View Full Version : Caprice
Pages :
1 2 [ 3]
4 5 6 7 8 9 10 11 12 13
- Oil leaking and possible coolant leak
- rattling clicking in steering column
- Sway bar end link dissapeared
- ABS Light on
- Nothing but new posts works?
- Carb adjustments
- Whoaaaa
- do you keep pictures?
- vent problems
- Is your caprice dirty?
- 95 9C1 idle/shifting issue
- 94 caprice rear outer bearing replacement
- 1966 Caprice
- brake issue
- 95 Caprice brake question
- I hate my front sofa (seat)
- it's like new!
- car smokeing i think is valve seals no sure tho
- power steering hose
- Your thoughts?
- Gas Vapors
- 1989 Caprice Overheated
- 2 wire or 1 wire alternator? '87 Caprice
- Pics of new dual exhaust on '87 Caprice
- Turn signal won't cancel
- Need Help
- Need AC help!
- hesitation problems
- No brake lights or turn sigals
- caprice has hesitation
- Where can I get these 9C1 wheels?
- Tilt wheel's all wobbly '87 Caprice
- OD of heater hoses '87 Caprice?
- can someone help me?
- cant find parts
- Factory battery hold down 87 Caprice what's it look like?
- Help
- my headlights went out what happened?
- 700r4 no lockup
- Door weatherstriping sticking
- Wanted NOS Caprice Parts ,Trim 80's-89
- Caprice Owners Living in Florida!
- '87 Landau trim removal
- chrome window trim
- I read the brochure... got questions now...
- Transmission ECU
- Airbox Mod (I know it's likely been said)
- 95 9c1 missfire HELP PLEASE
- Checking 1991 Timing
- Ignition switch adjustment?
- A/C Issue's!!!!!!
- Rear end?? What car? (3.42)
- Remove Vinyl top questions...
- I hate to post such a simple question...
- I found a jem of a 9C1, but need some help from yall
- almost wrecked the caprice
- Scared the hell out of me
- 1991 350 Exhaust question (I need quick responses)
- Rear end question???
- Newbie here... Is this forum active?
- 85 Caprice Classic Front Seats compatible with 89?
- Seat belt light
- brake light swich
- it's going up for sale
- Headlight trim/bezel help
- These are the best hedders headers for your 80's Caprice
- More emission woes...
- Time to fix it
- Caprice "hopping" on takeoff
- Deluxe instrument cluster to 9C1 cluster swap
- Rear end noise
- almost nothing works, headlights, brake lights etc etc
- New intake manifold gaskets didn't fix it.
- Steering box
- Ok...i Need Help
- Please Help Me
- front 4 door seats vs. 2 door seats
- Seats
- Need HP from my Chevy 267
- wont idle
- 72 caprice
- Help with vacuum and emissions
- 88 4.3 starter
- plastic piece between bumper and rear quarter?
- it died
- Custom 1991 Caprice Classic Wood Grain Steering Wheel
- Good police surplus site?
- What size exaust pipes and what about h or x pipe?
- Are the 9C1 center caps supposed to be steel or plastic?
- ethanol
- gas
- "Oh S**t" handles in a box caprice?
- Where to find Rims for a 94 Caprice Classic Lt1
- Summer's here and my car runs too COLD?
- trunk space
- who's put a 94-96 crossmember in a box chevy?
- URGENT: Water pump removal
- possible distributor failure
- any idea how to polish trim?
- code scan
- Hydrogen gas???
- caprice or similar for sale in central IL ?
- Dashboard replacement
- Car Starting, then Dieing immediatly,
- 94 Caprice Classic ex-FBI car questions
- Synthetic Fluids
- Grand National project
- early 80's to late 80's tailight conversion, and headlight cnversion
- need help with my new center caps
- how much is my car worth?
- Help!!!!!!!!
- I need help asap
- fender differences
- Major Help
- Junked my '84 Wagon Yesterday
- Parts
- 94 caprice wont start help
- I need a 94-96 dual hump crossmember
- Caprice died this morning...help!
- Nip/Tuck
- odd power lock problem
- optispark
- Nitrous system in an LT1
- Is the box chevy 2dr & 4dr roof the same?
- injectors and spark plugs/wires
- Transmission lines
- electrical short - windshield washers
- O2 sensor
- 87 Landau trim removal
- oil pressure
- 94 caprice body moldings
- Looking at a 9C1
- 1995 door chrome
- I thought all post '87 SBC engines came with roller cams!
- Domelight kilswitch?
- 1985 Caprice Doors
- ac repair?
- rev limiter?
- 96 caprice heater/vent control knob won't turn
- how to replace air compressor
- removing a/c installing bypass pully 94 Caprice
- Any one know which number...
- How do I post a picture of my vehicle option plate
- cruise control tower broken
- thump
- trunk popper
- alignment
- Flushing cooling system, 89 wagon
- moving the ac/heater controls
- Reverse lamp stay on 24/7 and engine idles when ignition off/key removed Please help!
- MSD distributor voltage question (motor's misfiring)
- OK Help Please!!!
- Electronic Level Control
- 84 overheating?
- how to change blinker lights on dash?
- Chevy/ caprice logo on trunk?
- what's this on my speedometer? 87 Caprice
- 1987 Caprice Want Posi Rear End
- What model engine do i have?
- Electrical Problem...
- vacuum engine troubleshooting
- 305 ecu vs. 350 ecu.
- Catalytic Converter....
- Burnouts: couple questions
- 89 speaker question
- '91 9C1? chevrolet has confused me..please help!!
- Name That Part!
- how do I tell?
- Feeling blue (and new)
- wiper adjustment
- New fuel saving device.
- messed up idle (btw Im a leangthy typer)
- Tapping sound?
- Sshould it stay or should it go?
- Re: 4.3 CPI Injector replacement pictures
- Anybody Need A LT1
- dont know....help?
- Caprice owners with a sound system-
- Hub Cap Covers
- **Will wagon springs fit**
- Starting issue still
- Idle is still too high
- My Caprice Hesitation on Video
- Window motor Help
- New Member
- Car won't start!
- New Duals Pics
- changing my ignition switch
- thinking of selling
- where is the ecu located
- Cracked vacuum line
- Power steering ?
- 92 Caprice Wont start....
- Anyone Interested...Selling my Dub Trumps
- Does any one have an ecu for sell
- Determining Rim Size
- Air cleaner / valve cover question
- Rear tire size
- Piezo element
- 87 Caprice heater hose routing here or here
- Tire size question
- Differential question open to a posi 1994 caprice
- O2 Senor and Dual Exhaust
- Electric Door Lock Switch
- Idle is high
- Help: need 1995 Caprice Classic tune-up advice
- how do i get the backseat out?
- 1993 GAS Gage Dosent work Or The Tempature Gage
- Squeeling Noise
- More '87 Caprice connector trivia woo hoo
- Need new battery tray, a good one!
- 94 swaping front clip to a 94 cadi fleetwood
- Me Again..
- Tranny Type.....
- 94 9C1 Low Oil Level Light
- vinyl roof question
- electrical help
- Slight vaccum issue
- Transmission lockup gear?
- How do I know which engine I have?
- How to check the oil in a 396?
- Front window swiches
- What do these connectors go to? '87
- Hello Carb Issue!
- Exhaust work est.
- gettin my 68 caprice together..
- Where is the headlight relay located on a 93' Caprice 9C1?
- Squeeky Speedo cable
- ECM with new engine?
- how do i hook up a tach??
- tach wire
- Caprice sits so high with new suspension
- Impala SS, 9C1, Caprice classic coil springs
- Throttle linkage problem '87 Caprice
- trunk release is not working
- Engine cleaning
- can 95-96 side mirrors fit on '92 doors
- Quick Question
- Headers
- Hello from the U.K
- 350 motor swap on an 86'
- Which way do the trani lines run? '87 700r4
- Starting problems
- Towing question
- Upcoming weekend project.
- Starting Problem
- odd change oil light
- I lost my ding ding!
- Carb Help
- 78 350 into a 95 Caprice
