View Full Version : Caprice
Pages :
1 2 3 4 5 6 [ 7]
8 9 10 11 12 13 14 15
- looking for more power
- change top or die
- shakey acceleration
- Side Rear View Mirrors
- 700r4 no overdrive
- Help need power seat switch for 89 caprice
- How do you change the flywheel on a 1988 caprice
- ac compressor/overheating
- Squeeky Windows?
- 84 caprice wipers wont turn on
- Starting problems on a 77
- How different is my 94 LS from a 9c1?
- hot spot on 4.3L Caprice engine
- engine cleaning
- stock muffler
- Overheating Problem HELP
- new to the forum
- caprice to impala conversion
- '84 Caprice brake lights stay on
- Rewiring Front Doors on 86 Caprice
- High idle
- pick and pulling at the yard
- quick ac compressor question...
- Please Read!
- gettin no poweron 91 caprice 5.0 305
- 87 dash board.
- help please
- Speed Sensor
- radiator leak
- A Caprice Lost in Minnesota Bridge Collapse
- What Trans.
- 2 door and 4 door models
- larger distributor
- The trunk of your Caprice
- Ac Problems
- tps adjustment
- removing wheel wells 87 Caprice
- radiator hose
- 66 caprice w/ 86 corvette engine should i buy it?
- dome lights
- 8.5 rearend with 5x4.75 pattern?
- getting ready to swap 700r4s
- O2 sensor replacement
- headers
- Where can I find 9c1 rims?
- 85 Caprice Wagon Lug Pattern
- 1988 Running Rough, need advice
- Time for new belts?
- electrical issue
- Did my first burn out today...
- Caprice Euro Conversion
- seat belts
- liscence plate for gas cap
- Catalytic Converter
- 1986 chevrolet caprice
- PCM, or coincidince?
- 95 Caprice Power Loss
- 94 Caprice Acts Sluggish
- How To Change Spark Plugs On 94
- vapor canister valve
- Thick white smoke on startup
- 94 Caprice LT1 wagon, High voltage reading
- Question bout 77-90 Caprices
- Emergency Fuel Shutoff
- Caprice new shoes, and check engine light?
- 88 CAPRICE 4.3L TBI Problems I think it may be the transmission
- Hose leak?
- 84 caprice classic not cranking
- decoding body id plate from 1987
- Obd 2
- suspension
- progressive door unlock
- Back Spacing Question
- Mitt Romney and his Caprice Collection!
- acceleration issue?
- Parts Catalog
- landau
- how much?
- idle speed not constant
- Chevrolet Caprice Classic Convertible 1973
- Caprice clone to Impala Ss
- Update on engine knock
- 1987 Caprice issue
- Water Pump Knocking ??? 1991 305 Caprice
- belt issues
- tire losing air no hole though...
- How to install rear seat belts
- Digital Display - Miles not changing to Km
- Problem with 1990 Caprice
- Cowl Hood
- Noise from underneath
- Power vs. Looks
- Temperature Gauge Failure
- 1990 capricce classic trans troubles
- power auto locks
- AC and electrical questions
- electrical issue, battery warning light
- sale price ????
- Emissions diagram 1975 454cid ??
- headers???
- Electrical problem
- air sound?
- 94 caprice door panel removal
- 94 caprice digital speedometer
- air condition delete
- a/c problem, 95 Caprice with HD cooling.
- Carb and computer mods?
- Alternator and Muffler Questions
- Keypass Fault Indicator Showing
- Timing Q
- Why is my chevy running hot?!?
- Supercharger/Blower - Out of my league?
- rear end
- alarm as remote key only
- tires, rain, and bogging
- Carburetor issues or What?
- 86 caprice issues
- Hoods and Engines?
- Distributor or Intake
- Extra Clean Caprice 1991 A/c, Power Locks, Power Windows, Flow Pipes
- Fuel pump relay and fuel pump/PCM fuse
- Re: 2007 Caprice - Must see
- Never Ends: Motor Issue
- 2 electrical questions
- random electrical issues
- 93 keyless module location
- wipers
- Headlights not working
- I think my car has a cold.
- New 1987 Caprice to me
- spid anyone?
- Another exhaust thread
- muffler
- 88 in a 91
- Differential
- Click and NO FIRE!
- Euro Conversion
- 2007 Caprice - Must see
- 1994 Caprice Turn Signal/Wiper Lever
- where can i find cragar
- Vinyl dye?
- Brakes Acting Oddly
- Just got a -94 Caprice
- New To Forum
- Water pump Question
- Can anyone help?
- low oil pressure fuel cutoff switch
- 85' caprice and a 85' SS frontend swap?
- What does everyone think of this rust?
- suspension
- wiper sprayer
- Water VS Antifreeze & Clutch fan VS Non-Clutch
- Ideling fast, please help!
- TH 700-R4 Odd shift.
- Sea Foam - yes, no ?
- hood logo
- Voltage Regulator?
- Caprice windshield interchange ?
- floppy steering wheel bolts are tight?
- Caprice 92
- Charging Issues
- UGGGHHH!!!!!! not starting!
- Just got my first car.
- R12 Refrigerant
- cant use gas pump?!
- 2 Quick Engine Questions
- what does a transmission slip feel like?
- 305 to 350 vortec
- Time for a new water pump?
- bad idle
- advancing distributor
- Problems after start up
- 90 caprice running rich
- Sucking down gas
- 1994 caprice classic what leather seats fit make and year
- 1965 Caprice Front Fenders
- cat converters
- Fuel Pump and Gear Ratio Q's
- sequential taillights
- need links to accesories for 1980 Caprice
- '83 is smoking
- Another Wire Question - Oil Pressure
- Th 700R4 TCC - 3 Wires
- Emmision systems & gas mileage
- problems finding proper ac belt
- question about key clutch....
- Suicide Doors
- Can't leave well enough alone.
- strange noise from rear end
- quick simple question about rims
- Project Motor Finally Complete
- cleaning the hood
- Water in Air pump.
- transmission help please
- Lifter Pressure Valve Adjustment
- loose sound from wheel
- 1984 Caprice - need info on dash gauge and cornering lamps
- I smell gas...
- Need help with 92 caprice dont know what to do?
- funny idle
- need new speedometer
- 94 Caprice Radio Install
- possible 8.8" rear end swap?
- experts HELP : spark knock
- trunk light
- Dash/speed in park
- Dash/speed in neutral
- transmission?
- caprice 88 gauges
- Spedometer
- caprice anti-roll bars
- rear main seal
- windshield wipers
- Where can I find this?
- Brush Honer
- fuel line
- door speakers
- Early shift into OD, rough "bouncy" downshift only when warm.
- 87 caprice Freeze plugs
- air injection ?
- dash repair
- Shifting from park
- 96 caprice brake light problem
- distributor question
- rear end swap ?
- brake trouble
- Piston Break
- minor mods
- Putting in a stronger motor in my 87
- looking for chevy impala
- hello fellow capricers
- Exhaust Crossover???
- rear end question
- new to the forum
- Blinker switch
- turn signal/windsheild switch issue
- couple of ?'s everyone read
- Rust
- Noise Coming from Wheel
- electronic spark?
- Alternator or Battery?
- 700-R4 Overdrive gear
- 88 caprice headlight switch
- 96 caprice
- 87 caprice classic transmission issues
- Steering not aligned
- Engine misses
- 95 caprice 4l60e swap to a th350
- Trunk lock gasket
- compressor clicks
