View Full Version : Caprice
Pages :
1 [ 2]
3 4 5 6 7 8 9 10 11 12 13 14 15
- My car, 350 install results VIDEO (exhaust and some tire spinning)
- Trans help needed
- HVAC blower fan works, dont work, works, dont work
- ABS about to get me killed!!!
- AC pressure switch question
- lift kits??????@#$%
- Running rough and loud pinging
- Smoke comming out of oil cap
- Can I wax my wheel covers?
- Running too hot (185-220)
- The 350 is back and running great! Heres what the problem was..
- Start Up/ Missing
- a/c clutch
- 93 caprice 305 tbi shut off while drving
- sputtering on cold starts
- Does R134a Stop Leak work
- TV "kickdown" cable adjustment
- Quick question about spark plugs
- Check engine codes,and a few more ideas
- 95 Caprice SW change distributor help (pulley removal)
- Poorly mounted torque converter?
- Check engine codes and some carb tuning
- 9c1.net??
- My 1991 Caprice AC
- Need some timing help, almost there!!
- No spark
- If i had to change the flywheel...
- "Potential" flywheel problem with my TH700
- car stalls when i do this...
- Edelbrock carb vs. Holley
- 3 Wire starter?
- Identifying the date of my engine
- Quick water pump question
- Distributor Question
- Do i need exhaust manifold gaskets?
- Anyone know what these sensors are?
- How to bypass auxiliary oil cooler
- stiff accelerate
- 700r4 is going down
- Weird AC leak location
- A/C Noise
- Idle Air Control Valve
- I Roc Z Rims
- Is it engine problems with 91 caprice?
- Broken Column
- Where is da charcoal canister located
- A/C Water Inside da Car
- AC help please.
- power steering lines
- power steering
- caprice classic chugging when accelerating
- '94 brake line.
- 1994 new water pump makes service engine light come on?
- which one is better? energy suspension or powerperformancemotorsports.com
- Urgent: No AC or Wipers
- Discolored upper dash on 96
- The 350 with paint!
- canister purge solenoid
- Except Brougham
- Problems With Steering.
- replacing an Ignition Switch...
- my 1994 chevy caprice will not turn off..
- Engine Light
- Low Voltage
- Heat riser gasket???
- Pass Key Fault Light
- A/C Fan...
- Headlight Fuse
- Engine Code 15
- body alignment issues please help.
- Could flipping my air cover over hurt my engine?
- Thinking of a POSI, and other engine accessories
- Cleaning A Engine....
- 94 Chevy Caprice Air Fuse.....
- Meet the New Caprice
- Changing tranny fluid
- HID Problem...
- please help 5.7 liter
- 87 wagon stalls
- Temp Gauge up to high
- widest tire I can fit on caprice 91 sedan? please help
- high idle
- Mufler, catylic convertor, headers etc
- Dash Help.....PLEASE!!!!!
- best fluid you reocommend oil, transmission etc
- brake bleeder removal
- 305 to 350 motor swap
- 94 Caprice Classic overheating
- widest tires for 16x8 wheels on 91 caprice
- V belt to serpentine conversion?
- '94 Caprice 5.7L Please Help!
- Name the parts
- Chroming rocker panels & more
- Time for my '87s new rear end...
- 96 Caprice Power Window Tract Guide Replacement
- Question about my engine when its cold.
- The New B-Body Pics
- 96 losing oil
- sound deadener applications? anyone
- Mechanic suggested tie rod end replacement?
- LT1 Fuel Rail Cover
- Need a new carb -- suggestions?
- Got ANOTHER B-body!! lol
- 96 AC not working
- I Think My Car Is Possesed!
- 95 caprice stalls when cold
- Removing the crankshaft pulley
- Roughly how many volts from TACH terminal?
- Caprice Frame
- 89 chevy caprice problems
- New Molding
- Speed pulse indicator??
- Carb misadjusted?
- catalytic converter size
- Pics of the new Caprice
- Front bumper rubber strip
- Canister Purge Valve ?
- Problems starting in warm weather?
- Got ANOTHER Caprice!!!
- How do you adjust brake pedal switch? 87 Caprice
- Leaking Tranny Fluid
- INTERIOR - Headrest Removal
- Getting new paint soon..i have questions
- quick help with coil springs please!!!!!!
- 94 caprice problems
- Few questions about my Electric Q-Jet Carb
- 83 Caprice Top speed limiter
- 1975 Caprice rear end gear/rear end swap?
- Oil light
- caprice tech question
- Vacuum hose diagram??
- ways to give car better fuel economy!!!
- 94 caprice wont start when engines warm...
- runs for 5 seconds!
- brakes help....drums/shoes and rotors/pads
- 1989 caprice classic
- Looking at a 95 caprice
- 91 caprice suspension help please
- 88 Brougham
- 94 wagon rear end ratio?
- Catalytic Converter Removal
- Online repair manuals?
- Electric Controlled Q-jet Rochester carb 87
- which transmission do I have?
- Changing to the "euro" front
- 1994 lt-1 tune up which plugs/opti
- 1986 305cid ?
- 1986 305cid ?
- 1986 305cid ?
- 1986 305cid ?
- 87 caprice 305 running issues when cold
- Hood Differences
- no start
- Is this a problem with the Transmission???
- Difference in Engines between Caprice Wagon LT1 and Corvette Engine
- Wanted:
- Parking light wire
- Tuned Caprice
- 94 caprice digital speedometer problem
- I think my alternator has gone out.
- Please help...94 caprice LT1
- 2001 Nissan Sentra service engine soon light is on.
- trunk leaking!!!!
- 95 Caprice wont start
- 87 caprice problems turning off
- 94 caprice dash light problem
- Check Engine PO410 code
- HID conversion kit
- Where do I get police parts for my Caprice?
- change instrument panel to the Digital speedo and added gages?
- when i start my car..
- Heat/ac control unit
- Wagon and Sedan
- What kind of differential?
- Unable to adjust climate controls..?
- Water pump - new or rebuilt?
- heater valve question
- EGR question
- 87 Caprice electronic quadrajet not running good...
- possible trans issue
- Bumper Filler: Rubber vs. Fiberglass
- Picked up a wagon
- Car alarm/car stalling when warm
- Hurts to let you go..
- Messing around in the snow with my caprice again..
- Water pump dripping
- I GOT the 350!!
- Fog Lights
- Ball Joint question - confused...
- 85 Caprice is missing, think its a vacuum issue.
- Picking up a 350 today!!
- custom interior?
- Overheating Issues.
- Seriously thinking about 305 upgrades
- ticking sound 94 caprice
- a bit boggy
- transmission cross member....
- Bench bled master cylinder and all 4 wheels, spongy brakes
- hard starts
- 94 caprice suspension
- Everybody else's look like this?
- Changing passenger side plugs
- Some 84 Issues
- 92 camaro
- excessive smoking
- Do I really need to bench bleed new master cylinder before installation?
- Found a weird part sitting inside throttle valve spring...
- Gave my car a new intake
- Best place to hook up vacuum for cruise control?
- holly 4barrel duel pump
- Anybody know what transmission this is? (pics)
- want to lift my car or at least get it back to stock height!
- Warming Up Your Car In The Winter...
- anyone else drag race their b-body?
- Busted transmission piece...what is this?
- Master Cylinder leaked all over booster, firewall, & frame :(
- Dash light problem
- Anybody got a pic of there throttle linkage with functioning cruise control?
- battery problems
- front windows
- 94 caprice. loss of power when its raining
- Loudest mufflers or resonators
- Shift points
- Carburetor Adjustments
- My 1988 caprice failed emissions
- transmission wont shift out of 1st
- Brightest legal headlight?
- I found a 350, need opinions
- 12v accessory power
- Winter storage questions
- Car Problems..
- i need help 89 caprice dies
- 91...tboned caprice
- 96 dash and cluster
- Rear Defogger Relay
- throttle sticking
- Uh-oh, heat not working
- Weird fogging
- Determining spring rate
- Advice on My 1980 Landau For new TPI Motor
- Valve cover change is killing me
- Trans adjustment?
- Won't start
- 89 caprice trans swap question
- Car shows!!
- Need Help With Guage Cluster Wiring.
- Should i buy another caprice?
