Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
> How-To's and Walk-Through's |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
Vtec not working...
99 CRV - Front Bumper Replacement
O2 sensor location for civic 99 LXi manual
Installing vtec controller
How to set Piston 1 to TDC (Top Dead Center)
Clutch Bleeding
Core [radiator] support replacement
help removing radiator support!
need help with changing front axel!!!!!! PLZ!
1990 Honda Accord water pump
Service Required Light
Si acting like a POS
Exhaust Piping
Exterior Door Handle
Helllllp
help with my v-tec
A/T to manual conversion
Targa Top Kit for Honda Civic
Timing belt on SOHC
Civic 1.6i ES - Alarm go off
Spark plug housing or nuclear triggering device???
Swapping to B18, need lots of help
Wiring D16Y8/D15B7 mini-me
Need Help! 94-97 A/C Passport...
air in cooling system
Mini-Me: D16Y8 on D15B7 Concerns
D16Y8 Head on D15B7.
2007 Civic
door switch
93 prelube problems
battery relocation
teg still leakin coolant after thermostat change
93' honda civic hatchback revs in park or neutral
94 Integra B20 engine swap with Auto tranny
Help me if you can with door locks 99 honda
Need help installing a turbo on my 99 Si
how can i tell what kind of engine i have...
H_Accord'94 radio code?
rad/thermostat
Flashing the ECU
Other Forums
Door Sill Molding Removal 92 Integra
Wow!
fuel pressure???
broken screw
1995 accord drum brakes
'90 Acura Integra
map sensor problem maybe??
d16y8 help!!!!
low end speed
94 accord, how to bleed my brakes?
Window tint removel??
Air intake question??
headgasket ?
2003 Pilot Fan Blower
2003 Pilot Door Locks
1999 Civic unstable revs help
1989 Honda Civic wont run
i need help badly for my crx swap.
sanding my bumper
my civic is not in time??
Wipers Stuck In Field Goal Postion....
89 Honda catalytic converter clogged,,
Engine swap
D16y8 head on a D15b vtec E
Main Relay Location
Don't know what I'm doing!!!!
help gas milage really bad
vtec not operating
Main Fuel Relay..
HELP! Programming keyless entry remotes!
??? about my stock muffler
exhaust return to carb 89 accord 200k miles
D16Y8 in my 91 DX honda civic
Help Help Help!!!!
turbo kit for 98 vtec honda civic
interior lighting question
Installing LED washers
Parking Lights
Headlights 90 accord
Teach me how to install CAI
91 hONDA ACCORD EX
Dashboard Indicator Lights Draining Battery
Main Relay ? 1992 Prelude Auto import
knock sensor replacement fo my 2000 civic
'07 Civic parts?
How To Install Oil Pressure Gauge In 89 Civic DX
striped bolt
Gauge cluster/overlay
new injen CAI help!!
Fender 88 civic dx
Dash Lights
93 Prelude engine problems
Windshield Wiper broke form being stuck on ice!
CRX motor swap
2000 Civic 2D - Replacing a Fender and Side Mirror
Mini Me Swap / Mpfi Swap Questions
a/c heater question??
01 Accord lighting problem!!
Need help installin radio to a 05 civic. PLEASE!!!
Lower strut brace install
Installing CAI on 02 accord SE (4cy)
How to: Yellow out fog lights.
transmission swap
wheel studs
? ...oil in the radiator fluid.
major clutch problem...help!!!!
'93 Honda Civic Electronical Problem
Heater problem in '94 Accord?????
Help: Honda CRV 2003 Automatic Front Door Lock Stopped Working
91 Integra with a b20
Ever wonder how VTEC works?
massive oil leak-1.5 ltr
Brake pads
1988 honda civic dx
timming and valve adjustment
94 Civic Timing Adjustment
h22a LSD
91 Honda CRX hf, no spark!
95 Accord Auto Tranny (shift adjustment)
Need to know how to pull the axle assembly
'93 Civic EX gas millage too low
2000 Civic DX 4dr O2 sensor
STeps or Info HELp.. RAdiator Support REmoval
PILOT 2006 Headlights
need b16 measurements motor trans ?
1997 Honda Accord LX Wagon front console removal
which fuse works the horn
help horn does not work
Upgrading the 06 si
92 Civic Si Anti Collision Bulb Replacement
89 CRX SI to 96-00 civic front end conversion questions...
95 civic dash lights
1995 honda ex, how to change a/c compressor
help!! 95 honda civic windshild wiper problem
chevy astro ext
94 civic spyder body kit problem
honda crx swap
how the hell am i suppose to read this thing?
Rebuilding Head
core support replacement
Indiglo Gauges - HELP!
Turbo Integra
Big Problem....NEED HELP
'93 Del sol will not start at all now--How do I test the module, coil, & wiring
side markers
Accord AC Knob Lights Out
AC kit for a 98 honda civic hatch
how to disable airbag (SRS) light
modification questions
Turbo d15b7
help! intake question!
2000 Honda Accord Driver Door Wont Open
replacing rotors on 1999 CL
AC thermostat replacement on civic
2.2 v-tech info
00 Honda Civic LX A/C
Help about supplies to paint my car.
a/c
91 Accord Clutch Problem
How do i turn off traction control (2000 accord)
any help i can get
Performance Parts
I need intake help
No power to fuel pump
i need some vtec help!!!
How Much R12/Freon Needed
Ac ??
Help on wiring
1998 gsr motor removal!!??!!
Car sometimes does not Start..sometimes
'90 accord..wheres the oil dipstick?!?
1990 honda civic dx blower motor removal and installation HELP!!
What intake should i buy for 98 civic???
94 civic ex Water Pump removal and installation
changing brake bulb - 98 Civic EX
can someone help me with my 97 honda de sol!!!!
help with my honda accord 1985 please
INTAKE HELP! Please asap
belt tensioner or bad mechanic?
injector problems
1979 Honda Civic CVCC wagon
How do I change an EGR valve in a 1996 Honda Accord?
89 legend problems
Replacing shift cable on 1992 Accord
radiator fluid
1992 honda accord lx how to change transaxle fluid ?
i want 2 turbo an 89 crx
cold intake 98 acura
abs light problem
write up on 93 civic shock/spring installation?
04 civic cam install?
2001 Civic Gauge Install Help
reinstalling factory springs
89 prelude burning lots of oil!!!!!!!!!!!!!
94 Vtec Engine
If The Distributor Bolt Mount On C-head Broke On 89 Lude?
Need Help with Rotor Replacement!!
00 Accord EX installing Cold Air Intake
Helpp!!.
shocks/spring installation walkthrough?
Need some help, buying 92 civic hatch
Radiator Swap Walkthrough
cv joint problem
'97 Civic DX
Remote Start questions...
Using the AF Search Feature
92 Integra Auto swap??!!
engine swap 91 prelude
brake upgrade
91 civic interior
91 Civic stereo installation no wiring...
97 accord coolant bumbling & oil in spark plugs
what i need 2 swap b16a1 into my 1996 civic
locating fuel line under hood? accord 97
2000 Civic bumper removal
changing civic 2002 ex headlight
how to get more hp cheap for accord 97 4cyl
97 accord is blowing hot air. Help! Freon didnt work.
No Clutch
Safc2
whats wrong with my car?
changing light display
1989 Honda Civic LX Help On Fixing Up
Need Help!!!!on Civic
Short Shifter help please
Retractable Headlight 1991 Prelude SI
timing problems with 1.6l engine swap plz help
engine swap plz help asap!!1
Remote Programming for 2003 Pilot
1994 Acura Integra Transaxle removal
i want to do up a crx
87 Honda Accord Lxi Hatchback 2.0l 5spd
how to put on an air intake for a 98 honda civic ex
voltage stabilizer 99-00 si ???
removal of a transaxle
94 Accord Ex front rotor replacement
D16y7 tranny swap
89 civic hb headlight help!!!
Programing Instructions or 99 Acura CL
I need your car expertise! HELP
what does SiR
d15- DOHC ZC 92-95 civic
'03 Civic SI intermittant starting problem
d15 to b16 swap, any help?
93 D16Z to 94 DX D15 Tranny???
1990 Civic Distributor
Tach Gauge Install Instructions
Web
AF
