start when warm
  178. 3.1 cylinder 6 fireing problem
  179. 3.1 engine blown smoke bad!!! then dies.
  180. Blown Gasket
  181. 92, 3.1, spark plug problem
  182. '94 corsica v6 coolant leak
  183. 1996 2.2L 4cyl 185k
  184. Heater Switch
  185. 1992 corsica for sale runs good
  186. air con
  187. 95 corsica for sale
  188. Heater Core
  189. Heater Fan Runs Slow or Not at all??
  190. corsica for sale in chicago
  191. I can't drop the oil pan
  192. Won't start in certain temperature range
  193. a/c, temp gauge, no heat
  194. chevrolet corsica 1989
  195. Belt tensioner
  196. Rear defroster
  197. Water in engine?
  198. 96 corsica gears wont engage
  199. 1994 Corsica (2.2) - Torque Strut Missing?
  200. Ignition Module Replacement
  201. For Sale 94' Corsica V6 Cheap!!!!!!!!!!!
  202. 93 corsica: my belt came loose
  203. heater blower works no air comming from vents
  204. 95 corsica problem starting and runs sluggish
  205. MAP sensor
  206. 1996 2.2L starter
  207. 89 corsica
  208. motor mounts location
  209. Heater won't blow anything
  210. lights on electronic dash-- confused-- help
  211. 94 Corsica Starting/eletrical issues
  212. 1994 Corsica
  213. 93 Corsica - Heater and turn signal
  214. "95 Corsica Left Door Power window won't go Up"
  215. "95 Corsica Left Door Power window won't go Up"
  216. 93 Corsica...overheats, shuts off, no bad codes?
  217. Starting problems
  218. Front Brakes
  219. Spark Plug Wires
  220. starter
  221. 89 ignition wont shut off
  222. Lack of power with A/C on
  223. 93 corsica stalls and lunges at low speeds and when stopping
  224. Airbag light on .....'91 3.1
  225. 1996 Corsica V6 idle / surging issue
  226. Front Right Side Thump
  227. 95 4cyl 142K shakes real bad on start up
  228. Ignition switch
  229. engine stalls after 10 miles - won't restart
  230. 1989 Corsica For Sale
  231. radiator hose blowing off
  232. Radiator line ?
  233. 96 corsica losing power/missing
  234. Corsica nightmare
  235. 91 water pump
  236. supercharged 3.8 V6 in a Corsica!?
  237. bouncing, rattling, what the @#^%
  238. Engine Idles high
  239. 1990 Corsica lacks power and backfires
  240. 1993 corsica jerks and shakes
  241. 1994 Corsica Dies
  242. 94 Power window schematic
  243. Please Help Me Dammzal In Distress
  244. Trunk Help
  245. stereo cutting out
  246. engine computer failure
  247. Replace Hi-Lo Switch 1990 Corsica?
  248. 95 corsica for $400
  249. 96 Chev Corsica Torque Converter Clutch Solenoid Sticking
  250. Brake Problem
