View Full Version : Park Avenue
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12
  1. 98 PA seems to be missing
  2. Losing power/ stuttering while shifting
  3. Change Radiator Cap?
  4. Park Avenue Climate Control
  5. 99 park avenue left turn signal not working??
  6. Low part-throttle power and awful mileage
  7. How to test the DynaRide
  8. 2001 Park Ave, driver window works every other day
  9. lights
  10. 95 PA rear window defogger problem?
  11. Park Ave. Brake Recommendations
  12. 99 PA driver side front window
  13. Locating Radiator Drain Plug?
  14. 96 Park Avenue power antenna
  15. no cruise
  16. 92 PA start up problems
  17. Noisy Serpentine belt
  18. sunroof leaking
  19. Oil Change Interval?
  20. Tackometer failure
  21. Car won't start and white smoke...
  22. Replacing front struts on ELC suspension
  23. 96 Park Avenue Front Bumper
  24. Ignition Coil
  25. Help just in stalled shocks and electronic leveling compressor wont turn on
  26. ABS Codes
  27. weird noise while driving through heavy rain
  28. Problem with Security lamp
  29. Car Won't Start
  30. Vatts by-pass
  31. warning lights test
  32. PCV Valve Spring?
  33. outside temperature
  34. 91 PA Lightpanel...
  35. 94 park ave rattling noise
  36. Voltage Drop
  37. Is the Park Avenue a 6 seater?
  38. 1991 Park Avenue Radio Replacement...
  39. AC warning reading.
  40. How to determine RPM's on my park ave.
  41. 99 rear shocks????any help would be greatly appreciated
  42. 1992 Speedometer cluster
  43. maintenance schedule
  44. Failed emission test, need help
  45. 97 buick park avenue
  46. 95 buick pa security light
  47. 97 Driver's Side Window
  48. Flashing LED
  49. Drop Pan or Flush?
  50. new tires for 1991 PA base
  51. 96 Park avenue tire placard
  52. Park Ave 99 - P0741 (Transmission Problem)
  53. 98 PAU driver's seat issue
  54. New 2 me car w/ small issues
  55. ceiling clothing becomes loose
  56. 2001 PK Ave radio & temp control
  57. 97 Park Avenue "ground bus"
  58. Tips for changing crank sensor
  59. 95 PA trunk pulldown fuse?
  60. Trans Module Problems????
  61. 3 Q's; Brake system, Keyless entry, Stereo Compatibility
  62. 98 buick park avenue supercharger
  63. 99 park ave studers cold
  64. what is this valve for?
  65. A/C and idle questions
  66. 95 Park Avenue Coolant Leak
  67. 1994 Ultra - DRL - Lamp Control Module
  68. 92 pa wont move
  69. 94 Park Avenue missing
  70. Supercharger issue
  71. Changing power steering fluid
  72. 2003 Ultra -- need to change bulbs in the trunk door
  73. 2003 Park Avenue Ultra - air ride system
  74. change oil soon light/computer
  75. ash tray light
  76. what is the 'economy' mode exactly?
  77. Oil in manifold?
  78. Transmission/Engine Stall & Slip when Shifting into Drive
  79. My Car Studders
  80. Climate 91 PA
  81. '96 Window Lift Motor - Driver Rear
  82. 96 park ave
  83. 99 Speedometer / Instrument Cluster
  84. ABS Brake Scan OBD 2 Tool
  85. 96 Park Avenue Coolant Leak
  86. 93 Park Ave Ultra A/C Issue
  87. 96 PA Check Engine Light is Blinking
  88. 3800 Missing under load - problem solved
  89. Want your Opinions!
  90. 2003 Buick Park Avenue Ultra Transmission
  91. ATF Fluid?
  92. 94 Buick PA - Braking & Electrical
  93. program keyless Remote Buick Park Ave ultra 1998
  94. Replace Mirror From 94 to 96
  95. Autolocks
  96. 94 Park Avenue
  97. Center Brake Light Access
  98. torque specs when replacing 4t65e accumulator
  99. door locks / power windows / power mirros NOT working!
  100. PA grinding noise (bad compressor?)
  101. GM Oil Life Moniter
  102. 94 PA towing 67 Ponti Bonneville
  103. 99 PA Inner Tie Rod
  104. Auto seats not working
  105. A/C panel lighting
  106. Washer Fluid Bucket
  107. 97 AC Compressor
  108. 1987 Park Ave. Compressor Clutch
  109. Memory seating is all jacked up
  110. changing a thermostat.
  111. transaxle removal
  112. 1992 pa vibration
  113. Struts for 99 Ultra
  114. Thinking about repainting her
  115. 91 Park Ave motor jerks on take off??
  116. Cruise Control problem '97 PA
  117. 97 PA heater hose tensioner fittings
  118. alternator going bad?
  119. G.M. Wonders Whether You’d Really Rather Have a Buick
  120. 2003 Buick Park Av. Ultra up-shifts hard
  121. 99 Park Ave parking brake stuck on
  122. 91 park avenue help plz!
  123. 91 park ave. 3800 , please help
  124. Procedure to bring this car to life-intake manifold gasket?
  125. Park avenue rear door panel
  126. A/C blowing in defrost mode!
  127. 91 park ave. 3800 , please help
  128. code 107 what does it mean?
  129. Buick Park Avenue Ultra EGR System
  130. Is the Ultra Supercharger a Problem Area?
  131. 1988 Park Avenue sometimes start, but rough
  132. 98 PA - replacing multifunction switch?
  133. 92 buick parkavenue misfire when taking off
  134. Old plug in card security sys.
  135. Buick 92 Climate flashes speedometer dies low power on accelration ok after ten minut
  136. 3.8 Intake Removal problem
  137. 96 Park Avenue abs & traction control
  138. '96 Park Avenue - Vacuum Actuator
  139. '96 Park Avenue Passenger Seat Recline switch
  140. 1996 PA - "Base -vs- Ultra"
  141. Buick Ultra check engine warning light
  142. 1989 Park Avenue Transaxle Problems?
  143. magnasteer
  144. wheel vibration/shimmy
  145. HELP!! 99 PA Water Pump Removal
  146. 98pa a/c
  147. Water pump remove
  148. ACC error code 38 - data line failre PCM
  149. 92 PA metal clanking noise
  150. 91 Park Ave just dies out
  151. 02 Park Avenue Oil pan gasket
  152. Battery Drain through Maxi Fuse
  153. 97 PA driver's side power window
  154. 98 PA compressor does not turn
  155. Tire replacement
  156. stabilitrak issue
  157. 1999 park avenue power seat problem
  158. 2000 PA ULTRA fuse box location inside car
  159. Questions about my 2000 PA ULTRA
  160. Buick 3.8 ltr. Supercharged recall
  161. 94 PA Stalls When Slowing Down
  162. 96 PA Not Running 124,000
  163. Dex Cool in 2002 Park Avenue
  164. 2003 Buick Ultra EGR
  165. 91 Park Ave. A/C troubles...
  166. 95 park ave struts
  167. 97 PA Ultra - No Fuel Delivery
  168. '92 PA oil pressure problem
  169. 94 PA, ABS light comes on at same time each day
  170. 2003 buick pa ultra
  171. 2001 PA: Repair or Run?
  172. '96 Park Avenue - What is this?
  173. ignition module and coil pack.
  174. '95 Park Ave OBDI port location?
  175. 94 Park Ave.
  176. Cam Sensor Replace
  177. airco does not work?
  178. Park Avenue won't start
  179. 98 Ultra Rear Caliper Removal
  180. Spark plug wires?
  181. Auto Rx any good?
  182. '96 Park Avenue - Cranks but won't start
  183. installing new multi function lever on 1993 P.A.
  184. 91 PA fuel line help
  185. 1999 pa BCM ????
  186. 1995 Bizzare PA electrical problems
  187. starts, runs, dies, starts and runs again...help
  188. Lean Exhaust Code-Mechanic Can't Resolve-Please Help!
  189. transmission whine
  190. 2000 park ave 3800 throttle body
  191. What's this part called?
  192. 91 PA parking lock
  193. ABS engages...
  194. changing transmission filter (91)
  195. Best deal on AC Delo O2 Sensor?
  196. Intake Manifold Repair Question???
  197. 99' Park Avenue 3.8L Coolant leak
  198. 1999 Ultra - Sticky Accelerator
  199. cruise control and trip odometer
  200. Car set all winter,condensation thur whole car
  201. Transmission issue 91 Park Ave
  202. 98 PA Battery dead Ignition key alarm
  203. Ignition Lock Cylinder
  204. 1989 Park Avenue Auto Level failure
  205. headlight assembly
  206. 97 PA Electrical Issues
  207. leaking vapor canister
  208. 95 Park Avenue - Upon Start cuts out
  209. 99 Park Ave park assist setting
  210. Help-I killed my friend's 94Buick PA Ultra SC
  211. 94 Park Ave
  212. lighting upgrade
  213. sidemarkers
  214. '97 Park Avenue Ultra Seat Switch
  215. '97 Park Avenue Ultra Door Lock
  216. High idle
  217. Uncooperative factory radio unit
  218. 94 park av ultra p1640 QDM error
  219. Replacing Gauge Cluster 1985-1990 Electra Park Ave
  220. Red book price of 99 Park Ave
  221. 1995 park avenue transmission
  222. 94 Buick PA-Battery, Starter or Alternator
  223. 86 park avenue bucks like a bronco when cold
  224. automatic climate control
  225. tuning 91 PA
  226. changing front brake pads
  227. Leather seat re-dye
  228. Re: code 45 - Redux
  229. 1991 Park Avenue Column Smoke
  230. 2001 Park Avenue Message
  231. PassKey Problem, 92 Park Ave.
  232. Rattling sound
  233. help on park ave
  234. 96 Park Avenue
  235. Turn Signals now have gone bonkers
  236. Starter?
  237. Power Door Locks
  238. Replace bulbs in radio & HVAC head
  239. Rear shocks
  240. Chrome Bumper Trim
  241. 1997 Park Avenue Starter replacement
  242. poor mpg 91 PA
  243. 2000 PA base, MF switch issue // recommendations
  244. 00 P.A. Low spark on #6 coil
  245. Thinking about buying a PA
  246. 1989 park ave probloms with ATC power module
  247. low oil pressurs light
  248. heater and a/cgoing crazy
  249. 91 Heat works on occasion
  250. Interior color/code?
