Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Isuzu
> Amigo |
View Full Version :
Amigo
Web
AF
Hello & Plz Help!!
1990 isuzu amigo 4x4 blck (does not run) for sale.
Acid building up on battery terminal
Radio and clock not working
94 amigo temp sensor
Losing Engine Oil
1994 amigo bed cover /tires?
Dead, only the dreaded clicking noise
1998 Amigo noise problem?
1998 isuzu amigo 2.2 4 cyl
1999 Amigo Rear Window Washer
Grinding and Squeaking
89 Amigo-no-start
89 Amigo-no-start
need sunroof for 99 amigo
1999 Amigo with a dash light issue
2004 Axiom XS Reliability and Value
vibration when accelrating and stopping 2000 amigo 4wd
WTB:2wd Isuzu Amigo
help idle problems
Parting out a Rodeo Sport or Amigo, anyone?
single mom ?over her head?
How to buy parts for Amigo from Europe?
serpentine belt
Isuzu Amigo 2000 - Sparkplugs or Gas Pump failing??
1998 Amigo starts and dies
1990 amigo 2.6 starts than stalls
Replaced the starter on 1998 Amigo
4x4 problems
1998 Amigo
1998+ rodeo/passport/amigo parts for sale
Removal of 99 amigo hardtop
94 Amigo instrument cluster 2WD, 5 speed
Hissing noise from tranny..
1999 Amigo Sunroof cover
Needing parts for 94 Amigo
Beware!!!
Rodeo Sport Amigo Top Zipper Window Repair
dash indicater says in Nuetral but I am actually in Drive
98 Amigo drivers door window motor, remove?
98 amigo 2.2l 5 speed 2wd-coolant loss
Hard Top for '92 Amigo
lightbar
Amigo brochure
Cam sensor
Want to buy: Isuzu Amigo Sunroof covers
Looking for Amigo differential or rear end
engine swap?
90 Amigo 2.3 - Idles then stalls
Vibration when accelerating from stop!
2.6L MFI to carb conversion
soft top hardware
Having trouble clearing P0401 code on a 98 Amigo
Amigo won't start
TPS Voltage Low
99amigo 2wd convert to 4wd?
amigo transmission wanted
Head removal
Need help removing old water pump
wont move?
Surge, Stall, Hard Start
remove sunroof
ABS light stays on & 4WD light flickers?????
multiple cilynder ignition malfunction p0300
Annuda Won't Start Thread '90 2.3ltr Amigo
i need the motor code
Torque specs. for fuel rail mounting bolts
Power Accessory Relay
1999 Isuzu Amigo Glove Box Door Stuck!
wont start :(
'98 Amigo clutch problems ?
Noob needs help with 91 Amigo starting problem
Rear Brake Caliper Torsion Spring loose
99 Hard Top
Factory alarm upgradeable?
92 2wd amigo 5sp $850
Blinker issue... HELP!!!
1999-Roof Question (Plastic Covers?)
2000 Amigo ABS Light
2000 Amigo Rough Ride
92 Amigo Lighter issues
Parting out 98 Amigo 4x4
1999 Amigo fuel level sending unit code P1627
Hi beams work lows don't
FS: 1999 Isuzu Amigo
Valuations 94 Amigo 4x4
Amigo turbonator
Amigo 1992 help parts
1999 Amigo Chasse Lubrication Points???
New Motor
Wrecked Amigo won't start!!!
Air leak?
What to look for.
Rodeo V-6 Engine blown
2000 Amigo 16 To 15 Inch Tires
93 Brake Caliper Compression
stalling
hose routing
size of gas tank
"99" Amigo/Rodeo Sport poor gas mileage
drive train failure??
Clutch Bleeding - No pressure
Need info on converting 90' amigo to 2.8 diesel
2000 amigo~crakced head
temperature sensor 91 amigo
stubborn pipe nuts
91 amigo exhaust manifold problems
'help motor problms'
Amigo starts then dies
hey
99' amigo coolant disappearing???
must sell my 02' Rodeo Sport
wiring diagram
Replacing dash lights help needed
red RH door needed
Bizarre Alarm Problem on '99 Amigo
Wanted: Hardtop For 91 Amigo!!!!! Help!!!
99 Amigo stalled. Turns but does not start.
Horse Power
4wd kicks out @ 45 MPH posted on Rodeo also
Front end
Isuzu amigo diagnostic code help!
98 3.2 dohc, want engine swap
New Sending Unit... Still says empty.
cold air intake
"multiple cilynder ignition malfunction".
Help Please!!!
1990 2.3L help
Soft top to hard top
bagged isuzu pickup?
'98 Amigo - stuck on crankshaft pulley
Accesories and parts for 91 Isuzu Amigo ?
Engine
Cam Sensor Voltage
Camshaft Sensor
Glovebox Removal???
isuzu amigo with tail lights blowing fuses
Racing Amigo
Fuel gage on 99 v6 4x4 messed up
'94 overheating. water in exhaust. help
99 amigo-fuel filter/gas hand
Shocks for 1999 Amigo
'90 Amigo horrible rear end squeal
Exhaust
1998 Amigo 2.2L head gasket needed. I think its blown
98 Amigo Parking Brake
Won't stay running
Speedometer, odometer, tacometer broken
dumb but true question
vacuum routing problems
99 Amigo Sunroof cover for front sunroof
will not start
99 Amigo fender
For Sale: Sunroof hard cover & head rests
OME lift springs
amigo tube bampers
Obdii Error 1220
Now Here Is An Idea!! Help me out!
Buying a '99 Amigo
1998 Amigo Buying
what type of oil?
1994 Amigo Loses Power Stalls/ Need Diagrams
2001 Rodeo Sport Gas Tank
1999 Amigo 4WD/Auto won't start or move
2002 Rodeo Sport leans slightly to right.
Welcome to the Forum: Read This FIRST!!
1998 Isuzu Amigo Hard Top Wanted
93 amigo v6 auto for parts in tampa fl
stuck parking brake 93 amigo
94 amigo parts?
Wanted: 98 Isuzu Amigo hard top
ignition stuck please help
capacities chart
"Check Engine" and "Check Trans" lights both came on after a gas fill-up
'99 Amigo - Average mileage life expectancy for these vehicles?
starting problem...
For Sale:K&N Replacement air filter
No turn signals on 90 amigo...
electrical or security system problem
1990 amigo fuel pump relay problem???
External oil pump on 99 Amigo with 3.2?
Vehicle speed sensor Amigo 99
FOR SALE... 92 Amigo Custom made parts.
Amigo Timing Belt Issue
Looking for Amigo to photograph in PA
Transmission Problems
FS: 94 Amigo
Softer ride
95 Isuzu Rodeo starter problem
does anyone have any advice for a 90 amigo 2.3
89-94 Amigo Top NEW!! $225.00
94 amigo looking for new owner
engine problems
amigo 94
isuzu amigo 94 for sale
ISUZU AMIGO HARDTOP anyone ??
Isuzu Amigo 1994 Many Key-click To Start Engine
Parts help.....
94 amigo
Accessories for sale
Web
AF
