View Full Version : Corsica
Pages : 1 [2] 3
  1. 96 O2 sensor wire colors?
  2. 93 3.1...acting like its not getting fuel...
  3. wix filter or k&n filter
  4. weeding out the rat
  5. 88 Corsica - bucking
  6. Tranni gone??!!
  7. (4 Power window motor problem with 94 Corsica
  8. Radiato replacement
  9. My brights stay on all the time
  10. Whirring noise and sluggish turn signals
  11. 90 Corsica drive shaft removal
  12. Fan relay and fuel relay
  13. 91 4 cyl rumbles like no tommorow
  14. Weird noise - like a whirring sound
  15. '95 Engine Trouble
  16. Paint on '90 Corsica
  17. Corsica seat replacement
  18. Temperature help
  19. 93 corsica brakes
  20. 90 corsica heat/air problem
  21. 95 Corsica Ignition Coil Dead Engine Knocking
  22. 96 corsica bogging and dying like it's out of gas
  23. 92 Corsica dies in drive or reverse.
  24. 91 corsica/radiator fan relay/switch/inline fuse
  25. flushing radiator of 1987 corsicia
  26. 93 corsica cooling fan
  27. removing cig lighter housing.....
  28. Water leak question
  29. Heater core question
  30. '90 Corsica DTC P0441 any hints?
  31. 89 Corsica where is the IAC
  32. 89 2.0L Radiator Fan
  33. 89 Corsica 4 cyl. Temp Switch/Sensors
  34. Heli Coil??
  35. Removing headrests in 96 corsica
  36. 88 door and wiper
  37. 95 Corsica A/C Problem
  38. Shifter knob 96 Corsica
  39. 95 Corsica gearbox will not engage
  40. New to this forum thing
  41. No Brake Lights-96 corsica
  42. 1990 Corsica 147,000miles.
  43. 91 corsica heater problem
  44. Blown HeadGasket?
  45. Speakers
  46. '92 3.1L Fuel Filter Replacement
  47. 95' corsica
  48. '96 Corsica 2.2L IAC Question
  49. 95 2.2 cold start problem.......
  50. 94 corsica jerking on highway speed! Help me
  51. Coolant motor help
  52. Fuel Pressure Regulator
  53. Fuel Pressure Regulator
  54. 95 corsica noise
  55. Rim Removal
  56. 95 corsica troubles PLEASE HELP!
  57. Door Locks
  58. 3.1 litre uneven compression
  59. 1990 corsica 3.1 problem
  60. Considering a Corsica?
  61. '93 2.2L Water Pump
  62. popping noise on front left side
  63. problem with brake lights on 90 corsica
  64. New, kinda old, Car!
  65. My 96 corsica starts to jerk as soon as i go over 45
  66. 92 Corsica power steering keeps getting low
  67. 92 Corsica power steering keeps getting low
  68. 95 Corsica klunk from park to R To Drive
  69. 95 Corsica klunk from park to R To Drive
  70. Corsica Radiator Fan Not Working....PLEASE HELP!!
  71. 94 corsica radiator fan
  72. Need to turn off DRL on '96 Corsica 2.2L
  73. '92 Corsica Door Latch Problem
  74. crankshaft sensor
  75. lights on instrument cluster?
  76. AC/heat controls
  77. corsica signal problems
  78. 94 corsica stumbles at hwy speed
  79. 89 Corsica runs rough and backfires
  80. '95 that won't go in park
  81. 1996 Corsica w/ 2.2L needs rebuilt head.
  82. 91 Corsica
  83. 92' Water Pump and Belt Tensioner
  84. !995 2.2L Transmission problem
  85. Starting issue
  86. cigarette lighter not working
  87. 94 corsica driner side floorboard wet
  88. 95 Corsica 2.2L
  89. help!!!!92 3.1 chatters /knocks can't figure out.
  90. Corsica Alternator odd problem? ...---...
  91. 93 corsica: battery???
  92. brakes
  93. 1995 V-6 Corsica Problems, Need advice ASAP!
  94. Jsgold Story on 1994 Corsica
  95. Wiper assembly
  96. 89 corsica 2.0 problems
  97. 93' Corsica
  98. Corsica quit running all of a sudden
  99. Thumping noise in speakers?? Short??
  100. Door Won't Open
  101. What engine to replace 94 2.2L
  102. Can I use a chevy 3.1 to replace a Buick 2.2 ?
  103. stalls upon acceleration
  104. 96 Corsica Blower Motor
  105. 1996 Corsica 3.1L V6 How to change thermostat?
  106. 1995 corsica 2.2
  107. corsica no code won't start when warm
  108. 3.1 cylinder 6 fireing problem
  109. 3.1 engine blown smoke bad!!! then dies.
  110. Blown Gasket
  111. 92, 3.1, spark plug problem
  112. '94 corsica v6 coolant leak
  113. 1996 2.2L 4cyl 185k
  114. Heater Switch
  115. 1992 corsica for sale runs good
  116. air con
  117. 95 corsica for sale
  118. Heater Core
  119. Heater Fan Runs Slow or Not at all??
  120. corsica for sale in chicago
  121. I can't drop the oil pan
  122. Won't start in certain temperature range
  123. a/c, temp gauge, no heat
  124. chevrolet corsica 1989
  125. Belt tensioner
  126. Rear defroster
  127. Water in engine?
  128. 96 corsica gears wont engage
  129. 1994 Corsica (2.2) - Torque Strut Missing?
  130. Ignition Module Replacement
  131. For Sale 94' Corsica V6 Cheap!!!!!!!!!!!
  132. 93 corsica: my belt came loose
  133. heater blower works no air comming from vents
  134. 95 corsica problem starting and runs sluggish
  135. MAP sensor
  136. 1996 2.2L starter
  137. 89 corsica
  138. motor mounts location
  139. Heater won't blow anything
  140. lights on electronic dash-- confused-- help
  141. 94 Corsica Starting/eletrical issues
  142. 1994 Corsica
  143. 93 Corsica - Heater and turn signal
  144. "95 Corsica Left Door Power window won't go Up"
  145. "95 Corsica Left Door Power window won't go Up"
  146. 93 Corsica...overheats, shuts off, no bad codes?
  147. Starting problems
  148. Front Brakes
  149. Spark Plug Wires
  150. starter
  151. 89 ignition wont shut off
  152. Lack of power with A/C on
  153. 93 corsica stalls and lunges at low speeds and when stopping
  154. Airbag light on .....'91 3.1
  155. 1996 Corsica V6 idle / surging issue
  156. Front Right Side Thump
  157. 95 4cyl 142K shakes real bad on start up
  158. Ignition switch
  159. engine stalls after 10 miles - won't restart
  160. 1989 Corsica For Sale
  161. radiator hose blowing off
  162. Radiator line ?
  163. 96 corsica losing power/missing
  164. Corsica nightmare
  165. 91 water pump
  166. supercharged 3.8 V6 in a Corsica!?
  167. bouncing, rattling, what the @#^%
  168. Engine Idles high
  169. 1990 Corsica lacks power and backfires
  170. 1993 corsica jerks and shakes
  171. 1994 Corsica Dies
  172. 94 Power window schematic
  173. Please Help Me Dammzal In Distress
  174. Trunk Help
  175. stereo cutting out
  176. engine computer failure
  177. Replace Hi-Lo Switch 1990 Corsica?
  178. 95 corsica for $400
  179. 96 Chev Corsica Torque Converter Clutch Solenoid Sticking
  180. Brake Problem
  181. Head Question
  182. 96 corsica - code p0441 evap purge fault
  183. A/C warm at idle
  184. factory hp for '96 3.1 Corsica
  185. 91 corsica no spark on 2&3 cylinder
  186. 1996 corsica emission purging code
  187. Installing A/C unit
  188. failed emmissions
  189. intermitent stalling while cruising
  190. 89 Corsica idle up and down
  191. 91 corsica engine cuts out
  192. 1991 Chevy Corsica Engine problems
  193. A/C question
  194. Aftermarket radiator question
  195. air conditioning help
  196. power steering fluid leak
  197. How to re-charge a/c system?????
  198. Where is my Thermostat located?
  199. Turn signals stay on and don't flash.
  200. power steering pump removal
  201. Should I or not
  202. '89 drum brakes
  203. vapor lock ?
  204. Plug wires mixed up
  205. Vacuum leaked fixed!!!
  206. Vaccum leak????HELP!!
  207. coolant leak, need part help!
  208. corsica engine stalls...but NOT tcc
  209. climate control knob???????
  210. Steering Wheel
  211. Where is the oil pump on '93 Corsica 3.l
  212. Timing Tensioner Broken 1990 Corsica
  213. Overheating and quitting
  214. Fuel Leak
  215. dead corsica?
  216. odd noise
  217. 91 corsica "Need help"
  218. Engine dies
  219. outside door handles
  220. rough idle, bad MAT sensor?
  221. corsica fuel leak
  222. 3.1 v-6 idles and shifts rough, codes 23 and 44
  223. 1989 Corsica keeps stalling
  224. Replaced altenator, problem with fan not kicking in when it should, help???
  225. Code 13... causes???
  226. replacing lifter
  227. Need Help no fan or ac 1995
  228. 96 Chevy Corisca/Disabling Child Locks
  229. Steering Problem...
  230. 1990 Corsica engine swap
  231. 88 corsica with no spark wheres the coil?
  232. Gas leak
  233. Engine Surging condition
  234. Replace Belt Tensioner on 01 Corsica
  235. 1995 Corsica 2.2L
  236. Corsica overheating
  237. New brakes 'soft'
  238. 1989 corsica with no headlights
  239. Radiator repair
  240. Need help with Engine Swap
  241. 1990 Corsica - Car doesn`t start at random
  242. no headlights
  243. The other 3 spark plugs
  244. Just bought first Chevy
  245. turbocharging
  246. sounds stupid, but my courtesy lamps dosnt work
  247. 89 Corsica Engine Races When Shifting From Park
  248. High Beam/Signal Switch... How hard to replace?
  249. '89 corsica no start- after remove broken lock
  250. Turn signals problems
