View Full Version : Caprice
Pages :
[ 1]
2
3
4
5
6
7
8
9
10
11
12
- installing a new alternator
- Also..Has Anyone Swapped Out Their Stock Headlights For
- What Is All Needed To Replace Shocks..
- electrical conversion question
- Another possible trans issue?
- 94 Transmission Possible Issue
- Timing Adjustment
- Cowl Induction or Ram Air
- 95 caprice dies after remote start install
- I have no SPID Label
- The best Caprice movie is Predator 2.
- 1987 Chevrolet Caprice. Need Some Help
- 91 700r4 repeat front pump leak
- Water leaks
- Throttle question
- rear defroster fuse
- oil all over passenger side under hood
- no start
- Crazy heater
- defrost
- Time for a new radiator
- how do you flush heatercore
- Alternator
- My new exhaust
- Rear End Clunking
- shifter linkage
- she took a bullet
- radiator fan is always on / so so heat !!!
- Wiper/washer blows fuses
- Stuck choke flap wide open
- help 94 caprice no taillights
- Rust on floorboards, gas tank, etc
- ECM necessary for cruise control? '87
- Blower problem - 1995 Caprice
- motor
- Holden Caprice 2005 Royale V8
- Sold but not forgotten
- 95 Caprice Hp?
- Noooo! Not another code!
- alternator
- ECM question
- power range on a 305?
- Car audio/electrical question
- caprice seats
- tires..
- Knocking Noise.
- my caprice is dead...... lovely
- what will fit 1986 Caprice Chassis?
- Problem with 1981 Caprice.
- 275's maybe?
- Gas Prices
- Keyless Entry Upgrade in my 95 Caprice Wagon
- Next Question...Tire Size For 82' Box
- Blown Fuseable Links...
- what year wagon rear ends are interchangable
- heater core issuses
- car leans
- non a/c heaterbox ? and posi rear end
- trunk question
- 1988 Caprice Cruise Control issues.(Where's the Fuse?)
- Key reminder chime?
- LS1 swap in my '93
- What color is my paint?
- 3 things
- a few odd problems
- a few odd problems i'm at a loss for ideas on these
- '87 Is computer necessary for heater to work?
- hail damage repair?
- instrument panel lights
- pinstriping removal
- Battery problem
- idles stumbles, then falls flat on its face
- Synthetic Trans Fluid. switch to or not.
- Differential fluid change?
- side mirrors
- New wheels.. New bolt pattern?
- Another paint question
- Which wheels compatible with a 94 9C1?
- brake block
- thought i would let yall see my work in progress.
- So I took my boxy to pepboys
- replace outter door handle?
- any one know if the newer 305 have roller lifters
- paint question
- shaking at high speeds...i think.
- towing capacity
- blue exhaust on startup
- i think its about time for an engine flush
- Check engine light code 174...
- lowering an '86 wagon
- 87 Caprice carrying on
- Moraine or bendix master cylinder?
- ignition wirers for alarm starter
- steering wheel problem
- 84 Caprice - Electric Choke not opening
- no pass no start
- Rare 9C1 magazine check it out!
- Newbie looking to get a 87-90 Caprice
- right side exaust doughnut gasket
- 1989 caprice rattling noise
- Code 14?
- 84 Caprice V8 350 5.7 Emission question
- 305 c.i.d life span
- Caprice Mpgs
- Blinker arm
- 86 Caprice TAILIGHTS WONT WORK! PLEASE HELP!!
- Wiper Switch
- Excessive play in ur steering?
- digital dash flicker
- caprice question
- just throwin da idea out there....
- Painting
- Car Wont Start Vats Wire Spark Help!!!!
- Sub/amp/electrical questions
- Update on the rear end noise
- Slow to heat/defrost
- ABS System.
- long road trip maintenance suggestions
- Oh, squeaky shocks
- GMC Jimmy Tires?
- idling problem info hesiatation/cutting off
- A few car show pics (mostly B-bodies)
- A post for Silicon :-)
- Installing alarm system
- 94 Caprice V8 'Engine light on, but no code"
- Strange rear end noise
- altenator change?
- Bouncing at idle?
- need some performance advice on a 305
- blower problem
- running prob's on a 79 caprice
- IGM needs replaced, how tough of a job?
- can some one get the history report on this car
- I just got a caprice
- Update on my car
- Window Tint
- Canada or not?
- i think i have a altanater prob
- 91 caprice leaking coolant leaking coolant
- Chrome Strip around Windshield
- 84 caprice dies at idle and stalls out in gear
- Carpet between rear seat and window
- '94 LT-1 proper fuel pressure number?
- weird problem
- Cant remove my valve cover
- A statement and a question
- Body work finished
- Smelling gas under the hood
- cutoff/kill switch
- I hit a tree
- Did some body work...
- EGR Valve
- be careful what you buy
- From manuel to power windows
- 95 caprice for sale?
- 85 305 Questions
- car stalls when shift into reverse when warm
- New video posted
- Results from my Emissions test...
- wont run
- 84 caprice door
- catalytic converter?
- Headliner replacement help...
- could fuel be my issue?
- Different sized alternator cases?
- Will a radiator from a 94 9C1 go into an 1980?
- still in need of advice
- 2 problems
- Ugh!
- more vacuum and EGR questions
- heater core?
- radio question
- Go 305 go!
- knock at startup?
- still having trouble
- 86 parisienne just died and will not start
- Im going to buy a caprice
- ac coversion
- tachometer?
- Update!
- Air cleaner question
- High Mileage Engine - Oil
- diagnostics codes
- what is this?
- 88 4.3L caprice RPM problem
- idling problem 3
- Rear End Questions
- rip off!
- idling problem 2
- wanted tail lights 1976 caprice classic
- Cuts Out !!!!!!!!!! help
- 9C-1 Transmission Specs
- 94 9C-1 LT-1 Starts, dies...starts, dies...
- rear end
- 9c1 springs
- great, just great.
- What causes speedo needle "parkinson's"
- Radio and Horn not working
- Wire Wheels
- does your speedometer move by itself?
- Oil leaking and possible coolant leak
- rattling clicking in steering column
- Sway bar end link dissapeared
- ABS Light on
- Nothing but new posts works?
- Carb adjustments
- Whoaaaa
- do you keep pictures?
- vent problems
- Is your caprice dirty?
- 95 9C1 idle/shifting issue
- 94 caprice rear outer bearing replacement
- 1966 Caprice
- brake issue
- 95 Caprice brake question
- I hate my front sofa (seat)
- it's like new!
- car smokeing i think is valve seals no sure tho
- power steering hose
- Your thoughts?
- Gas Vapors
- 1989 Caprice Overheated
- 2 wire or 1 wire alternator? '87 Caprice
- Pics of new dual exhaust on '87 Caprice
- Turn signal won't cancel
- Need Help
- Need AC help!
- hesitation problems
- No brake lights or turn sigals
- caprice has hesitation
- Where can I get these 9C1 wheels?
- Tilt wheel's all wobbly '87 Caprice
- OD of heater hoses '87 Caprice?
- cant find parts
- Factory battery hold down 87 Caprice what's it look like?
- can someone help me?
- Help
- my headlights went out what happened?
- 700r4 no lockup
- Door weatherstriping sticking
- Wanted NOS Caprice Parts ,Trim 80's-89
- Caprice Owners Living in Florida!
- '87 Landau trim removal
- chrome window trim
- I read the brochure... got questions now...
- Transmission ECU
- Airbox Mod (I know it's likely been said)
- 95 9c1 missfire HELP PLEASE
- Checking 1991 Timing
- Ignition switch adjustment?
