View Full Version : How-To's and Walk-Through's
Pages : 1 2 3 [4] 5
  1. HELP! I am locked out of my del Sol's TRUNK!
  2. cd player problem
  3. 1986 Accord Lxi steering problem
  4. Need help with Gauges!
  5. 88' CRX stock stereo removal manual?
  6. Power window regulator cable
  7. Idol troubles
  8. cruise control problems
  9. bulbs in instrument cluster
  10. Questions about 95 Civic EX
  11. Need Help With Exhaust System!!!
  12. 92 accord lx fuel pump removal
  13. how H22 Swap into a del sol 93
  14. I need plans for fiberglass enclosure in Hatch Civic
  15. B20A3 To a ?????
  16. Prelude Nightmare
  17. Mini me head swap?
  18. 98 civic PO420 check engine code
  19. Burnouts and time???
  20. 1999 Honda Civic LX
  21. Raising a Lowered Car?
  22. how to wire msd in my 97 hx
  23. help fuel problem?
  24. DC 4-1 header mod.help?
  25. Opinion on transmission
  26. 1987 Honda CRX Si how to install tach
  27. How to prime????
  28. ABS - How do you know?
  29. Replacing front upper control arms, is it easy?
  30. Drive Axles - how to replace?
  31. 94 Accord front brakes
  32. Slicking up a dash
  33. check engine light 96 integra gsr
  34. Master Brake Cylinder
  35. changing radiator-have manual but any advice would be great
  36. Location of Brake Lights on CRV?...
  37. 1992 b18 into a 91 crx?
  38. Check Engine Light 00 Accord V6
  39. rear wheel bearing
  40. timing
  41. 91 Accord - identify 3-wire connector?
  42. Car leaking white liquid Help
  43. intermittent wiper relay 89 honda accord
  44. North Carolina emissions sticker removal
  45. speaker trouble
  46. Need an experienced DIY's help
  47. Integra GS 1990 Distributor
  48. headlight help
  49. 85 crx engine
  50. hooking a tach up into my del sol
  51. vibration
  52. help
  53. Need information on replacing 87 Accord LXI hatchback
  54. painting
  55. h22 swap into a civic hatchback
  56. speaker panel
  57. more hp for my 2005 civic non-vtec
  58. Need help To convert to power windows
  59. location of srs module
  60. sealtbelt buzzer
  61. sealtbelt buzzer
  62. how to make this 93 accord faster
  63. Angel eyes on a 93 civic 4dr
  64. 93 Honda Accord NOTHING WORKS
  65. Installing aftermarket headlights
  66. b18a1 into a 95 civic HELP HELP
  67. tach on 2005 civic
  68. Need Help!!??
  69. Program Garage Door Opener on 99 Accord
  70. removing stock cd player
  71. 1990honda civic hatch virgin car please help
  72. Starter motor replacement
  73. air/fuel mixture
  74. 92 accord ex locating IAT and CTS
  75. how to on hardwiring a Bel 985
  76. 04 civic sedan, stereo and speaker removal
  77. MOMO Steering wheel on....horn????!?!?
  78. CRX Thats starting to p*** me off...
  79. Need Help With Cold Air Intake
  80. stereo wirediagram
  81. how to install a tachometer to a 1988 honda civic std, or a tach wire diagram
  82. dash light
  83. Paint
  84. 92 accord a good car??
  85. 91 civic dx vacuum
  86. Timing Belt on 89 Hatch
  87. Anyone ever install a Power trunk release (522t) on 03 Civic?
  88. re in dualpoint conversion
  89. Hood Release
  90. taking out factory stereo
  91. Paint chipping Q? Can I reduce it or stop it?
  92. Dual point coversion
  93. adding oil pressure guage
  94. looking for info
  95. Acura Legend, 1990
  96. how do i get the front rotors off of my 93 accord???
  97. Smoked/tinted taillights
  98. 96 Accord 25th Anniversary Edition
  99. altenator or ground short
  100. transmission makes a click sound
  101. help me wit my valve clinking??
  102. Header Gasket Problems!!!!!!!!!!hheellpp
  103. How to check my coolant temperature sensor?...
  104. Speedo
  105. 2003 accord questions
  106. white gauges???
  107. suspension install
  108. B16 Sir How Do I Hook Up A Tachometer
  109. no power
  110. honda civic 1.5l questions????
  111. spark plug question
  112. Eagle Eyes Projection light
  113. 93 Accord CV-Joint
  114. need info on b16 clutch replacement
  115. Need advice on installing 86 Accord Head
  116. half shaft help
  117. rust removal
  118. Looking for information on how to lower 85 civic
  119. 02 Civic Tail lights
  120. crvtec ????????????
  121. Tranny rebuild
  122. 1984 crx timing
  123. 1994 Civic EX - Electrical problems?
  124. 91 prelude spun bearing
  125. Motor Mount For Dohc Zc
  126. Skunk2 Cams
  127. antenna
  128. Automatic Shift Kit!!!
  129. Del Sol exhaust
  130. Horsepower/ torque help
  131. Underdrive Pulleys
  132. Controlled Shifting
  133. b16a swap into crx
  134. venom 400 installation
  135. Took yalls advice.
  136. Greddy Turbo timer qestions
  137. Please Help!!!
  138. Ram Air Intake
  139. ecu code 4
  140. newbe my 86 accord the tail lights wont turn off any ........
  141. integra guage cluster
  142. need help replacing alternator on '87 accord
  143. spray from your fenders, wiper nozzles....
  144. body mods for my hatchback
  145. problems with surging on my 91 civic
  146. hlp wit cylinder head cleaning
  147. HELP!! with 97b18 into 90 teg
  148. Engine performance HELP!
  149. 1992 Oldsmobile 88 Royale still stalls
  150. Transmission Help!!
  151. Quick question on brake pad shims
  152. 91 Accord Lower Radiator Hose
  153. how to set timming
  154. Gauges and Fuses
  155. Power Steering Belt
  156. eBay intakes
  157. having problems wit honda zc swap
  158. b18b with no spark, help me please!
  159. 1991 legend fuel pump problems
  160. Noob Needs Help
  161. Interior lighting made easy
  162. Rpm gage
  163. steering for civic
  164. HID kit, how to get it to work?
  165. autometer gauge help
  166. basic stuff
  167. Indiglo Gauges - 2001 Civic
  168. abs system problems
  169. Removing the Fuel Pump from 91 Accord
  170. indiglo gauges
  171. Accord starting problems
  172. '86 Accord that won't start...
  173. bodywork
  174. installing header
  175. possible to convert b18a1 to vtec
  176. Help!
  177. Timeing belt broke
  178. no power
  179. Honda civic tune up indicator
  180. 1995 acura legend help!!!!!!!
  181. This is off the subject
  182. 2001 Civic - Where is the starter?
  183. 92-96 prelude headlight removal?
  184. Lock mechanism failed
  185. Automatic window problem
  186. FORUM RULES AND GUIDELINES - MUST READ!!!
  187. VIN check...
  188. 89 Accord blown clutch
  189. Please Answer A.s.a.p.
  190. Lambo Doors-'99 Civic?
  191. Swap B18C1 into 93 Integra GS
  192. CV Joint?
  193. replacing water pump on 89 accord
  194. O2 Sensor
  195. engine over heating
  196. Accord 2002 Front Fender
  197. head lights
  198. No Spark (help) Me!!!!!!!!!!!!
  199. My Car won't start
  200. 1994 Honda Civic LX, 5 speed trans. Help!!!
  201. Changing Headlight Bulbs..
  202. Strut Bars------Push or Pull?
  203. Some more dumb Q's from me
  204. dome light + aftermarket radio
  205. Drive axle? Need help please!
  206. Removing Factory Radio
  207. where do i get it??????????
  208. signal wire
  209. Replacing The 2 belts
  210. Mini-Me Build Instructions?
  211. integera gauge faces???
  212. tokico brake line bracket
  213. 94 Honda Accord EX -- ABS Brakes
  214. Changing Parking Lights 91 Accord
  215. *HELP* please
  216. help with replacing floating rotors
  217. need help building up civic
  218. C-Pillar Instalation Help Please
  219. front rotor
  220. Ignition Key
  221. help! b16 head on b20a5 3rd gen prelude
  222. DIY- Angel Eyes
  223. 82 accord lx hatch b-kit
  224. wiring neons
  225. B18c1 swap into 88HB
  226. 98 accord rear brakes
  227. idle surge
  228. odb-0 to odb-1 or 2?
  229. pcv valve
  230. wiring diagrams
  231. reprogram civic keyfob
  232. Any Luck??
  233. Pursuit Security System Help!
  234. B16 swap
  235. angel eyes installation ( 91 teg)
  236. LS VTEC questions
  237. Honda Civic Breeze 1992' ??
  238. speedometer help???
  239. Camber Kit
  240. 91' CRX rough running
  241. lesabre dash lights
  242. Need to buy new remote access fob for '98 Honda Civic EX
  243. d 16z6 valve cover gasket problem
  244. throttle heater bypass
  245. steering racks for prelude 1986
  246. clock/stereo fuse
  247. how to conect purge selinoid on b18a
  248. took out the dip stick... smokey smokey
  249. Help Installing Cd Player
  250. Maint Rego Light
